LinkBack (48) Thread Tools
Old 15-08-2008, 10:24   #701
Drives: Nova Coupe
Re: Vauxhall Corsa 2.0 XE Club
well let go of the straw then. its all weight!
ba boom tish
The Simps is offline   Reply With Quote
Old 15-08-2008, 10:27   #702
Jack's Avatar
Drives: Cavalier 1.7 TD
Get some photos up of the rear suspension!
Cavalier TD: Going strong, 160'000 miles and 169ftlbs.
Corsa 1.6 16v: New inlet manifold!
Jack is offline   Reply With Quote
Old 15-08-2008, 10:29   #703
DaveB's Avatar
Drives: Corsa XE with TBs
anything in particular?
DaveB is offline   Reply With Quote
Old 15-08-2008, 10:33   #704
Jack's Avatar
Everything, the entire setup.
I can't picture in my mind how your setup works. Just some general overview shots would be awesome.
Old 15-08-2008, 10:40   #705
DaveB's Avatar
I'll try my best. Haven't seen the car since last Monday so it might not even be where I left it now Here's hoping
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
Old 17-08-2008, 19:17   #706
DaveB's Avatar
Here are a couple of pictures of the rear spring setup when the car is sat as normal. No coilbound in sight
A few random pictures of the car:
Ghetto Security
Now, before the car went off for corner-weighting I needed to know why it felt arse-end happy under braking. I've found the problem- the rear wheels are locking up as can be seen in this picture. So that's something that needs looking at
..and just for fun
Old 17-08-2008, 19:18   #707
Jack's Avatar
Awesome.
What rear brake setup are you using?
Old 17-08-2008, 19:19   #708
DaveB's Avatar
Originally Posted by Jack View Post
Awesome.
Just standard rear drums; assume it's cos the back of the car is empty tbh. It will be rectified
Old 17-08-2008, 19:20   #709
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Originally Posted by DaveB View Post
Thats funking cool!
Cars looking good.
Old 17-08-2008, 20:58   #710
Drives: Astra G SRI 2.0 16v
my old corsa let used to do that under heavey braking. and that was with standard drums aswell. can be scary in the rain
astra16V2004 is offline   Reply With Quote
Old 18-08-2008, 11:23   #711
Drives: A Euro'd Corsa-A
Though you had a battery in the boot ?
EU-Mania - UK's Euro & Dub Styling Scene (All makes)
Aamir is offline   Reply With Quote
Old 18-08-2008, 11:42   #712
Jack's Avatar
I've got the poxy standard 1.2 drums on the back of mine. I was toying with the idea of using larger Cav drums but it doesn't look like I'll need to!
Old 18-08-2008, 11:54   #713
Drives: 78 Kadett C
Mental !! Loving the animated gif .. Jack - many peeps fit discs to the back of their novas/corsas then spend ages and lots of money on bias set-ups to get them not to lock up same with well looked after drums ! A bit silly really . The hardcore-ness of this car is awesome love it!
Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me!
djivesp is offline   Reply With Quote
Old 18-08-2008, 14:34   #714
spanishfly's Avatar
Drives: ACT Nova TBs & less
Glad the springs aren't coil bound when the car is on the ground! That was never the issue in question though! The issue was when the vehicle is under load in a corner or what not! TBH I don't really give a poo what you do to your car, it's up to you. I brought this to your attention simply for you to keep an eye on it (I did the same to Olly, and he thanked me and is keeping an eye on it). In future I won't bother you with my unrequired advice, I will wait for you to contact me again to ask a question!
South-Eastern Coordinator
My nova
www.shonkyopels.de (now working lmao)
spanishfly is offline   Reply With Quote
Old 18-08-2008, 15:00   #715
Drives: Corsa Tbo n Prelude
exactly why i never bothered with rear disks, just not required on an empty corsa
Bring back the power of LET
vxlgsi is offline   Reply With Quote
Old 18-08-2008, 19:54   #716
DaveB's Avatar
Fitted my shift lights tonight. The drill slipped when doing one of them so it's not inline with the others but hey ho. I'm not going to get hung up over that. They're so fkin bright
LEDs and resistors twisted together to check
All soldered and heat-shrunk
Fitted
On Friday night I managed to damage something while showing off at some traffic lights to a scooby owner After said incident I was only able to get 3rd 4th and 5th gear I re-alligned the linkage and it was the same; infact I had to put the gearstick in the reverse position to get 1st
So off with the linkage to find some damaged and snapped bushes. That'll be the problem then I'll get some replacements tomorrow
Seeing as I couldn't actually drive the car tonight, I decided to get the grinder out I fixed the mess I made of the front bumper and it looks loads better IMO
Decided to make the air holes in my window actually DO something and let some cool air in.
Before:
After:
As you'd expect, I carefully covered up the car to stop it getting dirty before cutting
Quite a productive evening for me
Old 18-08-2008, 19:57   #717
Drives: Corsa 1.4 Corsa 2.0T
if you fit the auto adjuster in the drums to the wrong way round ( so the fork with the step is at the rear of the shoe) then you can set the pressure of the rear brakes without the auto adjuster tightening it back up again.
bit pikie though
Gaz86 is offline   Reply With Quote
Old 18-08-2008, 19:58   #718
DaveB's Avatar
Interesting that when Chip dived on Lees custom tie-bar setup you all defended him as it being R&D etc yet when somebody else tries something you immediately shoot them down. Pot...kettle
Old 18-08-2008, 19:59   #719
DaveB's Avatar
bit pikie though
Gonna run some new lines and get a bias valve I think mate
Old 18-08-2008, 20:01   #720
Drives: 78 Kadett C
good progress there chap loving the leds
i see you've lifted the bonnet at the back - i reckon you should cut the lip that folds underneath the back of the bonnet(difficult to explain), this means you'll get more of a low pressure pull and you could lower it a bit if you fancy
Old 18-08-2008, 20:04   #721
Drives: 78 Kadett C
Old 18-08-2008, 20:05   #722
DaveB's Avatar
Not a bad idea that, only problem is the bonnet flaps about abit at speed anyway, and I think if I chopped that anymore it'll be quite flexible lol
Old 18-08-2008, 20:08   #723
Drives: 78 Kadett C
lol aah yeah, it is a major structural part thats for sure! You can always bond some solid fibreglass rods in it's place with resin, as with the lip being so obtrusive i doubt it's pulling as much air out of the bay as it could
Old 18-08-2008, 20:11   #724
spanishfly's Avatar
The thing is there was nothing wrong with my TIE BAR setup! It was my crossmember that was at fault. However I did look at the car, hence it was fixed. I'm not shooting you down at all, I'm just giving you something to look at. I've not said anything will definetly happen!
Old 18-08-2008, 20:17   #725
Benn's Avatar
Bumpers looks cool, did wonder if you messed up a lil, like the air hole in the windows too.
Tags
2007bc, blue=fast, southernersaregay, tb+1, turbo-1
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/327064-vauxhall-corsa-2-0-xe-club.html
Posted By For Type Date
Problemcar / Koude start - herfst/winter This thread Refback 27-12-2008 12:54
Problemcar / Koude start - herfst/winter This thread Refback 28-11-2008 19:31
Problemcar / Koude start - herfst/winter This thread Refback 28-11-2008 19:12
12000 оборота маслояд!!!!! - Page 5 This thread Refback 26-11-2008 18:32
12000 оборота маслояд!!!!! - Page 5 This thread Refback 26-11-2008 15:51
MIG Performance Vauxhalls - Vauxhall Forum, Owners Club, Gallery and News This thread Refback 24-11-2008 14:02
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 27-10-2008 17:14
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 07-10-2008 22:35
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 28-09-2008 14:39
Power to the Van - Page 2 - Astra Sport and Astra Owners Club Forum This thread Refback 22-09-2008 10:18
opel korsa This thread Refback 21-09-2008 12:45
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 14-09-2008 10:26
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 04-09-2008 10:27
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 02-09-2008 16:52
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 29-08-2008 13:39
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 29-08-2008 11:22
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 28-08-2008 20:56
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 27-08-2008 10:40
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 27-08-2008 07:56
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 26-08-2008 16:08
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 25-08-2008 20:16
