16-01-2007, 13:42
#26 | | MIGWeb User
Join Date: Aug 2004 Location: southend Drives: cav GSI 16v 2ltr 92
| brian i have a new gm cam belt kit for sale my love
see my for sale thread or pm me |
16-01-2007, 14:07
#27 | | MIGClub Member
Join Date: Jun 2004 Location: Essex Drives: GSIT.... Allegedly!
| Brian - You can use your XE head, but that will require dismantling to fit the LET cams. Or you can use your XE cams for a bit more hp, but you would have to fir vernier pulleys and that would require an expenditure of more then £4.99.
Stef - The pipes are spanky. Thank you.... Mwah
JapCav - You'd be lucky to get more then £10 out of Brian for something new when he can use a 2nd hand belt for £5.  . Is it for a late engine?
__________________ "If your not breaking parts, your not making enough power!" |
16-01-2007, 14:30
#28 | | MIGWeb User
| Quote:
Originally Posted by Dave GSiT Brian - You can use your XE head, but that will require dismantling to fit the LET cams. Or you can use your XE cams for a bit more hp, but you would have to fir vernier pulleys and that would require an expenditure of more then £4.99.
JapCav - You'd be lucky to get more then £10 out of Brian for something new when he can use a 2nd hand belt for £5.  . Is it for a late engine? |
no this is for the early XE/LET i didnt know what one he had got himself
byt the way dave we had rob rework the head ect and the car is being remapped this week so ill let you know how it all goes  |
16-01-2007, 14:58
#29 | | MIGClub Member
| Quote:
Originally Posted by japcav the car is being remapped this week so ill let you know how it all goes  | Cool, what ECU you running? |
16-01-2007, 15:03
#30 | | MIGWeb User
| Quote:
Originally Posted by Dave GSiT Cool, what ECU you running? |
normal GM one
although its am early astra GTE one ( no lambda sensor ) they will be using a dastek uni chip and then live mapping it  |
16-01-2007, 15:33
#31 | | MIGClub Member
| Dastek uni chip...... oh...... |
16-01-2007, 15:37
#32 | | MIGClub Member
Join Date: Jan 2002 Location: Braintree, Essex. Drives: Astra cabrio, Skoda
| Quote:
Originally Posted by japcav brian i have a new gm cam belt kit for sale my love
see my for sale thread or pm me | Hello Laura. I believe I have a late LET, so I dont think your belt kit will fit  Thanks for letting me know though.
And Dave, I cant re use the old kit, I had to cut the belt off.
__________________ MK III Astra 2.0l Turbo Cabriolet (Its sleeping for the winter) Landrover Discovery Skoda Otavia 2.0 Diesel Elegance BMW 330 Ci Sport Convertible |
16-01-2007, 15:39
#33 | | MIGClub Member
| What is the difference between Let cams and XE cams then?
Sorry for these questions, we've all got to learn somewhere.  |
16-01-2007, 16:06
#34 | | MIGClub Member
| Brian, seriously, staples cost about 0.0004p each. You could even buy a pack of 1000, use four or five, then hand the pack back for a refund! Thats a free cambelt! Quote: |
Originally Posted by Brian NOW THATS A BARGAIN! | Brian, Its really long winded, but XE's have a "more agressive" cam profile then LET's, think of them as stage 1. They have higher lift and duration etc etc then stock LET cams.
Turbo cam timing is so massivly different to N/A cams the mind just boggles. I dont think there is anyone on the planet that knows it all 100%.
General concensus (as I have done) is to use the XE inlet cam and stock LET cam. Inlet needs retarding 6 degrees to time properly though. |
16-01-2007, 16:14
#35 | | MIGWeb User
| Quote:
Originally Posted by Dave GSiT Dastek uni chip...... oh...... |
16-01-2007, 16:22
#36 | | MIGClub Member
| Quote:
Originally Posted by Dave GSiT Brian, seriously, staples cost about 0.0004p each. You could even buy a pack of 1000, use four or five, then hand the pack back for a refund! Thats a free cambelt!
And the retarding is done vai the Vernia pullys then? If I fitted both the XE cams with Vernia (Sp) pully's then and got them set up on a rolling road, that would be a couple of extra BHP? Especialy if I use the Ported Coscast head from the XE?
BARGAIN....  |
16-01-2007, 16:23
#37 | | MIGClub Member
16-01-2007, 16:24
#38 | | MIGClub Member
| What are you syaing Dave...  |
16-01-2007, 16:33
#39 | | MIGClub Member
| Quote:
Originally Posted by Brian Stirrup And the retarding is done vai the Vernia pullys then? If I fitted both the XE cams with Vernia (Sp) pully's then and got them set up on a rolling road, that would be a couple of extra BHP? Especialy if I use the Ported Coscast head from the XE?
BARGAIN....  | No mate it dosnt work quite like that. You only fit the Inlet due to the cam timing. |
16-01-2007, 16:33
#40 | | MIGClub Member
| Quote:
Originally Posted by Brian Stirrup What are you syaing Dave...  | Wouldnt touch it with a barge pole cos it stinks. |
16-01-2007, 16:36
#41 | | MIGClub Member
16-01-2007, 16:38
#42 | | MIGClub Member
| Brian, try here... Tuning the LET - Cams
But dont forget your ...  |
16-01-2007, 18:55
#43 | | MIGClub Member
Join Date: Sep 2003 Location: Colchester, Essex Drives: BMW 323i M Sport
| Quote:
Originally Posted by Brian Stirrup I have taken the crank to Rob (Engine builder for those who dont know him) and will drop the block and pistons to him later this week. I will be asking him to regrind and balance the crank (balanced with the flywheel and clutch) and check and rebuild a short block with new piston rings and a honing of the bores if nessersary. | Rob, as in our friendly romford mincer? Need to get my crank balanced too, what sort of cost are we looking at? Quote:
Originally Posted by Brian Stirrup The following bits will be for sale
Pair of schrick cams
Chipped ECU
Inlet manifold (Very clean)
Throttle body (Very clean) | Prices on all the above please matey, very, very interested in the cams.
__________________ Vauxhall Breaker, collects MOT Failures, Accident Damaged, Stolen Recovered PM me. Wanted - MK4 Astra GSi rear Bumper and Spoiler. PM Me. Astra GSi and Turbo Parts |
16-01-2007, 20:17
#44 | | MIGClub Member
| Quote:
Originally Posted by Dave GSiT | What a site.  Have been looking at it for an hour and still need to look at it when I get some peace to take it all in. Very imformative  |
16-01-2007, 20:21
#45 | | MIGClub Member
| Chris. This is Rob from Braintree. Not on MIG. He builds racing engines and Dave and Stefan in particular have become close freinds with him along with Dan and I to a lesser extent. Stef even works with him on a Saturday to get experience.
I will PM you some prices I am looking for those bits.  |
16-01-2007, 20:27
#46 | | Regional Co-ordinator
| May well be interested in the powercap matey.
__________________ Joint Winners Best Region Billing 2008 Eastern Region Coordinator |
16-01-2007, 22:34
#47 | | MIGClub Member
| OK mark. the red should go with your Calibra OK. Comes with a Red Hose and clips as well.
I have had a couple of Gin and Tonics while watching dan install his xenon headlights so not the right time to think of anything right now,  Wow, I should have used the measure, my head is nicely spinning.  |
16-01-2007, 23:29
#48 | | MIGClub Member
Join Date: Jul 2001 Location: Suffolk Drives: Vectra GSi & A4 1.8t
| Brian i will be interested in either head please. Preferably the stock bare LET one, but either is possible
__________________ DRIZZ
DEVELOPMENTS |
16-01-2007, 23:53
#49 | | MIGWeb User
Join Date: Mar 2002 Location: suffolk Drives: Corsa Tbo n Prelude
| Nice work brian your doing the same as me, my engine is in bits too.. having a refresh, you can have my old cambelt if you like its a late spec and is like new. lol
__________________ Bring back the power of LET |
17-01-2007, 09:20
#50 | | MIGClub Member
| Quote:
Originally Posted by Drizz Brian i will be interested in either head please. Preferably the stock bare LET one, but either is possible  | If it's bare mate... then its the same head lol |
Members: 43,212
Threads: 310,608
now!
of being a MIGClub Member.
