Page 42 of 67 FirstFirst ... 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 ... LastLast
Results 1,026 to 1,050 of 1669
Thread: Vauxhall Corsa 2.0 XE Club
  1. #1026
    Suffolk
    335d E90
    Re: Vauxhall Corsa 2.0 XE Club
    You got it ok then Dave?
    DRIZZ
    DEVELOPMENTS
    Sep 2006
    sheffield
    c20xe tigra
    very interesting read, looks like my old corsa xe
  4. #1028
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Arrived on Thursday Drizz, you'd sent it to my parents house. nevermind, got it in the end
    So, todays mission should I decide to accept it; get a Cavalier mk3 rear ARB to fit to a corsa.
    Off we go then:
    My cavalier ARB was from a 2.0 sri cavalier. You can also use(I believe) one from a v6 cavalier, which is actually thicker.
    Then, measure up the up the distance between the holes on the base of the corsa rear beam (116cm) and compare that with the total length of the ARB (120cm)
    After measuring 116cm apart on the beam, drill a hole in each end that will fit the relevant bolt size (M10).
    <This bit was an absolute twat, and unless you have a pillar drill and some very good drill bits. A normal 'hand' drill might struggle>
    After offering this up and bolting it up loosely, I moved the standard (although in this case powerflex) cavalier arb mounting bushes nerear into the middle of the beam.
    A trip to the local motorfactors for 2nr 92mm exhaust clamps. Bolt it all up, and WALAH!
    An (almost) whiteline rear ARB for a corsa, for just £13.98 (tenner for the arb, 3.98 for the two exhaust clamps!)
    First impression, in wet weather, is a BIG improvement. The rear of the car is much stiffer. VERY impressed
    for Rick who gave me the idea in the first place, and Drizz for offering me the arb
  5. #1029
    Suffolk
    335d E90
    No worries at all chap, glad it does the job!
    DRIZZ
    DEVELOPMENTS
  6. #1030
    Macclesfield
    www.Retrobike.c
    Dave you can cover my costs the next time i see you!
    Nar looks good dave, will be doing this on my corsa i think, cheap is best and tbh thats as good as a whiteline setup, just not as bling.
    Back in the scene
  7. #1031
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    Quote Originally Posted by Rick Draper View Post
    cheap is best
    lmaolmaoNot something i'd ever have imagined you could/would ever say
  8. #1032
    Jul 2008
    Greece
    Excellent. Have you used any spacers or some rubber at the end bolts?
    Very simple and efficient.
  9. #1033
    Hhhmm looks good dave, sadly cant see it fitting the nova tho.
  10. #1034
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    why not? the beam is essentially the same.
    cant beleive how well that fits looks perfect. the only problem i se is where the exhaust clamps are going to cut through the polybushes, cant you weld on some cut down cav ARB clamps to the exhaust clamps to spread the load?
  11. #1035
    No the corsa beam is alot wider than the nova beam, i found that from trying to fit the whiteline rarb.
  12. #1036
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    how much is a lot? i thought it was something silly like 5mm
  13. #1037
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Looks a neat job
  14. #1038
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Nice one fella, must admit my whiteline mad a huge difference.... make sure you tighten it all up when its on the floor though or you will mess up all your corner weighting effort.
    www.wix.com/vxlgsi/zxr-750-r
  15. #1039
    Quote Originally Posted by Gaz86 View Post
    Its only about 15mm each end, but thats 30over all. Cav one might bend a lil tho.
  16. #1040
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    I 'modified' the clamps with my grinder to make them less sharp. I can't see them cutting through the rubbers, but I'll keep an eye on it
    Quote Originally Posted by vidas View Post
    There are rubber mounts on the end of the bar, that come from the cavalier. I've just drilled through those and used that as the rubber bit that clamps to the beam.
    Quote Originally Posted by vxlgsi View Post
    It was on the metal ramps that you drive up, so technically was 'on the floor' ? No?
  17. #1041
    Feb 2003
    merseyside
    corsa
    how thick is it compared to the whiteline one?
    and do all cav's have one? std rear arb?
    You dont know me!! Even i dont know me. jekyll<>hyde
  18. #1042
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Standard vaux arb thickness; so probably 18/21mm compared to the whiteline 24mm iirc?
    Don't know what cavs they come on tbh
  19. #1043
    Apr 2007
    Bradford
    Vectra B C20LET :)
    Quote Originally Posted by DaveB View Post
    I would imagine anything none four wheel drive.
  20. #1044
    Apr 2007
    Bradford
    Vectra B C20LET :)
    EPC lists a few different rear anti roll bars for Cavaliers with no four wheel drive so I'm guessing it varried through what engine and car spec they came with.
  21. #1045
    Macclesfield
    www.Retrobike.c
    Cav SRI
    Back in the scene
  22. #1046
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Oulton Park Trackday book for 7th February 2009. So we'll see just what a difference all the last few months worth of improvements have made (if any)
  23. #1047
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    will you be doing first corner comedy off moments
    looking good northy
  24. #1048
    middlesex/london
    ACT z20let
    alrite dave, i dont need the gsi rear arb but i will give you a tenner just to take me out in it lol
  25. #1049
    Aug 2005
    Manchester
    A Slow Corsa
    what a bunch of badgers on corsa-c
    http://www.corsa-c.co.uk/forum/showthread.php?t=186287
  26. #1050
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    lmao @ so i think YOU FAIL
  1. 29-01-2012, 23:45
  2. 26-12-2011, 01:17
  3. 09-12-2011, 20:47
  4. 19-10-2011, 19:58
  5. 24-07-2011, 23:51
  6. 25-05-2011, 18:18
  7. 14-04-2011, 18:53
  8. 08-03-2011, 21:03
  9. 03-01-2011, 03:20
  10. 26-12-2010, 10:29
  11. 22-12-2010, 12:30
  12. 12-12-2010, 10:02
  13. 17-11-2010, 21:42
  14. 16-06-2010, 11:46
  15. 21-02-2010, 18:34
  16. 07-01-2010, 08:34
  17. 29-12-2009, 01:28
  18. 08-11-2009, 20:06
  19. 03-11-2009, 01:30
  20. 20-10-2009, 08:56
  21. 22-07-2009, 19:04
  22. 21-07-2009, 16:36
  23. 19-07-2009, 14:34
  24. 06-07-2009, 18:28
  25. 07-04-2009, 16:01
  26. 06-04-2009, 12:07
  27. 06-04-2009, 12:06
  28. 28-03-2009, 22:44
  29. 24-03-2009, 18:52
  30. 13-03-2009, 10:17
  31. 11-03-2009, 00:55
  32. 05-03-2009, 16:32
  33. 05-03-2009, 09:41
  34. 05-03-2009, 09:17
  35. 18-02-2009, 15:07
  36. 17-02-2009, 20:38
  37. 29-01-2009, 18:19
  38. 29-01-2009, 18:17
  39. 27-01-2009, 08:58
  40. 26-01-2009, 10:21
  41. 26-01-2009, 08:44
  42. 23-01-2009, 12:04
  43. 19-01-2009, 13:38
  44. 27-12-2008, 12:54
  45. 28-11-2008, 19:31
  46. 28-11-2008, 19:12
  47. 26-11-2008, 18:32
  48. 26-11-2008, 15:51
  49. 24-11-2008, 14:02
  50. 27-10-2008, 18:14
  51. 07-10-2008, 23:35
  52. 28-09-2008, 15:39
  53. 22-09-2008, 11:18
  54. 21-09-2008, 13:45
  55. 14-09-2008, 11:26
  56. 04-09-2008, 11:27
  57. 02-09-2008, 17:52
  58. 29-08-2008, 14:39
  59. 29-08-2008, 12:22
  60. 28-08-2008, 21:56
  61. 27-08-2008, 11:40
  62. 27-08-2008, 08:56
  63. 26-08-2008, 17:08
  64. 25-08-2008, 21:16
  65. 25-08-2008, 09:47
  66. 25-08-2008, 06:23
  67. 25-08-2008, 04:56
  68. 24-08-2008, 22:53
  69. 24-08-2008, 21:10
  70. 01-08-2008, 20:52
  71. 24-07-2008, 13:07
  72. 24-07-2008, 12:52
  73. 03-02-2008, 14:21
  74. 29-01-2008, 21:59
  75. 26-01-2008, 03:49
  76. 23-01-2008, 12:55
  77. 22-01-2008, 13:44
  78. 22-01-2008, 08:47
  79. 22-01-2008, 08:38
  80. 22-01-2008, 07:07
  81. 21-01-2008, 17:55
  82. 20-01-2008, 15:22
  83. 20-01-2008, 02:45
  84. 20-01-2008, 01:25
  85. 19-01-2008, 23:43
  86. 19-01-2008, 21:37
  87. 18-01-2008, 09:23
  88. 11-01-2008, 16:28
  89. 08-10-2007, 13:38
  90. 08-10-2007, 13:36
  91. 08-10-2007, 11:28
Tags for this Thread
