Page 62 of 67 FirstFirst ... 12 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 LastLast
Results 1,526 to 1,550 of 1669
Thread: Vauxhall Corsa 2.0 XE Club
  1. #1526
    Dec 2007
    West Yorkshire
    MG ZR
    Re: Vauxhall Corsa 2.0 XE Club
    Looking great mate
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    had some issues with a stuck open throttle. Managed to figure out it was the Throttle Pot that was causing TB#4 to stay open!
    Bought one from rs components that's meant to work, but even once i'd figured out the voltages of it, the damn bolt holes wouldn't even line up. It was really getting to me so I took a road trip
    Got a new throttle pot and mounting brackets, all with the correct connector and ready to rock. Had a good half hour chat with one of the main chaps at Jenvey and learnt some good tips and tricks I didn't know about TBs lol. Can't wait to get the car working again
  4. #1528
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    would of thought they'd of had a shinyier sign lmao
  5. #1529
    Mar 2010
    Ive jus read this from start to finish, amazeing!
  6. #1530
    Mar 2005
    newport s.wales
    nova
    when is it going to run again?
    Built by Pete Burgess, Mapped by Dave Young
  7. #1531
    Jan 2005
    Malta
    Corsa 2.0, Corsa 1.7
    hi I would like to know how can I check the head valve guides in a C20xe?
  8. #1532
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Quote Originally Posted by rc View Post
    lol LOTS of shiney bits inside
    corsakid; it'll be working on Friday
  9. #1533
    Aug 2009
    bristol
    corsa b arden blue
    any chance you still know the paint code you done bumpers and arches
  10. #1534
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Quote Originally Posted by corsacraig55 View Post
    nope
  11. #1535
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Had a long day on friday;
    Got up to the car with my new TPS. Removed the old one, fitted the new one - just the same Still kept sticking.
    Threw my dummy out of the pram (hence no photos) and removed the inlet/tbs to box up and send to jenvey to setup, along with my dummy.
    but, when removed off the car; they didn't stick
    So, I stuck on the new TPS, and plugged in my laptop - got the .37v I was looking for within seconds... hmm
    Decided to give it one last chance, so fitted the inlet/tbs back onto the car. Still OK.
    Fitted the accelerator cable.... - that is the problem!!
    So I threw in the towel and left it, to return on Saturday morning with some new bits. Saturday afternoon I headed off to the scrappers and got:
    accelerator pedal and spring
    3 accelerator cables (just incase)
    I got home and removed my old accelerator pedal - to find I didn't have a spring on mine! (problem 1). Fitted the new pedal and spring.
    Removed the old accelerator cable and compared it with the new one - the old one had a huge kink in it just before the grub screw on my tbs; which is presumably why is was getting jammed.
    Abit of fettling later and I had a fully functioning set of TBs and accelerator cable that didn't stick wooh
    I let the car warm up and adjusted my WOT throttle voltage to fall inline with the new TPS and took it for a quick drive around the block. All the time I was at WOT it was fkin awesome, but at part throttle there was loads of popping and banging and misfires - I hadn't adjusted the throttle index to suit the new WOT voltage so parked it up and left it again.
    At least i know it's technically OK (sorry for the no picture update)
  12. #1536
    rc
    rc is offline
    Jan 2007
    359.9bhp astra
    good work
    3 throttle cables, just incase lmao lmao
  13. #1537
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    (I missed out the bit where I cut the first one too short )
  14. #1538
    Feb 2008
    Newcastle
    ZLET converted MK4
    good stuff. I had the same thing when I fitted my inlet manifold to my old engine with the sticky cables. It took me ages to find the problem and it turned out the cable had freyed(sp) and one of the bits of thin metal was stabbing the rubber and stopping the TB from closing up properly
  15. #1539
    A lot of hardship for a kink, hope you hit it with an axe.
  16. #1540
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    TPS now all setup, car is working fine.
    Took it for it's MOT today and it passed, woo. I did 1,978miles last year
  17. #1541
    rc
    rc is offline
    Jan 2007
    359.9bhp astra
    woo
  18. #1542
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Actually did some stuff on the car this weekend!
    Bored of the gay bright coloured wheels, so gone for a more sensible satin black;
    The other night while out playing I nearly took out a biker because I didn't see him in my gay SPA mirrors Thankfully we both ended up shaking hands and each of us going on our way, but I'm not taking that chance again. Got a pair of 'grey' mirrors from the scrappers, and put those on:
    So the car now sits like this:
    Also ordered an EPS controller from Ebay, only £35 so fitted that as well;
    Kit as it comes;
    Old wiring:
    New wiring:
    During;
    Adjustment Knob Mounted;
    Tested it, and surprisingly it worked OK first time lmao
    I also put a new fuel reg on, and noticed that my old one was at 3bar instead of the 50psi it should have been! I also still haven't been able to get my TPS setup properly so have booked in to Noble Motorsport on Tuesday afternoon to have an hour or two on the rollers to get the TPS setup properly, and give it a run through on the fuel sites to make sure everything is OK.
    Thought seeing as I'm doing that I'd best give it an oil change, and a spark plug change.
    Old plugs, bleurgh;
    JamieF is coming over tomorrow to help me change the cambelt and waterpump and then I'm good to go
  19. #1543
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    the flat lensed spa mirrors are ****, but the concave ones are better than a stock nova mirror imo
    SHoNkyOpELs.de
  20. #1544
    Dribble on Jamie for me.... Hahahaha
  21. #1545
    MIGClub Member MattJ's Avatar
    Oct 2001
    Kent
    Toyota Celica GT4
    give jamie a kiss from me dave bbbbbbbbb ffs
  22. #1546
    Sep 2002
    Ayrshire
    corsa SXi + LET
    looking good Dave, I was at Kenny's yesterday and we got my new head built up so hope to have the car running soon. Was supposed to be off this week to get it done, but my boss is stranded in Germany so I have to work
  23. #1547
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    wheels look better in black, did you have enough paint?
    Any pics as requested?
  24. #1548
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Had enough Warren, fankyou Forgot the exhaust pics though
    Jamie came over yesterday and we got the cambelt and rollers all changed. Both rollers were v v noisey so I'm happy that I laid out for the cost of the cambelt kit now, to be safe
    Annoyingly I then had an issue with the wiring where the car won't turn off, ever. Even with the key and battery cut-off removed Somewhere along the line when I've done some special wiring. After alot of dismantling and testing wires it turns out that somehow I've wired the alternator feed into my ignition live circuit, so when the key is removed, there is still c. 3v going around the ignition live circuit, meaning my ECU doesn't turn off.
    I've fitted an in-line switch to the ECU feed at the mo just to get me past the problem, but the only way to rectify it is going to be to remove all the dash board etc again *sigh*.
    Ah well, onto mapping tomorrow.
  25. #1549
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    So, tidied up my wiring, again
    Corsa is now outside work ready to go to Noble this afternoon
  26. #1550
    Apr 2007
    Bradford
    Vectra B C20LET :)
    Sorted the ignition live to the ecu problem then?
  1. 29-01-2012, 23:45
  2. 26-12-2011, 01:17
  3. 09-12-2011, 20:47
  4. 19-10-2011, 19:58
  5. 24-07-2011, 23:51
  6. 25-05-2011, 18:18
  7. 14-04-2011, 18:53
  8. 08-03-2011, 21:03
  9. 03-01-2011, 03:20
  10. 26-12-2010, 10:29
  11. 22-12-2010, 12:30
  12. 12-12-2010, 10:02
  13. 17-11-2010, 21:42
  14. 16-06-2010, 11:46
  15. 21-02-2010, 18:34
  16. 07-01-2010, 08:34
  17. 29-12-2009, 01:28
  18. 08-11-2009, 20:06
  19. 03-11-2009, 01:30
  20. 20-10-2009, 08:56
  21. 22-07-2009, 19:04
  22. 21-07-2009, 16:36
  23. 19-07-2009, 14:34
  24. 06-07-2009, 18:28
  25. 07-04-2009, 16:01
  26. 06-04-2009, 12:07
  27. 06-04-2009, 12:06
  28. 28-03-2009, 22:44
  29. 24-03-2009, 18:52
  30. 13-03-2009, 10:17
  31. 11-03-2009, 00:55
  32. 05-03-2009, 16:32
  33. 05-03-2009, 09:41
  34. 05-03-2009, 09:17
  35. 18-02-2009, 15:07
  36. 17-02-2009, 20:38
  37. 29-01-2009, 18:19
  38. 29-01-2009, 18:17
  39. 27-01-2009, 08:58
  40. 26-01-2009, 10:21
  41. 26-01-2009, 08:44
  42. 23-01-2009, 12:04
  43. 19-01-2009, 13:38
  44. 27-12-2008, 12:54
  45. 28-11-2008, 19:31
  46. 28-11-2008, 19:12
  47. 26-11-2008, 18:32
  48. 26-11-2008, 15:51
  49. 24-11-2008, 14:02
  50. 27-10-2008, 18:14
  51. 07-10-2008, 23:35
  52. 28-09-2008, 15:39
  53. 22-09-2008, 11:18
  54. 21-09-2008, 13:45
  55. 14-09-2008, 11:26
  56. 04-09-2008, 11:27
  57. 02-09-2008, 17:52
  58. 29-08-2008, 14:39
  59. 29-08-2008, 12:22
  60. 28-08-2008, 21:56
  61. 27-08-2008, 11:40
  62. 27-08-2008, 08:56
  63. 26-08-2008, 17:08
  64. 25-08-2008, 21:16
  65. 25-08-2008, 09:47
  66. 25-08-2008, 06:23
  67. 25-08-2008, 04:56
  68. 24-08-2008, 22:53
  69. 24-08-2008, 21:10
  70. 01-08-2008, 20:52
  71. 24-07-2008, 13:07
  72. 24-07-2008, 12:52
  73. 03-02-2008, 14:21
  74. 29-01-2008, 21:59
  75. 26-01-2008, 03:49
  76. 23-01-2008, 12:55
  77. 22-01-2008, 13:44
  78. 22-01-2008, 08:47
  79. 22-01-2008, 08:38
  80. 22-01-2008, 07:07
  81. 21-01-2008, 17:55
  82. 20-01-2008, 15:22
  83. 20-01-2008, 02:45
  84. 20-01-2008, 01:25
  85. 19-01-2008, 23:43
  86. 19-01-2008, 21:37
  87. 18-01-2008, 09:23
  88. 11-01-2008, 16:28
  89. 08-10-2007, 13:38
  90. 08-10-2007, 13:36
  91. 08-10-2007, 11:28
Tags for this Thread
