My Astra Sport - GSi Turbo rebuild.
Page 26 of 27 FirstFirst ... 16 17 18 19 20 21 22 23 24 25 26 27 LastLast
Results 626 to 650 of 657
Thread: My Astra Sport - GSi Turbo rebuild.
  1. #626
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    Re: My Astra Sport - GSi Turbo rebuild.
    tastey
    Dec 2009
    blythbrugh, suffolk
    ast3gsi,ast2tub,astra van
    Very nice!!! Indeed, dewis is certainly the man for the inlets, hes in the process of making mine now! Keep up the good work.
  4. #628
    Mar 2001
    KENT
    Astra T + Vectra Est
    Quote Originally Posted by c20letTim View Post
    Yes his welding is very good, cant wait to get it running!
    XBOX 360 repairs, modification, JTAG and Rest Glitch Hack (RGH) installation and sales
  5. #629
    Mar 2001
    KENT
    got my thorttle body back, after being bored out a bit with new shaft, butterfly etc, now 68mm, was originally 64mm
    some new petrol tank straps and TB gaskets
    PLastic rivits for arch linners etc
    Inlet now part built up
    Now using an RX7/8 inlet temp sensor as it reads much faster than the standard vauxhall one!
  6. #630
    Mar 2001
    KENT
    Another trial fit with fuel lines and rest of pipework
  7. #631
    MIGClub Member DrewyCoupe's Avatar
    Jan 2011
    Chesterfield
    Astra Coupe Turbo
    nice car mate defo some good work
  8. #632
    rc
    rc is offline
    Jan 2007
    359.9bhp astra
    inlet looks the tits
  9. #633
    Mar 2001
    KENT
    a few more bits today, finally got all the bits to remove ABS unit, -3AN fittings etc
  10. #634
    Mar 2001
    KENT
    Been a while once again, but a small update
    Managed to get another carello (Genuine GM headlamp for passenger side) as the one I had was manual adjust and driverside was electric. Anyway got it fitted and it looks different!
    Finally got my Tial Bov mounted! Used Durafix to weld it on!
    And finally changed the driver side wishbone for Genuine GM one, as the ones I was using were not GM ones and the cars geometry was always out by some!
    Passenger side to do next! and get it running...........again.
  11. #635
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    that durafix stuff rocks! must get some more for the garage, bet you cant wait to get it running
    SHoNkyOpELs.de
  12. #636
    Mar 2001
    KENT
    It does, but its not easy trying to get something like that done well, as being alloy it all heats up and then areas you get perfect then get too hot and run! Did take a while TBH.
    Yes its been over a year now since the the rebuild and spec is much higher, should be good for around 450bhp ish.
  13. #637
    Mar 2001
    KENT
    Once again, its been a while, thats what happens when you have 2 kids!
    Anyway, finihsed fitting the Genunine lower wishbones and new drop links.
    Removed ABS unit, as I sick of the bloody thing giving me problems.....
    Also fitted a brand new Master Cylinder and started to modify pipe work for use without ABS unit.
    Its not yet finished, just mocking up at the minute....
  14. #638
    Mar 2001
    KENT
    Rear caliper were shot, so that have been completly stripped, cleaned and fully re-built using new seals throughout and then treated to some proper caliper paint
    All usuable old rusty parts were left in white vinagar over night and gave some good results.....
  15. #639
    Mar 2001
    KENT
    A bit more progress, brakes done, just need to be filed with fluid and checked for leaks and then fixed into position around the bulk head! hopefully there will bo none.
    Rears completed, fully rebuilt.
    Inlet finally fitted, along with injectors, fuel lines etc and part of the engine loom
    Bracket made for Sard FPR
  16. #640
    Macclesfield
    www.Retrobike.c
    Looks good but does the throttle operate ok?
    Back in the scene
  17. #641
    Mar 2001
    KENT
    It would appear to be ok yes...
  18. #642
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    Looking good Sean some nice progress there! Glad I could help you out with your blonde moment yesterday
  19. #643
    Aug 2004
    glasgow
    astra 4x4 C20LET TURBO, v
    Great work mate, Does the throttle cable bracket not have to be moved for the angle of the throttle body.
  20. #644
    Mar 2001
    KENT
    Finally got my removable slam panel finished....well almost!
    Throttle cable is fine, moves nice and freely!
  21. #645
    Aug 2004
    peterborough
    mk3 astra
    has this car been finished?
  22. #646
    Mar 2001
    KENT
    Not yet, dont get the time these days!
    Have a week off work soon, so will hopefully get finshed very soonn, else its being broken!
  23. #647
    Mar 2001
    KENT
    More progress
    Car now almost fully back together..
    MSD Coil now mock up mounted! Another bracket to be made out of Alloy or stainless at some point.
    Engine loom tidy...err.....
    Modification to the front ended was needed
    Front end complete
  24. #648
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    That looks lovely great work!
  25. #649
    Aug 2004
    peterborough
    mk3 astra
    good to see some more progress being made
    what top mounts (suspension) are you using??
    cheers mike
  26. #650
    Mar 2001
    KENT
    Quote Originally Posted by mikeastra View Post
    cheers mike
    Top mounts, good question you should find the answer somewhere in this thread. Was so long ago now I really cant remember where i got them from, they are solid though....may have been Compbrake.
