Old 16-07-2007, 22:01   #1
Drives: Calibra V6 / Corsa D
Smile RWD CALLY
Right then
RWD CALLY Project.
back end will be pretty easy to do, we want to mount the Motor the other way so........
What steering rack can we use on it??? Calibra rack is going to be in the way so that's a no go.
any ideas.
So far we are looking at E30 rack and front setup(only because its from a RWD car really) Manta ??? prob not,Carlton to Big??
Really want to do this Project so any ideas welcome.
Yeah that's free mate, Oh Plus the VAT....
materey is offline   Reply With Quote
Old 16-07-2007, 22:04   #2
Drives: 118d,G1.8SE2,C1.2SXi
Have a look on astraownersclub.com, pete has managed to squeeze an LS1 V8 and gearbox in the front of his coupe, which has the same track and wheelbase as a cally.
Selling - PC and lots of meg's cleaning stuff, random z18(xe / xer) and z16(xe / xep) parts.
MarkyG is offline   Reply With Quote
Old 16-07-2007, 23:07   #3
Drives: NovaXE CorsaXE 325i
http://www.migweb.co.uk/forums/proje...-remember.html
Have a squint at that.
DaveC_ is offline   Reply With Quote
Old 16-07-2007, 23:42   #4
Drives: Fear into children
What gearbox you planning on using?
Transmission tunnel evaluation?
Rear axle and diff assembly?
Am i talking toss?
Ginge
A man goes into a library and asks for a book on suicide.
The librarian says, "**** off, you won't bring it back."
Ginge is offline   Reply With Quote
Old 17-07-2007, 01:14   #5
Banned
Drives: MSG blessed Calibra
Same as Ginge!
What rear diff are you using? I'm wondering what ratios work with different boxes?
Nemesis is offline   Reply With Quote
Old 17-07-2007, 08:19   #6
Drives: 2007 Honda Civic
what about the steering rack of another vaux rwd car, like carlton/senator? would it be possible to fit that type of rack in?
lewist123 is offline   Reply With Quote
Old 17-07-2007, 08:22   #7
Drives: Like its stolen
Nothing is going to be a very direct fit.
Rear end wise you dont really need to change anything if its just a cheapy project.
Sierra front subframe lends itself well to putting in other things as its so self contained, and obviously because of what a legend the cossies are, the number of performance bits available in terms of suspension components is massive.
chip is offline   Reply With Quote
Old 17-07-2007, 12:23   #8
Thumbs up
Cheers DaveC
had a look at the link, thats a really nice conversion.
so after reading the posts Guy am going off to research Diffs and front subframes etc.
Cheers for the replies any more pointers will be accepted with mucho gratitude.
Cheers
Matthew
Old 17-07-2007, 17:02   #9
EY
EY's Avatar
Drives: to get more petrol.
Thread subscribed to, should be interesting. Lots of people have looked into it, not many (if any) have actually done it in the Calibra, it's a huge ammount of work to make it work and at the end you'll still be left with a car that i think wont lend itself well to RWD.
Best of luck mate.
1993 Calibra turbo. Spare engine in the dining room.
EY is offline   Reply With Quote
Old 11-09-2007, 14:00   #10
Thumbs up umm
Best of luck mate.
Having done LOTS of research this thing is going to cost thousands to do right, i would have to be done right as we want to track it.
Idea not happening me thinks.
SORRY
Old 11-09-2007, 14:14   #11
Makes FAR more sense to just chuck a LET in an E30 bmw!
Looks cooler, has great geometry as standard, is almost certainly lighter than a calibra, and the gearbox on them is superb.
Old 11-09-2007, 18:03   #12
Drives: Girlfriend crazy
BTR Preparations built around 10 RWD Cally's for competition use. They retained the standard subframe, but removed the rear cross piece and put something at the front instead. They then used a 4x4 Sierra rack. 2.5 turns lock to lock and ps standard.
Why is it going to cost thousands to do right? Most of the vehicle is ready for it. BTR based the front end around Carlton suspension and the Calibra bottom arms. The rest of it was surprisingly standard. Yes weight is a problem. The Rally cars had composite bonnet and hatch and were stripped out, but the Cally has huge amounts of weight in places that you're going to ditch anyway. Use a Saab turbo engine from the newer GM cars. Easily tuned to 350 hp and bolts on to an Omega gearbox.
16vmanta is offline   Reply With Quote
Old 11-09-2007, 19:48   #13
mmmmm
Now that's a bloody good answer, cheers. Food for thought, have you ever seen one ? know of any or competitions they were in?
Old 11-09-2007, 20:58   #14
Gavin Cox ran the prototype and did quite well. It was a V6 3.0 so wouldn't have been too slow. He had previously run a 4x4 Calibra Turbo in the British Rally Championship. There's a lad just south of Birmingham has a self built one that rallies a few times a year. He sometimes appears on one of the Calibra forums and there are pictures of the car in one of the threads. The comments I've heard were very good considering what it is, i.e. not an Escort. Yes the BMW is a better package out of the box, particularly for the cost, and the BMW RWD challenge shows this. The Calibra is different and will get extra exposure because of this. I'm sure a Calibra coming out a junction sides way would make you look.
Old 12-09-2007, 11:05   #15
Thumbs up
Damm right It would, Big smiles.
I will have to go hunting for some pics.
Cheers mate
Old 12-09-2007, 11:12   #16
Interesting, ive not seen or heard of these.
Given that the sierra rack is mounted in front of the engine though, and the calibra steering arms go BACKWARDS, I think you may have missed some important parts of what was done!
Old 12-09-2007, 11:56   #17
They used Carlton front legs, not Calibra. They might have swapped sides too so that the steering arms were at the front. The steering arms were twisted slightly too, to improve the angles for the rose joints that they used instead of track rod ends.
Old 12-09-2007, 12:27   #18
That "twisting" is the key thing, as it effects the accamen (sp?) angles
All FAR less simple than you made it sound with your original post TBH
Making a car RWD is easy, making it RWD with the correct geometry so that its a GOOD rwd car is an entirely different story!
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
