Old 03-07-2007, 14:29   #1
mind_crash's Avatar
Drives: Project 200TS soon
New 200TS Replica Project thread
Due to a change of base car I felt I needed to start a new thread.....
work wont start for a couple of months due to some funding issues and a holiday or two coming up
but here are pictures of the new base car wich I collect on the 21st of july
she is an 98 180iE Auto (C18SEL with AF20?) being an E she has full electrics package so all 4 windows mirrors ect along with aircon.she was imported in late 2005 so is rust free!!!
I plan on taking my time with this project and clearing out more space in my garage and to get plenty of pics up this time!!!
So to start off I will list the planned specs for the car...........
Early 20XE basic rebuild, fully painted with some things polished keeping the early open thermo stat as my car has one now going to be keeping the aircon aswell......
I have an F18wr with F20 Diff in mind but have been toying with the idea of an F28 as the 5th gear ratio is the same on teh F18wr as it is on the F28 so I dont want to hear this nonse about it never getting into 6th as my old astra had an SEH and an F18wr.....
Also got a late calibra turbo front setup with 288's in the garage....so think I will get that all stripped and cleaned along with the veccy GSI rear hubs and brakes I have too
then got some cally turbo rims (all 5) with some 205/50 rubber on them.....then all I will need is a bit of a drop really..............
anyway gonna use this thread to keep track of the clean up and engine rebuild and gonna make it nice and picture heavy this time not like the last thread!!!!
I was the stig
My new 180iE
mind_crash is offline   Reply With Quote
Old 03-07-2007, 14:59   #2
Drives: GSIT.... Allegedly!
Where do you all find these saloons!?!?!?! Looks like a good project and in white too, smart colour.
"If your not breaking parts, your not making enough power!"
Dave GSiT is offline   Reply With Quote
Old 03-07-2007, 15:05   #3
Drizz's Avatar
Drives: Vectra GSi & A4 1.8t
Nice one chap. Shame about the Auto but can be sorted. Yet another SA to the big collection...
DRIZZ
DEVELOPMENTS
Old 03-07-2007, 15:09   #4
Drives: Like its stolen
To be a 200TS replica surely it needs a LET not an XE?
chip is offline   Reply With Quote
Old 03-07-2007, 15:21   #5
mind_crash's Avatar
yes.......but I dont have one at the mo.......so it wil be a limp replica :P
Old 03-07-2007, 15:22   #6
mind_crash's Avatar
took me over 2 years to track one down..............partly becuase drizz snaps teh things all up!!!
Old 03-07-2007, 15:23   #7
mind_crash's Avatar
indeed..........
when I get back from france we need a photo shoot....
Old 03-07-2007, 15:40   #8
ah, fair enough
Old 03-07-2007, 16:06   #9
Drives: Corsa Tbo n Prelude
love these cars, great find.... must have turbo rims
Bring back the power of LET
vxlgsi is offline   Reply With Quote
Old 03-07-2007, 19:29   #10
Drives: Cavalier 2lt dippy
sounds a cool project
dave's.cavy is offline   Reply With Quote
Old 03-07-2007, 20:52   #11
Drizz's Avatar
Well you know, im an enthusiast
Old 04-07-2007, 09:08   #12
mind_crash's Avatar
your practically an opel dealer lol
Old 30-08-2007, 15:55   #13
mind_crash's Avatar
ok bit of an update....I have been away and on a different planet these last couple of months....but update so far is as follows....
pics to foloow when i get my digicam repaired
radio in and cabling for ice installed...
late caibra front turbo legs with 288's fitted to front (308's will go on at some stage)
cat installed as it failed MOT...evne though it appears to never have had one fors to 2 other MOTs in the uk..........
rear vectra V6 hubs.....................not fitting..........seems like bolt holes line up but the large hole on the rear beam of the astra seems a few mm to small and wont fit (maybe because my car is non-ABS?) this is a bit of a set back.....I may have to find about a different rear beam or getting that made a bit bigger somehow....
got a replacement fog light and a gsi splitter waiting to go on when the car is returned......
but anyone got any ideas on why on earth my veccy hubs on the rear dont seems to fit
Old 30-08-2007, 16:01   #14
Drizz's Avatar
Yep if your car is non-abs then the rear beam needs to be an ABS one. Also have you modified the vectra hubs? as the handbrake cable fittings will be wrong too. Upside down i think. You have to modify them
Old 30-08-2007, 19:35   #15
the Early mk3 Cavs have this problem too, the ways around it is
another abs beam or grind the holes out with a die grinder/reamer thing
the backing plates require swapping sides and the holes redrilling for the linkage thing inside to be correct if i can remember right
Old 30-08-2007, 20:23   #16
Drives: 3.0 V6, 2.5 V6, 1.8
MK4 Astra 5 stud non ABS hubs could be used on your beam, instead of the Vectra hub.
[url=http://77.96.230.10/sytemsandsoftwaredevelopment/systems.htm] How Tos
The two most life changing experiences you'll ever have. Finding Jesus, and having a baby.
Mark T is offline   Reply With Quote
Old 30-08-2007, 23:14   #17
Drizz's Avatar
Hmmm interesting. No redrilling for handbrake required?
Old 31-08-2007, 10:01   #18
mind_crash's Avatar
interesting......more info required!.......
could I then use the rest of the vecra setup I have.......as i have new discs and pads and all sorts.....
i'll have to take a look as I have no idea if the hand brake cable comes in from the top.......
this would be much easier than fitting a mk3 ABS beam!
Old 31-08-2007, 10:07   #19
mind_crash's Avatar
any idea how much bigger I need to make it.......is it a case of getting a grinding stone on my drill and attacking it.......
I think I am liking the mk4 hub idea.......
Old 31-08-2007, 10:16   #20
Drives: 200TS REP.VEC GSi
Not alot in it mate,i had this problem changing the hubs on my 200i.
In the end i just changed the beam and fitted a gsi one as its a pretty easy job.
That's bloody brilliant that is!
gwillzy is offline   Reply With Quote
Old 31-08-2007, 11:14   #21
mind_crash's Avatar
think i'll just go for the rear beam then.....how easy are they to change?? and beams are there beams that will fit from other astras............I know there is (or atleast was) an astra estate with ABS in my local srappy...
Old 31-08-2007, 13:38   #22
Drizz's Avatar
Yeah only bolt on with 4 bolts. Two on the car and two on the shocks. Then brake lines etc
Old 31-08-2007, 14:15   #23
mind_crash's Avatar
ok cool beans.........depending on how brave I feel this weekend i'll see if i can get it sorted..........
had a look under the car and the exhuast is a complete mess.........looks like it's made out of homebase tube or something....so replacing that as we speak.......gonna be an expensive day...
Old 31-08-2007, 14:28   #24
Drizz's Avatar
Rear beams are easy. Ive changed sooooo many now.
Funny my 180i exhaust is like that. Botched bad!
Old 31-08-2007, 14:29   #25
Drives: Opel Astra 180iE
Good to here of the progress mate, make sure you get those photos up!
....and make sure you all remind me of this when i start talking about 5 studding mine!!!
Kev 180iE is offline   Reply With Quote
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
