Would have thought you'd take the oppurtunity to go a bit more with the power benn, match the looks etc.
Lapping the valves and stem seals whilst the engine is out would be well worth it Benn.
The seals were the cause of my oil use before I did them on my new head.
Up to you of course.
Almost missed this thread mate! Might have to come down and get involved with some top mincing!
Simps.
Benn without wanting to sound sensible, if you're having the lump out anyway would it not make sense to fit it up with a set of carb's as planned (40's will work if you have them jetted properly, just won't make as much power as on 45's...) and do the small bit of wiring needed nice and tidy as it all goes back in...
I vote silver for box and bottom end, hand polish the outside of the head as much as you can - use a dremel etc to set it super smoothWould look sweeeeeeeeeeeet.
I think AL is talking some sense there. Stick the 40s on so everything is in place then it will be an easy swap to 45s surely?
And oh, don't be so cheeky! Respect your elders
Simps.
Update.............................
engine wise,
sorted out sump gaskets and seals and bits,
cluch in the garage waiting,flywheel off getting lightened and bal,
Gear box all painted up in a nice bright silver...
was gonna polish it..but after looking at all the small bits i thought no..i wouldnt have the time,and the boys at the polishers said it would be hard getting in the small bits, so silver with polished bits it is...
Started stripping the car...as it was running a lil poo after a small fire
Bonnet off lights out,wiring loom out..
perfect place to store stuff...
Bit dirty under there...needed a tart up...so...
Before...
After...
But should i do the front arches like it??
gonna carry on in a bit....
And lastly my newly tinted in kandy red light....
not sure onthe fully clear bits..might need a light smoking...what do you think?
Liking the gearbox all painted,
prefer the light on the right as opposed ot the other one.
And that has to be about the only Nova Ive seen in a while with the front end off an no rust :P
Couldn't think of anything good to put in here.
cheers dave,
the light on the right is the one on the left but unmasked....lol
and yeah seam ok,nothing i could find which is good,
so i sealed it and painted to help keep it that way...
more pics getting uploaded...
Dirty sump...couldnt have that
soaking in degreaser
a bit better...
how the garage looks...lol
and finely glued up my engine mount,hopefully give a lil less movement...
nice advert for sikaflex that bottom photo.
Selling - PC and lots of meg's cleaning stuff, random z18(xe / xer) and z16(xe / xep) parts.
Cool stuff mate, very cool.
I'd do the arches black or grey like your bumpers.
Lets hope these carbs can get on there for PV!
Simps.
lol...better for AMG Windscreens, the Best in the south....privte and insureance work....
as i got the glue from them...lol
Looking good benn, how much was that stuff your doing the engine mounts with? Could do with some of that, does it take long dry?
A Small fire????![]()
Tell more? lol
Lights look cool.
Coming along nicely dude!
My Nova Turbo Build - http://www.migweb.co.uk/forums/vauxh...rbo-build.html
i got it for a fiver for the tube...normaly about30ish as its windscreen bonda stuff,
takes a few hours to fully harder...
i might have a spare tube....
and yeah a small wiring fire....behind the dash....panic? yes i did!
the roof light wiring rubed thru...got a lil warm...and caught light behind the fuse box...
so panicing as you do....i put it out with the hose.
After wards...i thought the hose wasnt the best thing to use.
might fix one light to see how it looks...
cheers keith,
top mincing there Benn, love the gearbox
loving those lights benn. You mincing today?
LMF VAUXHALL - 01858 433599
as you found out yes byron,
Todays up date,
Engine allout...
mounts off,
stoped for tea...
engine comming outthe top..
emtpy bay ready for tlc,
engine bay has been washed off,ready for a few bits and a damn good clean and wax,
The engine crane in action again,Lol.
Looking good.
Through the bottom! lol
still taking the engine out the wrong way then lol!
[quote]The Simps;
If you find the water leak and its a hole that needs welding up gimme a shout[QUOTE]
cant under stand thru the botty,just no need...lol
