yes!!
yes!!
Turbo Nova
**** !! easy weight saving to be made there then!
78 Kadett C 2.0 8v turbo
Did you ever get a power run done?
Got a power run done; made 159.1bhp with slightly above average torque. The torque curve was huge, and kept going alot more than it should (due to the cams I assume). I'll be truly honest; I was hoping for 165-170; but as the car is running no superchip/unichip to bring the ignition forward to help the cams it's probably not performing aswell as it could be with the setup
Regardless, I'm bored of it already. So I'm very actively looking for some jenvey throttle bodies with aftermarket management. I miss the noise they gaveRegretting selling the astra?? maybeee..
are racing line really accurate?
Turbo Nova
Well I'd certainly hope they don't over-read lmao
lmao
im gunna take mine there but worried about the outcome..
Turbo Nova
What's to be worried about? DONT go chasing numbers; just go to make sure your engine is performing to the best of its ability.
am not i just worried that its going to be less than 200![]()
Turbo Nova
Dont stop with the car then, and don't ask for the figure.
ok
p.s sorry for hijacking your thread![]()
Turbo Nova
saweet
BIG update coming from me hopefully by the weekend/during the week. My savings account has just been spanked, and the corsa has got some pressies coming![]()
oooo..
what you bought now...
im guessing tb's maybe??
did you get them tb's and management from here somewhere then?
and those seats i you were interested in?
Turbo Nova
i know, i know *jumps about*![]()
what?![]()
Turbo Nova
Well, over the past couple of days I've had the ECU light coming on - "Co Potentiometer - Voltage High". I know this is most likely to be the airflow meter, but I did what any self-respecting XE owner would do to cure the fault once and for all; throw away all the motronic **** and get MBE with some Throttle Bodies
The kit I went for was the SBD TP208 kitIt arrived earlier in the week (Massive thanks to JamieF
) and I started fitting it yesterday evening.
The Start
The Middle
Bit Removed:
Bodies Built Up
Fitted to the Car
Aeroquip Fittings were an un expected bonus
That's where I got up to last night, will have it finished by the end of Saturday
Oh, I also got an SBD TypeC Hi-Torque manifold too![]()
about time you did this dave! aint half going to shift now!
looking good matey, glad you sorted some TB's out now though...you going to be at PV in the car???
Yip, will be on the www.autovaux.com stand and spending a good deal of time on the strip too![]()
ooh that should shift, how much weight you saved between the 2 setups? gotta be at least 2 kilo lmao
I was thinking that myself last nightI reckon it might be more like 5-6kilo - the standard inlet is really heavy, then also all the wiring loom, ECU etc
