LinkBack (3) Thread Tools
Old 07-07-2007, 11:19   #1
donvaux's Avatar
Drives: Corsa GSI c20let WIP
Talking **C20LET Corsa GSI WIP**
hiya guys and gals i've just started getting a load of bits together to convert my c20xe corsa to a c20let corsa i know this convertion has been covered loads of times but i thought well i didn't do a project thread when i converted my corsa to a c20xe because of the big rush i was in i thought i have to do one this time heres a few pics of my parts so far pics were taken on my mobile sorry ain't the best
and here's what all this will be going in
If in doubt give it a klout
donvaux is offline   Reply With Quote
Old 07-07-2007, 11:23   #2
donvaux's Avatar
today i've been cleaning the gearbox heres how it looked
and now
Old 07-07-2007, 13:41   #3
donvaux's Avatar
i should soon be receiving steel rods off rallyman and then the block will be sent to my local engine builders. what sort of power are the standard pistons able to take does anyone know just that i'm looking at making a very solid engine that will run around 300bhp maybe a bit more cheers
Old 07-07-2007, 15:16   #4
Drives: 78 Kadett C
keep 'em coming buddy i'll be doing this myself at some point, it will be handy for many people
i've heard 350 mark for pistons/rods is the limit in the Let. I think its probably more down to how dialled your ignition timing and fuelling is, if it's knocking like hell as it is, then it wont see anywhere near 350 before the pistons fall apart.
What are you going to use for management ?? Let ECU or programmable ??
to make reliable power, check all the clearances (piston to bore, crank end float, etc) - they're in haynes i think, renew shells and make sure you have good oil pressure and a good cooler if you're planning to give it pain.
Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me!
djivesp is online now   Reply With Quote
Old 07-07-2007, 15:27   #5
Drives: Vectra B C20LET
std piston's can take 500bhp but have to be in good condition not tired worn one's.
lee866 is offline   Reply With Quote
Old 07-07-2007, 15:56   #6
Drives: Cav Tbo Evo5 on 18's
standard pistons can take 400bhp
as for rods its better to be safe and use uprated ones i.e. scoobys ones especially for the price u can get em at the mo
Adam is offline   Reply With Quote
Old 07-07-2007, 16:05   #7
donvaux's Avatar
i'll be using standard management to start with i might progress to standalone but dunno yet
Old 07-07-2007, 16:24   #8
Drives: 2L 16V Turbo 1995
On of my friends is running a 20LET Corsa with standard rods/pistons with a T4 turbo. 400Hp @ 1.8bar and 12.1 @200km/h 1/4mile on semi slicks. I you get the fuel/timing wrong at this power level, you will loose the motor in a few secs. I would have a good look at the managements system options before proceeding.
Opel 2l 16V T3/T4 Turbo & NOS
Opel T Car T3/T4
moua is offline   Reply With Quote
Old 07-07-2007, 16:59   #9
Drives: 78 Kadett C
sheeet, 1.8 bar !! low compression pistons i'd assume ?!
If youre gonna use standard management with a rising rate FPR then a wideband is essential so you can always monitor the mixture and make sure it's not going lean. Also i'd suggest looking into det-cans - i've seen some funky diy set-ups, the knock sensor is a mic so you could theoretically hook it up to your stereo and listen for knock, but i think motronic would probably sort itself out ??
chip is the man i think he's turboed a c20xe.
Im tempted to go water injection and standard compression - honda style they push out massive bhp with piddy engines !!
Old 07-07-2007, 20:47   #10
Yes/No Mahle with the tops machined. Run 102.6 leaded racing fuel mixed with tolune and Water/Methanol water injection 51/49 mix. (not aquamist) Boosted 2.2 bar on the dyno. Strangely the car is his wife's everyday drive !!! He is busy building his drag car.
I would recommend the use of a wideband. If you intend using it on the road, you will need fine tuning as the dyno is not always that representive of road conditions.
The motronic knock sensing will not work properly if you change cams and it is only used up to a certain RPM (If I remember correctly 5500 RPM) Knock sensors is sensitive for certain frequency band but the when is important and that get changed with different cams.
If you are going to use water injection as a way to achieve high boost,...remember it becomes a single point of failure.(Make sure the pump....pumps at the right pressure and the water bottle is full etc etc.
Old 07-07-2007, 22:35   #11
Administrator
Andy_L's Avatar
Drives: Cavalier 1.8
Any how many half naked chaps can you get in the back of a Corsa gen??
Gonna be a monster when done!
Andy_L is offline   Reply With Quote
Old 08-07-2007, 15:00   #12
donvaux's Avatar
lol
Old 09-07-2007, 07:37   #13
Drives: Astra GSi 1992
its gonna be a beast keep us updated. if i had spare money, i wouldnt mind making a sleeper corsa let.
*Jen* is offline   Reply With Quote
Old 11-07-2007, 06:39   #14
slash's Avatar
Drives: Corsa GSI, Astra GTE
check out cjgwillz on ebay he's got ecu for sale which may be of use to you.(slash snr)
slash is offline   Reply With Quote
Old 11-07-2007, 14:50   #15
donvaux's Avatar
already got a phase 2 chipped ecu bud but thanks for looking
Old 11-07-2007, 15:00   #16
Drives: 350+bhp Nova Turbo
thats my mates old engine and my old box!
good luck with getting it all fitted
is that wills old charge cooler as well?
corsakid is offline   Reply With Quote
Old 11-07-2007, 15:06   #17
donvaux's Avatar
yep it is lol you got the red corsa ain't you?
Old 11-07-2007, 15:10   #18
yes mate i added you to msn jus now
Old 11-07-2007, 15:22   #19
donvaux's Avatar
ok mate so hows the corsa
Old 11-07-2007, 15:41   #20
corsa is good, jus getting a few go faster bits, a new head, verniers, a few other bits hopefully see it over 300bhp next weekend
Old 11-07-2007, 16:31   #21
donvaux's Avatar
nice
Old 17-07-2007, 16:41   #22
donvaux's Avatar
little update some presents have arrived
recon turbo
steel rods off rallyman cheers chris
when i get paid i'll be building up the bottom end hopefully
Old 17-07-2007, 16:50   #23
dont forget to give autovaux a tinkle for a set of cav 1.7td oil squirters only £4.79 each plus the ole vat...u'll have under piston cooling then
Old 17-07-2007, 16:53   #24
donvaux's Avatar
i was thinking of that i'll ask the bloke who done slashs engine to see if he can do it i don't feel confident to do them
Old 17-07-2007, 16:54   #25
piece of pshh to do...well my mechanic said so lol sozzz he's doing mine u seen the step by step on vaux forum aye?..chips account.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/323353-c20let-corsa-gsi.html
Posted By For Type Date
VauxSport - Vauxhall advice and chat forum :: View topic - no compression problem - c20let This thread Refback 08-06-2008 17:03
VauxSport - Vauxhall advice and chat forum :: View topic - no compression problem - c20let This thread Refback 05-06-2008 21:19
VauxSport - Vauxhall advice and chat forum :: View topic - no compression problem - c20let This thread Refback 05-06-2008 16:44
Members: 43,209
Threads: 310,605
Top Poster: LEE69 (43,149)
Welcome to our newest member, nova mad
