Old 16-08-2007, 18:13   #1
Jack's Avatar
Drives: Cavalier 1.7 TD
Jack's diesel Cavalier
I reckon I've done enough to it to warrant it having it's own little project thread. I've got to keep the fans happy!
A bit of background; my Astra:
I really wanted something that would be a bit faster and that was a bit better on fuel than my Astra had been. I'd done a lot of work on it, and I was really upset when I looked outside and saw an empty drive.
I was looking ideally for an Astra with the Isuzu engine, but no-one seemed to be able to tell the difference over the phone, and I was almost tempted by some very ropey (in hindsight) GM-engined ones!
Eventually I found a Cavalier on the auto trader website. It looked very nice in the photos, and as it was only in Burntwood (literally 5 minutes away), I decided to go and have a look. It was abslutely spot on, bodywork wise, which is what I was worried about.
The Cavalier as I bought it, for the princely sum of £600.
Full service history, good tyres, and 128'000 on the clock.
Like any second hand car, it needed a few things doing to it to get it to Jack's High Standard of Awesomeness.
It was losing coolant very slowly, and we eventually narrowed it down to the water pump, which meant a new one was sourced and slid on. Ignore the axle stands. Ignore them.
Pick a pump! It wasn't technically new. It had been bought new, and used on a car for a few weeks. He sent me the new one, and the old one he took off. What a gent!
That one will do. It's the shiniest, therefore the best.
Needed moving along the shaft a bit as the belt didn't run true, so out came the bearing puller, and we managed to get it looking like this:
The better side, due to having dented doors on the other side! Doh!
Ooops!
In Long Eaton with Chav after I'd picked up my new £16 ebay alloys (that I have now found out at BSA 801s) and had my old tyres swapped over! Some mental wheel wobble meant I had to drive back along the A50 at 45mph.
Got it up on the ramps and discovered one tyre was completely deformed, I needed spigot rings badly and they all needed balancing with adhesive weights.
It took about three weeks of new tyres, balancing and faffing around to get them acceptable.
Poor Cav.
A rare shot of the "dark side", showing the dodgy doors.
An equally rare "just washed" shot.
The two diesels preparing to see once and for all who is the manliest Mig member.
My nice boost gauge that I tried very hard to get it to look like a standard part. It's all interferance fit too, so I can put it back to how it was without damaging or marking anything. Reversible mods are where it's at.
It took months to find someone breaking a Cavalier in my colour, as there are two colours that share the same paint code. I eventually found some near the coast in Wales, which was an ideal oppurtunity for a trip out and show my girlfriend where I'd been on holiday a few months previous.
Spot the new doors! Very nice! The front one has some peeling lacquer and a small scrape at the bottom, but it's much better than the old one. I paid £10 for both doors, and the tat man picked up my old ones off the drive.
New seat frame for the MOT, as the seat belt socket was crap.
Scrap yard tip #1: Take all the bolts with you that you take off, as I'd have been stuck without these little beauties.
MOTed and beautiful once again.
Maximum speed! Cover the eyes of small children...etc!
My new white LEDs behind the dash. They were cheap and nasty, and not as diffusional as the ones I had in my Astra, but they look good at night. Sublety is the key, and I prefer white to camel piss yellow.
Called some imaginative use of a breaker bar to get the bolds undone with only two hands. I know, I'll brace it against the wheel and cable tie it to the tow bar.
Slid off easier than I thought it would, and no rust in sight! Beautiful. A quick slide over with a damp sponge and it looks good enough to eat off!
Ghetto panel straightening courtesy of Mr Nigel "I can fix anything with a rock and a toothbrush".
SRI goodness.
And the front. Spot the colour coded mirrors!
Cavalier TD: Going strong, 160'000 miles and 169ftlbs.
Corsa 1.6 16v: New inlet manifold!
Jack is offline   Reply With Quote
Old 16-08-2007, 19:28   #2
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Looks good dude,
slamming up next?
Old 17-08-2007, 11:58   #3
Brett's Avatar
Drives: '88 Astra GTE 16v
When I think back, when i first joined MIG in 2001 there must have been 50+ people doing this sort of thing to Mk3 cavs. Even I joined in.
Now I think your the only one! Fair play mate.
Needs a black boot panel, behind the reg plate IMHO.
Brett is offline   Reply With Quote
Old 17-08-2007, 12:11   #4
tommychimp's Avatar
Drives: Astra Mk3/Mk4 Cabrio
Slam it jack, and maybe some 17's?
1.8 Mk4 Astra Cabrio rolling on 18s
1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns
tommychimp is offline   Reply With Quote
Old 17-08-2007, 12:16   #5
Jack's Avatar
Doing what?
I'm not trying to acheive any particular "look", just trying to make my car nice.
I'm unsure whether I like the black panel or not. I might get one and see what it looks like.
I don't think I'm going to lower it, as my drive to work and my general area is speed-bump central, and it's nice and comfy as it is.
I'm not a fan of massive alloys either. I quite like the ones I have at the moment, although I am picking up some more tonight, so I'll see what they look like.
Old 17-08-2007, 12:46   #6
CraigGreen's Avatar
Drives: smallblock Novas
Atleast drop it 35-40mm. Its amazing how much less of a boat it can be when a little closer to the tarmac.
Liking it though, but for some reason I cant put my (little) finger on it still doesnt look SRi enough.
Good write up though.
V8 blender FTW
Old 17-08-2007, 12:53   #7
Jack's Avatar
Black slanted grille? Pre-facelift headlights? Side skirts?
Loads of things missing to make it an SRI, but I didn't want to make it into an SRI.
Old 17-08-2007, 13:00   #8
CraigGreen's Avatar
Mmm. Needs the skirts. I never thought of that.
I know you havent said its to be an SRi rep, but you're just adding bits to refine it I know.
Thing is most Sri's end up looking half like turbo's or something else. To actually attempt an SRi rep in that colour is cool IMO.
Old 17-08-2007, 13:03   #9
Jack's Avatar
Might see if I can get some skirts, that might be a nice little touch.
Old 17-08-2007, 13:14   #10
Gagged
Drives: foreverwhite.co.uk
i'd have left it completely standard on black steelies.
i prefer the steelies over chav looking tiny 5 spokes with massive tyres.
i hate the 15" 5 spokes on my calibra that comes as standard, think they ruin the looks.
and i think the standard bumpers were better as they are smoother with more colour coding.
MIGweb mobile phone/teeth whitening expert.
foreverwhite is offline   Reply With Quote
Old 17-08-2007, 13:18   #11
tommychimp's Avatar
Each to there own, although alloys beat steelies any day!
Don't diss the Cav of love man!
Old 17-08-2007, 13:27   #12
Drives: admin up the wall
Jack, it's higher than SimonP's post count!?! Sort it out!
You can't moderate me, I am far too important!
wayne451 is offline   Reply With Quote
Old 18-08-2007, 02:44   #13
BlackIce's Avatar
Drives: Shonky Focus C-Max
its got a ma-hoooosive boot though!
If I like it, I lick it. If I dont, I kick it
NEED DECENT PART WORN TYRES? CONTACT ME FOR A COMPETITIVE PRICE
BlackIce is offline   Reply With Quote
Old 18-08-2007, 06:52   #14
Benn's Avatar
Jack :
What Brett means is people where doing them up,
making thema lil sexier,
agree with him on the boot pannel,
Old 18-08-2007, 08:36   #15
Jack's Avatar
Ah, I see. I think I'd be doing it no matter what car I had.
Old 20-08-2007, 09:49   #16
Brett's Avatar
Originally Posted by Jack View Post
Doing what?
Doing = playing around with a Mk3 cav, not spending a fortune, just tidying it up and improving it here and there. I did the same with mine and there were loads of people doing it at the time!
Please fit some early SRi sideskirts!! they will make the car. Sills shouldnt be a worry if you tret them well before hand
Old 22-08-2007, 11:26   #17
Jack's Avatar
The sills are absolutely solid. I shall endeavour to find some skirts.
Old 22-08-2007, 12:08   #18
Drives: around looking Cool!
Coming on strong now! Keep up the good work Jack.
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot!
Old 24-11-2007, 18:52   #19
Jack's Avatar
Now sporting a new aftermarket radiator, a new alternator and a John Deere battery.
On the rollers...
Old 01-12-2007, 08:31   #20
have u just turned the boost up
yogibear47.lee is offline   Reply With Quote
Old 01-12-2007, 08:58   #21
Jack's Avatar
I don't know what you're talking about, it's just well serviced.
Old 20-12-2007, 00:00   #22
DaveB's Avatar
Drives: Corsa XE with TBs
Dude just drive it. Save your money.
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is offline   Reply With Quote
Old 20-12-2007, 09:00   #23
Jack's Avatar
I love it too much to replace it.
Old 20-12-2007, 15:47   #24
Ed
Drives: GTE 16v
That was a funny write up lol. That shot of just under 70mph is not really the max speed is it?
Ed is offline   Reply With Quote
Old 20-12-2007, 15:54   #25
Jack's Avatar
What, 0 - 60 in 9 seconds and a top speed of 70?
I don't really know what the top speed is. It's not really geared for high speed. 3000rpm is bang on 75mph, so 4000rpm works out to be 100mph and 5000rpm is 125mph.
I daresay it would reach 120mph before the boost fell away.
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
