29-07-2008, 21:40
#651 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
| Re: Vauxhall Corsa 2.0 XE Club Quote:
Originally Posted by rallyman Hiya Dave, on the offside front you fitted, if you had fitted the bolt the other way round you wouldnt have needed to cut the chassis out. | and had you fitted it the other way you wouldnt be able to slide the bolt out and you wouldnt be able to move the mount out |
29-07-2008, 21:53
#652 | | MIGClub Member
Join Date: Apr 2004 Location: Chorley, Lancs. Drives: 2 fast,12 points eek
Originally Posted by GBE86 and had you fitted it the other way you wouldnt be able to slide the bolt out and you wouldnt be able to move the mount out | That doesnt matter as you bolt both parts together before fitting as Dave did in the pic in his progress pics. Also looking at the pic of it fitted looks like it is 180degrees out as the mount isnt symetrical. the side with the radiused ends should be pointing down but appears they are facing the bodyshell |
29-07-2008, 22:31
#653 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club true but i like to be able to remove the mount and leave the bodymount in place as it makes lining everything up again easier.
just checked and your right hes fitte it upside down  |
30-07-2008, 07:22
#654 | | MIGClub Member
Join Date: Nov 2000 Location: Huddersfield Drives: Corsa XE with TBs
| Re: Vauxhall Corsa 2.0 XE Club How is it upside down  Pic to explain? In my picture the mount is held up against the old one in EXACTLY the same position as it came off  There's no way I'd have got the bolts lined up if that mount had been fully tightened up before fitting on the car.
Chris; if it really matters that much; put some instructions in the box
Fitted my 2nd solid engine mount last night. My old mount was snapped!
You can't really see, but it's the bottom rubber mount that was knacked.
There are only 3 words to describe how good solid mounts are; JESUS ****ING CHRIST! They are awesome! The car feels sooo more poised, precise and stuck to the road. I actually scared myself in the car for the first time tonight  It's ****ing awesome!
__________________ Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
30-07-2008, 17:04
#655 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club  told ya, real transformation to the whole feel.
the gearbox mount just needs spinning through 180deg and possibly the other bolthole needs to be used iirc |
06-08-2008, 07:40
#656 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club |
06-08-2008, 07:50
#657 | | MIGClub Member
Originally Posted by DaveB Fitting pictures tonight, so if you haven't seen this setup before, all will become clear  |   |
06-08-2008, 12:17
#658 | | MIGWeb User
Join Date: Oct 2002 Location: Scotland Drives: Mazda RX7 FD3S
| Re: Vauxhall Corsa 2.0 XE Club Where would one get the adjustable cups and smaller springs?  |
06-08-2008, 12:20
#659 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club Adjustable cups are from my FK 'pig-tail' springs - these need turning down as they are currently 2.5" dia
Springs are from Demon Thieves |
06-08-2008, 14:44
#660 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: 16v Nova, Astra TD
| Re: Vauxhall Corsa 2.0 XE Club Nice one.
The setup certainly works well enough on Ollys car |
06-08-2008, 15:03
#661 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club Wonder where I could source some seperatly, I seen olly doing this and thought it was ALOT easier than making rear turrets up for coilovers and give some adjustment on the rear. |
06-08-2008, 15:07
#662 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club I believe you can buy them directly from FK |
06-08-2008, 15:43
#663 | | Regional Co-ordinator
Join Date: Oct 2002 Location: South London/ Surrey Drives: ACT Nova TBs & less
Originally Posted by PERALBOY Wonder where I could source some seperatly, I seen olly doing this and thought it was ALOT easier than making rear turrets up for coilovers and give some adjustment on the rear. | I know what I would prefer. |
06-08-2008, 15:44
#664 | | MIGClub Member
Originally Posted by spanishfly I know what I would prefer. | ..and what is the reasoning behind this pls?  |
06-08-2008, 15:46
#665 | | Regional Co-ordinator
| Re: Vauxhall Corsa 2.0 XE Club How many points do you want? The main one being the name FK... I haven't seen anyone running this set up, but a spring on damper will always handle bumps and load better than a remote spring. |
06-08-2008, 15:47
#666 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club The only thing 'FK' about it is the adjusting cup; which is just made from metal. lol I can't see how that bears any resemblance on the quality of the rest of it?  |
06-08-2008, 15:48
#667 | | MIGClub Member
Originally Posted by spanishfly I haven't seen anyone running this set up |
PS> Olly ran this setup at TOTB |
06-08-2008, 15:49
#668 | | Regional Co-ordinator
| Re: Vauxhall Corsa 2.0 XE Club Also how do you locate the springs? |
06-08-2008, 15:50
#669 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club Weld a mount onto the car chassis. See ollys thread on PNG pages 99-103 for more information <his posts will be far more exhaustive than mine will> |
06-08-2008, 15:50
#670 | | Regional Co-ordinator
| Re: Vauxhall Corsa 2.0 XE Club He may have done but unfortunetly I didn't get down and have a look! |
06-08-2008, 15:52
#671 | | Regional Co-ordinator
Originally Posted by DaveB Weld a mount onto the car chassis. See ollys thread on PNG pages 99-103 for more information <his posts will be far more exhaustive than mine will> | So you still have to get the welder out  So in essence it's slightly less work for not as gooda results! I can adjust my rear to sit high in the air or low to the deck. Also have the plesentry of having a coil spring wrapped round a damper  |
06-08-2008, 15:53
#672 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club I will have the same adjustment, BUT:
I'm not cutting apart the inside of the car - the welding required is nothing like cutting out and turretting the rear
I haven't paid Ј250 (ish) for a pair of rear coilovers
I don't have to worry about it catching the tyre/arch |
06-08-2008, 15:56
#673 | | Regional Co-ordinator
Originally Posted by DaveB I will have the same adjustment, BUT:
1: I'm not cutting apart the inside of the car - the welding required is nothing like cutting out and turretting the rear
2: I haven't paid Ј250 (ish) for a pair of rear coilovers
3: I don't have to worry about it catching the tyre/arch | 1: Fair enough...
2: Ј500 for rear coilovers, dam thats loads, think I paid not much more for my front and rears.
3: Nor do I, I also run 195/55R15 atm
If your happy then thats what is important! |
06-08-2008, 15:56
#674 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club Ј250 a pair I said..
I'm more than happy, and so is my wallet  |
06-08-2008, 15:57
#675 | | Regional Co-ordinator
| Re: Vauxhall Corsa 2.0 XE Club  Fair play mate! |
