It looks well other than those wheels. lmao
Don't try to use the OE PAS pipes, they will eventually burn through on the manifold. lmao IIRC I used a 1.6 Mk3 Astra PAS pump and then did the tried and tested method of running a piece of string around the pulleys and measuring it - the length in mm's refer to which belt you need!
I assume your new business is something to do with ceramics by the van?![]()
