Page 5 of 22 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 101 to 125 of 529
Thread: corsa B project
  1. #101
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    another update today
    painted block and just threw it back together!! nothing is bolted down though! accept mounts and dipstick etc
    also cut slam panel out! no pics of this yet as i still need to make it so i can bolt it back in, still need arp con rod bolts! will order them tomorrow or monday i guess with new sump gaskets
    Roll on LET power....
    Nov 2005
    chester/n.wales
    evo 6 gsr
    Re: corsa B project
    your mounts too lowlmao
    phil nichols - Engine building and Cylinder head work. stock - performance. - can now supply gaskets, water pumps, cambelt kits, oil pumps, uprated bearings, bolts, rings, pistons. PM FOR INFO
  4. #103
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    oh yeah!! i thought it looked wrong when i put it on LMAO!!
    cheers mate
  5. #104
    Nov 2005
    chester/n.wales
    evo 6 gsr
    Re: corsa B project
    id love it if you tried to fit it like that and ended up thinking wtfs goin on!lmao
  6. #105
    Apr 2007
    Bradford
    Vectra B C20LET :)
    Re: corsa B project
    Quote Originally Posted by philip2 View Post
    I actually did that once lmaolmaolmaolmaolmaolmao
  7. #106
    Nov 2005
    chester/n.wales
    evo 6 gsr
    Re: corsa B project
    o nolmao
  8. #107
    Apr 2007
    Bradford
    Vectra B C20LET :)
    Re: corsa B project
    o nolmao
    First ever engine conversion, I had a reason lmao
  9. #108
    Aug 2006
    huntingdon
    E46M3/GSXR750/RWD SCOOB
    Re: corsa B project
    Quote Originally Posted by turbo gav View Post
    Dont worry about that bottom end if your not coming to PV, It was only for spares so no big deal.
    I'll bring £75 with me if you coming up with the complete bottom end
  10. #109
    Nov 2005
    chester/n.wales
    evo 6 gsr
    Re: corsa B project
    ill give you £100!!lmao
    joke, ive got no use for a LETlmao
  11. #110
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    got headgasket, head bolts, water pump, cam belt with tensioner/rollers.. all to be fitted, put gasket and bolts in hand tight just waiting on torque wrench to arrive!
    also found when i removed the sump that it has been fitted with a 8v rubber gasket and some lovely ARP rod bolts! well chuffed! selling the ones i brought now!
    only thing im struggling with is the getting cams in? and finding bottom timing mark
    cheers
  12. #111
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    collected my head bolts and gasket
    head is on just needs tightening down..
    re-routed the PAS pipes..makes it easier with new turbo!
    put turbo on to see whats what... lol not much room at all!
    about it today, waiting on pulley and rocker cover still. hopefully sunday i will have it all tight and wired up! all the plumbing is done though! and need to shorten oil cooler pipes so its just little bits...soon adds up time though lol
  13. #112
    Re: corsa B project
    That looks awesome.
  14. #113
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    thanks mate, all the loom is plugged in now hopefully sorting my battery out tomorrow as its going in the boot.
  15. #114
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    update:
    turbo is on, all intercooler pipes had to modify my hose but was dead easy.
    my old rocker cover which my girlfriend kindly updated for me lol
    then she went wild with the cam taking pics of light saber loool
    pretty much finished now, just need to do cambelt and wire battery in boot
  16. #115
    Sep 2008
    South Devon
    1998 Corsa B C20LET
    Re: corsa B project
    I just read your topic for the first time. When a Saw the first picture I thought 'ow Jesus'.
    But buy the end I thoroughly enjoyed looking through it, extremely good effort
  17. #116
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    thanks
  18. #117
    Nov 2007
    Southend
    Coupe turbo
    Re: corsa B project
    Good effort buddy glad its going well cheers
  19. #118
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    done some more today, moved coil and finished plumbing in the rad also fitted the fan round the back as it didnt work round the front end lol ops! all the oil cooler hoses are fitted! was going to shorten them but there spot on now i routed them slightly different bumper will fit better now to which is good...the battery is also wired up first time i seen the ignition on in 3months lol!!
    heres the pics
    going to saw off another slam panel at a scrappy, also need a 90deg bend off the turbo so i can hook some hoses up as the pas is in the way
    and there is 2 pipes off the wastegate, what one goes where?
    thanks for now
  20. #119
    Nov 2008
    North Wales
    Re: corsa B project
    Fairplay for having the balls to mod a 5 door Its not only a nice 5-door corsa, its a nice corsa all round mate. Great job im well impressed!
  21. #120
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    thanks mate good comments always makes me carry on with it, it is nice to be different!
  22. #121
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    got it running today fired up straight away pretty much!
    any help with those wastegate pipes?
  23. #122
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    done some more bits today
    cam cover and air filter back in place, dirty marks have been wiped off
    3" downpipe, fits a gt28rss so needs flange changing for my t34
    slam panel bolted in an painted, went over it again when on the car as it scratched a few bits bonnet looks slightly open when its shut...might have to adjust that!
    battery is flat which is gay! but will sort that when its running for good oil pressure sat bang on 60psi yesterday so thats all good, vacuum was spot on to and no oil leaks as of yet lol!
  24. #123
    Sep 2002
    Ayrshire
    corsa SXi + LET
    Re: corsa B project
    looking good mate, glad you got it back together and running. Mine hasn't been bad for oil leaks either, though I am using the sump baffle with the bonded rubber this time which seems much better than the stupid dual gasket set up the let has as standard.
  25. #124
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    yeah i got 8v rubber one to
    just got gearbox/clutch probs now! i have another thread up.
  26. #125
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: corsa B project
    found the problem!
    clutch wasn't lined up!?!?!
    gearbox out half empty bay again!
