LinkBack (16) Thread Tools
Old 19-12-2007, 22:51   #101
Regional Co-ordinator
spanishfly's Avatar
Drives: ACT Nova TBs & less
Lee good project matey. If you ever need a hand holla.
Good idea on mounting the engine as far back as possible.
South-Eastern Coordinator
My nova
www.shonkyopels.de (now working lmao)
spanishfly is offline   Reply With Quote
Old 19-12-2007, 23:04   #102
Benn's Avatar
Drives: A shineeeey Nova
Originally Posted by Steve! View Post
Thought of all people, you would know that answer....
no.
Old 19-12-2007, 23:17   #103
Drives: around looking Cool!
You bring shame to MIG, go over there >>>>>> and have a word with yourself!
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot!
Old 19-12-2007, 23:23   #104
Benn's Avatar
*stands in the corner*
Old 21-12-2007, 20:36   #105
Drives: Vectra B C20LET
cheers for the offer mate. not doing anything to it until the new year then work flatout on it
lee866 is offline   Reply With Quote
Old 22-12-2007, 22:36   #106
Drives: like its a hire car
So exactly how hard is it to fit the rear suspension from the calibra to the vectra? You said all but two of the mounts bolt up? does it fit with the standard floor or does it need clearancing? Which mounts didnt fit? Any pics?
alistairolsen is offline   Reply With Quote
Old 22-12-2007, 22:50   #107
Banned
Drives: like its leased
way to go m8
montytronix is offline   Reply With Quote
Old 23-12-2007, 16:01   #108
Drives: astra gsi j93 let
nice ,ive got a calibra turbo rear floor pan ,prop annd complete rear diff lying, il be doing a similar project when i get space and time on my mk 3 gsi let
260bhp ,280lbs of torque
mickygsi is offline   Reply With Quote
Old 03-01-2008, 23:05   #109
Drives: Astra MK4 SRI 2.2
Great to see something different. Wish I had the ability to do something like this!
flopstocks is offline   Reply With Quote
Old 04-01-2008, 12:13   #110
Johnny A's Avatar
Drives: Saloon of Doom MKII
Originally Posted by lee866 View Post
You do realise that the engine is meant to be slightly tilted (in your case) to the N/S, this would have the side-effect of giving you the required clearance between the servo and inlet (remember the engine will be able to rock). This isn't a operational requirement of the setup but IMO it is a good idea.
Wanted - 3 door Nova, any colour/engine considered but must not be rotton
Vauxhall Carlton 2.0 16v Supercharged - Nutcase edition
Vauxhall Calibra 3.0 MV6 4x4 - How Vauxhall should have built it edition
Johnny A is offline   Reply With Quote
Old 05-01-2008, 14:42   #111
yes mate 7degrees. Even with the tilt it would of still fouled the servo i think and with the rocking i didn't want it hitting. Once i have the mounts i'll mount it as close to 7degrees.
Old 05-01-2008, 18:52   #112
Drives: Silky The Nova GSI
I No Most Of The Xe Escorts Are Tilted But What Is The Benefit?
6 speed, LSD, 5 stud, Silk Violet Gsi Turbo. NOW A 12.3 @ 116 Without Nitrous 11's when i do????
Chris S is offline   Reply With Quote
Old 05-01-2008, 20:35   #113
in the FWD car the engine naturally tilts forwards (onto the exhaust) to get more room at the back for the intake manifold and associated pipework, in the RWD escorts they tilt them for the same reason, although there's no power/running/reliability difference in it. the engines will run at 7 deg or completely vertical.
blakep82 is offline   Reply With Quote
Old 06-01-2008, 16:46   #114
Drives: '94 Cav SRi,L/R V8
Top job mate,id love to get my hands on it when its done!
Are you gonna run it at santa pod?
CavSRi16v2008 is offline   Reply With Quote
Old 06-01-2008, 18:24   #115
Reading on the sbd site it's more natural for the engine to lean 7degrees to the exhaust side. nothing to do with clearances but i can't give a techniqule answer as i'm not 100% sure.
I wanting to use it more to start getting into drifting more than strip action tbh.
Old 10-01-2008, 19:53   #116
Drives: astra gsi let, gte
any progress
ddiorazio is offline   Reply With Quote
Old 10-01-2008, 21:50   #117
Should start again on it it soon. should be picking up an omega over the weekend for loads of bits so next week should get some progress once again.
Old 18-02-2008, 14:07   #118
Drives: Nova P2 Turbo
any progress yet?
LiD0N is offline   Reply With Quote
Old 18-02-2008, 21:43   #119
need a fix!
Old 18-02-2008, 22:01   #120
Copied off vvoc as i'm to lazy to type again Going to pick up a welder in half hour so by the weekedn i should have the tunnel, firewall done.
Should the have the tunnel in place this week and start on the firewall. i've repositioned the engine and is sitting lower and got engine mounts just need to fabricate moutinng points on the subframe. not going to use the calibra rear subfame anymore as there's no adjustability on it at all so looking into a rear cadle only problem is gen wrc items go for 2k so looking into getting one made. when i get my phone back from 02 i'll stick the pics up as there on the memory card.
Old 28-02-2008, 20:57   #121
quick update. sorted the front sub frame so i can fit the rack. Also started on the tunnel now. battery died so only got a few pic's. Will be back up there tomorrow so will take more pics.
Some mods to the subrame. i'll box section it and strengthen it back up
Steering rack in place
Old 28-02-2008, 21:08   #122
Benn's Avatar
Are you gonna box that back in? maybe a moveable top bit? For strengh...
Old 28-02-2008, 21:13   #123
yes mate above the first pic says i'm gonna box it in and strenghten it back up
Old 28-02-2008, 22:15   #124
Drives: 3.0 V6, 2.5 V6, 1.8
Wonder who will get an MOT first?
This or Pete's LS1 Astra Coupe.
[url=http://77.96.230.10/sytemsandsoftwaredevelopment/systems.htm] How Tos
The two most life changing experiences you'll ever have. Finding Jesus, and having a baby.
Mark T is offline   Reply With Quote
Old 28-02-2008, 23:56   #125
hasn't he got that on the road yet? i was speaking to someone who said it came to there workshop the other week.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/328206-project-rear-wheel-drive-vectra.html
Posted By For Type Date
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 18:58
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 18:34
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 15:56
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 07-12-2008 05:53
BLITZ-GSI.com :: Voir le sujet - vectra turbo propulsion This thread Refback 15-11-2008 13:03
BLITZ-GSI.com :: Voir le sujet - vectra turbo propulsion This thread Refback 15-11-2008 12:24
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 09-09-2008 02:29
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 09-08-2008 22:27
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 09-08-2008 08:36
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 09-08-2008 06:07
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 08-08-2008 15:02
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 08-08-2008 10:26
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 08-08-2008 09:23
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 08-08-2008 09:15
Red top vectra?? - Page 2 - CavalierCrazy.co.uk This thread Refback 21-06-2008 16:28
Red top vectra?? - Page 2 - CavalierCrazy.co.uk This thread Refback 21-06-2008 16:27
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
