16-08-2007, 14:19
#1 | | MIGWeb User
Join Date: Oct 2005 Location: South London Drives: Vectra B C20LET
| PROJECT: rear wheel drive vectra Now i've got my charger for the laptop i can finally start my project thread. After owning my last c20let vectra for nearly 4 years (starting as a 1.8) i fancied a change. I thought about selling all my stuff and starting again but i didn't want to go jap and i'm not rich enough for an escort cosworth just yet  . The only other option was to rear wheel drive my vectra but the car had rear damage from when i bought it though and wasn't really an option. I had a X plate 2001 laying about so that's what i'm using. The shell is mint although the interior was filthy. I'm looking for 400hp in the end but will happily get it running on std power.
my old turbo
[IMG]  [IMG]
The new daily runner
[IMG]  [IMG]
Some pic's of the car when stripping it down
[IMG]  [IMG]
[IMG]  [IMG]
[IMG]  [IMG]
The first thing i done was lose all the bracket's in the engine bay so i can smooth it all down. i then got a friend to weld all the holes up and grinded back down and filled
[IMG]  [IMG]
[IMG]  [IMG]
Started on the rear. First thing was to take the rear axle off
[IMG]  [IMG]
Then the fuel tank
[IMG]  [IMG]
I had to go over to near santapod to pick up a calibra rear axle off jamied on. Got to see his rear wheel drive astra mk2 and was a top man
[IMG]  [IMG]
started to fit the rear axle
[IMG]  [IMG]
[IMG]  [IMG]
I took out the spare wheel well so the rear can be strengthened
[IMG]  [IMG]
This is where i'm up to at the moment. I'm finding it harder to get parts then i thought it would. Once i've got the gearbox and rear diff i can start on mounting the engine. |
16-08-2007, 14:30
#2 | | MIGWeb User
Join Date: May 2004 Location: northants Drives: Astra G SRI 2.0 16v
| looks to be a good project and should be fun when its finished. |
16-08-2007, 14:37
#3 | | MIGWeb User
Join Date: Jun 2007 Location: Charlton, London Drives: Snail powered Astra.
| Damn! I was thinking of a similar project. Ohwell, hope it turns out good, sounds interesting.  |
16-08-2007, 14:42
#4 | | MIGClub Member
Join Date: Jul 2001 Location: Suffolk Drives: Vectra GSi & A4 1.8t
| Nice one Lee! |
16-08-2007, 15:04
#5 | | MIGWeb User
| Interesting project - looking forward to seeing how this one comes out!
__________________ Scuderia Ferrari - Formula One Constructors' Champion 2008
Hamilton: Races finished (17) Races Won (5) 29% win ratio
Massa: Races finished (15) Races Won (6) 40% win ratio |
16-08-2007, 15:17
#6 | | MIGClub Member
Join Date: Jul 2005 Location: 31.5175 - 34.453056 Drives: XE'd Corsa
| Nice one mate should be a cool project!
__________________ ///O RLY? |
16-08-2007, 15:52
#7 | | MIGWeb User
| hopefully should be fine. My biggest headache will be the steering but hopefully omega/carlton stuff will be persuaded to fit. we'll see  |
16-08-2007, 17:37
#8 | | Regional Co-ordinator
| christ,
good work dude! |
16-08-2007, 20:29
#9 | | MIGWeb User
| Nice project do the calibra, rear beams bolt straight in ?
Will be keeping a good eye on this one... |
16-08-2007, 20:36
#10 | | Banned
Join Date: Sep 2004 Location: MIG's dungeon :-( Drives: MSG blessed Calibra
| Why are you changing the steering? |
16-08-2007, 20:52
#11 | | Regional Co-ordinator
| Quote:
Originally Posted by Nemesis Why are you changing the steering? | so he steers left and the car gos right?
like when you invert your mouse...
__________________ Quote: |
16-08-2007, 21:59
#12 | | Banned
No really, why? The steering is separate from the engine/drivetrain is it not? |
16-08-2007, 22:21
#13 | | Regional Co-ordinator
Join Date: Mar 2002 Location: Birmingham Drives: E46 320D
| If he mounts the engine the right way round it will foul the steering rack.... id imagine even to do the transmission tunnel the rack will be in the way.
Originally Posted by Jack on about diesel tuning Turn the boost right up and turn your fueling up to match! Leaving a trail of dead dolphins in your wake! | |
16-08-2007, 22:26
#14 | | Banned
| Ah I see. I wonder if a Calibra Turbo would have been a better starting car (ie there is already a trans tunnel) |
16-08-2007, 23:01
#15 | | MIGWeb User
Join Date: Nov 2002 Location: Vale Garage Drives: 400BHP Evo+911 Turbo
| Quote:
Originally Posted by Nemesis Ah I see. I wonder if a Calibra Turbo would have been a better starting car (ie there is already a trans tunnel) | I can't say I remember seeing a transmission tunnel last time I was under a cally turbo. They have a slightly bigger space for a prop, but nothing like what would be required for a RWD box.
Rich
__________________ Vale Garage, Car Sales, Servicing, MOT's and 24 hour recovery. |
17-08-2007, 12:47
#16 | | MIGWeb User
| As said above the vectra steering goes across where the gearbox want's to go down. the omega steering sit's underneath the gearbox so will need to change over to that. |
17-08-2007, 16:52
#17 | | MIGWeb User
Join Date: Apr 2006 Location: Atherstone Drives: 2 many 2 list
| As all ready asked are the rear drive trains easy to fit??
stu |
17-08-2007, 17:47
#18 | | MIGWeb User
Join Date: May 2003 Location: durham Drives: R1 ,Astra V6, cav.t
| the exhaust tunnel serves as as prop tunnel on the cav/cally turbo does it not? Should be the same on the vectra.
Nice project mate..... Good luck with it. I recall the vectra steering rack is mounted on the bottom of the subframe, unlike the cavalier which is mount on the bulkhead. So the standard might sit below the engine/gearbox?
__________________ LET the fun begin....... |
17-08-2007, 17:54
#19 | | MIGClub Member
Join Date: Aug 2003 Location: gosport/swindon Drives: wife around the bend
| Quote:
Originally Posted by lee866 hopefully should be fine. My biggest headache will be the steering but hopefully omega/carlton stuff will be persuaded to fit. we'll see  | imo thats not your biggest headache thats not to much of an issue there are lots of ways to sort that out
the biggest problem is getting the rear geometery correct because if it is not 100% in the correct place the car will never drive right
it might not even drive straight |
17-08-2007, 17:59
#20 | | MIGWeb User
| Quote:
Originally Posted by stuartp As all ready asked are the rear drive trains easy to fit??
stu |
yes and no. it could of been alot harder. the fact that the vectra share's the same platform is helping. Quote:
Originally Posted by bowman the exhaust tunnel serves as as prop tunnel on the cav/cally turbo does it not? Should be the same on the vectra.
Nice project mate..... Good luck with it. I recall the vectra steering rack is mounted on the bottom of the subframe, unlike the cavalier which is mount on the bulkhead. So the standard might sit below the engine/gearbox?  |
i'll be using the exhaust tunnel as the prop tunnel (after the gearbox section is cut away) and worry aboiut the exhaust later on. the vectra steering rack sit's straight across the tunnel so not possible to go underneath. i looked at calibra stuff but it doesn't sit high enough. i want to mount the engine and box as far back as possible. Quote:
Originally Posted by sbd16vastra imo thats not your biggest headache thats not to much of an issue there are lots of ways to sort that out
only 2 mounting point's don't have a mount so getting it stright won't be an issue imo. the suspension lines up as well as the the support bar that bolts to the subframe. |
17-08-2007, 19:57
#21 | | MIGWeb User
Join Date: Sep 2005 Location: durham Drives: astra g 1.6 3door
| so in some way the cally irs will bolt to the car ? |
17-08-2007, 23:11
#22 | | Banned
| Does the omega rack bolt up to the vectra rack mounts? If not then how do you plan on mounting it? |
18-08-2007, 17:38
#23 | | MIGWeb User
| Quote:
Originally Posted by spue2001 so in some way the cally irs will bolt to the car ? |
some ways yes Quote:
Originally Posted by Nemesis Does the omega rack bolt up to the vectra rack mounts? If not then how do you plan on mounting it? | until i have the parts thast i need i'm not sure. it's all about trial and error |
18-08-2007, 18:40
#24 | | MIGWeb User
Join Date: Sep 2006 Location: south london Drives: c20let mk4 astra
| seriously cool project mate, look forward to seeing it about
__________________ Ldv pilot van 1.9d-1 300bhp astra coupe-0
Vauxsport shonkyopels |
18-08-2007, 19:09
#25 | | MIGWeb User
Join Date: Jan 2006 Location: mansfield, notts Drives: LET'd 306
| Good project mate  hope everything goes ok with it all.
__________________ C20LET powered Peugeot 306. |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
