06-08-2007, 22:23
#1 | | MIGClub Member
Join Date: Aug 2007 Location: hampshire Drives: corsa b 1.6 8v carbs
| omega/corsa hybrid, drift machine or death trap? ive been thinking wud it be possible to cut front an rear ends off an omega an a corsa b an make a 2.5/3.0l v6 rear wheel drive corsa using the omega drive train and suspension,electrics an floor pan, while still retaining a corsa like shape, all be it a very wide version?? ive seen a croation guy do similar with a calibra 4x4 and a black tigra. would it be any good at drifting or drag strips?? any 1 wi previous experience wanna comment? i understand the legal implications of a "cut an shut" but hey it wud b fun round a track, cant promise ill build it but im a mechanic whos off work for 2 mth soon.......... who knows wat i mite get up to!!!!! |
07-08-2007, 09:03
#2 | | MIGWeb User
Join Date: Nov 2002 Location: Sunny Ipswich Drives: like a girl
| Would think the wheel base would be a little short and snanchy for drifting, V6 Omegas drift well with the right bits sorted.
__________________ On most other forums you would now be looking at a picture of my 2.1 Zetec powered Series 1 RS Turbo. |
07-08-2007, 16:18
#3 | | MIGClub Member
| cheers 4 the reply wat bits need sorting mate?? lsd an lowerd? with a stripped interior? |
07-08-2007, 16:55
#4 | | MIGWeb User
Join Date: Jan 2007 Location: West Midlands Drives: c20let corsa
| you need a screw driver, a piece of wood and a hammer...jobs a good one! |
08-08-2007, 03:12
#5 | | MIGClub Member
| Quote:
Originally Posted by mark106mark you need a screw driver, a piece of wood and a hammer...jobs a good one! | ok i admit defeat, i dont ave a clue wat the job is???
or was that a piss take????
im a mechanic, experienced at nut an bolt mods but i dont think ill find this in a haynes manual will i???? |
08-08-2007, 19:32
#6 | | MIGWeb User
Join Date: May 2003 Location: durham Drives: R1 ,Astra V6, cav.t
| use a cav v6 donor and build a rear engined corsa, similar to the skoda build thats on here.
__________________ LET the fun begin....... |
08-08-2007, 19:39
#7 | | Banned
Join Date: Sep 2004 Location: MIG's dungeon :-( Drives: MSG blessed Calibra
| Just buy a 200sx |
08-08-2007, 19:42
#8 | | Regional Co-ordinator
| *robot benn with arms waving "warning tom spanner warning"* Quote:
Originally Posted by Nemesis Just buy a 200sx | be easyest and best...gonna be a silvia for metho...
__________________ Quote: |
09-08-2007, 00:03
#9 | | MIGClub Member
| cheers 4 ur input guys, im really interested in seeing if i can do it, if i was after a drift car ive got a tuned omega coming to me for free but i wanna see if i cud do the conversion, ive not seen it done before, maybe theres a reason for that!!!! so was after something abit different.
my mate who wud help runs a garage so it cud be good advitiseing for him, well till its wrapped on a greasy roundabout!!!!! |
09-08-2007, 16:13
#10 | | MIGWeb User
| theres been a white rwd nova on here before. used cosworth rear suspension i think. |
09-08-2007, 17:25
#11 | | Regional Co-ordinator
| Austin did it with his nova,
xe running the rear wheels..
havent got a clue on the rear beam/diff set up them,
guess it woyld be cav/cally. |
09-08-2007, 21:03
#12 | | MIGClub Member
| cheers bowman, benn, and the others. ill have a dig around to find them threads if i can. ill keep u posted if i do go for it. i got a track car to build first an this project wil b next |
09-08-2007, 21:08
#13 | | MIGWeb User
Join Date: Oct 2005 Location: london Drives: steve!'s bwm :D
| Quote:
guess it woyld be cav/cally. | its an escort rear beam i think, although i could be wrong........................as usual
__________________ i sendz warningz...i haz uber phailz
volvo - the ultimate battle between rev counter and fuel gauge |
09-08-2007, 22:37
#14 | | MIGWeb User
| Quote:
Originally Posted by tom_spanner cheers 4 the reply wat bits need sorting mate?? lsd an lowerd? with a stripped interior? | My mate had an ex-police MV6, it had coilovers, camber ajusters, custom exhaust, Lsd and ran full road trim and it love to go sideways! |
09-08-2007, 22:44
#15 | | MIGWeb User
Join Date: Jun 2006 Location: Suffolk/Staffs Drives: 78 Kadett C
| tbh it would be easyer to put the engine in the back, driving the rear wheels imo.
overall you'll have less weight (no prop/txb), and grip would be immense over the rear wheels. Suppose not really suitable for a drift car tho  .
Hey you'll still be drifting just have to go faster
__________________ Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me! |
10-08-2007, 08:39
#16 | | MIGClub Member
| cheers for the replys guys, ive seen the skoda/caviler rear engined set up on here an to be honest i think id rather change the floor pans an suspension over an go front engine rear wheel drive, that way all the suspension is in line properly, provided i weld the new floor in square!!! |
10-08-2007, 09:33
#17 | | MIGWeb User
| Quote:
Originally Posted by tom_spanner cheers for the replys guys, ive seen the skoda/caviler rear engined set up on here an to be honest i think id rather change the floor pans an suspension over an go front engine rear wheel drive, that way all the suspension is in line properly, provided i weld the new floor in square!!! | you will most likely need to change the rear suspension anyway depending on what rear beam you use, so either way its a bitch of a conversion  |
10-08-2007, 11:33
#18 | | MIGClub Member
| Quote:
Originally Posted by Grim Reaper you will most likely need to change the rear suspension anyway depending on what rear beam you use, so either way its a bitch of a conversion  | i was gonna cut both floor pans out and match the shortened omega one up to the sills/chassis on the corsa as best i can. that way i shud have all the rite suspension mounts an manage to run std omega suspension set up front and rear. this wud also give me the larger transmission tunnel, gear selector mounts etc etc etc. it will be really wide under a corsa but ill just have to wide arch it, possibly by cutting out the omega wings an welding them on as they r the rite shape for the wheel size, hmmm wud 18s still fit???
i think i need to get the two cars together an take pics an measurements  |
10-08-2007, 11:54
#19 | | MIGWeb Moderator
Join Date: May 2003 Location: northampton Drives: GTE 3lt V6 TwinTurbo
| Take the shell off the corsa and put to one side...take the shell off the omega and put to other side, shorten the chasie on the omega mid section, fabricate a new floor for the short base omega, cut floor from corsa and place shell over new omega floor and weld (might be wise to fit rollcage in before hand for a snug fit). tweek corsa shell to fit wings and wheels. |
10-08-2007, 12:11
#20 | | MIGClub Member
| cheers jamie i think u got the same idea as me,have u done one similar b4? was gonna do the bulkhead aswell so i got the whole front end minus wings bumper an bonnet (size depending) inc engine, front suspension, inner wings, bulkhead the floor pan between the sills an the boot floor/rear suspension mounts off the omega. this wud give steering column an rack electrics full transmission etc from the omega wi a shorter lighter shell. yeah was gonna do the cage aswell, its gonna be fiddley as a standard one wont fit wi the new floor but still worth doin. |
10-08-2007, 12:31
#21 | | MIGWeb User
Join Date: May 2007 Location: High Wycombe Drives: 2007 Honda Civic
| if you are going to do all that work, what about a full spaceframe chassis? then just drop the corsa shell onto it?! might be a little more work and welding, but i would image you would end up with a slightly better car! |
10-08-2007, 12:32
#22 | | MIGWeb Moderator
| Its the same type of thing im doing with the astra but the whole cage/chasie/bulkhead/floor ect is built from scratch. and then the astra shell is lowered on to it. |
10-08-2007, 12:36
#23 | | MIGWeb User
| do what has been done for years..... make a street legal hotrod Corsa Hotrod |
10-08-2007, 12:37
#24 | | MIGClub Member
| i was being blonde, ive just had a quick look at ur project, ill read it all 2nite, thats kinda wat i got planned but more of the omega chassis, makes the steering & engine mounts etc easier, good luck mate,i cant start mine for bout 2 mth so i can watch ur progress an pick up some ideas until then. |
10-08-2007, 12:43
#25 | | MIGClub Member
| i wish i was good enuf and had the time to make the space frame an floor from scratch, an i cant afford to pay for it either. ill hold my hands up now, its gonna be rough an ready, not overly polished or shiney, the v6 wil be standard, lets face it the omega can shift an i shud loose a few kilos at least. this is more about making it work in my 2 mth off work than making it shiney.
cheers for the link lewis |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
