06-08-2008, 16:19
#676 | | MIGWeb User
Join Date: Feb 2003 Location: ruislip Drives: nova 1.8 16v on tbs
| Re: Vauxhall Corsa 2.0 XE Club only problem you might find with that setup is there isnt much room,so the spring may well end up coilbound far too easily, which isnt great
__________________ shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008 |
07-08-2008, 07:56
#677 | | MIGClub Member
Join Date: Nov 2000 Location: Huddersfield Drives: Corsa XE with TBs
| Re: Vauxhall Corsa 2.0 XE Club Lee; the springs are nowhere near becoming coilbound - the 150lb ones I had on there before weren't compressed that much; and my new springs are 300lb ones!
Old and new
Bits removed
Nipple cut off
Grinding to make something nice to weld to
Mounting bracket for new coil spring made
Mounting bracket welded in place
Pics end there because my phone is crap and doesn't have a flash on it's camera. sorry
__________________ Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk |
07-08-2008, 08:09
#678 | | Regional Co-ordinator
Join Date: Oct 2002 Location: South London/ Surrey Drives: ACT Nova TBs & less
On the left we have a spring that has huge gaps off the car between coils. The are also tapered. On the right we have a lil 4 " spring that is untapered, there is less gap between each coil now, add some weight to it the gap will become smaller, then go into a corner and hit the kerb mid corner (on track) and all of a sudden you have a coil bound spring which means you might as well put scaffold poles there instead.
I can see no matter what me or Lee say your not going to listen, but I'll like to warn you that if you were to do the above scenario the chances of the car going belly up are highly likely. I spoke to Olly about this last night, I didn't realise he run this set up. He's going to look into it now. |
07-08-2008, 08:14
#679 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club There is hardly any compression in the spring when the car is on the ground Rob; there is no way I could ever manage to get these springs coilbound; there is just not enough weight in the back of the car |
07-08-2008, 08:17
#680 | | Regional Co-ordinator
| Re: Vauxhall Corsa 2.0 XE Club Well I hope i'm wrong and you right mate! Just keep an eye on it!  |
07-08-2008, 08:19
#681 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club I will
I'm actually going to mount the new teeny tiny digital camera I've just bought to the underside of the car, and I'll video what the spring movement is like when driving. |
07-08-2008, 08:26
#682 | | MIGWeb Moderator
Join Date: May 2003 Location: Nottingham Drives: Mk3 Astra LET
| Re: Vauxhall Corsa 2.0 XE Club Quote:
Originally Posted by DaveB I will
I'm actually going to mount the new teeny tiny digital camera I've just bought to the underside of the car, and I'll video what the spring movement is like when driving. | I can see some useful application for that camera
__________________ MIG Moderator |
07-08-2008, 08:28
#683 | | MIGClub Member
Originally Posted by Orange Peel I can see some useful application for that camera  | I'm hopefully strapping it to my dogs collar tonight when he goes swimming in the local lake  |
07-08-2008, 08:42
#684 | | Regional Co-ordinator
Good idea on camera! |
07-08-2008, 09:09
#685 | | MIGWeb User
Join Date: Feb 2002 Location: West Yorks Drives: Corsa Sport 2.0 XE
| Re: Vauxhall Corsa 2.0 XE Club Looking good Binns!
What is it like to drive? Noticed any great difference? |
07-08-2008, 09:12
#686 | | MIGClub Member
Originally Posted by wazpaz Looking good Binns!
What is it like to drive? Noticed any great difference? | Nope, didn't break any speed limits on the way home; terrential rain so I didn't want to test it out  |
07-08-2008, 14:27
#687 | | MIGClub Member
Join Date: Dec 2007 Location: West Yorkshire Drives: carefully....
| Re: Vauxhall Corsa 2.0 XE Club looking good as usual,
its always raining in huddersfield
__________________ Turbo Nova |
08-08-2008, 11:52
#688 | | MIGWeb User
Join Date: Mar 2008 Location: Weston-super-mare Drives: c20xe
| Re: Vauxhall Corsa 2.0 XE Club alrite dave. cars looking good. got myu polycarbs today. got any advice on removing rear windows???? the front windows are easy. just having trouble removing back sides!! |
08-08-2008, 12:13
#689 | | MIGClub Member
Originally Posted by DaveB | |
08-08-2008, 12:55
#690 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club  top man  |
08-08-2008, 19:08
#691 | | Regional Co-ordinator
| Re: Vauxhall Corsa 2.0 XE Club Why is there the thread bar welded in to the nipple?
__________________ Quote: |
08-08-2008, 19:33
#692 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
| Re: Vauxhall Corsa 2.0 XE Club to screw the adjustable mount onto without it rattling around. |
08-08-2008, 19:41
#693 | | MIGWeb User
Join Date: Aug 2002 Location: Manchester Drives: Nova GSi 16v Turbo
Originally Posted by Benn Why is there the thread bar welded in to the nipple? | To bolt a strip of metal to to hold the spring in place when its fitted. |
08-08-2008, 20:15
#694 | | Regional Co-ordinator
| Re: Vauxhall Corsa 2.0 XE Club Ah, will the spring not be held in when the cars lowerd down? |
08-08-2008, 20:30
#695 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club There is nothing for the top of the spring to sit in though when its lowered down now so needs bolting in. |
08-08-2008, 20:48
#696 | | Regional Co-ordinator
| Re: Vauxhall Corsa 2.0 XE Club Ah so it replacces the nipples totaly, i get ya. |
11-08-2008, 08:15
#697 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club No picture update:
Did some mincing with the new rear suspension setup last night - the car was way too low as it was on it's lowest setting. So I raised it about 10mm; doesn't sound like much but made a big difference and the car sits as it should now.
There was some slight knocking with the new setup; after jacking up the rear beam of the car and removing a wheel I could see that the spring coil was catching on the FK adjuster cups - to rectify I simply slackened off the new retaining nut, and moved the spring backwards to a better angle. Retaining nut was tightened and all was good. It then started raining  I still went out for a little jaunt and the car feels massively different! a BIG improvement over the other setup. I've just to give it some proper abuse in the dry weather though, but expect a proper report when I do. (unless I hit a bump mid corner, and the spring becomes coil bound, and I rollover and die  ) |
11-08-2008, 15:58
#698 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club  @ the last comment,
rallydesign do all the components to do this conversion, i priced them up to around Ј50 for the lot which imo is very cheap i just never got round to doing it. |
12-08-2008, 08:24
#699 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club Looking good,
nice progress  with your car.
waiting for your next step.. |
15-08-2008, 09:34
#700 | | MIGClub Member
New seat ordered. I collect it tomorrow  Should save me abit more weight (and yes I really am clutching at straws now) |
