10-11-2007, 23:32
#1 | | MIGWeb User
Join Date: Dec 2004 Location: Colne Drives: TT 225/Track nova
| My WIP 1600 16v Track motor Evening all. Ive been on here a while now just generally getting tips and advice so i thought it was about time i started a wip thread. The cars going to be used for track days and maybe hill climbs with the local motorsport club. Hoping to have it finished by xmas but very much doubt it, been on with it for about 12 months now and all i seem to have is a room full of parts  . Supose the best place to start would be the shell.
Trying to make the car as light as possible so the following parts have hoarded
Fibreglass bonnet and boot
Fibreglass roof
Fibreglass wings
And fibreglass doors
Still waiting to buy the fibreglass rear quaters. Dont realy know what weight to aim for, the cage weighs quite a bit and still needs finishing (im going through to the turret tops and a lil bit more sich welding throughout the shell).
Hope you all like it will get some more pics up soon.
Ste |
10-11-2007, 23:43
#2 | | MIGWeb User
Join Date: Nov 2005 Location: chester/n.wales Drives: class 7 corsa;)
| looking pretty good so far. what are plans suspension/engine wise(spec)
good to see some more pics |
10-11-2007, 23:51
#3 | | Regional Co-ordinator
| looks nice and light weight and hardcore...
__________________ Quote: |
10-11-2007, 23:51
#4 | | MIGWeb User
| Currently building a 1600 16v with the following spec:
1600 16V Engine spec
Bottom end
SBD dry sump kit
Ultra light fly wheel
SBD multi vee pulley with crank sensor
ARP rod bolts
Steel con rods
Omega 80.00 mm forged pistons
SBD steel idler rollers
Cometic laminated metal head gasket
SBD starter motor
Top end
ARP head stud kit
Ported and polished cylinder head
SBD Titanium valve cap
SBD valve spring platform
Bronze valve guides
SBD double valve springs
SBD solid cam followers
SBD underground shims
Pair of SBD/Kent 295 degree, with 11.60mm lift cam shafts
SBD/Kent vernier pulleys
SBD/Jenvey inlet manifold
SBD/Jenvey Taper throttle body kit with 90mm trumpets
SBD fuel rail
Peco cream injectors
MBE 967 engine management
SBD wiring harness
SBD ultra small alternator and mounting kit
Modified cam cover for dry sump system
BTB exhaust manifold
Obviously holding that in with solid mounts.
Using a transx straight cut box, not sure what diff to put in yet.
Suspension ive got gaz coilovers with eccentric top mounts. Just orderd the clark motorsport (formally walden) wide track kit with adjustable tie bars etc  will try and get some more pics up.
11-11-2007, 00:06
#5 | | MIGWeb User
| keep your steel wings, not much weight different, much stiffer, not completely written off after the slightest touch against something and offer slightly more crumple material when you stack it.
so long as the pillars are well tagged to the cage the roof should be ok but i wouldnt fancy rolling...
__________________ competition nova parts needed! see below... migweb.co.uk/forums/cars-items-wanted/375558-competition-high-end-nova-parts.html |
11-11-2007, 02:09
#6 | | MIGWeb User
| if using the car on the road id be tempted for the ATB dif not the trans x plated one. mate has one in his 205 rally car and says its a pain on the road.
spec sound pretty good for the motor, only thing ive noticed with the sbd heads are the inlets look to be too smooth/polished, which id of thought would cause pooling/poor combustion
be good see pics of the motor build, and turret work when youget it done, im starting mine on my corsa this week  |
11-11-2007, 06:35
#7 | | MIGWeb User
| forgot to comment on the shell, looks to be a nice piece of kit, looks like the same cage as my old one minus the dash bar and forward triangulation, is it a custom cages job?
you going for power steering rack or lengthened rack since you have to make new rack mounts anyway? |
11-11-2007, 09:41
#8 | | MIGWeb User
| Your right about the inlet on the SBD head nothing that a bit of 80 grit cant sort. Will get some pics up when building it. The reason ive gone f/g wings is due to the wide track, im using a nova quick rack with corsa epas. The arms on the rack are then lengthned to match the track.
Ive heard mixed opinions on the quaiffe diff, the car is primeraly for track use. Need a diff with the f20 side gears due to running larger cv's shafts and hubs.
Yeah the cages is a custom cages jobie, im adding the dash bar and forward triangulation and am currently making some gussets at work to tag the cage to the pillars. |
11-11-2007, 10:05
#9 | | MIGWeb User
Join Date: Feb 2003 Location: ruislip Drives: nova 1.8 16v on tbs
| looking good!  titanium valves though? caps and platforms yes, but valves? also wouldnt bother with the big shaft setup, adds weight for no reason, never seen a small block car break a hub/shaft on track
__________________ shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008 |
11-11-2007, 10:33
#10 | | MIGWeb User
|  Got carried away with titanium. The reason im using the large shaft setup is because i was under the impression that because i was widening the track i would need longer shafts? please excuse my ignorance its all a bit new  good chance to learn just hope i havnt bitten off more than i can chew  |
11-11-2007, 13:10
#11 | | MIGWeb User
| mate ran gte shafts on his nova turbo..300bhp...he's had more problems with motorsport types as he went 5stud than the standard ones. |
11-11-2007, 14:11
#12 | | MIGWeb User
| Finished tarting up the gearbox. Still aint finished, needs gasket kit and diff. Box is a trans X 4 speed straight cut gear set in f13 housing.  |
11-11-2007, 14:49
#13 | | Regional Co-ordinator
| Gear box looks and sounds good, |
11-11-2007, 16:43
#14 | | MIGWeb User
| Quote:
Originally Posted by t45_ste The reason im using the large shaft setup is because i was under the impression that because i was widening the track i would need longer shafts? please excuse my ignorance its all a bit new  good chance to learn just hope i havnt bitten off more than i can chew  | to be fair, i didnt even think about that  why are you wide tracking? not sure whch shafts you would need, (guessing astra) big block or otherwise for that conversion, RodgerQ will know though, or speede who bought his car, but you definitely wont be breaking the small stuff with a small block |
11-11-2007, 16:57
#15 | | MIGWeb User
| Reason ive gone wide track is mainly due to the fact i can adjust toe etc. The kit comes in at the same price as the hockley pillbeam setup, pluss widening the track cant do the handling any harm  (please dont beat me for not buying one of your kits  )
ste |
11-11-2007, 17:02
#16 | | MIGWeb User
| ha, havent even got them ready for sale yet so dont worry  be interesting to see how this develops anyways, another cool nova track toy  |
11-11-2007, 17:02
#17 | | MIGWeb User
| forgot to add. built my brakes/susspension up
Rear
Just hope they fit under the wheels  |
11-11-2007, 17:04
#18 | | Regional Co-ordinator
| ooooo nice susspension, same as what i'm gonna get. |
11-11-2007, 19:38
#19 | | MIGWeb User
| Ste, did the rear turet towers comes as in pic or have you fabricated them yourself, if not where did you get them and how much are they..... |
11-11-2007, 21:24
#20 | | MIGWeb User
| same ones i used, rally design meant for an escort mk2, standard height, they even come with a little axle bracket that can be made use of when re doing the lower mount http://www.rallydesign.co.uk/catalog...oducts_id=4313 |
11-11-2007, 22:16
#21 | | MIGWeb User
| As Lee said rally design, i got the idea from him. I have the larger type, gives you a bit more to work with (i hope). |
12-11-2007, 10:52
#22 | | Regional Co-ordinator
| Sounds good, I'm not keen on the wide track idea but I'd love to see it progress.
Keep at it.
12-11-2007, 19:01
#23 | | MIGWeb User
| Todays tasty bits
Quick rack 2.5 turns lock to lock, with solid rack mounts although i have heard mixed opinions on these?
and hhms internal shifter kit (straight to the box turret)
Was suposed to be doing some work on the shell this weekend but doubt i will be doing now. Just had a fault code read on the daily driver variable valve timing is out causing high emmisions and lumpy idle  fookin £600 pounds of a job! Well pissed of! |
12-11-2007, 19:21
#24 | | MIGWeb User
Join Date: Oct 2002 Location: Scotland Drives: Mazda RX7 FD3S
| Nice project will be keeping an eye on this. Out of interest where did you get the shifter and do the do one for a corsa? lol |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
