Page 7 of 39 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 151 to 175 of 972
Thread: InsaneSwede's Astra MKI
  1. #151
    Oct 2002
    Sweden
    Astra MkI
    I got to ask you on what basis do you base that on?
    The turbo can produce up against 690-700hp on regular fuel.
    that has been confirmed many times.
    and i´m running E85 and will probably stretch the capacity up against 700-720hp.
    But i´m not saying i will reach that amount of power.
    I´m happy with 600hp on 'low boost'
    my calculations is that i´ll be in the area of 600hp at 1,6-1,7bar.
    And the turbo is good for about 2.2bars before it runs out of effiency on my setup.
    That dyno paper earlier in thead is equipped with an GT3582r too and produces 656hp at 1,85bar.
    and calculated to reach 700 on 2.2bars.
    Garrett speces their turbos low...........
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
    Moderator Nobbie's Avatar
    Hemel Hempstead
    with blue lights
    Yeah thats my interpretations from the Garrett specs, and i'm sketchy on that too if truth be told.
  4. #153
    Nov 2005
    chester/n.wales
    evo 6 gsr
    one way to find out....rolling road printout, be better have an actual wheel hors power figure and not a flywheel number, as at end of day its about how many ponies are getting through the wheels
  5. #154
    Oct 2002
    Sweden
    Astra MkI
    This weekend there will be no work on the car.
    I´m working on the chimney in the house.
    Got to get the heating to work before winter.
    Maybe maybe i can find time to do something small tomorrow.
    Cheeeers lads..
    Kadett GT/E
  6. #155
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Quote Originally Posted by Nobbie View Post
    GT3520R .82 should see 400-600bhp.
    What bar are you lookiing at running it at, as the specs look like it wont be any good unless it get 1.3 bar min.
    You sure your looking at the right specs?
    It'll do about 62lb/min which is probably a tad conservative considering a few have been ran up recently and nothced 697 and 701 on 2.4/2.5 bar.
    "THE ROB"
  7. #156
    Hemel Hempstead
    with blue lights
    Apparently the turbo i'm looking atm 3571r is most efficient at 1.4 bar, so i need to reread my graphs, i've missed something.
  8. #157
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    A ha, problem solved.....your looking at the wrong turbolmao
    "THE ROB"
  9. #158
    Hemel Hempstead
    with blue lights
    Yep thats about it, i've looked at so many i'd confused myself. I was looking at the 3571R, but was also looking at the 3582R, not only does it look like a better spec, it is oil and water cooled.
  10. #159
    Oct 2002
    Sweden
    Astra MkI
    here are some pics of some pipework i did today:
    getting closer
    Kadett GT/E
  11. #160
    Nov 2004
    Oslo, Norway
    Nice work, where's the throttlebody going to be intalled?
  12. #161
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by Classic View Post
    Its installed in those pic's.
    Back in the scene
  13. #162
    Nov 2004
    Oslo, Norway
    aiii, can see the pully for the butterfly now, on the middle picture.
    was looking for a original opel item at first, hehe
  14. #163
    Mar 2004
    whitby
    single turbo rx7
    what is that on the right hand side inner arch/chassic leg?? some sort of pump. oil, water, p/s??
    no cam belt backing plate either
    i miss my vauxhalls breaking down
  15. #164
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by astragsi View Post
    Hi..
    It´s the fuelpump you can see.
    and i have a soultion for the cambeltcover.
    I will make an 'spiess' coverplate between the pulleys.
    some pics:
    fuel pump and trigger mounted:
    Fuel pump from above:
    Cambelt went on:
    Kadett GT/E
  16. #165
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Mr InsaneSwede, ive not seen a fuel pump like that on a petrol before....thats quite interesting that is
    Why not a elec pump then?
    Do you massive amounts of pressure when using E85?
    And on another note....the vaux txb setup(if not locked) has the fluid pump, accumulator and all the stuff to go with, does the toyota has a similar system? If not then what does it have?
    CheeRS
    "THE ROB"
  17. #166
    Oct 2002
    Sweden
    Astra MkI
    Hi Rs1
    I want the safety of an mechanical pump.
    if engine stops, fuelpump stops.
    and then it´s got massive capacity, i do not need to worry
    The toyota gearbox have an mechanical centerdiff with an viscous coupling that 'brakes' it.
    It´s got full 50/50 drive at all times.
    But there are a small lever that changes between:
    1 front wheel drive only
    2 open centerdiff (4wd)
    3 'braked' centerdiff(4wd)
    the option number two is quite unuseful, as the moment can shift between front and rear.
    But can be very useful if i upgrade the visco to brake even harder.
    Rgds
    Kadett GT/E
  18. #167
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Ah, a centre diff aswell...hmm thats getting a little to complicated for me now lmao
    I wish i'd never seen this thread, i want 4wd
    "THE ROB"
  19. #168
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    spanner on fresh paint!!
  20. #169
    Hemel Hempstead
    with blue lights
    Not sure i'm liking the idea of a mechinical pump. With the electric pump it will only be on when the ignition is turned on, to pressurise, and then it will pump when it see's throttle/cold start map.
  21. #170
    Jan 2005
    Newport
    Focus LX
    But this way prevents the pump from not recieving full voltage due to damaged/corroded ends, no place for a voltage drop.
  22. #171
    Mar 2004
    whitby
    single turbo rx7
    you will only get damaged or corroded ends because the wires are old and tatty, im sure if he rebuilding a car like this, or any one would replace such wires with new items.
    so is the alternator driven of that pulley are well??
  23. #172
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by The Simps View Post
    It´s not an trailerqueen,,, it´s ment to be abused hard....
    Kadett GT/E
  24. #173
    Oct 2002
    Sweden
    Astra MkI
    And one more advantage of my pump setup to bear in mind:
    There are no good quality pumps on the market that can produce the flow i´m after in a single setup.
    this one flows a liiiiitle bit more than i need.. but who cares?
    about 2000hp and 200psi
    Kadett GT/E
  25. #174
    Hemel Hempstead
    with blue lights
    lmao, so room for expansion then!!.
    I would have thought a Bosch 044, 200LPH@5bar, would cut it though.
  26. #175
    Oct 2002
    Sweden
    Astra MkI
    No a single 044 won´t keep up with my 1680cc injectors.
    If you look at the pressure regulator, it´s an Aeromotive, this one has quite small outer measurements.
    But can flow all the '2000hp' back to the fueltank.
    The pipes will have to be 1/2" in inner diam too.
    This might be a secret to high powerlevels..
    DO NOT TAKE ANY CHANCES ON FUELSYSTEMS!
    And as i´m running 'alcohol' as fuel i need ~40% extra capacity against petrol, i got to go big
    Kadett GT/E
  1. 06-02-2012, 15:20
  2. 30-01-2012, 00:34
  3. 29-01-2012, 23:45
  4. 28-01-2012, 21:31
  5. 27-01-2012, 22:23
  6. 27-01-2012, 00:32
  7. 11-12-2011, 12:42
  8. 10-12-2011, 22:43
  9. 10-12-2011, 22:43
  10. 10-12-2011, 22:02
  11. 10-12-2011, 21:41
  12. 10-12-2011, 20:14
  13. 10-12-2011, 18:11
  14. 10-12-2011, 00:06
  15. 09-12-2011, 20:47
  16. 09-12-2011, 20:04
  17. 09-12-2011, 17:55
  18. 09-12-2011, 16:33
  19. 09-12-2011, 08:48
  20. 06-12-2011, 21:35
  21. 03-12-2011, 23:06
  22. 10-11-2011, 20:01
  23. 08-11-2011, 23:39
  24. 01-11-2011, 00:39
  25. 27-10-2011, 11:09
  26. 27-10-2011, 10:20
  27. 25-10-2011, 23:33
  28. 24-10-2011, 09:39
  29. 23-10-2011, 21:43
  30. 23-10-2011, 21:43
  31. 21-10-2011, 21:14
  32. 02-10-2011, 21:17
  33. 02-10-2011, 20:51
  34. 17-09-2011, 20:32
  35. 28-06-2011, 00:36
  36. 09-06-2011, 20:33
  37. 08-06-2011, 18:45
  38. 02-06-2011, 17:02
  39. 01-06-2011, 16:47
  40. 28-05-2011, 16:33
  41. 22-05-2011, 09:37
  42. 22-05-2011, 09:37
  43. 21-05-2011, 19:26
  44. 20-05-2011, 22:10
  45. 19-05-2011, 16:50
  46. 17-05-2011, 09:57
  47. 10-05-2011, 00:49
  48. 09-05-2011, 21:00
  49. 10-04-2011, 21:58
  50. 27-03-2011, 22:43
  51. 21-02-2011, 00:23
  52. 14-02-2011, 18:19
  53. 05-02-2011, 16:32
  54. 29-01-2011, 19:08
  55. 24-01-2011, 14:05
  56. 13-01-2011, 20:17
  57. 25-12-2010, 09:26
  58. 30-11-2010, 08:48
  59. 14-11-2010, 01:07
  60. 29-10-2010, 13:14
  61. 07-10-2010, 11:21
  62. 03-10-2010, 13:29
  63. 08-09-2010, 19:17
  64. 02-09-2010, 20:10
  65. 01-09-2010, 14:09
  66. 14-07-2010, 23:50
  67. 14-07-2010, 12:19
  68. 11-07-2010, 18:12
  69. 08-06-2010, 19:40
  70. 24-05-2010, 20:34
  71. 16-05-2010, 21:22
  72. 25-04-2010, 08:20
  73. 21-04-2010, 17:31
  74. 15-04-2010, 23:25
  75. 12-03-2010, 08:14
  76. 09-03-2010, 18:28
  77. 02-03-2010, 10:11
  78. 27-02-2010, 21:45
  79. 17-02-2010, 18:45
  80. 12-02-2010, 22:20
  81. 06-02-2010, 20:07
  82. 02-02-2010, 16:04
  83. 01-02-2010, 16:23
  84. 29-01-2010, 12:39
  85. 24-01-2010, 08:08
  86. 20-01-2010, 12:13
  87. 18-01-2010, 16:50
  88. 12-01-2010, 04:00
  89. 05-01-2010, 20:40
  90. 20-11-2009, 12:36
  91. 18-11-2009, 16:11
  92. 05-11-2009, 18:49
  93. 01-11-2009, 17:37
  94. 26-10-2009, 21:08
  95. 20-10-2009, 10:22
  96. 02-08-2009, 21:07
  97. 20-07-2009, 18:18
  98. 15-07-2009, 21:00
  99. 09-07-2009, 21:46
  100. 06-07-2009, 19:15
  101. 01-07-2009, 05:10
  102. 28-06-2009, 13:01
  103. 21-06-2009, 21:52
  104. 13-06-2009, 14:51
  105. 13-06-2009, 12:20
  106. 13-06-2009, 08:01
  107. 13-06-2009, 07:38
  108. 13-06-2009, 06:36
  109. 13-06-2009, 06:16
  110. 13-06-2009, 05:34
  111. 07-06-2009, 18:52
  112. 02-06-2009, 23:27
  113. 30-05-2009, 18:36
  114. 28-05-2009, 22:27
  115. 27-05-2009, 19:22
  116. 25-05-2009, 17:09
  117. 24-05-2009, 14:39
  118. 20-05-2009, 14:20
  119. 19-05-2009, 10:44
  120. 19-05-2009, 07:18
  121. 18-05-2009, 20:50
  122. 18-05-2009, 18:59
  123. 17-05-2009, 17:49
  124. 10-05-2009, 14:24
  125. 06-05-2009, 15:00
  126. 29-04-2009, 14:05
  127. 19-04-2009, 20:37
  128. 15-04-2009, 16:03
  129. 13-04-2009, 10:44
  130. 10-04-2009, 07:41
  131. 06-04-2009, 17:35
  132. 31-03-2009, 23:55
  133. 31-03-2009, 22:11
  134. 27-03-2009, 21:02
  135. 26-03-2009, 22:17
  136. 19-03-2009, 14:35
  137. 14-03-2009, 17:16
  138. 11-03-2009, 03:52
  139. 10-03-2009, 13:42
  140. 09-03-2009, 23:52
  141. 09-03-2009, 01:48
  142. 08-03-2009, 10:39
  143. 04-03-2009, 14:51
  144. 03-03-2009, 08:35
  145. 02-03-2009, 14:31
  146. 27-02-2009, 22:04
  147. 27-02-2009, 11:17
  148. 23-02-2009, 17:49
  149. 22-02-2009, 16:46
  150. 22-02-2009, 10:54
  151. 22-02-2009, 10:32
  152. 21-02-2009, 20:19
  153. 21-02-2009, 20:16
  154. 18-02-2009, 02:18
  155. 16-02-2009, 19:21
  156. 16-02-2009, 17:55
  157. 13-02-2009, 19:59
  158. 09-02-2009, 20:28
  159. 09-02-2009, 18:53
  160. 09-02-2009, 12:48
  161. 09-02-2009, 12:48
  162. 08-02-2009, 15:22
  163. 06-02-2009, 13:24
  164. 04-02-2009, 14:57
  165. 03-02-2009, 10:56
  166. 29-01-2009, 21:14
  167. 25-01-2009, 15:28
  168. 17-01-2009, 21:10
  169. 13-01-2009, 15:15
  170. 07-01-2009, 12:07
  171. 03-01-2009, 11:49
  172. 30-12-2008, 12:20
  173. 27-12-2008, 16:39
  174. 26-12-2008, 04:02
  175. 22-12-2008, 19:40
  176. 22-12-2008, 17:13
  177. 22-12-2008, 16:26
  178. 22-12-2008, 13:04
  179. 22-12-2008, 13:04
  180. 20-12-2008, 15:34
  181. 13-12-2008, 19:25
  182. 01-12-2008, 14:38
  183. 30-11-2008, 17:32
  184. 29-11-2008, 19:52
  185. 24-11-2008, 06:47
  186. 23-11-2008, 10:20
  187. 23-11-2008, 09:56
  188. 20-11-2008, 06:50
  189. 19-11-2008, 08:55
  190. 05-11-2008, 22:18
  191. 03-11-2008, 17:27
  192. 02-11-2008, 10:39
  193. 28-10-2008, 00:15
  194. 26-10-2008, 20:11
  195. 19-10-2008, 12:34
  196. 11-10-2008, 16:48
  197. 30-09-2008, 19:41
  198. 29-09-2008, 19:01
  199. 28-09-2008, 21:58
  200. 25-09-2008, 23:14
  201. 19-09-2008, 19:35
  202. 14-09-2008, 08:14
  203. 13-09-2008, 19:55
  204. 12-09-2008, 19:32
  205. 11-09-2008, 19:45
  206. 11-09-2008, 19:04
  207. 05-09-2008, 20:55
  208. 02-09-2008, 19:17
  209. 30-08-2008, 23:05
  210. 18-08-2008, 21:11
  211. 31-07-2008, 19:01
  212. 30-07-2008, 13:12
  213. 09-07-2008, 02:13
  214. 08-07-2008, 21:08
  215. 07-07-2008, 21:48
  216. 29-06-2008, 10:22
  217. 16-06-2008, 21:28
  218. 15-06-2008, 21:15
  219. 15-06-2008, 15:07
  220. 14-06-2008, 17:08
  221. 27-05-2008, 18:32
  222. 25-05-2008, 19:36
  223. 20-05-2008, 18:43
  224. 20-05-2008, 18:06
  225. 19-05-2008, 23:59
  226. 19-05-2008, 01:08
  227. 15-05-2008, 11:35
  228. 13-05-2008, 13:05
  229. 13-05-2008, 12:39
  230. 10-05-2008, 18:50
  231. 05-05-2008, 18:20
  232. 03-05-2008, 21:13
  233. 01-05-2008, 08:30
  234. 27-04-2008, 21:13
  235. 24-04-2008, 16:18
  236. 22-04-2008, 11:57
  237. 21-04-2008, 20:25
  238. 19-04-2008, 14:28
  239. 17-04-2008, 15:08
  240. 14-04-2008, 20:12
  241. 12-04-2008, 19:12
  242. 11-04-2008, 18:16
  243. 11-04-2008, 16:52
  244. 10-04-2008, 18:57
  245. 08-04-2008, 20:00
  246. 08-04-2008, 12:18
  247. 08-04-2008, 11:37
  248. 07-04-2008, 09:17
  249. 07-04-2008, 07:51
  250. 06-04-2008, 21:43
  251. 06-04-2008, 21:12
  252. 06-04-2008, 20:01
  253. 06-04-2008, 13:44
  254. 06-04-2008, 08:56
  255. 04-04-2008, 15:57
  256. 30-03-2008, 14:05
  257. 30-03-2008, 11:23
  258. 21-03-2008, 19:35
  259. 20-03-2008, 10:45
  260. 18-03-2008, 20:30
  261. 17-03-2008, 14:06
  262. 10-03-2008, 16:30
  263. 10-03-2008, 09:39
  264. 08-03-2008, 14:23
  265. 07-03-2008, 19:13
  266. 06-03-2008, 20:56
  267. 06-03-2008, 20:55
  268. 04-03-2008, 21:13
  269. 03-03-2008, 11:38
  270. 01-03-2008, 07:33
  271. 29-02-2008, 13:36
  272. 29-02-2008, 11:32
  273. 29-02-2008, 08:56
  274. 27-02-2008, 17:32
  275. 26-02-2008, 17:59
  276. 25-02-2008, 19:44
  277. 24-02-2008, 05:39
  278. 23-02-2008, 20:14
  279. 23-02-2008, 13:53
  280. 23-02-2008, 10:59
  281. 23-02-2008, 09:07
  282. 22-02-2008, 05:03
  283. 19-02-2008, 12:47
  284. 18-02-2008, 10:39
  285. 15-02-2008, 14:24
  286. 11-02-2008, 01:10
  287. 10-02-2008, 17:17
  288. 09-02-2008, 22:08
  289. 08-02-2008, 05:54
  290. 07-02-2008, 16:42
  291. 06-02-2008, 19:28
  292. 06-02-2008, 17:37
  293. 06-02-2008, 17:04
  294. 06-02-2008, 16:04
  295. 06-02-2008, 15:05
  296. 05-02-2008, 14:31
  297. 03-02-2008, 16:53
  298. 31-01-2008, 19:38
  299. 27-01-2008, 16:44
  300. 26-01-2008, 21:40
  301. 26-01-2008, 16:13
  302. 25-01-2008, 21:39
  303. 24-01-2008, 20:04
  304. 24-01-2008, 06:50
  305. 24-01-2008, 05:59
  306. 23-01-2008, 22:49
  307. 23-01-2008, 22:35
  308. 23-01-2008, 22:34
  309. 23-01-2008, 22:17
  310. 23-01-2008, 22:10
  311. 23-01-2008, 22:09
  312. 23-01-2008, 22:05
  313. 21-01-2008, 20:42
  314. 21-01-2008, 19:43
  315. 20-01-2008, 13:55
  316. 20-01-2008, 11:53
  317. 17-01-2008, 10:10
  318. 17-01-2008, 01:01
  319. 16-01-2008, 21:42
  320. 16-01-2008, 20:59
  321. 16-01-2008, 19:48
  322. 16-01-2008, 19:24
  323. 16-01-2008, 18:36
  324. 15-01-2008, 06:51
  325. 14-01-2008, 15:32
  326. 14-01-2008, 15:02
  327. 13-01-2008, 09:40
  328. 10-01-2008, 18:54
  329. 09-01-2008, 11:47
  330. 09-01-2008, 08:46
  331. 08-01-2008, 14:11
  332. 08-01-2008, 12:31
  333. 08-01-2008, 00:03
  334. 07-01-2008, 19:13
  335. 07-01-2008, 18:21
  336. 07-01-2008, 10:28
  337. 06-01-2008, 19:16
  338. 06-01-2008, 00:18
  339. 05-01-2008, 22:35
  340. 04-01-2008, 20:06
  341. 02-01-2008, 18:36
  342. 01-01-2008, 17:49
  343. 01-01-2008, 08:29
  344. 31-12-2007, 13:03
  345. 31-12-2007, 11:46
  346. 31-12-2007, 11:46
  347. 30-12-2007, 20:47
  348. 30-12-2007, 20:43
  349. 30-12-2007, 20:40
  350. 30-12-2007, 20:07
  351. 30-12-2007, 19:56
  352. 30-12-2007, 14:07
  353. 30-12-2007, 01:59
  354. 29-12-2007, 14:22
  355. 29-12-2007, 13:49
  356. 27-12-2007, 16:43
  357. 26-12-2007, 20:34
  358. 26-12-2007, 16:59
  359. 26-12-2007, 16:37
  360. 21-12-2007, 18:52
  361. 21-12-2007, 08:57
  362. 20-12-2007, 01:37
  363. 19-12-2007, 08:20
  364. 18-12-2007, 17:11
  365. 18-12-2007, 11:26
  366. 17-12-2007, 13:34
  367. 16-12-2007, 10:15
  368. 16-12-2007, 07:43
  369. 15-12-2007, 15:05
  370. 14-12-2007, 19:52
  371. 14-12-2007, 14:15
  372. 14-12-2007, 10:54
  373. 13-12-2007, 22:34
  374. 13-12-2007, 17:49
  375. 13-12-2007, 17:12
  376. 13-12-2007, 15:52
  377. 13-12-2007, 15:46
  378. 13-12-2007, 15:13
  379. 13-12-2007, 14:33
  380. 13-12-2007, 14:31
  381. 13-12-2007, 14:20
  382. 12-12-2007, 11:49
  383. 11-12-2007, 15:14
  384. 07-12-2007, 11:42
  385. 02-12-2007, 10:56
  386. 01-12-2007, 10:40
  387. 30-11-2007, 12:24
  388. 29-11-2007, 14:09
  389. 19-11-2007, 10:11
  390. 15-11-2007, 19:37
  391. 15-11-2007, 13:04
  392. 15-11-2007, 10:38
  393. 14-11-2007, 19:17
  394. 14-11-2007, 09:19
  395. 13-11-2007, 10:54
  396. 13-11-2007, 02:10
  397. 12-11-2007, 20:09
  398. 08-11-2007, 15:41
  399. 08-11-2007, 12:22
  400. 04-11-2007, 17:04
  401. 30-10-2007, 22:08
  402. 24-10-2007, 02:29
  403. 23-10-2007, 19:49
  404. 23-10-2007, 18:56
  405. 23-10-2007, 12:29
  406. 21-10-2007, 21:29
  407. 21-10-2007, 15:01
  408. 21-10-2007, 11:44
  409. 20-10-2007, 17:47
  410. 20-10-2007, 17:27
  411. 20-10-2007, 17:00
  412. 20-10-2007, 10:15
  413. 20-10-2007, 09:20
  414. 19-10-2007, 21:14
  415. 19-10-2007, 17:52
  416. 19-10-2007, 14:37
  417. 19-10-2007, 13:34
  418. 19-10-2007, 11:36
  419. 19-10-2007, 11:17
  420. 19-10-2007, 10:26
  421. 18-10-2007, 21:15
  422. 18-10-2007, 20:42
  423. 18-10-2007, 20:16
  424. 18-10-2007, 20:12
  425. 18-10-2007, 20:08
  426. 18-10-2007, 19:52
  427. 18-10-2007, 19:51
  428. 18-10-2007, 19:48
  429. 18-10-2007, 19:48
  430. 12-10-2007, 06:48
  431. 06-10-2007, 09:45
  432. 28-09-2007, 20:52
  433. 27-09-2007, 08:42
  434. 24-09-2007, 17:51
  435. 23-09-2007, 22:10
  436. 23-09-2007, 22:08
  437. 17-09-2007, 17:39
  438. 17-09-2007, 13:24
  439. 17-09-2007, 12:20
  440. 17-09-2007, 12:10
  441. 17-09-2007, 09:49
  442. 17-09-2007, 09:11
  443. 17-09-2007, 09:09
  444. 17-09-2007, 00:41
  445. 17-09-2007, 00:30
  446. 17-09-2007, 00:07
  447. 21-08-2007, 19:14
  448. 21-08-2007, 18:59
  449. 20-08-2007, 22:46
  450. 20-08-2007, 14:05
  451. 17-08-2007, 15:59
  452. 17-08-2007, 15:30
  453. 23-01-2007, 20:46
