LinkBack (10) Thread Tools
Old 24-11-2007, 23:01   10 links from elsewhere to this Post. Click to view. #1
Drives: c18xe smallblock
porszak's c16xe, stage 0.75-176hp/187Nm. project c18xe smallblock
Many times, there was some discussion about connecting c/x16xe and x18xe1/z18xe parts in one engine. So I want to show U little something.
Basic engine: c16xe with about 150 000km behind it
At first I wanted to have only fast c16xe, I disassembled engine only to check it. It was in good condition, but then came idea to do something unusual.
Many hours in the net and I started collecting parts.
That’s the result
max hp 157hp@6585 and 195Nm=144lb*ft@4790(so Torque is the same like in std c20xe)
and afr. We did 3 runs and during only one afr was too poor in about 5000rpm
What is done:
c16xe rods with z18xe crank and pistons
head work-intake and exhaust runners and valves, cr 11.4, porting
schrick 264degrees cams
Balanced crank with flywheel, pistons and rods. lightned flywheel
SuperSprint exhaust manifold without catalyzer and rest of exhaust 2.25 inch
Upper part of inlet manifold from x14xe
ECU without remap
When spring come there will be mantzel style inlet and remap
here You can find many pics from engine work, all things i could i did by myself
http://www.forum.tuning.info.pl/view...er=asc&start=0
porszak is offline   Reply With Quote
Old 25-11-2007, 10:10   #2
Drives: nova 1.8 16v on tbs
interesting, any reason you didnt want to use the whole 1800 engine? as the head esign is way better than the c16
shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008
lee303 is offline   Reply With Quote
Old 25-11-2007, 11:02   #3
becauce i had whole engine c16xe, and like i wrote, at first i wanted only fast c16xe.
oil and water gallerys are different in c16 and z18. i think c16 head is way better than z18. if i remember well dia of valves is the same in both,or only not much biger in z18
Old 25-11-2007, 16:33   #4
seriously, the 1800 head is just awesome, casting abilty has clearly moved on alot since they cast the 1600,5mm valve stems too it has a differerent inlet manifold setup though that may be a bit tricky to fit a mantzel type box too, interesting project anyway
Old 25-11-2007, 16:49   #5
Drives: 16v Nova, Astra TD
So is it a 1800cc engine then? Sounds like a good hp/torque output considering its on standard management and inlet etc.
LongLiveTheNova is offline   Reply With Quote
Old 25-11-2007, 16:53   #6
if he has used the 1800 crank and pistons then it will be 1760cc, smaller combustion chamber on the 1600 head so a bit more compression too, also beacuse of the increase in cylinder size
Old 26-11-2007, 13:04   #7
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
Sounds like a pretty good result. Will bookmark for a read & glance at the pics later.
V8 blender FTW
Old 26-11-2007, 23:17   #8
Drives: Calibra & Nova
^^ same..
peester is offline   Reply With Quote
Old 27-11-2007, 14:23   #9
with a Mantzel Powerbox, enlarged trottle boy, and remapped you can be close to 180 bhp with a lot less weight then a C20XE
Very interesting result indeed
ffls is offline   Reply With Quote
Old 01-10-2008, 11:33   #10
Re: porszak's c16xe, stage 0.5-157hp/195Nm. project c18xe smallblock
ok, so i'm back with again not quite finished project but with bigger power.
this is result with std c16xe injectors+mantzel look power box, and std ecu with rev limit set at 7000rpm. afr 12.5-13
Old 11-10-2008, 22:25   #11
Drives: 400 BHP Skyline GTR
Re: porszak's c16xe, stage 0.75-176hp/187Nm. project c18xe smallblock
That’s the result
What is done:
ECU without remap
You have given me some great ideas Mr Polski!
My Skyline for sale, PM me or see for sale section.
observer is offline   Reply With Quote
Old 14-10-2008, 19:46   #12
Hi Porzaks,
Do you know how many cc's the C1.6XE or X1.8XE1 injectors are?
Kind Regards,
Axel
Axel is offline   Reply With Quote
Old 18-10-2008, 18:04   #13
Why did you use the c1.6xe rods an not the x1.8xe1 rods? Are they stronger?
Kind Regards,
Axel
Old 19-10-2008, 11:47   #14
Drives: vauxhall corsa
Axel
I think they are stronger
richard_cooper is offline   Reply With Quote
Old 01-01-2009, 22:56   #15
Hi,
Which injectors are you going to use in the future?
Regards,
Axel
Old 02-01-2009, 19:38   #16
c16xe rods look like stronger, and i think they realy are.
now engine is running with std c16xe injectors, and mantzle power box with 176bhp@7000rpm, but as U can see rev limit is still to low
what ideas??
Old 03-01-2009, 07:01   #17
Drives: Tigra 1.8 turbo hp?
fit an standalone ecu,pistons,rods, wider TB,aftermarket header,and full exsaust system and take it to the sky!!!lovely job so far!
Any one else has a strocked x16xe pm me.
MIG.....Made In Greece LOL
TigraTurbo is offline   Reply With Quote
Old 03-01-2009, 08:07   #18
Hi Porzak,
I have also a 1.8 since few days, i drives prerfect! Yesterday a found some info about the X1.6XE injectors, the flowrate is 165cc at 3 bar. And the X1.8XE1 injectors are 175CC at 3 bar!
Did you use a power boost valve (FSE), because your engine runs poor after the 5000rpm?
Kind Regards,
Axel
Old 03-01-2009, 11:31   #19
@ TigraTurbo, yes that's the plan. but now corsa is still dailyuse car. have to buy another
@Axel c16xe injectors are bigger than x16xe. x16xe's are good till about 150bhp, that's what i konw. i didn't find efficiency of c16xe injectors
if FSE is fuel pressure regulator, i don't have one. afr is ok, isn't perfect all the time, but still between 12.5-13.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/339809-porszaks-c16xe-stage-0-5-157hp-195nm-project-c18xe-smallblock.html
Posted By For Type Date
Lanos club -> Головка блока 16 кл на 1.5 This thread Refback 04-11-2008 21:05
Lanos club -> Головка блока 16 кл на 1.5 This thread Refback 20-10-2008 20:03
Lanos club -> Головка блока 16 кл на 1.5 This thread Refback 20-10-2008 18:27
Lanos club -> Головка блока 16 кл на 1.5 This thread Refback 12-10-2008 20:51
Lanos club -> Головка блока 16 кл на 1.5 This thread Refback 12-10-2008 13:27
Lanos club -> Головка блока 16 кл на 1.5 This thread Refback 12-10-2008 07:56
Lanos club -> Головка блока 16 кл на 1.5 This thread Refback 12-10-2008 06:51
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 05-10-2008 12:14
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 02-10-2008 12:37
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 01-10-2008 11:56
Members: 43,212
Threads: 310,610
Top Poster: LEE69 (43,149)
