Old 11-02-2007, 20:14   #1
Drives: Vectra B1 3.2V6
Viziers Vec: Project 3.2V6
this is my litle project so far in short
il try to go into details but i dont know all the part names in english
whe pulled the engine out a while back:
the heater (verry important :P ):
the old handbag 2.5:
empty :
last week i bought an 3.2V6 on german ebay:
fitting the new gearbox on the old engine:
with the help of a alluminnium watercut ring, a perfect fit
and last whe drove 450km thru germany to pick up my new engine :
putting the hydrolic Slave Cylinder from the f25 in the f28
some cutting
and now it fits
whe still have to drill new holes, and whe have to cut something out of the Slave Cylinder so that the oilringthing will fit between the Slave Cylinder and the gearbox
and thats about it
have fun reading and il update the topic occasionnaly
Life is a Game -> Enjoy :)
Vizier is offline   Reply With Quote
Old 11-02-2007, 21:17   #2
Drives: 3.0 V6, 2.5 V6, 1.8
Druklager = Slave Cylinder.
Mark T is offline   Reply With Quote
Old 11-02-2007, 21:30   #3
thx , i edited my post
Old 13-02-2007, 00:41   #4
new brakes r orderd
I500 308mm disks (for the front, back wil be normal vec V6 size but with drilled disks)
brackets
i hope these will be big enuf to stop me
Old 13-02-2007, 01:24   #5
looks cool, dont know much about these big engines but im keen to learn.
top marks for posting in a foreign language!
competition nova parts needed! see below...
migweb.co.uk/forums/cars-items-wanted/375558-competition-high-end-nova-parts.html
kennybarbour is offline   Reply With Quote
Old 13-02-2007, 21:35   #6
stript the engine a bit today
Old 13-02-2007, 21:50   #7
Drives: black jap thing
why did you fit a spacer between the the gearbox and block?
surley by doing this you will have problems with the input shaft from the gearbox not meeting up properly with the clutch drive plate?
Jamie_F is offline   Reply With Quote
Old 13-02-2007, 22:35   #8
the F28 is a bit shorter then the original F25 (il take a picture so u can c)
if i dont then i wil have to move the block (a bit back) in the engineroom for the gearbox to fit in the right place
that would mean making an all new suspension system for the block, plus the chance that it wont fit, already short on room behind the block
this way, i only need to make 1 new bracket for the gearbox, and the engine is in the place where it should be
the input shaft is long enuf btw
there's an astra mk3 (astra f) driving around with a 3.0V6 F28 and the same spacer
that car is also driving around with a 2.0 flywheel and clutch witch is alot thinner then my fly wheel
there have been no problems with that car yet
the guy who build it in there is helping me with my project
Old 13-02-2007, 22:38   #9
Drizz's Avatar
Drives: Vectra GSi & A4 1.8t
Any build pics for the Astra F?
DRIZZ
DEVELOPMENTS
Old 13-02-2007, 22:41   #10
You can use the F28 Flywheel and Clutch then just space the engine over a bit like I did.
http://82.34.52.15/sytemsandsoftware...F25WithF20.htm
[url=http://77.96.230.10/sytemsandsoftwaredevelopment/systems.htm] How Tos
The two most life changing experiences you'll ever have. Finding Jesus, and having a baby.
Old 13-02-2007, 22:55   #11
Drives: astra g 1.6 3door
how thick is the spacer?
spue2001 is offline   Reply With Quote
Old 13-02-2007, 22:59   #12
foto: http://i125.photobucket.com/albums/p...s/DSC00151.jpg
topic: http://forum.astragsi.nl/viewtopic.php?t=6236
c the difference
Old 22-02-2007, 02:11   #13
some paintwork
new brakes came in today
Old 23-02-2007, 01:20   #14
Drives: Vectra B C20LET
looks good. as mark said you could of used the f28 clutch and flywheel and used 23mm spacers
lee866 is offline   Reply With Quote
Members: 43,212
Threads: 310,608
Top Poster: LEE69 (43,149)
