Old 15-09-2007, 18:36   #1
Drives: Astra MK4 SRI 2.2
My turbo Corsa finally ready for the road :-)
flopstocks is offline   Reply With Quote
Old 15-09-2007, 18:46   #2
keithcdb's Avatar
Drives: Coupe 2.2/MK1 Escort
Good luck to you mate, its lookin good.
keithcdb is offline   Reply With Quote
Old 15-09-2007, 18:47   #3
Drives: Corsa C Sxi
looks menacing from the front! Is it lower at the back that the front?
Statto is offline   Reply With Quote
Old 16-09-2007, 09:37   #4
lol At present it's got cut rear springs on - a nasty surprise! I got 60 mm springs comming soon! Yea the front bumper was done like that to improve air flow -the bloke who had the car before done it! Unfortunately for me I blew the engine and had to fit another :-(
Old 16-09-2007, 09:42   #5
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Looks very nice,
not a fan of the rear lights tho,
like the turbooo.
Old 16-09-2007, 10:59   #6
CortraGTE's Avatar
Drives: XE'd Corsa
Looks good mate! Not a gan of the rear lights but other than that good job. the front looks hard!
///O RLY?
CortraGTE is offline   Reply With Quote
Old 16-09-2007, 11:09   #7
Drives: Corsa C Sxi
hmmm cut rear springs, dead safe that so i take it the fronts on -60mm coilovers/spring n dampers? Shud handle like its on rails that thing!!
Old 16-09-2007, 11:26   #8
Drives: a Chocobo!
I'd lose the front are rear lights an get just tinted euro style on it
other than that nice
AK_LET is offline   Reply With Quote
Old 16-09-2007, 12:32   #9
Drives: class 7 corsa;)
they 17s? id go for 16's if can fit over brakes, handle even better then, looks well tho.
whats spec of motor?
philip2 is offline   Reply With Quote
Old 16-09-2007, 13:06   #10
dearing5's Avatar
Drives: C20LET 5dr corsa
tidy
change them rear lights though.
Roll on LET power....
dearing5 is offline   Reply With Quote
Old 16-09-2007, 13:13   #11
Banned
Drives: MSG blessed Calibra
I'd ditch the tints, the lights and add some colour coded doorhandles.
Engine wise you might want to route the coil lead a bit better and wtf is that dump valve?
Nemesis is offline   Reply With Quote
Old 16-09-2007, 18:02   #12
Yea I'm not really a fan of the lights either - they came with the car! Was a nasty surprise when I found the cut rear springs. The engine was removed from a L reg Cav from my local salavage yard (i'm assuming it was standard but it may not be!). Running phase 3 and i've fitted an upgraded intercooler, VXR injectors, f28 box, bigger diesel rad (hence putting the saxo PAS pump on!). It's running GMAX shocks front and rear. I'm not sure if the dump valve is working correctly, as it sounds like it's dumping through the air filter - got to look into that! The bottom engine failed on the old engine after 1 day Apparantly running 2.1 bottom end approx 305 bhp, but I'd take it with a pinch of salt! Guess I should strip it some time lol
A recent post
http://www.migweb.co.uk/forums/engin...corsa-let.html
Old 17-09-2007, 09:17   #13
Drives: Astra G 1.6 16v SXI
looks good mate going be an animal on the road. no a fan of the rear lights but other than that i love it. front end looks mean
kieron_67 is offline   Reply With Quote
Old 19-09-2007, 19:58   #14
Drives: Corsa C Sxi
u should remove the turbo badge from the side....kind of gives the game away a bit!!
even better, you could badge it up as a merit/LS or sumthin equally as sh1te. that wud surprise a few evo's etc.... haha
Old 19-09-2007, 20:26   #15
Drives: 200sx S13 Turbo
Very Nice
Should motor along well dude
vauxhallastra is offline   Reply With Quote
Old 19-09-2007, 22:05   #16
Drives: c20let corsa sport
its looking good the car m8!
any gen on the epas fitting as i wudnt mind getting rid ov ps pump and fitting a saxo electric pump! thanks
bolton is offline   Reply With Quote
Old 20-09-2007, 10:18   #17
Was quite really simple to fit. I used a corsa ABS mount bracket and simply welded the bracket with the PAS bracket! Wiring was simple, the rubber pipe is straight off the rack, and the metal one needing cutting and joining the saxo bit on the end. Also I had to shorten the filler neck, as it was too high!
Old 20-09-2007, 13:44   #18
thanks for info, mite have a go doing it to mine!
what model/yr saxo wos the pump off? thanks
Old 20-09-2007, 17:25   #19
Think it was an S reg VTR, there are two types one with a separate filler bottle, and one with a built in bottle (thats what I've got)
Old 29-10-2007, 11:31   #20
Ok sorted out my insurance with Adrain Flux, £500 fully comp However they will only insure as market value, because they require:
Independent Valuation - This is to be provided by an independent source, such as an owners club. It should be on headed paper and state clearly who has provided the valuation and their qualifications.
Unfortunatley for me I don't know any qualified people
Anyone know someone that could do this for me?
Old 29-10-2007, 11:51   #21
Drives: Astra Mk2 SX 24v
Little Evil!
Ross_Mk2 is offline   Reply With Quote
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
