01-11-2007, 19:37
#76 | | MIGWeb User
Join Date: Jul 2002 Location: Northern Ireland Drives: Builds Nova Turbo
| Awesome work so far  |
01-11-2007, 20:07
#77 | | MIGWeb User
Join Date: Jul 2001 Location: Oldham, Lancs Drives: 3.0V6 Corsa With NOS
| Let me know how the Manifold fits mate
Anyone interested in one feel free to contact me for prices and infomation
__________________ www.Vox-All.com - Vauxhall Specialist |
01-11-2007, 20:26
#78 | | MIGWeb User
Join Date: Oct 2005 Location: South London Drives: Vectra B C20LET
| manifold seems fine. I'll trial fit it tomorrow and get some pic's up. Excellent quality |
01-11-2007, 20:33
#79 | | MIGWeb User
Join Date: Aug 2003 Location: penrith, cumbria Drives: nova gsi c20let
| manifold looks very nice ! whats it made from and is it tig welded ? |
01-11-2007, 20:34
#80 | | MIGWeb User
Join Date: Jun 2006 Location: windsor Drives: cavalier turbo
| nice looking manifold im still in the marke for one but dont know which one to get yet.
what sort of power you aiming for lee |
01-11-2007, 20:52
#81 | | MIGWeb User
| don't think there's a better quality manifold other than peter g's and unfortunally chip's got the last ones of them. I've got a figure in my head but my minimum is 400-420 which is realistic i think. |
01-11-2007, 21:24
#82 | | MIGWeb User
| Looks like an interesting project, could I suggest another way of doing your engine mounts?
Will scan some photos of some I made years ago, might be useful to you |
01-11-2007, 22:07
#83 | | MIGWeb User
| Quote:
Originally Posted by tom reid Looks like an interesting project, could I suggest another way of doing your engine mounts?
Will scan some photos of some I made years ago, might be useful to you | Yes by all mean's. Was hoping someone would have another view on mounting the engine. Would be appriceated. |
02-11-2007, 21:37
#84 | | MIGWeb User
as promised, the rubber mount was sourced from Rally and Competition Equipment in Stoke, the block mounting plate is 5mm thick and the tube is 3mm wall thickness.
The metal shroud for the rubber mount was sourced from a steel stockholder, sorry, can't remember the dimensions.
Hope this helps |
02-11-2007, 21:37
#85 | | MIGWeb User
02-11-2007, 21:49
#86 | | MIGClub Member
Join Date: Apr 2005 Location: London Drives: Calibra 16V 2L P Reg
| Lee866 I think you are absolutely fookin Jenious! I have to give you that mate! good project.
__________________ Calibra simply Calibra
I blessed Nemesis's Calibra and he got gagged, anybody else wants their Calibra blessed? |
02-11-2007, 21:50
#87 | | MIGWeb User
| Thanks thats much appriciated. Thats given me another way to think about which i prefer to my method tbh. I've just had a thought where maybe i could mix the 2 together. backing plate with the tube then another plate at the end of the tube and use the rubber mount in my pic to mount to the subframe. i'll make some dummies tomorrow and take aload of measurement's again
thanks |
17-11-2007, 18:31
#88 | | MIGWeb User
| looking good!  |
09-12-2007, 16:29
#89 | | MIGWeb User
| Got the steering sitting in place now. Need to get brackets welded up to the subframe and will have steering. Probably won't do nothing else to it until after christmas now. Going to start on the welding now and get the tunnel and bulkhead done
Once dry sumped and engine up another 1/4 inch it'll all be fine or mod a manta sump
View from the inside
Just cleared using the 1.8 sevo  |
09-12-2007, 16:33
#90 | | MIGClub Member
Join Date: Jul 2001 Location: Suffolk Drives: Vectra GSi & A4 1.8t
| Good going chap! |
09-12-2007, 17:08
#91 | | Regional Co-ordinator
| Looks very cool, does the streering knuckal clear the starter?
__________________ Quote: |
09-12-2007, 17:42
#92 | | MIGClub Member
| What is the final position of the engine? In some of those pics, you're never going to be able to get the last spark plug out...
__________________ Cavalier TD: Going strong, 160'000 miles and 169ftlbs. Corsa 1.6 16v: New inlet manifold! |
09-12-2007, 18:25
#93 | | MIGWeb User
| Quote:
Originally Posted by Benn Looks very cool, does the streering knuckal clear the starter? |
Yes clears it fine. the starter goes up. did have a picyure with the starter in but can't find it. Quote:
Originally Posted by Jack What is the final position of the engine? In some of those pics, you're never going to be able to get the last spark plug out... | LOL if that was the case i think i'd have my work cut out with this project. The vectra has a plastic panel that sit's along the top. Where the i'd need to access the last spark plug is where the pollen filter would sit and there's a panel that lifts up to access it. how the engine is sat now i could access eveything. the rocker cover can lift up and slide out also. my only concern is the external wastegate but i'll be picking that up soon so will sort that out then. |
09-12-2007, 18:40
#94 | | Regional Co-ordinator
| How come the engines so far back?
Surely if it was father forward you have more clearance on the sump and things... |
09-12-2007, 18:52
#95 | | MIGWeb User
| Having the engine further back will help with balancing the car up. I don't want the engine in front of the front wheels making it nose heavy and want to understeer all the time. Where ever the engine is i'll have clearance issues. In fact if i had it forward i'd have alot more problems mounting the steering. It looks further back than it is as the bulkhead doesn't start where the panel goes over the top it's further back than that. |
09-12-2007, 18:54
#96 | | Regional Co-ordinator
| Ah ok, |
09-12-2007, 19:03
#97 | | MIGClub Member
| Ah ha, I didn't realise that bit was removeable plastic.  |
19-12-2007, 22:18
#98 | | MIGWeb User
Join Date: Jan 2006 Location: Derby/notts boarder Drives: vecy c20let
| Looking good matey  |
19-12-2007, 22:36
#99 | | MIGWeb User
| looking good, should be mad when done, keep it up |
19-12-2007, 22:41
#100 | | MIGWeb User
Join Date: Oct 2005 Location: ThickFord, Shrops... Drives: around looking Cool!
| Quote:
Originally Posted by Benn How come the engines so far back?
Surely if it was father forward you have more clearance on the sump and things... | Thought of all people, you would know that answer....
__________________ (='.'=)
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot! |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
