Old 05-08-2007, 16:35   #1
Drives: astra gte 16v
turbo mk2 astra gte
had a busy few weeks so i thought it was time to put a thread up about my project
had the bay welded and sprayed which i did with a friend
the interier has been stripped of everything i could, carpets insulation and seats ,so the car should be alot lighter. we managed to source a dolly that was only about 4 inchs high put a piece of work surface on it and were ready to go.
i sourced a lowish milage c20let replaced the belt and flywheel alternator as the late spec has a massive pulley on and won't fit in the bay.
put my f28 on it and the brackets i had made up.
it has also had a new cross member and slam panel
we put the engine in after work . It took us a bit longer as had to have a play with the alloy engine mounts as they had one bolt in and the standard ones had two and were a smaller size
we jacked the car up leaving the suspention attached .but took the ball joint of the end of the wishbone removed the wheels
by this time it was 1 am and the curtain twitchers were on high alert
front bumper and intercooler on but was a very tight fit as the intercooler was from a renault van
i had to move the rad over to the center of the intercooler pipes but as i had dropped the engine down on the new mounts, i had to have a play to get the pipe to fit
back on the ground
mot time
here is the list after i had done all that i could thought i would stick it in for a mot and this is the list i got.
check out the brake efficiency
astrayorkie is offline   Reply With Quote
Old 05-08-2007, 16:55   #2
Drives: single turbo rx7
so how long did it take you to fit and what time did you finish?? all nighter??
that is some list mate
i miss my vauxhalls breaking down
astragsi is offline   Reply With Quote
Old 07-08-2007, 17:59   #3
we finished about two in the morn which was a bit to much as we were both shot to pieces by that time.
rear beam has been sourced and making a good one out of the two will put some more pics up at a later date.
Old 16-08-2007, 18:43   #4
As i was doing the rear brakes i thought i would do all the jobs i was planning on doing. so to get the rear bushes out i purchased a blow torch(flame)
Basically i set fire to the bushes and pushed it out with a screwdriver and a hammer.
after getting the bushes out there is a liner on the inside and the poly bushes don't fit (as we had tryed )
We started by bending over the liners.
and wacked it with a 3 lbs hammer and a cold chisel
bushes on
here is the finished artical with all the poly bushes on and koni adjustables ,brakes and new brake lines.
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
