Im looking after brians vernier pulley situation
according to his list above he isnt doing it on the cheap or cutting corners, the only thing i disagree with is the oil pump but thats personal pref.
He has a good xe head, the block is being sorted, new bearings, bolts, rings etc.. a good engine is 75% how its put together and maintained.. using good standard parts is probably the best way to keep the engine safe, its when you start f~cking around with everything trying to make it better that it can go tits up.
Sounds like he is thinking of phase 2 which will be fine....but the nos sounds like a bad idea tbh.
Brain, do a good standard rebuild and enjoy it.
and also if your planning on tunning it stick with me on this clutch we spoke about for your xe flywheel as the ball is already rolling.
oh and also ditch the deadline and give your self a sensible one.
