14-06-2007, 22:27
#1 | | MIGWeb User
Join Date: May 2002 Location: Croatia Drives: Opel Kadett LET
| Opel Kadett E 1.6i ,now C20LET inside After my cav almoust broke in half on dyno (mega-rusty bucket  ) it had btw 361whp and 525Nm  I went to find rust free opel (imposible you say...well,NO  )
bougt myself stock kadett E 91.y. ,1.6i,94K km on the clock, lets go edition (it's one with Bayern Munchen stickers on it...there's no that model in UK of course,it would be set on fire by manU or reds fans :P :P
now I mad a swap everything from that rusty vectra A into kadett
its C20LET
forged pistons CR 8:1
steel conrods
ARP bolts all around
XE block,cranckshaft
XE inlet cam
KKK 29/26 hybrid
downpipe with separation of wastegate and turbine gases
80mm exhaust (and backbox has 80mm perfored pipe)
70mm intake pipes with 70mm tophat
intercooler 760x300x100
630cc siemens injectors
F28 box
sachs sport clutch set
Bailey BOV
EDS phase 4
etc
brakes ate power 288mm front,back- stock GSI
koni sport set (springs,shocks-adjustable)
borbet typ T 16"
etc etc
what was at the begining (vectra) http://www.youtube.com/watch?v=Dqnz_Jp6qHo
later with rebuilt engine http://www.youtube.com/watch?v=rYzUvFNIVX8
now LET is in the kadett (dont have pics when I was doing the swap,but,let's say that it took me one month to dismantle kadett , stich weld it along with 4x4mm tubes in front,paint it in black(not by me  ),than put LET,brakes,GSI optics,seats,instruments etc...  |
15-06-2007, 11:04
#2 | | MIGWeb User
Join Date: Mar 2001 Location: KENT Drives: Astra T + Veccy Esta
| Where did you get the 70mm top hat? can you get more of them? |
15-06-2007, 11:51
#3 | | MIGWeb User
Join Date: Oct 2001 Location: Bedfordshire Drives: Cavalier SRi
| quality work mate! loving that rebuild video as well
__________________ The cake is a lie :( |
15-06-2007, 16:23
#4 | | MIGClub Member
Join Date: Apr 2002 Location: High Wycombe Looks@: Drives: The White Wonder
| cool stuff  |
10-07-2007, 20:27
#5 | | MIGWeb User
Join Date: Aug 2006 Location: sunny swad, derby Drives: mk3 astra turbo
| if you watch the video mate you will see its a custom job. |
10-07-2007, 23:43
#6 | | MIGWeb User
| Quote:
Originally Posted by seanr28 Where did you get the 70mm top hat? can you get more of them? | it's a custom job...
just get 70mm 90deg alu pipe,than cut the stock tophat,than make 70mm opening with biax tool than weld it together...it can cost you max 20 euros
just neet to cut and weld that conector for the pipe wich goes into idle valve |
11-07-2007, 10:28
#7 | | MIGWeb User
| Quote:
just neet to cut and weld that conector for the pipe wich goes into idle valve | Did you recevied any answer for vectra digital tacho how to reset it  ?
dennis18 |
16-05-2008, 20:03
#8 | | MIGWeb User
| Re: Opel Kadett E 1.6i ,now C20LET inside |
16-05-2008, 20:06
#9 | | MIGWeb User
24-07-2008, 13:56
#10 | | MIGWeb User
24-07-2008, 14:00
#11 | | MIGWeb User
24-07-2008, 14:05
#12 | | MIGWeb User
24-07-2008, 16:35
#13 | | MIGClub Member
Join Date: Aug 2007 Location: brighton Drives: C20LET 5dr corsa
| Re: Opel Kadett E 1.6i ,now C20LET inside ha nice mate!
keeping an eye on this thread  wish i had the money to buy lots of new bits
good luck to you fella
__________________ Roll on LET power.... |
24-07-2008, 18:39
#14 | | MIGWeb User
Join Date: Aug 2003 Location: penrith, cumbria Drives: nova gsi c20let
| Re: Opel Kadett E 1.6i ,now C20LET inside why did you use this ?  |
24-07-2008, 18:47
#15 | | MIGWeb User
Join Date: Mar 2002 Location: suffolk Drives: Corsa Tbo n Prelude
| Re: Opel Kadett E 1.6i ,now C20LET inside awsome car, but you shouldnt heat wrap a turbo manifold
__________________ Bring back the power of LET |
24-07-2008, 22:13
#16 | | MIGWeb User
| Re: Opel Kadett E 1.6i ,now C20LET inside 2stevebarker: its a flange for strengthening the block ... its done on wrc engines and have use when crank is producing 700+ Nm of torque (than lower side of the block is trying to "strech" ) ...
U need longer bolts (12.9 index strenght) and modify that oil tube wich goes into oil pump
2vxlgsi: after some thinking,I wraped that manifold,screamer pipe and downpipe with TermoTec heat insulator to lower the temp inside engine bay and to keep as much as possible heat energy from the engine wich is spining the turbine wheel  |
24-07-2008, 22:45
#17 | | Administrator
Join Date: Jul 2004 Location: Southampton Drives: GTE 16v/Vectra CDX
| Re: Opel Kadett E 1.6i ,now C20LET inside Awesome project, I will be keeping an eye on this!
Keep up the good work and post more pictures! |
24-07-2008, 23:21
#18 | | MIGWeb User
Join Date: Jun 2003 Location: Thatcham,Berkshire Drives: Fear into children
| Re: Opel Kadett E 1.6i ,now C20LET inside Another top thread with some home brew machining coming into to play!
Loving the thread so far, keep up the good work!
Ginge
__________________ A man goes into a library and asks for a book on suicide.
The librarian says, "**** off, you won't bring it back." |
25-07-2008, 09:13
#19 | | MIGWeb User
| Re: Opel Kadett E 1.6i ,now C20LET inside correct me if i'm wrong.
you broaden your cylinder space ??>
and now you inserting a much biger pistons ?
A 86.5mm !
if i understand it properly, then what was your original pistons size ?
and one more thing,
until how much hp the Garrett T3 holding on ?
and the Bosch 044 fuel pump ? how much psi he runs ?
25-07-2008, 10:38
#20 | | MIGWeb User
| Re: Opel Kadett E 1.6i ,now C20LET inside yes...block is bored 86.5mm than honed...pistons are 86.5mm
stock block is 86mm
turbo is Garrett T3/T4 wich is
T3 turbine A/R 0.63 stage 3 and
T4S 60-1 compressor is A/R 0.7
it produces enough CFM for 550-600 HP
bosch 044 pump is aprox 300 liter/hour and holds 7-8 bar pressure...and its louder than engine on idle  |
25-07-2008, 10:57
#21 | | MIGWeb User
| Re: Opel Kadett E 1.6i ,now C20LET inside good work, got to love a high spec let in the makeing. |
28-07-2008, 08:17
#22 | | MIGWeb User
Join Date: Mar 2002 Location: Reading, Berkshire Drives: Omega & 1.8 Corsa B
| Re: Opel Kadett E 1.6i ,now C20LET inside Quote:
Originally Posted by stevebarker why did you use this ?  | Have a look inside a late X20XEV block, they are girdled as standard  |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
