16-01-2007, 16:36
#1 | | MIGWeb User
Join Date: Mar 2002 Location: suffolk Drives: Corsa Tbo n Prelude
| Corsa track/Sprint build The project car, something ive always fancied a little corsa gsi, with a blown head gasket came home with me for £200. Its abit tatty here and their but hey its a track car.
Stripped out the interior havnt gone mad, im going to leave the dashboard and the roof lining in place for now. Was pleased to see it all painted inside.
Engine in place and looking abit manky
2.5 hours later
Corsa waiting to be taken to my bro's house for the next step
Wacked in an electric sunroof
Gaz coilovers + harnesses
Bargain bucket seats £120 B/new
The donor car, N reg calibra turbo which i was driving about in for afew months to make sure it was running right before i pulled it out. Have to say although im not much of a calibra fan it was good fun to drive.. It had been running very lean when i bought it, turned out to be a faulty alternator. Swapped that and some new plugs and she was going like a gooden again, but i suspect their will be underlying damage from "running hot" that ill have to check out. YouTube - calibra turbo 0-140
So soon it came time to rip the heart out of the cally so i can crack on with the rebuild,
Stripped off all the ancils ready to mount on the engine stand
LET in a box + hours of cleaning needed for it all.
On its stand and ready to be ripped apart
Cams out then head off
Found that what i had suspected was right, from running so hot No3 cylinder (which runs the hottest anyway) had glazzed the bore and this is why it was burning oil, So now ill have to rebuild the block.
Valves are dirty with allot of deposits, probably from runing lean, but is going of to a friend to check everything else is ok, ie valve guides and seats etc and refresh whatever is needed.
More to come as and when i get time..
__________________ Bring back the power of LET
Reason: spelling
16-01-2007, 16:50
#2 | | MIGWeb User
Join Date: May 2004 Location: Manchester Drives: BMW E36 320 Coupe
| looks good
bargain of a gsi to begin with. keep up the work |
16-01-2007, 19:34
#3 | | MIGWeb User
Join Date: Jul 2006 Location: Northants Drives: 12.1 sec Corsa..@120
| good work mate!! you got the big hill to climb now!! im nearing the top, just gotta go down the other side
__________________ 12 second corsa....0.1secs away from an 11 sec car wohooooooooo www.vauxsport.com |
16-01-2007, 20:42
#4 | | Regional Co-ordinator
| looks good dude, |
16-01-2007, 21:48
#5 | | MIGWeb User
| Floor looks mint, has it been painted before, mines a grey GSI and its half undercoat still. grey is only misted on the outer edges. |
16-01-2007, 22:51
#6 | | MIGWeb Moderator
Join Date: May 2006 Location: beddau, South Wales Drives: mk3 astra
| going to be intersting this summer as theres a lot of track only cars being built. (will be watching this one carefully as i have a track gsi to play with too) looking good so far fella. |
16-01-2007, 22:56
#7 | | MIGWeb User
| mines a hill climb,sprint trackcar build as well. |
16-01-2007, 23:31
#8 | | MIGWeb User
| Quote:
Originally Posted by neo1 Floor looks mint, has it been painted before, mines a grey GSI and its half undercoat still. grey is only misted on the outer edges. | No it hasnt been painted, i ripped out all the origonal carpet etc, i didnt know any different untill i saw another stripped out car an realised i got lucky Quote: |
| Yeah so much to do its unreal and lots of cash to to do it properly, just hope its worth it. The car is going to be 100% mechanically sound as i wnat to take it to the ring at some point, the body work will be tidy but not mint. Quote: |
| Cheers, ive been tracking a mk2 astra gte and its so much fun, me and my bro are doing a sprint championship next year as afew mates already compete (a build and pics of his car will be up nearer completion), it should be a blast.
17-01-2007, 14:06
#9 | | MIGWeb User
| Not too interesting but the crank, rods and pistons are out and in good shape.. which is nice!  |
28-01-2007, 10:09
#10 | | MIGWeb User
| Little bit more work done, rear beam will now accept cav rear disks....
Std corsa rear beam, with our little alignment tool..
Rear beam with origonal plates cut off
These are the conversion plates that need to be welded on in the place
Plates lined up, tacked on, then clamped into place ready to weld.
All done, ready to be painted up properly.
Also got my block back all honed and good again!! and my crank has been polished, just got to make some new inlet valve guides for the head so that can be finished. |
29-01-2007, 12:59
#11 | | MIGWeb User
Join Date: Nov 2002 Location: Sunny Ipswich Drives: like a girl
| Glad to see you have started a thread on this little project, will be worth the effort once its done!
Tobys car looks proper in the background of your second to last pic, i will have to pop over and have a butchers at it with the wheels on.
__________________ On most other forums you would now be looking at a picture of my 2.1 Zetec powered Series 1 RS Turbo. |
29-01-2007, 16:49
#12 | | MIGWeb User
| I thought updating it bit by bit would be easier than doing it all when im finished... got a foooooooooookin long way to go though..
Toby had his Mo's fitted with the 888's and it looks awsome.... just struggling to get it low enough now its so light.. even on 60mm front springs the front is still to high. lol |
29-01-2007, 18:33
#13 | | MIGClub Member
Join Date: Jul 2005 Location: 31.5175 - 34.453056 Drives: XE'd Corsa
| Looking good mate! |
30-01-2007, 10:41
#14 | | MIGWeb User
| Quote:
Originally Posted by vxlgsi Toby had his Mo's fitted with the 888's and it looks awsome.... just struggling to get it low enough now its so light.. even on 60mm front springs the front is still to high. lol | I reckon he is going to have to do some more weighing in and get some coilovers to get it to sit how he wants. |
30-01-2007, 11:59
#15 | | MIGWeb User
| He wont do that it wont be a budget track car if he just buys everything he needs lol, he is going to make the suspension mounting in the turret adjustable |
01-02-2007, 18:34
#16 | | MIGWeb User
| Update..... Few bits have arrived..
Hats off to balance motorsport they supplied my cage which arrived in 7 days and ARB came in 2 days gave me superb prices and great service.
Whiteline 22mm rear ARB
Rollcage
mocked-up, just got to test fit it, and get some paint flung at it.
quaife ATB diff (thanks to steveboyslim)
Also got my block and rear beam painted up..
Phosphor Bronze valves guides from TTV Racing components
02-02-2007, 22:37
#17 | | MIGWeb User
Join Date: Jul 2002 Location: newcastle Drives: 2ltr turbo 6 speed nova
| thats little tool of yours does it just keep them inline? |
02-02-2007, 22:54
#18 | | MIGWeb User
Join Date: Oct 2005 Location: clacton on sea,essex Drives: corsa c20let
| looking good  |
02-02-2007, 23:42
#19 | | MIGClub Member
Join Date: Jan 2005 Location: In The Woods Suffolk Drives: Kadett 200ts
| Looking good mate! I reckon you could have her ready for PVS!!!
__________________ Turbo Power is here!!!! And my god i LOVE IT!!!!!!!!!!!! |
02-02-2007, 23:58
#20 | | MIGWeb User
| Quote:
Originally Posted by GSIDecturbo thats little tool of yours does it just keep them inline? |
Yes it worked a treat.. Quote: |
| I doubt it mate, still got loads to do.. it wont be at any shows untill its finished.. lol , not that anyone will be interested in another corsa turbo lol. |
03-02-2007, 01:00
#21 | | MIGWeb User
| hows bout gettin me one  |
03-02-2007, 01:07
#22 | | MIGWeb User
| its pretty simple just takes some thought. |
03-02-2007, 04:15
#23 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
nice work fella
one question though,
do those plates line up with the holes on the back of the beam? my mate did a nova and the way the instructions said you have to cut here bend there weld here and it seems too much but if they can be lined up and welded on then im doing that on mine!!!! |
03-02-2007, 08:08
#24 | | MIGWeb User
| Quote: |
people proably wont be that intrested mate but...........at least people like me and you and all the others that do home builds can stand back and look at wot we have achieved!! better than payin sumone to do it for you ay!! keep up the good work!! i wanted a quaife diff for mine.....but i want to drive it 1st and make sure i deffo like it.........but then again i have thrown a hell of alot of cash at it already so wot would an extra £500 or so matter  lol |
03-02-2007, 15:24
#25 | | MIGWeb User
| Quote:
Originally Posted by gazzamec
nice work fella
do those plates line up with the holes on the back of the beam? my mate did a nova and the way the instructions said you have to cut here bend there weld here and it seems too much but if they can be lined up and welded on then im doing that on mine!!!! | the holes that the hub studs go through wont line up with the origonal holes, you just have to re drill them, the holes that we used as guides are the hole in the center of the new plate, and the hole in the center of the bit you weld it to.. that way the hubs stay central.
hope that makes sense. Quote:
Originally Posted by bux people proably wont be that intrested mate but...........at least people like me and you and all the others that do home builds can stand back and look at wot we have achieved!! better than payin sumone to do it for you ay!! keep up the good work!! i wanted a quaife diff for mine.....but i want to drive it 1st and make sure i deffo like it.........but then again i have thrown a hell of alot of cash at it already so wot would an extra £500 or so matter  lol | Yeah mate its just abit of fun really, Personally i love having mint motors, but they always got to the point where i didnt wanna mess it up (winter weather etc) leaving it in carparks where it may get damaged etc, this will be a worry free car.
I thought if i dont buy a diff now, ill have to pull it all out again, pull without one it will be rubbish on trackdays.. if i was doing it for just road use, i may not have bothered. |
Members: 43,212
Threads: 310,608
now!
of being a MIGClub Member.
