LinkBack (48) Thread Tools
Old 23-07-2008, 16:39   #601
Drives: single turbo rx7
Re: Vauxhall Corsa 2.0 XE Club
iirc sticky plates arent illegal if there is no where to place a "normal" plate.
ive had one for ages, passed MOT, police dont bother, even been stopped and checked car and didnt even mention it.
i miss my vauxhalls breaking down
astragsi is offline   Reply With Quote
Old 23-07-2008, 17:49   #602
Drives: Corsa 1.4 Corsa 2.0T
they are in fact illegal, i looked into it its only kit cars and such like that are allowed, i curently have one on my 205 and have to put a standard one on to pass an mot they must be acrylic and the bll**** type to be legal, if we want to split hairs the square one is only legal on vans imports and bike, the corsa is none of the above.
Gaz86 is offline   Reply With Quote
Old 23-07-2008, 19:17   #603
DaveB's Avatar
Drives: Corsa XE with TBs
yeh, see my post in Mig Torque some weeks ago. You'll probably get away with it. but the car isn't really subtle, and I cba with the rozzers giving me stick for something so irrelevant
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is offline   Reply With Quote
Old 23-07-2008, 19:45   #604
wing mirrors are full of hefty chuck of plastic too
Old 23-07-2008, 19:47   #605
DaveB's Avatar
I know; I kinda use them though
Competition engine mounts fitted tomorrow. Airbox being made on Saturday
Old 23-07-2008, 20:27   #606
DaveB's Avatar
Deal done on low mileag XE bottom-end. I collect on Sunday wooh.
Old 23-07-2008, 21:10   #607
good good, i meant strip them out of unneccesary bits, loads of plastic to be lost
which mounts did you go for in the end, hope my PM helped
Old 23-07-2008, 21:35   #608
DaveB's Avatar
what bits could I remove? They're not electric or owt :s
PM helped; got Chris Astley ones. Looked at fitting them in my drive, but I can't get the car high enough to make it a nice job. GOing to a mates garage tomorrow so I can use a 4poster to get the car properly in the air
Old 23-07-2008, 21:56   #609
Drives: c20xe
Where did you get your windows from mate??? Im doin a track corsa at the mo. were they a pain to fit???
corsa 2.0 track project: http://www.migweb.co.uk/forums/proje...k-project.html
dan_adams_c20xe is offline   Reply With Quote
Old 23-07-2008, 22:25   #610
yeah a posted lift is the only way youll get the rear one on, if just jacked the engine swing will make it a pain in the arse like mine were.
i didnt realise you had manual one my sport came with all the added extras so i dont know what features are standard and whats an option, manuals are much lighter.
Old 24-07-2008, 06:29   #611
Drives: Opel Tigra 1.4 16V
Originally Posted by DaveB View Post
Small update from me. Went back over to FPE to have my oil cooler fitted;
Where exactly have you placed the cooler? at what point of the "cycle" have you connected it? to what pipes and how? do you have any pics?
Aditi is offline   Reply With Quote
Old 24-07-2008, 07:14   #612
DaveB's Avatar
www.acwmotorsportplastics.com - cheaper than anyone else. Relatively easy to fit, but I did it with self-tappers rather than using the rubbers; so it depends how perfect you want things to be
Old 24-07-2008, 07:16   #613
DaveB's Avatar
That's where the oil cooler is mounted. It's bolted to the standard vauxhall sandwich plate (if you do a search there are looads of threads about it). The pipes and fittings were obtained from hydraulic hose specialist, pirtek.
Old 24-07-2008, 07:50   #614
i think you didn't anderstand me question,
were do you fit the pipe ? before the filter/ after ?
or befor/ afrer the oil pump ?
where you conected the inlet pipe ? and where the outlet pipe coneted to the motor ?
Old 24-07-2008, 08:07   #615
DaveB's Avatar
I used the standard oil cooler sandwich plate. I don't have any pictures of it unfortunately. But, here are some others that I have found which gives you an idea. (ps. I did understand the question)
Standard Sandwich Plate
The sandwich plate can be seen BELOW and the RIGHT of this red circle
The oil filter screws on to the exposed thread on the above picture. I am unsure of which pipe is the inlet/outlet - but it doesn't really matter to me.
Old 24-07-2008, 13:16   #616
thank you very much,
i will try to " investigate" it more..
if i want to join an a oil cooler to my X14XE.
Old 24-07-2008, 15:20   #617
Drives: c20xe
Phoned him this morning, there based 10mins away from me! so i ordered the kit Ј189 which aint bad. ye he said just use rivits and some silicone to keep the water out. got to wait 2 weeks for em tho
Old 24-07-2008, 15:26   #618
daddy cav's Avatar
Drives: 1.0 12 V Corsa
Originally Posted by The Simps View Post
looks like he ran over a raver
Sticky numberplates are lighter, but illegal
Are you saying you can't double side tape a plate on now ?
daddy cav is offline   Reply With Quote
Old 24-07-2008, 15:34   #619
Drives: like its a hire car
no, he means like vinyl ones that you apply tot he bonnet like old retro rally cars. they arent legal because they are non reflective.
alistairolsen is offline   Reply With Quote
Old 24-07-2008, 15:45   #620
daddy cav's Avatar
Gotcha , like the ones on old Mini rally cars
Thought he meant all plates must be screwed incase they come of on the road .
Old 24-07-2008, 15:46   #621
DaveB's Avatar
noo noo
Old 24-07-2008, 15:47   #622
Drives: class 7 corsa;)
Ј189 is cheap if you've got the front, rears and rear boot windows.
tweeks charge something like Ј30-Ј35 each just for a slider. and polycarb isnt that cheap tbh.
good price really tbh
philip2 is offline   Reply With Quote
Old 24-07-2008, 15:50   #623
DaveB's Avatar
aye they're really good quality too. My rears cracked abit cos I self-tapped rather than rivetted them in, but hey ho. All good after I slackened the screws off abit
Old 24-07-2008, 15:55   #624
you get a bit excited???
Old 24-07-2008, 15:57   #625
DaveB's Avatar
I didn't know it'd crack
Tags
2007bc, blue=fast, southernersaregay, tb+1, turbo-1
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/327064-vauxhall-corsa-2-0-xe-club.html
Posted By For Type Date
Problemcar / Koude start - herfst/winter This thread Refback 27-12-2008 12:54
Problemcar / Koude start - herfst/winter This thread Refback 28-11-2008 19:31
Problemcar / Koude start - herfst/winter This thread Refback 28-11-2008 19:12
12000 оборота маслояд!!!!! - Page 5 This thread Refback 26-11-2008 18:32
12000 оборота маслояд!!!!! - Page 5 This thread Refback 26-11-2008 15:51
MIG Performance Vauxhalls - Vauxhall Forum, Owners Club, Gallery and News This thread Refback 24-11-2008 14:02
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 27-10-2008 17:14
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 07-10-2008 22:35
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 28-09-2008 14:39
Power to the Van - Page 2 - Astra Sport and Astra Owners Club Forum This thread Refback 22-09-2008 10:18
opel korsa This thread Refback 21-09-2008 12:45
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 14-09-2008 10:26
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 04-09-2008 10:27
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 02-09-2008 16:52
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 29-08-2008 13:39
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 29-08-2008 11:22
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 28-08-2008 20:56
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 27-08-2008 10:40
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 27-08-2008 07:56
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 26-08-2008 16:08
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 25-08-2008 20:16
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 25-08-2008 08:47
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 25-08-2008 05:23
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 25-08-2008 03:56
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 24-08-2008 21:53
GSi KLUB POLSKA :: Zobacz temat - ITB do c20ne This thread Refback 24-08-2008 20:10
opel korsa This thread Refback 01-08-2008 19:52
