My Nova's Rebirth
Page 201 of 203 FirstFirst ... 101 151 191 192 193 194 195 196 197 198 199 200 201 202 203 LastLast
Results 5,001 to 5,025 of 5051
Thread: My Nova's Rebirth
  1. #5001
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: My Nova's Rebirth
    get a decent sized one, on a die grinder if possible, will chew through that in no time
    SHoNkyOpELs.de
    lol and get a die grinder too...
  4. #5003
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    very handy tool to have though, got my last one for a whole £15 brand new!
    SHoNkyOpELs.de
  5. #5004
    Wow that's alot cheaper than i thought it would be.
  6. #5005
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    i found my drill goes just as quick as my die grinder. (with the bonus of not having to wait for the 50ltr compressor to charge up, really need to get a bigger one)
  7. #5006
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    your drill does 22,000 rpm? i need a drill like that! or you need a new die grinder
    http://www.ebay.co.uk/itm/rotary-air...#ht_716wt_1219
    SHoNkyOpELs.de
  8. #5007
    lol not a bit over board no?
  9. #5008
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    no, the faster you can spin the burr the cleaner and faster it will cut, they are designed for high rpm
    SHoNkyOpELs.de
  10. #5009
    True.
    Found the ABS ring isn't that hard. But have just finished off my last two belt sanding belts...
  11. #5010
    Broken my belt sander. So i thought i'll take them apart and then get them machined so it's a proper job... Then i got the funking dog.
    So one side, loosen off the handbrake spinning adjuster, disc wont come off, beat off with beat blow hammer as bit of the handbrake shoes fall out... One shoe is jammed out some a unknown reason.. Needs to be replaced even tho they arn't that low... Stub axle taps out..
    Other side, thinking the worse.. Disc comes off easy, tap the axle.. Don't move. 20mins of beating with a proper hammer, its not lose, but wont come off, maybe a burr of metal is holding it on.. Funking dog with it.
  12. #5011
    ABS bit machined off..
    Now it doesn't stick though the back..
    But still sits in the back plate, so it centers and holds the hub in the right place..
    All back together now, off to get the tracking check tomorrow after work and hope it's ok. If not then the real funking about starts...
    And the tiny amount of room i have...lol
  13. #5012
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    good work, at least now you can get a true reading if the beams scueiff or not.
  14. #5013
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Great work Benn
  15. #5014
    Quote Originally Posted by rc View Post
    Yeah really hoping it isnt...
    Quote Originally Posted by Daz H View Post
    Great work Benn
    Cheers dude.
  16. #5015
    Took the car out the garage yesterday, even tho there was an inch of salt on the road.. Popped down to Protyre (thank you to Paul and Jim and Euan)
    New print out...
    One from before to compare..
    So it's better and now in the "acceptable" area But i'd like it better than that. So with a bit of maths (trig) i can work out the size of the skim to make to correct the toe and get the camber the same on both sides...
    So car back in the garage, get the back jacked up again and start stripping...
    In the week i popped in to the bodyshop and made a brake line loop to stop fluid loss.
    Getting it fitted, (can see bits that need a repaint under there too)
    Then start unbolting everything again...
    Everything off, beam out, again see more bits that need painting
    Stripped everything off the beam..
    Can re-furb my calipers now, paint my break lines too.
    Beam out side so i could beat the ARB out,
    Only one bit stuck.. I cant get the bushes out to replace..
    So i've cut the outer rubber down, so it can all be powder coated and then i'll try and get the bushes out again..
  17. #5016
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Quote Originally Posted by GaryVaux View Post
    You may need to strip it down with new bearings and vane blades, they can wear if you're not using any lubricant - made a huge difference to mine, even with an oiler there were quite worn.
    TBH, if buying again I think I'd pay the extra and get an electric die grinder - maybe a small one to start with and a heavier one later. Flexible drive would be nice as well!
  18. #5017
    Hhhmm been a while since i updated, that cause i've been working away..
    So rear beam... With it off and at the powder coaters i stripped the hubs down..
    Backing plates cleaned and painted,
    Beam back.. Looks great, had to drill out the old bushes (hence the rusty dust in some pics)
    Time to build the hubs and braking bits up.. Garage isn't the nicest place too sit. So made a work bench and sat in front of the tv to do it..
    Not a fun job when you stripped it a month before and didn't take any pics to help you remember...
    Discs grease masked and painted. (painted the edge of the disc as i hate it when they are all rusty)
    Grease it,
    Then paint it,
    Then wipe paint off and the braking surface is clean...
    So then start rebuilding beam, Remember my bad caster? Using some tig (soh-cah-toa) i worked out what was needed to fix it and had some shim made to correct. (left 1.4mm and right 2.9mm cut on a lathe)
    Hubs on, disc on.
    Calipar on,
    Bolts painted
    ARB painted Arden blue.. and fitted with new bolts..
    Coilovers stripped and cleaned ready to refit.
    All new brake lines made.. Altho that don't look that great, they are all bent with a bender to be right and night, all have been painted too.
    Hose clips..
    The Goodrich braided hoses are sh*te too. So i've wire wheeled them all clean and repainted them too.. So they look a bit better..
    Will refit tomoz,
    And that's everything up to speed.
    Edit, needs an oil change so...
  19. #5018
    Jul 2004
    Southampton
    GTE 16v / Saab 2.0t
    Nice work dude.
    Where is the lil man?!
    in this pic below, is it me or is it cross threaded.....
  20. #5019
    The copper lines where knackered so the union was seized, so it was just in place to keep paint from the threads...
  21. #5020
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Great work Benn Is it much longer until it's back out on the road?
  22. #5021
    Need to do a bit of tweeking, one side the shoes are out to far so are holding the disc locked on..lol Other side the toe is still a bit out.. So not long.
    Cheers too.
  23. #5022
    Got the hub off, measured everything and worked out the angles again. Still says 2.9. So put everything back together and will wait till i get a tracking report before worrying any more. Adjusted the handbrake as well so it's just touching as it should be set. Did a lil touching up too.. As bit had got marked when fitting, so took finished pics.
    Looking at the above, i dont like that old looking fuel pipe.. Might replace it.
    Did the brake lines in blue to match the under side of the car (lines on the floor plan are black so they don't look like I've painted over them while doing the floor)
    Saw this some where, thought what a great idea. So used some black silicone and did it. Looks tidier i find.
  24. #5023
    MIGWeb Technical Moderator Dale's Avatar
    Jul 2006
    Swindon
    Monty / Vinnie (AstraVXR)
    Looking good Benn.... Like the rear beam!!
  25. #5024
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    Great work Benn Looks great under there. How are you finding rear disks? Not sure whether I should bite the bullet and get some?
  26. #5025
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Been panic buying then benn?
  1. 02-05-2012, 14:03
  2. 02-05-2012, 14:03
  3. 23-01-2012, 22:52
  4. 19-01-2012, 11:27
  5. 26-12-2011, 19:59
  6. 11-12-2011, 11:42
  7. 09-12-2011, 17:39
  8. 09-12-2011, 07:48
  9. 29-08-2011, 11:34
  10. 20-05-2011, 21:12
  11. 09-05-2011, 07:44
  12. 08-05-2011, 21:43
  13. 08-04-2011, 18:25
  14. 22-12-2010, 13:09
  15. 26-06-2010, 09:37
  16. Novas
    Refback This thread
    23-06-2010, 09:05
  17. 04-05-2010, 19:59
  18. 12-05-2009, 16:39
  19. 26-03-2009, 20:53
  20. 11-03-2009, 22:51
  21. 11-03-2009, 22:47
  22. 10-03-2009, 12:43
  23. 30-09-2008, 08:23
  24. 17-07-2008, 07:27
  25. 18-03-2008, 21:19
  26. 01-11-2007, 23:46
  27. 30-10-2007, 20:40
  28. 30-10-2007, 15:37
Tags for this Thread
