LinkBack (16) Thread Tools
Old 18-08-2007, 21:42   #26
mike-turbo's Avatar
Drives: tigra twin top
great project mate,love to do that to my astra.
mike-turbo is offline   Reply With Quote
Old 20-08-2007, 19:22   #27
Got to agree with the others and say its a great idea. Best of luck with it, and hope to see some more pictures soon.
Mr_Exe is offline   Reply With Quote
Old 20-08-2007, 20:12   #28
Drives: nothing...
nice project. was thinking of doing something like this when funds are abit better
vallanc3 is offline   Reply With Quote
Old 20-08-2007, 20:52   #29
Drives: Nova Coupe
Gonna keep an eye on this one!
chrisastleymotorsport.com - Vauxhall Parts Specialist & Projects Forum
The Simps is offline   Reply With Quote
Old 20-08-2007, 21:01   #30
tommychimp's Avatar
Drives: Astra Mk3/Mk4 Cabrio
What engine are you planning on using? I think V6 would be cool!
1.8 Mk4 Astra Cabrio rolling on 18s
1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns
tommychimp is offline   Reply With Quote
Old 20-08-2007, 21:02   #31
Drizz's Avatar
Drives: Vectra GSi & A4 1.8t
Its a LET
Old 20-08-2007, 21:09   #32
tommychimp's Avatar
ah right then, i look forward to seeing the end results
Old 20-08-2007, 21:25   #33
Drives: mk3 astra turbo
Talking
mint project goin on dude, will be keeping an eye on this as i am goin to do this to my astra but 4x4 so will be pm you soon askin for some info and that.
16vastraturbo is offline   Reply With Quote
Old 04-09-2007, 21:01   #34
Drives: R1 ,Astra V6, cav.t
any progress dude?
bowman is offline   Reply With Quote
Old 04-09-2007, 21:07   #35
Drives: Like its stolen
Originally Posted by Nemesis View Post
Does the omega rack bolt up to the vectra rack mounts? If not then how do you plan on mounting it?
Its not just the rack that is wrong, its the entire front suspension and steering setup, the arms come out of the shocks facing back instead of forward, and if you swap them side to side to reverse them then the ackerman angles are all reversed.
NONE of the vectra stuff will be of any use to him at all (or calibra or any other FWD vaux setup) if he wants it to handle properly
chip is offline   Reply With Quote
Old 04-09-2007, 21:38   #36
Drives: around looking Cool!
Was going to say that Chip......
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot!
Old 06-09-2007, 11:49   #37
Drives: Vectra B C20LET
Originally Posted by bowman View Post
any progress dude?
Waiting on my Omega box to come as it's taking it's time. also need a part of the rear suspension still but should have that sorted from one of 2 people soon.
As for the steering i'm still looking into it. the person who done the rwd cav used a vectra rack but i'm looking at taking the whole front subframe of the omega and seeing what does and doesn't fit. The only way i can see the vectra stuff fitting is by lowering it down and having the track rod ends facing up side down and then they'd be at a mad angle.
lee866 is offline   Reply With Quote
Old 07-09-2007, 00:19   #38
Drives: Vectra SRI
Lee that is a great project m8. And i hope everything goes ok
When you finish this project we can talk how much you want so you can do this to my Vectra
Good Luck m8
http://img201.imageshack.us/img201/7...csig333ji5.jpg
Vectra B running on VXR 19's
SAIMIR is offline   Reply With Quote
Old 07-09-2007, 05:33   #39
tom_spanner's Avatar
Drives: corsa b 1.6 8v carbs
track rod ends faceing upside down?? sorry mate but i think the holes in the steering arms are taperd and the taper is the wrong way up, either weld the hole up and redrill the taper, some how??? or cut the end off flip it over and weld back on, im not sure what the mot man would say about welding the steering arms tho!
tom_spanner is offline   Reply With Quote
Old 07-09-2007, 12:10   #40
can you not get ball joints that bolt through rather than have a tread attached...rose joints? then you would not need the taper......
LET the fun begin.......
Old 07-09-2007, 15:07   #41
Good Luck m8
lol i'll let you know
Until i get to doing things it's hard to know which way i can and can't do things's. cheers for the advice
[quote=bowman;3404159]can you not get ball joints that bolt through rather than have a tread attached...rose joints? then you would not need the taper......
QUOTE]
looked into that and think that was the best way so far
Old 08-09-2007, 08:41   #42
sounds like an option just need some way of stopping the bolt slopping around in the taper, but if you can convert to rear wheel drive im sure that wont be a problem, good luck mate
Old 08-09-2007, 10:41   #43
i dont know specific sizes but im sure the taper could be drilled out (it is only very slight) and a larger bolt used through it. This would also be a good fix for extra low cars, allowing the steering arms to leveled out.
Really intersted in how the rear beam mounts up. I didint realise the vectra rear floor was so similar!
nice one mate!
Old 09-09-2007, 14:23   #44
Johnny A's Avatar
Drives: Saloon of Doom MKII
Omega rack (same as carlton) will work better, however it may foul the LET inlet manifold (like mine did). It's totally different to the vectra racks so a lot of modifying will be needed. Remember you will need a steering idler on the N/S too.
Wanted - 3 door Nova, any colour/engine considered but must not be rotton
Vauxhall Carlton 2.0 16v Supercharged - Nutcase edition
Vauxhall Calibra 3.0 MV6 4x4 - How Vauxhall should have built it edition
Johnny A is offline   Reply With Quote
Old 09-09-2007, 14:43   #45
dearing5's Avatar
Drives: C20LET 5dr corsa
qaulity thread mate!
good luck with it
Roll on LET power....
dearing5 is offline   Reply With Quote
Old 13-09-2007, 20:55   #46
little update. my gearbox came today
[IMG][IMG]
mated to a block
[IMG][IMG]
picture of the subframe modded for the gearbox and started to cut the bulkhead away
[IMG][IMG]
a pic showing how the steering get's in the way so will have to look into omega stuff.
how the car looks with the axle nearly all on
Over the weekend i'll start attacking the floor and lining up the engine and box so i know how far back it'll go. i'm going to try to have it as far back and low down as possible so we'll see how it goes
Old 13-09-2007, 21:27   #47
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Funking crazy,
looks fun tho,
Old 14-09-2007, 11:37   #48
Drives: Tigra 14xe
I like this project, but the first pic for the Vectra Silver its the final or the first pic from the final project?
Pulpo is offline   Reply With Quote
Old 14-09-2007, 14:26   #49
there's 2 different silver ones at the beginging. one is is the car i use everyday. the other is this car before i started taking it apart
Old 14-09-2007, 16:38   #50
Beenie's Avatar
Drives: Audi S3
wow! how did you line up the rear axle setup? I mean the last thing you wanna do is get the rear wheels wonky lol
Beenie is offline   Reply With Quote
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/328206-project-rear-wheel-drive-vectra.html
Posted By For Type Date
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 18:58
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 18:34
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 15:56
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 07-12-2008 05:53
BLITZ-GSI.com :: Voir le sujet - vectra turbo propulsion This thread Refback 15-11-2008 13:03
BLITZ-GSI.com :: Voir le sujet - vectra turbo propulsion This thread Refback 15-11-2008 12:24
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 09-09-2008 02:29
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 09-08-2008 22:27
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 09-08-2008 08:36
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 09-08-2008 06:07
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 08-08-2008 15:02
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 08-08-2008 10:26
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 08-08-2008 09:23
oldschool.co.nz • View topic - Random Picture Thread - Mk III This thread Refback 08-08-2008 09:15
Red top vectra?? - Page 2 - CavalierCrazy.co.uk This thread Refback 21-06-2008 16:28
Red top vectra?? - Page 2 - CavalierCrazy.co.uk This thread Refback 21-06-2008 16:27
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
