Page 1 of 16 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 25 of 383
Thread: C20LET Westfield Project
    Sep 2001
    Devon
    Westfield C20LET
    At the end of November I began breaking my cherished Mk2 Astra to fund my new project. I ordered my Wesfield kit car after researching and putting together my desired spec. Because this would be my first build I wanted something relatively straight forward in terms of complexity. I ordered a lightweight SEiW Sport 2000 rolling chasis, which is around 20% lighter than a standard Westfield chasis and comes with a lower floorpan (Which is ideal for lanky gits like me). I also specced it with AP Racing 4 pot brakes, nylon bushes and the new FW bodystyle.
    At this early stage I decided to run a 5 speed Borg Warner T5 gearbox from a RWD Saphire Cosworth because they're quite cheap and can be easilly modified with Quaife big tooth kits etc. I also obtained a Ford 3.62 LSD Diff. Westfield prepare the chasis and supply all the correct mounts for your exact setup which will save a load of hassle later on.
    The kit is due for collection on Wednesday (31st January 2007) so between November and January I had a lot of prep work to get on with as well as sell all the bits I no longer needed from the Astra.
    Pre Kit Preparation
    Engine out - that's 10 year or so of grime all over that
    I start off cleaning the exhaust side - Blinking heck it's going to be a long job!
    Starting to get the worst of it off
    Cor look - Cast iron can look shiney!
    This side is just about done now
    Oh but look at the state of the other side - it's even worse!
    First I use a medium sized wire brush to loosen the worst of the muck
    A liberal use of brake cleaner / carb cleaner to get that grime moving
    Then using a combination of small copper and steel brushes I scrubbed at the more stubborn muck
    A harsh grade of abrasive paper shifts the really difficult dirt an surface rust
    Almost done - I'm not going to bother too much with the sump because I'm dry sumping it anyway
    The head looks much better after the steel brush treatment too
    Before painting I mask up the bits I don't want to cover in spay
    The exhaust side now looks a bit blingier
    and so does the inlet side
    and with some small dabs of blue here and there it's pretty much as tidy as I'm going to get it.
    2008 Westfield SEIW Turbo For Sale (300 - 450 Bhp)- £16,995 - Tel 07071 061 673 - Email: neil@fw500.co.uk
    May 2001
    South Wales
    Nippy Cav Turbo
    bring it onnn
    Sep 2001
    Cavaliers Mk1 Mk2 and Mk3
    looks fantastic neil, cant wait to see this and it inspires me to get on wih my own engine work!
    What happened to the old astra shell?
    Jan 2003
    South Wales
    corsa c20xe
    if you dont mind me asking how much was the cost so far not inc 4 pots and the engine intrested in doing this aswell
    cheers
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    I've been waiting for this thread!
    How easy is it to mount the LET to the box? Just an adapter plate?
    Simps.
    Jan 2002
    ayrshire scotland
    like a saint-9points
    you're keener than me mate, i cant be ****ed with all that cleaning malarky
    what gearbox are you using?
    rodgerq
    Wales Regional Co-ordinator Tathan's Avatar
    Jun 2002
    Wrectum
    From what I understand, he's using a 5 speed Borg Warner T5 gearbox from a RWD Saphire Cosworth because they're quite cheap and can be easilly modified with Quaife big tooth kits etc.
    Jan 2002
    ayrshire scotland
    bbugger, i was gony ask what flywheel he using if he was using a manta box
    rodgerq
    Jun 2002
    Wrectum
    it's all in the black squiggly stuff at the top rodger
    Jan 2002
    ayrshire scotland
    its quarter to 4, i'm just by driving a 700 odd mile round trip a gloucster, forgive me if i just stare at the pictures
    rodgerq
    Jun 2002
    Wrectum
    i used to be like that with smut mags, but then i realised just how good the stories were
    Dec 2003
    NEWCASTLE
    NOVA 1.6 16v + Vectra GSI
    Great project!! Should be an awesome machine when its done!!
    1.6 16v Nova. Something newer!!
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Awesome mate
    www.shonkyopels.de
    Sep 2001
    Devon
    Westfield C20LET
    Quote Originally Posted by Brett View Post
    I sold the shell to a local lad - he's putting an XE in it (Almost finished by all accounts). I didn't get much back for it but tbh it was the trickiest thing to sell.
    Quote Originally Posted by k127atx View Post
    cheers
    A standard rolling chasis is £5,250 and that includes the body panels. The FW bodystyle is an extra £500, the Sport 2000 chasis is an extra £500 the AP Brakes are an extra £500, the nylon bushes are an extra £100.
    This gets you about 2 modules into a 6 module project, but if you've got your own engine, box etc you're going to knock a serious chunk off the final build price. Module 3 - completion could cost you anywhere between £3k to £15k depending on what you're going to do and where you're going to source the parts. It seems Westfield's parts are a bit pricey for some things but quite competitive on others.
    I'm going to source my own fuel tank, rad, intercooler, exhaust, seats, instruments, wheels & tyres, but will use westfield for the odds and sods.
    Quote Originally Posted by The Simps View Post
    Simps.
    It couldn't be easier mate - the clutch is the trickiest part. These guys do a XE/LET to T5 Bellhousing for £160.
    Update
    Westfield just called to tell me the chasis is ready... just one problem, they've built it without the racing chasis - do I wait for them to sort it out (extra couple of weeks) or do I just take the 25% heavier one?
    MIGClub Member jav786's Avatar
    May 2002
    Yorkshire
    Vec GSI/Evo IV/Cav T
    Engine is nice & clean now
    If you always tell the truth, people will stop believing you!
    http://www.iconperformance.co.uk/ - Vauxhall Specialist Tel 07962398027
    Jan 2002
    ayrshire scotland
    i'd wait for the lighter shell. its only a couple of weeks and 25% is a good saving by any means
    rodgerq
    Mig Club Member Orange Peel's Avatar
    May 2003
    Nottingham
    Quote Originally Posted by rodgerq View Post
    rodgerq
    Agreed!
    No point in using the 'heavy' chassis if you wanted the lighter one. In the mean time you can tweak what you already have
    Mar 2005
    Bristol, SW of UK
    GTE turbo
    I'd wait as well Neil, unless they are willing to knock the difference in weight percentage off of the price as a discount percentage
    TBH I would have thought you needed the heavier shell to keep you on the road! - What do you intend to run your LET at whilst in this one?
    Fantastic project BTW, I'd imagine its going to be a great feeling when you 1st take to the road in something you have pretty much built! Good luck.
    You cant stop the spirits when they call you - This life is more than just a Read-Thru
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    This will be so quick, trust me!
    4th gear will disappear like 2nd gear does in a typical LET Astra or cav. Imagine going from 90 to 125mph in not much more than the time it takes to swallow. Only you wont be able to swallow because of the G's.
    fantastic! Wait for the lightweight chassis!
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Quote Originally Posted by Neil Adams View Post
    PM sent to help solve the clutch problem..
    www.wix.com/vxlgsi/zxr-750-r
    Sep 2004
    Nottingham M1 J26
    Cars. Loves: Dirty sluts
    Neil, what paint did you use to spray the block there? Looks awesome.
    Oct 2005
    clacton on sea,essex
    corsa c20let
    that engine is going to be good fun in that!! looking good!
    Sep 2001
    Devon
    Westfield C20LET
    Quote Originally Posted by Chavtastic View Post
    Yeah it came up way better than I thought it would. It's Plasticote Hot Paint - I think the colour is 'Aluminium'. I got it from Halfords.
    Sep 2001
    Devon
    Westfield C20LET
    Just picked up the wheels and tyres. As I liked em so much on the Astra I went for the Toyo R888s again and they're WAY cheaper than the Astras 18's. I paid the same here for a set of 4 Wheels and Tyres as it cost for a set of Tyres for the Astra.
    The wheels are Team Dynamics Pro Race 1.2 - chosen for the weight and not their looks clearly. Although this type of wheel seems to look quite nice on bright yellow Westies.
  26. #25
    Macclesfield
    www.Retrobike.c
    Are your going to go to wasted spark on the engine neil beofre it goes in the westfield? Looks good.
    Back in the scene
  1. 03-01-2012, 21:12
  2. 10-12-2011, 18:11
  3. 09-12-2011, 11:38
  4. 19-06-2011, 11:41
  5. 16-05-2011, 21:54
  6. 06-04-2011, 23:30
  7. 09-09-2010, 15:45
  8. 07-08-2010, 11:05
  9. 16-12-2009, 17:08
  10. 30-06-2009, 23:14
  11. 30-06-2009, 18:05
  12. 30-06-2009, 16:08
  13. 29-06-2009, 21:14
  14. 29-06-2009, 20:49
  15. 19-06-2009, 13:28
  16. 16-06-2009, 19:35
  17. 16-06-2009, 11:14
  18. 16-06-2009, 09:18
  19. 16-06-2009, 08:43
  20. 24-03-2009, 12:07
  21. 18-03-2009, 12:54
  22. 11-03-2009, 14:13
  23. 08-03-2009, 20:35
  24. 08-03-2009, 18:49
  25. 08-03-2009, 17:53
  26. 08-03-2009, 16:01
  27. 08-03-2009, 15:44
  28. 09-02-2009, 19:38
  29. 09-02-2009, 18:39
  30. 09-02-2009, 18:12
  31. 09-02-2009, 17:44
  32. 09-02-2009, 17:43
  33. 09-02-2009, 17:41
  34. 01-11-2008, 20:55
  35. 31-10-2008, 21:55
  36. 07-07-2008, 14:49
  37. 07-07-2008, 14:34
  38. 07-07-2008, 14:18
  39. 06-07-2008, 14:57
  40. 06-07-2008, 02:00
  41. 12-06-2008, 07:34
  42. 12-06-2008, 07:25
  43. 28-05-2008, 17:20
  44. 19-04-2008, 12:19
  45. 18-04-2008, 23:00
  46. 27-01-2008, 21:28
  47. 04-07-2007, 14:03
