Page 1 of 2 1 2 LastLast
Results 1 to 25 of 29
Thread: The birth, re-birth, death and re birth of the Silver GSI
    Dec 2002
    S Wales
    TB'd Nova, S2000
    Thought I would post this as a reminder to me how much time it owes me! lmao
    Shell purchased in 2005 with roll centre cage and 2L Engine fitted
    Fully stripped down and repainted. No rust found, so it was a simple rub down and re-paint both exterior and interior. Notice the new GM roofskin to get rid of the sunroof!!
    Engine and associated parts sold off (for a profit!! Lol)
    1600 16v engine fully rebuilt (for 3rd time!) with new pocketed pistons, rods, bearings etc. SBD 184 kit included (cams etc) was fitted in June 2005
    Ran for approx 8 months with a few problems until…
    Engine Death!
    Decision was made to go 2L power, as the 1600 had been too much of a nightmare!
    Started buying bits to convert the 1600 TBs to fit the 2L….along with an sbd type C manifold and some Pico high flow injectors
    Then bought an F28 with an ATB diff in, to swap into the F20 I had. Fitted all new bearings and seals for good measure too….
    Bought a 1988 20XE with an early Coscast head with the larger guides and hand-finished ports.
    Then found a John Toovey built ‘race’ spec engine that was going for a reasonable price that had recently been built, with receipts that would make your eyes bleed! Lol
    It was a bare engine, but most of the bits either fitted off the 1600 or were taken from the other XE I had.
    Also fitted an alloy bottom pulley and a 5kg flywheel from an Escort XE.
    Realised that my SBD manifold would clear the Swindon baffled sump! So had a standard alloy sump baffled from Toovey.
    Fitted a Corsa PAS quick rack with a Saxo electric pump
    Took a while to mount the 16 row Mocal oil cooler too, but got a hydraulic place to make me up some pipework, so I could squeeze it in, next to the rad.
    Most bits fitted and almost ready to go….
    Then it was mapped at Mech Motorsport in Cheltenham, but we couldn’t get it to sit properly on the rollers to get a full power reading…. But it was sitting at 217 bhp @ 6700, and it needed as much fuel at the limiter (8200) as it did at 6700…. So it goes well!
    Here she is at Llandow a few weeks later!!
    Too many Vauxhalls, not enough fuel.
    Dec 2001
    East Sussex
    Cav with TB's & lots
    Very nice. Like that.
    Change the HP fuel line from the FPR to a braided item though. Especially with those JIC connectors.
    MIGClub Member donvaux's Avatar
    Jul 2005
    pontypool, s.wales
    Corsa VXRArctic, Combo
    looks great will, novas like yours make me wanna buy one
    Jul 2007
    aberdeen
    mk3 astra gsi c20let
    that looks awesome!
    Nov 2005
    chester/n.wales
    evo 6 gsr
    fair do's v.nice how long did it take you to entend the cage to the front turrets?
    That is funking lovely,
    Fitting a full roof skin... christ.
    everything looks top notch,
    does the corsa rack fit stright on? no messing about?
    engine looks very very nice, taking it shes spec'ed right up?
    how come you dont have to have anything at the dizzy blank bit?
    Dec 2002
    S Wales
    TB'd Nova, S2000
    Cheers matey, the corsa rack needs about .5" cut off from each end and re-threaded. You also have to cut away where it meets the bulkhead, but its nothing really. Easily one of the best mods I have done.
    Unsure what you mean ref the dizzy? Its blanked and I am using the 1600 coil pack for the MBE...
    Will post an engine spec when I have 10 minutes! lmao
    when you say cut off and re threaded.. where do you mean from?
    and normal xes have a dome like end on the dizzy blank bit, with a sensor onthe bottom,
    where you have nothing...
    Aug 2005
    Manchester
    A Slow Corsa
    basically shorten where the track rod end's screw on i guess, as corsa one's are longer
    hhmmmm shouldnt be to hard really...
    Dec 2002
    S Wales
    TB'd Nova, S2000
    Its been blanked off mate, no need for it.
    ah cool,
    just looks differetr and made me wonder thats all,
    Dec 2002
    S Wales
    TB'd Nova, S2000
    Also notice that there is no oil breathing system....
    MIGClub Member CortraGTE's Avatar
    Jul 2005
    On Guard
    XE Nova
    Thats mint looking mate!
    Royal Marines Commando
    Mar 2004
    whitby
    single turbo rx7
    tis very nice, need a engine spec though may be a vid
    i miss my vauxhalls breaking down
    Dec 2002
    S Wales
    TB'd Nova, S2000
    Rough Spec:
    Head:
    Extensive porting and headwork, with stainless, one piece, wasted valves. 33mm Inlet, 29mm Exh.
    Bronze Valve guides.
    Double valve springs, with titanium caps and
    solid lifters.
    Piper 296/300 cams
    TurboSport adjustable pulleys
    Cometic Head Gasket
    Block.
    Machined to 87mm with JE forged ‘slipper’ pistons.
    Total Seal rings
    Arrow Steel Rods
    Uprated big end and main bearings
    Knife Edged crank
    Arp bolts throughout
    Modified Swindon Race Baffled sump kit
    Lightened flywheel/crank pulley
    Nov 2002
    Vale Garage
    400BHP Evo+911 Turbo
    Quote Originally Posted by Foy Bacer View Post
    and me you cheeky bastad!lmao lmao lmao lmao lmao
    Rich
    Vale Garage, Car Sales, Servicing, MOT's and 24 hour recovery.
    Knife Edged crank
    is it just what it sounds like?
    they've made the round edge knife like? and if so why?
    Dec 2002
    S Wales
    TB'd Nova, S2000
    So it can 'chop' through the oil quicker apparently!
    Ah cool, thank you.
    Dec 2003
    NEWCASTLE
    NOVA 1.6 16v + Vectra GSI
    That was the nova that was done by ASW wasnt it, was featured in Fast Car (i think) years ago with Nick Caro's nova with it!
    Look nice all finished, i think everybody has had theyre nova stripped at some point to re do it to a different level of modification and upgrading!
    1.6 16v Nova. Something newer!!
    Mar 2005
    newport s.wales
    nova
    and me and kristan didint help at all did we!
    Dec 2002
    S Wales
    TB'd Nova, S2000
    Kristin did, and so did Rich. Fair play to them.
    Dec 2002
    S Wales
    TB'd Nova, S2000
    Quote Originally Posted by GDN16v View Post
    Feck me, well spotted! It was indeed... looks a bit different now! lmao
    I have the full feature at home from 1997!
  26. #25
    Dec 2003
    NEWCASTLE
    Thought it was! Was called! Couple of sweet 16's or somethinglmao lmao lmao
    Remeber seeing it and thinking,yip i want a 2.0 16v nova, then went down the 1.6 16v route!
    From the pictures it looks like youve used the 1.6 16v coil pack?
