Re: corsa B project
love it. were the side skirts a straight fit?
Re: corsa B project
yeah, just a few self tappers in the arch and along the cill
Roll on LET power....
Re: corsa B project
phase 2 chips in, what an animal lol! cured my boost problem as well, seems the guy who had the engine before took his chips out (p3 i think) and put some cheap things in there...ran like **** for months!
next jobs:
spray engine bay
respray rocker cover
new exhaust
battery cover
Re: corsa B project
oops double post
Re: corsa B project
That manifold is awful! I hope you left bad feedback
Re: corsa B project
i've been in contact with them, waiting for reply
tbh the manifold is OK but the elbow i agree is toilet.
Re: corsa B project
nice work! car looks great. say it goes the same!!
Re: corsa B project
the manifold looks not soo bad, could maybe run a bead of weld around the first pic and file it down till its smoth, witch turbo is that you are using if you dont mind me asking?
Re: corsa B project
just some t34 from america, my mate had it sitting in his garage after taking it off his rs turbo lol only used it for a day an hated the lag! so its brand new really, only going to be running 18psi through it so it will more then cope.
do you think the manifold isn't that bad? i probably could get someone to weld the **** bits? bit of hassle for me though expected it to be straight fit.
Re: corsa B project
Where's the fan from mate?
Re: corsa B project
Nice car its good to be different sometimes.
Re: corsa B project
i got from someone on here...not sure what size it is or make etc..
cheers v6h.
Re: corsa B project
all back together
Re: corsa B project
thats looking tasty mate, nice one
Re: corsa B project
cheers people, oil cooler is spot on, doing mot bollocks today
lol
Re: corsa B project
Nice work, pistons will be fine most of the time. Headstuds whilst its apart as it wont stay together forever if you push hard? I got fed up buying headbolts. what gasket are you going to put back on?
Re: corsa B project
oh really? im taking the engine out now to give it the once over...had enough of things going wrong with it.
not sure on gaskets etc or studs....bit new to that stuff lol. advise would be greatful...
Re: corsa B project
defiantely go with the studs mate, there is nothing worse than tightening down the head bolts and the threads getting pulled out of the block. This just happened to me and that was even with a stud kit, but generally the risk is much lower.
