Page 92 of 105 FirstFirst ... 42 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 ... LastLast
Results 2,276 to 2,300 of 2604
Thread: my new mk3 astra gsi...... turbo ;)
  1. #2276
    Mar 2008
    Carshalton, Surrey
    BMW E36 M3 3.0
    Re: my new mk3 astra gsi...... turbo ;)
    Quote Originally Posted by rc View Post
    yea its not a drip, its a constant stream of oil!
    ... Oh sh1t mate, it's just never ending, on the plus side your oil presure won't be too high... your heart rate, that's a different story.
    Chin up bud.
    Official Migweb Pervert!
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    well the plans gonna be to whip the driveshaft back out, get a small power file on the crack and give it a bit of serface area then chemical metal all round there, will be the last chance without disconecting everything, if that fails i will get another adapter made and use the lug next to this one and totally block the origional off!
    coludnt be bothered to have another day laying under the astra today, so kust gave it a wash off
    all looks a bit high, havnt got any interior in the back at the mo
    and heres the heightening those new top mounts have done!
  4. #2278
    Jan 2007
    cheshire
    mk3 astra turbo 4x4
    not having much luck glad to see its not getting you down to much. when you get around to 4x4 yours you are more than welcome to come up and have a look at mine and pick are brains there are one or two thing we would do diffrent
  5. #2279
    rc
    rc is offline
    Jan 2007
    359.9bhp astra
    Quote Originally Posted by shanger View Post
    cheers mate! i'll be rear wheel driving mine! but all the rear half will be the same, i'm gonna be talking to as many 4x4 astra people as i can find to see how they've done their rear floor etc, think im in a good position to let tother people do the research and development this time lol!
  6. #2280
    Hope you can get it sorted dude, keep ya chin up.
    Not feeling the top mounts tho..
    *gary, thinking aboutit manifolds are cast yeah.. seen my olf boss weld one of them easyly..*
  7. #2281
    Jul 2002
    Northern Ireland
    6SPD 16V Turbo Nova
    Gutted to see another person has had the same trouble as me. I took mine to my engine builder and he said there is no way of gaurenteeing a proper job on the feed as at full rev's it could be around 6 bar of pressure.
    I was told chemical metal wouldnt hold either.
    I was also told that welding would be tempory and that there's no gaurentee the weld wont crack, because the weld will always cool down faster than the block causing it to crack again.
    With this advice I sourced another block, had it bored and everything swapped over.
    Keith
  8. #2282
    Mar 2004
    Dunstable, Beds
    Astra GSi 1.8 16v
    FFS dude, really wanted this to go well for you
    but feel safe in the knowledge that we're all behind you and feel your pain
    probably quite as much as you, but we feel it lmao
    good luck with it pal
    (p.s. did ask previously but you've had a bit on your plate since then, what suspension springs you using mate? )
    Not playing with a full deck....
  9. #2283
    Jan 2002
    Oswestry, United Kingdom
    Cbr 600 F
    Quote Originally Posted by KeithRobinson View Post
    Keith
    Was going to say the above its just not worth your engine after you have spent all that time and money on it,
    I have a let block has a scored bore(tiny mark) still complete
    just feel sorry for you after reading all of this
    Good luck whichever route you choose
  10. #2284
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    what did he use? did he heat it before and slowly bring the temp down after? cast is easy to blat a weld onto but if it is left like a normal weld itll crack straigh away, he probably brazed it which could solve ronnies problem come to think of it.
  11. #2285
    rc
    rc is offline
    Jan 2007
    359.9bhp astra
    right well had a bash with it tonight
    whipped the driveshaft out for acess
    here it is
    got the magic stuff
    v'd out the cracks and cleaned up and degreased all the area
    chemical metaled it all up
    the packet said cured in 10 mins, able to drill and tap in 20mins, so i left it for two and a half hours to be sure
    but 30seconds after start up
    what a prick!
    i give up!
  12. #2286
    Quote Originally Posted by GBE86 View Post
    It was left running to warm it up, then welded it.. i know it didnt blow. Not the neatest welding i've seen but it did the job.
  13. #2287
    Dont give up dude, can you not use the one next to it? (closeest to the camera?)
    Thern just seal the other one up..
  14. #2288
    rc
    rc is offline
    Jan 2007
    359.9bhp astra
    if i could seal the other one then i wouldnt have a problem!
  15. #2289
    Jun 2008
    Merseyside
    clapped out astra
    Walk away from it, have a break and clear your head. I take my hat off to you for your perseverance, alot of people would of broke the car by now.
  16. #2290
    Oct 2001
    Bedfordshire
    Vectra CDTI 150
    Gutted for you dude
    could you not sleeve it inside further than the crack ?
    The cake is a lie :(
  17. #2291
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Not good mate, looks like it will need a new block. Or could you not bolt it from inside, chemical metal from the inside, then use the other hole.
    www.shonkyopels.de
  18. #2292
    Whatabout fitting cap to it and then brazing it?
  19. #2293
    Jan 2006
    mansfield, notts
    Just a guess mate but could the allen bolt on the left be removed and fitted with some sealer in the cracked hole but from the inside then use the other for the feed?
    Proper gutted for you mate but as said dont give up will be worth it in the end!
    R.I.P PUGLET (2002 - 2010) :(
  20. #2294
    Apr 2004
    Ayrshire, Scotland
    Audi S3
    off the oil leak subject bud but i wouldnt recommend using that new spring on the cambelt tensioner. renown for coming off and f*cking up the timing by getting jammed round the pulleys. with your luck n all!
    EDZELL CONVERSIONS Best built valvers in the south west!
    MK4 astra van bits wanted.... 60mm springs, tailgate spoiler & bottom trim panel.
  21. #2295
    Jun 2003
    Thatcham, United Kingdom
    Fear into children
    Ronnie, take a step back and look, take the block lesson on the chin and source a new one.
    I assume you can reuse most of the parts from the latest build up?
    You have no choice but to complete this build...
    So who cares if you are going to rip it apart next year to make the RWD one, this has to be finished or i'll Rick Draper you.
    Ginge
    www.virtualseason.net For all your sports streaming needs
  22. #2296
    Mar 2008
    Carshalton, Surrey
    BMW E36 M3 3.0
    You seem to have spent more time fixing this than driving it - no point giving up now matey. Don't run into the RWD project - get it working first and enjoy it a bit surely?
    A new block will be a hassle, but surely it's the best option?
  23. #2297
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Ronnie, just plug the damaged hole and use another oil feed, pain in the arse and id have given up if it was mine, but you've worked too hard on it now.
    www.wix.com/vxlgsi/zxr-750-r
  24. #2298
    MIGWeb Admin @ndy's Avatar
    Caerphilly S.Wales
    Vectra SRI
    Keep at it Ronnie.
    *Pending Approval*
  25. #2299
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Fook me, how much of that chemical metal did you put on? lol
    This leak is starting to piss me off now, and its not even my car lmao
    Hope you keep at it mate
    How was it leaking through the chemical metal? Seeping "through" the actual chemical metal, or is it leaking from somewhere else and then dripping down the chemical metal?
    I would of thought that chemical metal would do the job tbh, if it was mixed right. Its hard as F**k and even survived inside inlet/exhaust ports on my old engine! lol I would of expected it to withstand oil easily, unless its just the pressure it cant hold back.
  26. #2300
    Mar 2004
    Dunstable, Beds
    Astra GSi 1.8 16v
    really really feel for you mate.
    nothing worse than something like this messing everything up.
    chin up mate , onwards and upwards
  1. 29-01-2012, 13:41
  2. 10-01-2012, 16:01
  3. 10-01-2012, 13:34
  4. 10-12-2011, 22:58
  5. 10-12-2011, 19:00
  6. 09-12-2011, 21:42
  7. 09-12-2011, 17:08
  8. 09-12-2011, 15:38
  9. 30-11-2011, 21:37
  10. 27-11-2011, 17:30
  11. 21-10-2011, 21:15
  12. 19-05-2011, 16:50
  13. 08-12-2010, 19:06
  14. 06-10-2010, 18:54
  15. 06-09-2010, 06:04
  16. 21-08-2010, 09:59
  17. 06-07-2010, 10:50
  18. 05-06-2010, 19:38
  19. 08-02-2010, 07:05
  20. 17-12-2009, 18:40
  21. 08-12-2009, 07:57
  22. 12-07-2009, 19:36
  23. 26-05-2009, 13:13
  24. 18-05-2009, 20:03
  25. 27-04-2009, 10:15
  26. 11-04-2009, 21:51
  27. 16-03-2009, 15:58
  28. 25-02-2009, 07:28
  29. 16-02-2009, 13:32
  30. 07-02-2009, 14:11
  31. 16-01-2009, 19:15
  32. 16-01-2009, 15:03
  33. 09-01-2009, 16:10
  34. 09-01-2009, 07:39
  35. 07-01-2009, 07:08
  36. 04-01-2009, 10:37
  37. 03-01-2009, 21:49
  38. 01-01-2009, 10:43
  39. 31-12-2008, 10:42
  40. 30-12-2008, 10:55
  41. 29-12-2008, 10:21
  42. 27-12-2008, 16:01
  43. 26-12-2008, 22:32
  44. 26-12-2008, 20:52
  45. 30-11-2008, 11:39
  46. 15-11-2008, 13:37
  47. 09-11-2008, 06:33
  48. 07-11-2008, 22:16
  49. 04-11-2008, 14:47
  50. 19-09-2008, 13:23
  51. 19-09-2008, 11:53
  52. 17-09-2008, 09:48
  53. 12-09-2008, 11:52
  54. 12-09-2008, 08:45
  55. 12-09-2008, 08:24
  56. 12-09-2008, 08:06
  57. 12-09-2008, 08:02
  58. 09-09-2008, 13:52
  59. 09-09-2008, 11:45
  60. 09-09-2008, 09:06
  61. 08-09-2008, 21:44
  62. 11-07-2008, 10:50
  63. 06-04-2008, 21:35
  64. 16-01-2008, 06:23
  65. 11-01-2008, 23:37
  66. 19-12-2007, 10:12
  67. 19-12-2007, 10:03
  68. 19-12-2007, 09:27
  69. 07-12-2007, 23:02
  70. 08-11-2007, 10:14
  71. 06-10-2007, 22:25
  72. 14-08-2007, 07:17
  73. 09-08-2007, 23:20
  74. 09-08-2007, 20:10
  75. 09-08-2007, 18:12
