LinkBack (2) Thread Tools
Old 16-07-2007, 09:10   2 links from elsewhere to this Post. Click to view. #1
Drives: Corsa LET
my white corsa gsi turbo
well have done a wip post on here so ill have to fill you in
some may have seen it before but ill start from the begining
well first off i got the car. started off as the mrs's car,
1993 1.6 gsi in white, the best colour, with only 48k on the clock and was in very good condition for its ages. well after having it for a few months the it spat a rod and sat in the garage looking very sorry for itself
engine was taken out and the car was forgotten
at the time i had my other gsi 2.0 on throttle bodies
was a good car but i got just got board of it and so i decided i wanted a turbo. tb's were stripped off and sold and put back to a standard 2.0. i then did a swap with the mrs for the white gsi as ive always loved white and she loved my car so we did a swap and i got a bit of cash too
soon after this i started to look for an engine and i soon found one near me off breeny off here out of his nova. was said to have a full bottom end rebuild 12k ago,more on that later, the head was off but all gasket and parts came with it and it was a good price so i got it.
so i get to work building the engine
head was stripped and check valves all ground in etc
after trying to fit the head before and being given the wrong bolts and stripping 2 treads in the block, i ordered a stud and nut kit after helicoiling the block.
head was put on and a few parts tarted up
car looked like this at that time
good clean and a bit of paint
welded in a strengthening kit just to be safe
engine was soon ready to go in
with a little help from my mate it was soon in was still waiting for a gearbox so engine was but in first, seems wrong but it was easier for me to do
that will do for now will at soom more up in a bit
tomgsi is offline   Reply With Quote
Old 16-07-2007, 09:34   #2
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
How come the suspension turrets are Grey? White GSi's are the best colour IMO.
V8 blender FTW
Old 16-07-2007, 09:34   #3
Drives: Corsa LET
lol that was primer
Old 16-07-2007, 14:14   #4
Drives: class 7 corsa;)
looking good so far, whats spec of the motor? standard or .....?
philip2 is offline   Reply With Quote
Old 16-07-2007, 14:24   #5
Banned
Drives: MSG blessed Calibra
White GSi's rule, they really are one of the best looking hot hatches IMO. I hope you don't find the LET a dissapointment like I did, best of luck to you
Nemesis is offline   Reply With Quote
Old 16-07-2007, 19:40   #6
Drives: corsa C,2.0 corsa b
I've just finished my corsa valver and already want a turbo!
Looking good!
dodge_one is offline   Reply With Quote
Old 16-07-2007, 19:42   #7
Benn's Avatar
Drives: A shineeeey Nova
Please say your putting a cam belt over on that...
looks very nice dude!
love the green gsi too.
Old 16-07-2007, 21:40   #8
Gagged
Drives: 96 Calibra V6
tom, i deliver post to your house sometimes mate, spotted the car a few times in progress, quality
my mrs bought parkers old 306.
He gets everywhere
calibrav624v is offline   Reply With Quote
Old 17-07-2007, 11:39   #9
Drives: Corsa LET
here is a bit more
after fitting the engine i decided i didnt like the colour of the rocker cover so painted and spare set white. also my intercooler arrived to so got that fitted. was an ebay uitem but is very good for what i paided for it. also got a few boost hoses fitted
then fitted my freshly painted front bumper. the intercooler is covered up a fair bit tho but i didnt want to spoil the shape of it by hacking it out. plus i wanted a sleeper
then the moment came to start it up. struck up first time but was only running on 3, check for spark and compression all were good so swapped about the injectors and found one to be fooked. got a new set and soon got it running sweet
after that i started to build the rest of the car back up, 288mm groved disks, pad, calipers were ordered from lmf, brained hoses, crappy g-max suspension was refitted untill i could afford coilovers.
was un happy with the rear hight wanted it lower
anyhow first time to more the car under its own steem and the gearbox was stuck in reverse
so stipped it down and had a look see
couldnt really find anything so put it back together and all was good, for now anyway
ran fine for a while so did a little modding to the rear springs lowered it a bit more.
soon after the gearbox got stuck again so got a nother box and was fine after that
first car show out was mod nats. car was running sweet
soon after that got a photo shoot with redline/total vauxhall
had a day at bruntingthorpe testing a corsa vxr and seeing how it compaired to my car
pics will be in next months redline
was having a good day had a play with rentons timing equipment even tho it was the wettest day ever. did a quarter in 15.3 in the wet with a lot of wheel spin, also did a top speed run off 143 in 1.7 mile, came back all was fine, went to go move it and it was tapping its knackers off to me it sounded bottom end and so had to be trailered home i was gutted but oh well
got it back home and stipped the bottom end down.
shells were a bit worn but not too bad , check crank all was ok, decided to fit some new shells anyway, got a set of heavy duty ones for 15 quid off a mate, bargain
got it all built back up struck it up and was fine, so i called it a night. next day went to go run it up and it was tapping again now at this point i was pissed off and nearly just put it on ebay. but in the end i took the engine out again
sat there engineless for a few weeks again.
will update again tomorrow
Old 17-07-2007, 20:44   #10
what wheels are those ?
neo1 is offline   Reply With Quote
Old 17-07-2007, 21:10   #11
Benn's Avatar
looks great dude!
Old 17-07-2007, 21:38   #12
Gagged
as its an L reg 93? Do you get problems with the b pillar cracking?
btw its a proper sleeper, till you spot that little IC in the front
Old 17-07-2007, 21:43   #13
Drizz's Avatar
Drives: Vectra GSi & A4 1.8t
Does it handle?
Old 17-07-2007, 21:48   #14
ANDYRACER's Avatar
Drives: Jap Crap wit Booost!
Cesaros.
Looks a proper little sleeper.
Rememeber Pop Up Headlights are the Future!
ANDYRACER is offline   Reply With Quote
Old 17-07-2007, 22:28   #15
Drives: Corsa LET
thanks for the comments
yeh b pillar have cracked as always
and it didnt handle at all on the g-max crap but now i must say its one of the best handleing cars ive had, will update with what its running on suspension wise soon.
Old 17-07-2007, 22:38   #16
Drives: calibra 8 valve
Nice fookin build mate,really got that corsa lookin as hard as nails,quality job,,,wish i could do this maself instead of building houses,,
calibra! it rocks my boat,,,,,
caliscotia is offline   Reply With Quote
Old 03-03-2008, 19:23   #17
Drives: Corsa LET
right forgot i ever started this thread, im board at the minute so i thought id better update it a bit
well after ****ing the engine at brunters i took it out and stripped it down again.
after first thinking the bigends had gone i took the head off and found that the tapping was only the headgasket, part of the sealing ring was sat on top of the piston and that had been hitting the head causing the tapping. any hoo had nother better to do so stripped the block down and got it acid dipped then put it all back to gether with new bearings uprated main bolts, arps rod bolts ect
gave the block a bit of a paint. had never seen a white block before so id thought why not
new genuine gaskets used etc and was gradually built back up
few more bits were painted to tart things up a bit
then took a week off work to get the engine back in and couldnt of asked for better weather
engine on the floor read to go in
was a right coont pushing it under the car on my own but got there in the end
all bolted up
then started to pipe it all back up
and all done
new lights were fitted as well then a quick visit to my mates work for a dyno
made 204bhp at the wheels at 12psi boost, was running on phase 3 chips but with a crappy actuator
new acutator fitted and made a lot of difference
then started to paint my wheels
got some cavs slabs to put on for the time being
Old 03-03-2008, 19:48   #18
Drizz's Avatar
Cool!
Old 03-03-2008, 20:08   #19
DaveB's Avatar
Drives: Corsa XE with TBs
what sorta power is it running with the new actuator, should be happily the best side of 260bhp now?
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is offline   Reply With Quote
Old 03-03-2008, 20:08   #20
Drives: 2.0 CorsaB <- Snaped
done nice job there pal
Novafied is offline   Reply With Quote
Old 03-03-2008, 20:19   #21
car looks very clean mate, well done, what did you use to paint the cesaro's white? drippy cans or gun? btw any chance of getting a new camera without a smudge on the lense? lol!
elitedriver is offline   Reply With Quote
Old 03-03-2008, 20:24   #22
Drives: Corsa LET
right bit more
got a few bits for my bday like hoses so got round to fitting them
turbo off
quick blast off high temp paint to improve things a bit
hoses the fitted
the refitted back on the car
well that all lasted about a week then the head went porous
so back to bits it was
one fooked head
wasnt too bacd tho as i had a spare head so just swapped a few bits over
block give a quick clean
and head back on
by this time had a few wheels done so tried them on to see what they looked like and i loved them
well finally got round to fitting the f28 i had, the clutch on the f20 had having fun trying to hold the power too
stripped the box down to fit the f20 speedo ring
quick paint to clean things up a bit
new helix sport clutch at a very very good price
decided to fit the box at work as it was a lot easier
easy
new clutch all bolted up
and new box on
and back on the floor
had a few issues with 2nd gear but got it all sorted in the end.
now it was time for more power
turned up the fuel pressure
from
to
then found out on a quick road test that my pump couldnt hold the pressure
so ordered a walbro pump and got that fitted and it runs very well.
just waiting to get back on the dyno
well thats about as it stands at the minute so heres a few pics of what it looks like when its clean or not in bits
Old 03-03-2008, 21:04   #23
Drives: Without Due Care
bloody hell you've been busy. im loving it tho!!!
where do you find all that energy?, i've been stripping down a single head for nearly a month now lol!
doge5644 is offline   Reply With Quote
Old 04-03-2008, 07:28   #24
looking well, what are you hoping for figure wise???
nice to see people qouting WHP not FWHP.
dodge...sort it out, i had an xe, i stripped, fully rebuilt bottom end, and stripped/rebuilt head in 2 days
Old 04-03-2008, 13:48   #25
Drizz's Avatar
How does it handle. My old LET corsa was toss!
DRIZZ
DEVELOPMENTS
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/324489-my-white-corsa-gsi-turbo.html
Posted By For Type Date
אוטו ספורט : צפייה בנושא - פרויקט טורבו עתידי על פיאט טיפו/אונו This thread Refback 24-07-2008 13:14
אוטו ספורט : צפייה בנושא - פרויקט טורבו עתידי על פיאט טיפו/אונו This thread Refback 24-07-2008 11:35
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
