24-07-2008, 21:34
#626 | | MIGClub Member
Join Date: Nov 2000 Location: Huddersfield Drives: Corsa XE with TBs
| Re: Vauxhall Corsa 2.0 XE Club Right, as spanishfly has already said. Fitting solid mounts sucks arse. I planned on doing all 3, I managed 1
Mounts all laid out and setup with bolts in place
Got the mofo up in the air(hmm, stiffy...)
Then tried to get the rear mount off, I didn't have enough room, so down it came and I went for the passenger side gearbox mount instead.
The old and new mount side by side
Mounted onto the F20 gearbox mount
Ooooh, then guess what; problems. The bolt that the F20 mount bolts onto through the mount fouls the chassis leg; so out came the grinder
All fitted and finished:
I gave up then  It took me 90mins and I didn't fancy attempting the other 2 without a 4 poster. Took the car for a quick blast to make sure it's OK, and I can already tell that there is less engine movement. Full verdict when the other 2 are fitted
__________________ Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk |
24-07-2008, 21:40
#627 | | MIGWeb User
Join Date: Oct 2001 Location: Kent Drives: Toyota Celica GT4
| Re: Vauxhall Corsa 2.0 XE Club  your such a tart dave b |
24-07-2008, 21:40
#628 | | MIGWeb User
Join Date: Feb 2002 Location: West Yorks Drives: Corsa Sport 2.0 XE
| Re: Vauxhall Corsa 2.0 XE Club I'll let you fit mine if/when i get some  |
24-07-2008, 21:41
#629 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club Quote:
Originally Posted by wazpaz I'll let you fit mine if/when i get some  | No way. I'll point and laugh at you getting stressed  This is definately a job that requires patience, cups of tea, sunshine and a steady soundtrack  It does not require the presence of friends that are able to laugh when you drop the bolt from the new mount onto your face, several times  |
24-07-2008, 21:42
#630 | | MIGWeb User
Join Date: Mar 2008 Location: Weston-super-mare Drives: c20xe
| Re: Vauxhall Corsa 2.0 XE Club oo where did u get these??? and how much. |
24-07-2008, 21:48
#631 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club search and yee shall find  |
25-07-2008, 07:54
#632 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club solid mounts sucks! is a important step.
nice progress (and even whit the little influential objects)  |
25-07-2008, 08:11
#633 | | Regional Co-ordinator
Join Date: Oct 2002 Location: South London/ Surrey Drives: ACT Nova TBs & less
| Re: Vauxhall Corsa 2.0 XE Club Glad my pre mount fitting tips helped! Told ya though! Good luck mate  |
25-07-2008, 13:00
#634 | | MIGWeb User
Originally Posted by DaveB No way. I'll point and laugh at you getting stressed  This is definately a job that requires patience, cups of tea, sunshine and a steady soundtrack  It does not require the presence of friends that are able to laugh when you drop the bolt from the new mount onto your face, several times  | Or laugh when petrol goes in your eye  |
25-07-2008, 13:06
#635 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club ...Funniest thing, ever!. |
25-07-2008, 14:36
#636 | | MIGClub Member
Join Date: Dec 2007 Location: West Yorkshire Drives: carefully....
Originally Posted by DaveB ...Funniest thing, ever!. | no its not, it stings.
have you got the other mounts done yet then?
__________________ Turbo Nova |
25-07-2008, 15:26
#637 | | MIGClub Member
Originally Posted by ad4mb1nns have you got the other mounts done yet then? |
The above post was at 10.30pm last night. I work monday-friday 8.30-5pm. What do you think? |
25-07-2008, 16:54
#638 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club sorry half asleep |
26-07-2008, 09:16
#639 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
Originally Posted by DaveB No way. I'll point and laugh at you getting stressed  This is definately a job that requires patience, cups of tea, sunshine and a steady soundtrack  It does not require the presence of friends that are able to laugh when you drop the bolt from the new mount onto your face, several times  |  i send my mates up the shop when they turn up, ill kill someone otherwise.
told you bout that bolt didnt i  mine just thumped a perfect circle into the leg so i crowbarred it a bit  |
28-07-2008, 07:50
#640 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club |
28-07-2008, 08:10
#641 | | MIGWeb User
| Re: Vauxhall Corsa 2.0 XE Club looking good, massive, large pass.
all the positive benefits. |
28-07-2008, 10:01
#642 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club looks ace.
spill a bit of oil? |
28-07-2008, 16:36
#643 | | MIGWeb User
Join Date: Mar 2004 Location: whitby Drives: single turbo rx7
| Re: Vauxhall Corsa 2.0 XE Club looks good but surely you will be loosing a bit of power now??
__________________ i miss my vauxhalls breaking down |
28-07-2008, 17:33
#644 | | MIGWeb User
Join Date: May 2004 Location: Manchester Drives: BMW E36 320 Coupe
Originally Posted by astragsi looks good but surely you will be loosing a bit of power now?? | why? the air is directed into the ports via the airbox now |
28-07-2008, 19:48
#645 | | MIGClub Member
Originally Posted by astragsi looks good but surely you will be loosing a bit of power now?? | nope, still made the exact same mph on my speed test hill  |
28-07-2008, 21:35
#646 | | MIGWeb User
Join Date: Jun 2006 Location: yorkshire Drives: nova gsi
| Re: Vauxhall Corsa 2.0 XE Club how much was your tracking/camber setup?did they adjust the castor? |
28-07-2008, 21:38
#647 | | MIGClub Member
| Re: Vauxhall Corsa 2.0 XE Club I want my whole car painted in whatever your rocker cover is.
__________________ Cavalier TD: Going strong, 160'000 miles and 169ftlbs. Corsa 1.6 16v: New inlet manifold! |
28-07-2008, 22:30
#648 | | MIGWeb User
Originally Posted by Jack I want my whole car painted in whatever your rocker cover is.  | Oil and grime? |
29-07-2008, 07:29
#649 | | MIGClub Member
Originally Posted by corsa xe how much was your tracking/camber setup?did they adjust the castor? | Haven't been to 'that' place yet; that's later on thsi month  |
29-07-2008, 19:08
#650 | | MIGClub Member
Join Date: Apr 2004 Location: Chorley, Lancs. Drives: 2 fast,12 points eek
| Re: Vauxhall Corsa 2.0 XE Club Hiya Dave, on the offside front you fitted, if you had fitted the bolt the other way round you wouldnt have needed to cut the chassis out. |
