12-07-2007, 18:13
#1 | | MIGWeb User
Join Date: Apr 2005 Location: London Drives: Calibra 3.0 V6
| Opel Manta V8
12-07-2007, 19:27
#2 | | MIGWeb User
Join Date: Sep 2005 Location: durham Drives: astra g 1.6 3door
| best bit is that GM desinged that motor lol. |
12-07-2007, 19:37
#3 | | MIGWeb User
Join Date: Jan 2005 Location: hertford Drives: v6 veccy+legnum vr-4
| was buick a gm company then??? |
12-07-2007, 19:42
#4 | | MIGWeb User
| I belive so, but Opel is german? |
12-07-2007, 19:42
#5 | | MIGWeb User
| just checked and your right has always been a gm company !! |
12-07-2007, 19:47
#6 | | MIGWeb User
| It's is an old Buick 215".
160bhp and 201lbs. Think I will go with a Newman Cam though. |
12-07-2007, 19:49
#7 | | MIGWeb User
| Just need one of these to put it in.  |
12-07-2007, 20:14
#8 | | MIGWeb User
Join Date: Dec 2005 Location: Solihull, W.Midlands Drives: 118d,G1.8SE2,C1.2SXi
| any reason you didnt spend your £50 on a newer rover v8?
__________________ Selling - PC and lots of meg's cleaning stuff, random z18(xe / xer) and z16(xe / xep) parts. |
12-07-2007, 21:03
#9 | | MIGWeb User
| It's all that I found, it will be being re-built so don't think it really matters. |
15-07-2007, 22:59
#10 | | MIGWeb User
Join Date: Jan 2001 Location: Glasgow Drives: saab turbo
| pegasus or thor block would be nicer. 4 bolt cross bolted mains caps. and upto 5.2 litres from the box with the scope to go bigger if you speak nicelty to wildcat.
but try to find some of the rare twin turbo conversion kits. used to be mde but janspeed i think. cops had them then ditched them as it was a bit too much for them. i.e scared the pants off them
__________________ curiosity killed the cat...................but for a while i was a suspect!! |
15-07-2007, 23:11
#11 | | MIGWeb User
| jeah the also did janspeed turbo v8 rangerovers!!! |
16-07-2007, 20:37
#12 | | MIGWeb User
Join Date: Dec 2001 Location: Chelmsford, Essex, Drives: 3.0 V6, 2.5 V6, 1.8
| Saw one at Billing.
Must be cold in winter without a heater box.
__________________ [url=http://77.96.230.10/sytemsandsoftwaredevelopment/systems.htm] How Tos
The two most life changing experiences you'll ever have. Finding Jesus, and having a baby. |
16-07-2007, 20:45
#13 | | MIGWeb Moderator
Join Date: May 2003 Location: northampton Drives: GTE 3lt V6 TwinTurbo
| That is the same engine im sticking in the calbra for drag strip...the power from them is huge. Did you get the gearbox with it as its a bit of a bitch finding them. also if you are going to strip the carbs down (should be SU type) have a look inside the chambers for cast fatigue, the carbs are strong and easy to maintain but i have found a few with bad cracks or marble affects. Also if you need gaskets look on ebay, i was surprised on how cheap they are. |
16-07-2007, 20:47
#14 | | MIGWeb Moderator
| Quote:
Originally Posted by phunky monkey jeah the also did janspeed turbo v8 rangerovers!!! | was this the draw-through system...carb was set in front of the turbo inlet? |
16-07-2007, 20:49
#15 | | MIGClub Member
Join Date: May 2004 Location: Stafford/Chesterfiel Drives: Shonky Focus C-Max
| Arent manual gearboxes a sod to come by with these?
__________________ If I like it, I lick it. If I dont, I kick it NEED DECENT PART WORN TYRES? CONTACT ME FOR A COMPETITIVE PRICE |
16-07-2007, 20:51
#16 | | MIGClub Member
| Quote:
Originally Posted by jamied was this the draw-through system...carb was set in front of the turbo inlet? | No, the later ones had fuel injection. |
16-07-2007, 20:57
#17 | | MIGWeb Moderator
| Quote:
Originally Posted by BlackIce Arent manual gearboxes a sod to come by with these? | yep...it took me 2-3 months to find one, got a manual 4 speed with strengthen gear rods (ex police). I had to keep on looking on ebay and some of the rover/mg clubs. |
16-07-2007, 21:01
#18 | | MIGClub Member
| Why not just use a range rover box and adapt it to 2wd..? |
16-07-2007, 21:03
#19 | | MIGWeb Moderator
| Quote:
Originally Posted by Jack Why not just use a range rover box and adapt it to 2wd..? | you could but you find that the bell houses are different on them...had two in the unit next door to mine and the shape was totally different. |
16-07-2007, 21:06
#20 | | MIGWeb User
| boxes are easy sherpa van springs to mind so does jag. LT77 (ok) or R380 (better) would work fine and bolt on. see land rover mags as well. T5 as well but more expensive
if your going drag racing i'd ditch the rover and go chevy. so much easier to screw power out of.
i.e getting 250bhp from a rover is possible just starts to get expensive. do foa chevy and for the same money you'd get a hell of a lot more than 250 bhp. down side is chevy weighs abit more but is a physically smaller block. although the rover can be made shorter by changing the water pump and pulleys from other v8 rovers. look to p5, p6,sd1 and various landies.
the turbo rangies use the same basic engine as the sd1. only difference is one is tuned for bhp and the other for torque.
go to rimmer bros for the std rebuild stuff as they know what you want. and the do some tuning stuff. real steel too. |
16-07-2007, 21:52
#21 | | MIGClub Member
| Quote:
Originally Posted by jamied you could but you find that the bell houses are different on them...had two in the unit next door to mine and the shape was totally different. | Yeah, V8 bellhousings fit on V8s, and the rest don't.
Different bellhousings for V8s and TDIs, IIRC. |
17-07-2007, 00:16
#22 | | MIGWeb User
Join Date: Nov 2005 Location: Dundee, Scotland Drives: Skoda Fabia vRS
| Quote:
Originally Posted by Ghost_Walker LT77 (ok) or R380 (better) would work fine and bolt on |
R380 is an awful box, BTW
Dont-rush-me-or-ill-start-crunching gearchange... |
17-07-2007, 07:46
#23 | | MIGClub Member
| Quote:
Originally Posted by Disco_Mikey R380 is an awful box, BTW
Dont-rush-me-or-ill-start-crunching gearchange... | That's because it's a land rover gearbox.  Take your time, we'll get there when we get there, enjoy the scenery...etc |
17-07-2007, 10:58
#24 | | MIGWeb User
| yes true but it's a physically stronger than an LT77 and easier to find than a good T5 for sensible money |
17-07-2007, 11:25
#25 | | MIGWeb User
Join Date: Mar 2005 Location: Upt'north Drives: Mini Cooper
| Quote:
Originally Posted by Ghost_Walker yes true but it's a physically stronger than an LT77 and easier to find than a good T5 for sensible money | T5's arent that expensive, how much have you been quoted?
__________________ Two chavs, Dave and Bob race their Novas over a cliff to see who hits the bottom first...who wins? Society. |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
