12-11-2007, 21:02
#26 | | MIGWeb User
Join Date: Feb 2003 Location: ruislip Drives: nova 1.8 16v on tbs
| solid rack mounts are great, just remember to fit the plastic packers behind them or the rack can move about, alot
__________________ shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008 |
12-11-2007, 21:20
#27 | | MIGWeb User
Join Date: Dec 2004 Location: Colne Drives: TT 225/Track nova
| I thought you were against them? Due to the fact if you hit a kerb there nothing to absorb the impact? Im all for em, they look cool, nice and light and tighten up the steering what more do you want for £25.  |
12-11-2007, 21:22
#28 | | MIGWeb User
| i have them on mine so dunno why you thought that, they rock  |
12-11-2007, 21:40
#29 | | MIGWeb User
| Good stuff. If there good enough for you. Thanks for the guidance on the rear susp. Will make up a set of spacers at work, probably outa titanium have tonnes of the stuff at work (benefits of working for a firm that produces jet engines  ) |
13-11-2007, 14:51
#30 | | MIGWeb User
| nice, just make sure they dont touch in the middle of the joint and they'll load the joint correctly  |
15-11-2007, 16:37
#31 | | MIGWeb User
| Had a quiet shift at work today so made a start on polishing my sump No real need im just a tart and like things clean  . Also started to make some titanium spacers for my rear coilovers and some titanium brackets for the golf rear calipers. Heres the sump:  |
17-11-2007, 18:04
#32 | | MIGWeb User
Join Date: Mar 2003 Location: Manchester Drives: Corsa C / RWD Nova
| Quote:
Originally Posted by t45_ste |
You've got to carefull with some of the stuff Hockley sells - sometimes cheaper to buy the genuine item http://www.montgomery-motorsport.co....sa%20Parts
Quaife gearlever £325
A mate who's building a Corsa C Super1600 had quite a lot of parts off hockly recently - All excellent quality - however the plain black steel sequential gearlever that hockly supplied was quickly sent back when we found out a Sadev machined alloy sequential lever was roughly the same price !!!!
Dave
Reason: link incorrect
17-11-2007, 18:14
#33 | | MIGWeb User
| thats where i got my gearlever from  |
17-11-2007, 18:20
#34 | | MIGWeb User
| Quote:
Originally Posted by lee303 thats where i got my gearlever from  |
Cheaper than buying it direct from quaife
Unless you know a man that can
Dave |
17-11-2007, 18:26
#35 | | MIGWeb User
| it was at the time as they bought all of quaifes stock! they were £25 cheaper including delivery iirc |
21-11-2007, 17:20
#36 | | MIGWeb User
21-11-2007, 17:29
#37 | | MIGWeb User
| ideally you want both sides of the spacer to fit nside the rose joint, and to have a small gap in the middle so they dont touch each other, this way you load the rose joint the way it should be loaded
pics of the door handles?  |
21-11-2007, 17:41
#38 | | MIGWeb User
| The stepped bush doesnt exeed the width of the bush so never touches the other spacer. Its only like having SPACER - 10MM BUSH - SPACER. I could part the step from the stepped bush and have 3 seporate pieces. It Nips the rose joint when tightned. Havnt go any pics of the handles. Cant take a camera to work. Will get some when finished. If you like em i could knock you a pair up for free? Doesnt cost me owt  |
21-11-2007, 21:21
#39 | | MIGWeb User
| sounds good, love to see some pics when they're done  i see what your saying about the spacers, but if your making them from scratch, i would have had both going into the rose joint, and if you part the inner spacer from the outer ones, then you wont load the joint as its designed to be loaded, in relation to the inner radius on the ball of the joint, dont think it will cause any worries in this application, but for stuff under lots of load, its worth doing imo
dont mean to nit pick though, and am jealous of your ease of access to free titanium  |
22-11-2007, 15:43
#40 | | MIGWeb User
| I see what you mean now. The material is an absolute pain to work with! Notr realy much of an update, recieved my arp head studs and just ordered full gasket kit with 1.3mm metal head gasket and steel rollers and new cam belt. Finished one of my hangers for the rear calipers :  |
22-11-2007, 16:19
#41 | | MIGWeb User
| bitch to work with it may be, but its titanium!  |
22-11-2007, 18:25
#42 | | Regional Co-ordinator
| Quote:
Originally Posted by t45_ste | Sorry for being dumb, but what is it?
__________________ Quote: |
22-11-2007, 18:31
#43 | | MIGWeb User
| Looks like a mounting bracket for a rear caliper - 4 holes to the left are where the stub axle mount through - the two to the right look like caliper mounts !!!
I'm sure Ste will correct me if I'm wrong
Dave |
22-11-2007, 18:53
#44 | | MIGWeb User
|  Correct  . Im using golf mk3 rear calipers- as per the build manual. The reason its all blue is so that i can scribe on it. |
22-11-2007, 21:27
#45 | | MIGWeb User
| i think you should change your user name to Ti_ste  |
22-11-2007, 21:31
#46 | | Regional Co-ordinator
| Ah i get it, very cool.
Why the golf ones? surely mk4 astra use the same kinda set up? |
22-11-2007, 21:32
#47 | | MIGWeb User
| Quote:
Originally Posted by lee303 i think you should change your user name to Ti_ste  |
Lee - So you were the only person paying attention when you had to learn chemical symbols at school
Dave |
22-11-2007, 21:33
#48 | | MIGWeb User
| yeah, kinda had to pay attention in science, my mum was the science class technician  |
22-11-2007, 21:34
#49 | | MIGWeb User
Join Date: Oct 2003 Location: glasgow/oban Drives: like its a hire car
| the mk4 astra still uses gay handbrake in drum bollocks doesnt it? the golf one, while prone to seizing, fit straight onto nove stub axles and have a disk handbrake
__________________ Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!" |
22-11-2007, 21:38
#50 | | Regional Co-ordinator
| No thats the point...
it uses the calipar and disc as the handbrake. |
Members: 43,212
Threads: 310,610
now!
of being a MIGClub Member.
