Page 12 of 40 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... LastLast
Results 276 to 300 of 984
Thread: Ronnie's new runaround - Project VAN!
  1. #276
    rc
    rc is online now
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    Re: Ronnie's new runaround - Project VAN!
    Quote Originally Posted by fix View Post
    Just stop messing around with rubbish gm engines and put an Isuzu in it!
    when u brining it round?
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    Quote Originally Posted by adzie_2005 View Post
    just been reading this thread. my cuz just sold a diesel head for 20quid , it was brand new! dint think anyone would want it
    if you want i can give you the number for the guy he sold it to
    where bouts are you mate?
  4. #278
    Aug 2008
    Felixstowe
    Quote Originally Posted by rc View Post
    Felixstowe, my cuz sold it to a guy called pat seagar he owns a shop in ipswich
  5. #279
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    yes please DEFFOOOO find out, can get it asap!
  6. #280
    Aug 2008
    Felixstowe
    PM'd
  7. #281
    Oct 2001
    Bedfordshire
    Vectra CDTI 150
    Hey ronnie, just checked with my mate, and we have one of these kicking around if you want it ? has new springs, all the valves recently lapped in, but needs a stem seal
    The cake is a lie :(
  8. #282
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    Quote Originally Posted by SteveM View Post
    p'm'd
  9. #283
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Good to see you're sticking with the GM, Ronnie. They're not bad engines if they're looked after, I think they just get a bad rep because they're always compared with the Isuzu. Which obviously is miles better. And attracts women like you wouldn't believe.
  10. #284
    Oct 2001
    Bedfordshire
    Vectra CDTI 150
    Quote Originally Posted by Jack View Post
    only when running on veg oil, you'll get all the fat chinese lovers chasing after you lmao
    replied
  11. #285
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    cant change a habbit with the van, it gets as little as possible spent on it whats so ever! lmao
    if i was to change a whole engine it would be for another diesal anyway, how ever much better it is lol!
  12. #286
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    BIG thanks to SteveM for sourceing me a head
  13. #287
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    well managed to go get a head finally
    went to milton keynes today, bout 2 hours and picked it up, had new valve spring, valve stem seals, and all the valves lapped in, and had a pressure test and a skim before fitting, and wasnt on for all that long before the guy found his bottom end was nakered, so he just got a new engine!
    and all for 30quid
    gave it a clean up
    the oly thing he did say was he caught one of the valve stem seals when fiting it so he glued it up, so thought as i had a full head set id replace it
    stuck my injectors and glow plugs in as i new they were deffo all good
    got my delivery from autovaux out
    but went to put the manifolds on and its the wrong ****in head set
    its correct on the packageing though isnt it??
    nothings ever easy
  14. #288
    Mar 2007
    essex
    corsa c
    if the head gasket the same use that. and go to local motor fActors and get some gasket paper and make the rest mate
  15. #289
    Oct 2001
    Bedfordshire
    Vectra CDTI 150
    Happy to help mate
    Wish i could help you with the astra lmao
  16. #290
    Banned
    Oct 2005
    ThickFord Shropshire
    a BMW again lol
    OMG
    When will it go right, when it does Ronnie... Put a pound on the lottery mate
  17. #291
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    wel finally got the head set through today, genuine erling plesant suprise lol
    so went out to the van, where it had been sitting for a fortnignt now
    correct gaskets this time
    built up the head
    new headgasket on
    gettin all ready to go on and noticed something really strange.....
    on the end of the cam is the locating hole
    but nothing on the cam sprocket?????
    how the **** are you suposed to know where it goes? got 360degrees of cam adjustmaent???????even if you work out where the cam is tdc, and line the sprocket timing mark up, its still gonna spin when you tighten it up???
    things are never bloody simple
    could see where it was on the sprocket by the whitness marks, so dot punched and drilled it
    and made up a 6mm dowl for the cam
    then stuck the head on
    went to put the cambelt ont but got stuck on the tensioner??
    how do you work/lock/adjust it????
    help please....
  18. #292
    Oct 2001
    Bedfordshire
    Vectra CDTI 150
    put an alen key in the tear shaped bits hole, twist round, and do up the 13 in the middle
    and yeah, the diesels have no locator on the sprocket i was also confused lmao. theres a tool you can get that goes on the vac pump end which locks it tdc, then your meant to just do up the pulley and keep your fingers crossed it doesn't spin lmao
  19. #293
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Turn the alley key till the pointer is by the New mark(if your using a new belt), and tighten the 13mm.
    Turn it over by hand, then undo the bolt, turn the alley key bit till the pointer is lined up to either the used/new belt mark, and then torque the bolt up
    Done
  20. #294
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    so wheres the new/used belt mark?
    it is a new belt by the way.
  21. #295
    MIGClub Member Fow16v's Avatar
    Feb 2006
    Pontypool, S.Wales
    Mk4 GSi Van
    in the last picture the pointer lines up with the v cut out when tensioned up.
  22. #296
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Looking at your last pic, there aint any lma
    Must be different than petrol engine auto tensioners.
    Just turn the alley kit bit until the pointer points towards that V cutout in the back plate on the tensioner.
  23. #297
    MIGClub Member Joe's GSI's Avatar
    Jan 2005
    Uxbridge
    Astra Gsi Turbo
    ron i got auto data here if you want me to email you the timing belts info?
    just give the engine number and can email over? and is it a bosch or lucas.
  24. #298
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    pm'd cheers
  25. #299
    Sep 2005
    Huddersfield
    astra mk4 isuzu
    theres no locator for the cam pully cos your suppose to use a dial gauge on the camshaft to find the right posistion to bolt it on at , thats why there's no timing marks and stuff . these engines r a nightmare , lucky you could see that marking on the pully .
  26. #300
    rc
    rc is online now
    Jan 2007
    359.9bhp astra
    well worked out all the cambelt tensioner in the end, easy when you know how lol
    started up first time, didnt even need to bleed the injectors up or anything which was handy!
    idled lovely and all ran perfect!
    all going well, gave it a little rev, only to like 1500rpm, then all missfireing and getting alot of backfires through the turbo and it stopped, i thought doh cambelts slipped, bent the valves, took the cambelt covers off, and all the timing marks were spot on still strange, tried stating it again, just jumpy turning over on the strarter and popping aback through the turbo!
    strange, so whipped the rocker cover off and found this
    a broken rocker on cyl1 and cyl3
    so whipped the head bolts and cam box off
    put all my old rockers and lifters in incase there was someting wrong with the ones in the new head,
    and back together, reused the bolts and gaskets, its ****ed already so whats the worst that can happen
    started it up again, fired into life again, idles perfect, smooth as ever!
    gave a little 1500rpm rev again and bang pop pop pop, cambelt cover was still off so linded up the timeing marks and all spot on still,
    so took off the rocker cover and another broken rocker, in cly3 again, but the other valve
    what the **** is goin on???
