| homemade coilovers questions Has anybody used the coilover conversion kit from rally design to make a pair of front coilovers for an astra (mk1 using mk2 2.0 GSI struts)? It seems that the threaded tube will fit (I've measured my own struts). Which springs would I need to order and which top cap should I use? I would think I need the top caps with the 10mm pilot hole and drill to a larger size if necessary.
For the rear I've found a set of Golf 4 coilovers (thank you InsaneSwede for the advice)! |
