29-03-2007, 12:42
#51 | | MIGWeb User
Join Date: Sep 2001 Location: Glasgow Area-ish Drives: EVO VI & GTE 16v
| Quote:
Originally Posted by Jamie_F nice work there Rob, ill have to a have nose at it at Coombe, but if you want noise wind the screw out on the dumpvalve, i have the same one and its stupid loud. | FFFFFFFFFFF!!!!!!!! thats some bad advice there
I also had the same dump valve and the screw on the top adjusts the spring tension on the piston to weak (ie wound out) and the valve wont close quick enough or at all if its out far enough leading to stalling and poor running.
__________________ Never get an EGG credit card they do nothing to protect you if your card is subject to Fraud!!!!!!!!!!!!!!!!!!! |
29-03-2007, 12:57
#52 | | MIGWeb User
Join Date: Jun 2004 Location: Sunny old Bristol! Drives: Mitsi Evo & Focus TD
| Cheers peeps
Yeah I've found the best balance on the Blitz BOV so its loud but doesn't make the car cut out after dumping the clutch after a bit of abuse
I got a feeling that the blowing on the manifold where it joins to the turbo may be due to slight warpage of the flange which will mean it needs a skim
May have to take it apart on Sunday and get it skimmed on Monday if thats the case, will find out tomorrow when I get it back again lol (having new aircon pipe and oil cooler leak sorted)
Need to invest in some good tyres now and I think I might get a 360bhp remap until I can afford standalone management  |
29-03-2007, 13:34
#53 | | MIGWeb User
Join Date: Sep 2001 Location: Portsmouth Drives: black jap thing
| bah, your car must have a afm then, mine has a map sensor so i have no stalling issues  |
29-03-2007, 14:16
#54 | | MIGWeb User
| Quote:
Originally Posted by Jamie_F bah, your car must have a afm then, mine has a map sensor so i have no stalling issues  | Yeah all Evo's do..... Will be gone when some aftermarket goodness arrives  |
30-03-2007, 09:21
#55 | | MIGWeb User
| Just dropped it back up there for the following to be looked at/fixed (for free as they done it):
* Aircon pipe to be replaced
* Oil leak on oil cooler pipe union fixed
* Hopefully stop manifold blowing (if not may have to come off for a skim  )
* Funny noise to be investigated
* Clutch adjustment
* Last few days speedo has stopped working intermittently
When all the above is sorted then over next couple of weeks I will be relocating the battery to the boot, buying a proper non-restrictive induction pipe for turbo and then it will prob stay like that until I can afford the management  |
30-03-2007, 09:49
#56 | | MIGWeb User
| straight turbo intakes make so much difference, i made one for mine, spool up is loads quicker and it made full boost 400rpm earlier, even better if you can make one for £8 like i did  |
30-03-2007, 09:56
#57 | | MIGWeb User
| Ohhh nice one Mr F, got any pics?  What did you use?  |
30-03-2007, 10:06
#58 | | MIGWeb User
| i made it of of some random pipe from Pirtek, i have a mate who works there so just got an off cut, its double spiral bound 5 layer silicone, then just made the air filter fit.  |
02-04-2007, 10:31
#59 | | MIGWeb User
| Nice one, will be sorting mine this week hopefully
Aircon pipe has now been replaced, oil leak fixed, know what funny noise is and speedo wire has been repaired otherwise the manifold is still blowing so yesterday took it off and found that the turbo side flange is warped which is why it was blowing
Will get it skimmed and see how it goes from there...
Have put standard one on for now anyway and thought Hmmmm that original cast looks a bit rough so 2 hours & 11 dremmel bits later, well see the pics  |
02-04-2007, 19:01
#60 | | MIGWeb User
Join Date: Dec 2004 Location: Newcastle Drives: 35R LET..coming soon
| Twin port  , sneaky bastards. I didnt know that, learn something new everyday
__________________ There's no replacement for displacement. |
02-04-2007, 19:37
#61 | | MIGClub Member
Join Date: Jul 2005 Location: 31.5175 - 34.453056 Drives: XE'd Corsa
| looking good mate! |
02-04-2007, 20:12
#62 | | MIGWeb User
| Quote:
Originally Posted by Rs1 Twin port  , sneaky bastards. I didnt know that, learn something new everyday  | Yahhhh twin-scroll turbos  |
03-04-2007, 11:51
#63 | | MIGWeb User
03-04-2007, 12:00
#64 | | Regional Co-ordinator
| How much was the battery cradle/box Rob?
03-04-2007, 12:54
#65 | | MIGWeb User
10-04-2007, 15:35
#66 | | MIGWeb User
10-04-2007, 15:37
#67 | | MIGWeb User
Join Date: May 2004 Location: Manchester Drives: BMW E36 320 Coupe
| no pics of the air intake fitting?
sorry couldn;t resist!
joking aside. rear brace looks tidy enough and least you found the problem quickly  |
10-04-2007, 15:53
#68 | | MIGWeb User
| Quote:
joking aside. rear brace looks tidy enough and least you found the problem quickly  | LOL  Nah not yet mate, will do once I have a non-fooked one  |
10-04-2007, 15:55
#69 | | MIGWeb User
|  good stuff fella
did you put the nut.bolt back in with some loctite to try and prevent it from un-doing itself again? |
13-04-2007, 16:45
#70 | | MIGWeb User
|  that oil leak could of been......costly  Old copper washers perhaps  |
13-04-2007, 17:36
#71 | | MIGWeb User
Join Date: Jun 2003 Location: now in a evo Drives: 1.4bar = 356bhp :-)
| is the manifold now skimmed and re-fitted?
i ask because before you do, i had this problem with my turbo and like a div i just kept replacing gaskets  untill i spoke to the likes of reyland and norris and they don't run a gasket due to them always failing especially with LC
so i just bolted the turbo to the manifold with no gasket and have had no problems since (12mths no problems) |
20-04-2007, 15:56
#72 | | MIGWeb User
| Quote:
Originally Posted by Rs1  that oil leak could of been......costly  Old copper washers perhaps  | Yeah could have been  No they were brand new washers mate
Lee - thats interesting mate, no not refitted it yet, dunno if I can be arsed at the moment as they are proper chunts to do because of the funny angle of em  Might get it lapped/skimmed and refit the turbo to it without a gasket then see how it goes
Cheers bud  |
13-05-2007, 20:12
#73 | | MIGWeb User
Join Date: Jul 2003 Location: Near Oxford Drives: STi Type RA VII
| Have you had the re-map done yet mate?? |
13-05-2007, 20:14
#74 | | Regional Co-ordinator
| a part co oil filter? eek:
__________________ Quote: |
13-05-2007, 20:33
#75 | | MIGClub Member
Join Date: Jan 2007 Location: Felixstowe, suffolk! Drives: 359.9bhp astra :D
| feel like im living in your shaddow, got a mk3 astra turbo at the mo and was planning to get that shape evo next  |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
