10-11-2008, 21:36
#126 | | MIGWeb User
Join Date: Jan 2003 Location: LEICESTERSHIRE Drives: gte gsi 16v Racer
| Re: My WIP 1600 16v Track motor Very nice, so thats where it went, will go nice with the box |
10-11-2008, 21:56
#127 | | MIGWeb User
Join Date: Feb 2003 Location: ruislip Drives: nova 1.8 16v on tbs
| Re: My WIP 1600 16v Track motor no roller barrells? surprising for a swindon engine, looks nice though...
__________________ shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008 |
10-11-2008, 22:05
#128 | | MIGWeb User
Join Date: Dec 2004 Location: Colne Drives: TT 225/Track nova
| Re: My WIP 1600 16v Track motor Quote:
Originally Posted by MPH Very nice, so thats where it went, will go nice with the box | Did you see it go when it was in martins astra? |
10-11-2008, 22:07
#129 | | MIGWeb User
Originally Posted by lee303 no roller barrells? surprising for a swindon engine, looks nice though...  | I wish they were roller barrells. Going to have to see how i go on with the flywheel/clutch, i may not like it. |
10-11-2008, 22:08
#130 | | MIGWeb User
| Re: My WIP 1600 16v Track motor yeah, i think it will be a bit much if you want to road it, are they sintered plates? if so you definitely want to swap, as if you slip them they're funked, whereas you can slip a cerametallic and it will be fine, maybe just go for a 7.25 single plate if your looking to do road miles |
10-11-2008, 22:16
#131 | | Regional Co-ordinator
| Re: My WIP 1600 16v Track motor Christ that engines a bit hard core.. Flywheel looks tiny.
Of was thins the one in the astra that was shunted at combe?
__________________ Quote: |
10-11-2008, 22:47
#132 | | MIGClub Member
Join Date: Aug 2003 Location: gosport/swindon Drives: wife around the bend
Originally Posted by lee303 yeah, i think it will be a bit much if you want to road it, are they sintered plates? if so you definitely want to swap, as if you slip them they're funked, whereas you can slip a cerametallic and it will be fine, maybe just go for a 7.25 single plate if your looking to do road miles |
yeh i agree my i dont think i can get more than a few k out of a set of plates, think i will change to cerametallic at some point soon |
11-11-2008, 07:22
#133 | | MIGWeb User
Join Date: Feb 2002 Location: West Yorks Drives: Corsa Sport 2.0 XE
| Re: My WIP 1600 16v Track motor Spec list on the engine looks lovely, what sort of power will this be making (above 250bhp?) |
11-11-2008, 10:47
#134 | | MIGClub Member
Join Date: Nov 2000 Location: Huddersfield Drives: Corsa XE with TBs
| Re: My WIP 1600 16v Track motor Looks like a serious bit of kit!! What sort of cost was that to build?
Any videos/pics of the engine in it's previous home?
__________________ Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk |
11-11-2008, 11:05
#135 | | MIGWeb User
Join Date: Nov 2005 Location: chester/n.wales Drives: class 7 corsa;)
| Re: My WIP 1600 16v Track motor think ste said made 270 ish.  |
11-11-2008, 15:16
#136 | | MIGWeb User
Join Date: Apr 2007 Location: Doncaster Drives: A4 + Corsa kit car
| Re: My WIP 1600 16v Track motor Looking good mate, The Egg Sauce manifold makes it worth it - what a work of art!!
Rob |
11-11-2008, 15:20
#137 | | MIGWeb User
Originally Posted by wazpaz Spec list on the engine looks lovely, what sort of power will this be making (above 250bhp?) | It made 275bhp / 183lbft on its last rr but since then the manifold has been changed and a few other bits and bobs. |
11-11-2008, 15:29
#138 | | MIGClub Member
| Re: My WIP 1600 16v Track motor That exhaust manifold is fkin special. Can someone explain the benefits of that over the normal straight down and under the sump ones? |
11-11-2008, 15:45
#139 | | MIGWeb User
| Re: My WIP 1600 16v Track motor clearance!  the shape in itself is probably a tiny bit more restrictive than just going under the engine as it has an extra 90 degrees of bend, but it will allow the extra long primary lengths of a type c type manifold with out the issue of getting it to fit in the car without hitting the chassis etc
typical of matty simpson though, nice large radius bends and spot on fabrication work |
11-11-2008, 15:46
#140 | | MIGWeb User
| Re: My WIP 1600 16v Track motor All the pipes are equal length, a normal manifold has longer pipes on the outside and shorter on the inside. Its more balanced as all the gas' escape at the same rate.
I think.... please correct me if im wrong (im sure someone will)
rob |
11-11-2008, 15:50
#141 | | MIGWeb User
| Re: My WIP 1600 16v Track motor any decent manifold has equal primary and secondary lengths though, those 'loops' are not neccesary to achieve that |
11-11-2008, 15:52
#142 | | MIGClub Member
| Re: My WIP 1600 16v Track motor Clearnace?  My huge SBD TypeC manifold fits in my corsa ok. Are you saying that that manifold is designed purely for a high powered XE into a Nova? Or that that manifold is looooads better than the SBD TypeCs?
PS. Saw a picture on PNG the other day of a chap with a manifold that went around by the dizzy on an XE. That was also mental! |
11-11-2008, 15:55
#143 | | MIGWeb User
| Re: My WIP 1600 16v Track motor The manifolds that go round the dizzy and over the box were used on some of the btcc cavs i think? This allowed the engine to be pushed lower down. |
11-11-2008, 15:59
#144 | | MIGWeb User
Originally Posted by DaveB Clearnace?  My huge SBD TypeC manifold fits in my corsa ok. Are you saying that that manifold is designed purely for a high powered XE into a Nova? Or that that manifold is looooads better than the SBD TypeCs?
PS. Saw a picture on PNG the other day of a chap with a manifold that went around by the dizzy on an XE. That was also mental! | that manifold is better than a type c mainly because of the large radius bends matt uses, the type c from SBD is actually fairly compact for what it is, but thats because of the way the secondaires are stacked, and i wouldnt be surprised to find the primaries on the one above are a slighlty larger diameter than the type c
all i'm saying is matt will have built that to fit the car, and obviously though that was the best way of getting the primary and secondary lengths correct without running into clearance issues with something, or so he could tuck the pipes close to the dry sump pan, the design of the 'loops' does not enhance the performance because of their shape |
11-11-2008, 16:10
#145 | | MIGClub Member
Originally Posted by lee303 the design of the 'loops' does not enhance the performance because of their shape | thanks  |
11-11-2008, 16:32
#146 | | MIGWeb User
| Re: My WIP 1600 16v Track motor no worries  |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
