thought should put some pics up of little project i started couple of months ago.
main reason for doing the car is because i collapsed end of aug, and cant dirve til march(6months) and after some **** with 'mates' decided to **** it and strip the corsa and build a TB'd xe on f28 as a bit of a toy
hope you like. any comments welcome
heres what started off like, nice and standard
then fitted spax adj. shocks/springs, inlet, rebuilt engine, ashley manifold/system etc and fitted some astra gsi rims.
seeing as i cant drive i started on stripping the interior, and sorting the wiring out, dash, roll cage etc.
dash was out and marked the bits that i wanted to keep and i started to tidy the wiring
i removed the heaters, and started to prime the floors, until i realised i had the cage to weld in, and a small hole in the passeneger side wheel arch, so ignore the white primer. inside will be painted in body colour.
dash back in, and i spiral wrapped the loom instead of tape so i can access it easier if need be. cage is also fitted/bolted in.
im just waiting on my unit off my uncle so i can cut all my door bars, turret bars, diagonals etc for the cage. so to save some £££ i popped up the road to demon tweeks and bought a tube notcher ready for when i can get in and finish the cage off(engineer so no probs cutting/welding all myself). then paint it all nice and red.
Whilst im waiting for that i started on the motor, i bought a 20xe off a mate, but only used the block, crank and sump pan. heres a few pics of the motor all cleaned up, just need to bore block and order steel rods next month. got some of the gaskets, will be using arp all the way through.
started to port the head(inlets are roughed out)
these arrived today from QED so i can now crack on with fitting the guides, cutting back into ports to finish inlets, and crack on with the exhaust and build it up![]()
also got my pistons...nice set of flat top slippers from redline![]()
thats sort of it at the moment, will try to get head all ported/polished this coming week when im off...still need cometic HG to match the chambers too, then thats done. then order rods/arps next month and a steel oil pump gear. just read how much the valves, guides and springs have cost me...trip to the bank now see what i got left!!lmao
hope you like, should go well when done!! hopinig around march/april time
lmao
