Advertise Here - Click for More Info
LinkBack (379) Thread Tools
Old 17-08-2007, 13:20   #126
The Simps
Drives: Nova Coupe
Originally Posted by Jack View Post
I want to move to Sweden.
It really is so unfair isn't it. Not only do they have all the mental cars but they have all the lovely blondes who want to be naked all the time!
The Simps is offline   Reply With Quote
Old 17-08-2007, 13:23   #127
foreverwhite
Gagged
Drives: foreverwhite.co.uk
holy schmoke batman.
intercooler looks like something from a refrigerated articulated lorry.
loving the oil cooler, such an effective position, such a good use of space...
MIGweb mobile phone/teeth whitening expert.
foreverwhite is offline   Reply With Quote
Old 17-08-2007, 14:28   #128
Nobbie
Central Regional Coordinator / Moderator
Nobbie's Avatar
Drives: Mk3 Astra GSi XE
Originally Posted by masch.tab View Post
It's a mk1 Astra!!!
Amazing work by the way.
I know, i was refering to other tight engine bays.
Good going on the turbo, maybe you could duct air from around the turbo for a heater, then save weight by not having a heater matrix, etc, lol.
Central Region Co-ordinator
Central Region Forums/Events
Nobbie is offline   Reply With Quote
Old 17-08-2007, 16:38   #129
stuartp
Drives: 2 many 2 list
Just said and read near on all this tread and trust me its hard with dyslexia.
Absalutly amazing mate i want a mk1 just made 5 phone calls trying to source a shell so i can start it in 6 years.lol
top work dude.
stu
stuartp is offline   Reply With Quote
Old 17-08-2007, 18:47   #130
InsaneSwede
Drives: Astra MkI
top work dude.
stu
hehe,, it´s harder to not have english as motherlanguage than dyslexia
I´m trying my very best.
MkI is the **** you know...
a pic:
Started to look for my 'bearings' my my camshafts, couldn´t locate them.
So i looked in my scrapbox and found a lot of others.
took me 3 hours to get the cams to spin freely...
also did some measuring on valve heights,, they are a couple of tenth´s off alignment.
Maybe the hydraulic tappets 'swollow' it?
as most 0.5mm to high, that one i´ll grind off a little thou.
I´ll call Enem in Sweden to hear what 'Janne Carneborn' has to say about it.
Have a nice one mates,,,
Kadett GT/E
Sometimes you are the bug
sometimes you are the windsheild
InsaneSwede is offline   Reply With Quote
Old 18-08-2007, 07:38   #131
InsaneSwede
Drives: Astra MkI
And,, don´t worry guys about the 'play' in the bearings.
I tested them all with Plastiguage to get them correct.
rgds
Old 18-08-2007, 08:00   #132
gatecrasher3
Drives: GT
Only just stumbled across this thread. What a fantastic project. MK1 Astra on of my favourite Vauxhalls ever.
gatecrasher3 is offline   Reply With Quote
Old 18-08-2007, 19:56   #133
leesturbo
Drives: 1.4bar = 356bhp :-)
not too far away now really. will come together quite quick
with just top end work/pipework and some electrics
leesturbo is offline   Reply With Quote
Old 23-08-2007, 21:14   #134
InsaneSwede
Drives: Astra MkI
Hi guys,,
the head is complete now as we speak.
Will recive the headgasket on saturday.
HAven´t got any new pics right now.
but i´ll take som in the weekend.
Finally i´m about to bolt the head on for good.(i hope)
in these quiet days from me i have lapped in the valves in the head and got the heights on the valves adjusted, all this,, 'takingmuchtimeandalmostnoworkdone' work is done
Rgds
Patrick
Old 24-08-2007, 09:04   #135
Nobbie
Nobbie's Avatar
Class, its good to know i'm not the only one who tried not to rush the last bit, so many people come unstuck in their egerness to complete.
I say take your time, build it once!
Old 24-08-2007, 10:42   #136
leesturbo
are dynoing the engine or rolling road or just a asre dyno?
Old 24-08-2007, 21:42   #137
Quarterless
Drives: Mk1 Escort
Great project is it 650bhp you are aiming for? HAve you got any more info on your block? Which model Frontera is it from? where can I find out more about its short comings? Does it come with the girdle as standard?
Thanks
James
Quarterless is offline   Reply With Quote
Old 26-08-2007, 13:28   #138
InsaneSwede
Drives: Astra MkI
Exactly,, it has also become much money involved.
Dont want to ruin all that with eager to get it done.
it´s done when it´s done...
Rgds
Old 26-08-2007, 13:29   #139
InsaneSwede
Drives: Astra MkI
Probably engine Dyno.
or else it´ll be Rolling road.
Here in sweden we call 'arse dyno'..... BUTT DYNO *lol*
Old 26-08-2007, 13:37   #140
InsaneSwede
Drives: Astra MkI
Thanks
James
Hi James, Thanks for the words.
I´m aiming for 600+ and 650+ is only a bonus.
It´s not equipped with an girdle as standard.
honestly,, if my calculations are correct it will sniff on 700hp,, but,, something can be totally wrong although i don´t think so.
I flowed a head to an Audi 3b this winter.
That engine has the same setup as mine only a cylinder more and little bit less volume.
It has the most greatest curve i´ve ever seen on an Audi 20v engine, those ones uses to rev like bitches and no boost under 5000rpm..
This one has full boost at 3500rpm´s and got full power at slightly underneeth 7000rpm.
Almost like an std engine but really really pissed off.
little info about that Audi:
1.85bars of boost(they got problem with amalvalve) should have got´n closer to 700hp with 2,1-2,2bars of boost.
Fullboost at 3500rpm(locked on dyno)
Fullboost at 4000rpm(simulated run on dyno)
With this engine we aimed for 600+,, you could say we had a little bonus...
Rgds
Patrick
Old 26-08-2007, 13:56   #141
InsaneSwede
Drives: Astra MkI
Here´s a couple of pics..
an uprated Z20LET gastket:
uprated headstuds: (M12x100mm torqued to 115Nm)
And modified exhaustcam for distributorless ignition:
Head had been bolted on and now the manufacturing takes place for the manifold and all the tubing,, the fun stuff
all bearings and guides has been lubricated with Redline 'break in oil'
Cheers
Old 27-08-2007, 08:59   #142
astragsi
Drives: single turbo rx7
good stuff. there must be some crazy powered cars over there?? we need vids
i miss my vauxhalls breaking down
astragsi is offline   Reply With Quote
Old 27-08-2007, 10:50   #143
leesturbo
the torque curve on that graph is awesome
god dam that is train pulling teritory.
Old 27-08-2007, 21:24   #144
InsaneSwede
Drives: Astra MkI
here´s a movie from cockpit of the blue astra MkII i posted pics on earlier.
http://www.youtube.com/watch?v=9Z3S7kTjd9s
hold on to your speakers...
at 5th gear they are in about~125Mph.. quite fast astra...
Old 28-08-2007, 00:27   #145
elgan
Drives: Project Nova GLF
outstanding.
love the way youve got a huge turbo, a radiator, oil cooler and massive intercooler behind the std bumper carrier!
Nova GLF 2006... Coming Soon
elgan is offline   Reply With Quote
Old 29-08-2007, 17:15   #146
InsaneSwede
Drives: Astra MkI
Elgan:
Cool you notice the work..
It took some time to sort things out.
and it wasn´t cheap either.
new turbo, new IC, new oilcooler
but well worth the money as i got a lot cooler turbo now
Old 29-08-2007, 18:10   #147
2.2DTIdarryl
Drives: 92 Astra GSI 2.0 16V
WOW.... that sound the nuts
GSI ..... now gone. it will be sadly missed.
2.2DTIdarryl is offline   Reply With Quote
Old 30-08-2007, 08:03   #148
InsaneSwede
Drives: Astra MkI
Finally..
one of theese in A/R 0.82 is heading my way,about 2 weeks until arrival.
Old 30-08-2007, 15:32   #149
philip2
Drives: class 7 corsa;)
that sounds mint, what spec of the motor in the mk2??
work looks very well too on the mk1, should be good see some vids of that
philip2 is offline   Reply With Quote
Old 30-08-2007, 16:01   #150
Nobbie
Nobbie's Avatar
GT3520R .82 should see 400-600bhp.
What bar are you lookiing at running it at, as the specs look like it wont be any good unless it get 1.3 bar min.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/293172-insaneswedes-astra-mki.html
Posted By For Type Date
MK1 Astra Owners Club :: View topic - Long time ago since login. This thread Refback 12-03-2010 08:14
Ready to hit the street´s - Sida 2 - Opel Sport Club This thread Refback 09-03-2010 18:28
Ready to hit the street´s - Sida 2 - Opel Sport Club This thread Refback 02-03-2010 10:11
Opel-Forum - Powered by XMB This thread Refback 27-02-2010 21:45
:: Team Calibra 026 :: - Ver Tema - colectores de admision artesanales This thread Refback 17-02-2010 18:45
:: Team Calibra 026 :: - Ver Tema - colectores de admision artensalales This thread Refback 12-02-2010 22:20
2.2 & 2.4 XE Rally Engines This thread Refback 06-02-2010 20:07
först i år med racebilen? - Sida 2 - Opel Sport Club This thread Refback 02-02-2010 16:04
MK1 Astra Owners Club :: View topic - 4x4 help Glenn and Ant B This thread Refback 01-02-2010 16:23
jogr - Opel Kadett GSi Type-R - Sidan 6 - zatzy.com This thread Refback 29-01-2010 12:39
jogr - Opel Kadett GSi Type-R - Sidan 41 - zatzy.com This thread Refback 24-01-2010 08:08
C20LET-Forum :: Thema anzeigen - Kadett D GT35 AWD ?? This thread Refback 20-01-2010 12:13
• Temos rodymas - Projektai-Opel ... This thread Refback 18-01-2010 16:50
Der Opel-Sechser Talk • Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 12-01-2010 04:00
Opel Tuning : super Kadett - Page 4 - 4TuningRO This thread Refback 05-01-2010 20:40
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 20-11-2009 12:36
Opel Calibra Club :: Ïðîñìîòð òåìû - Ñöåïëåíèå ê F28 This thread Refback 18-11-2009 16:11
C20LET-Forum :: Thema anzeigen - Leistungfähigkeit LET-Saugrohr This thread Refback 05-11-2009 18:49
Laatste bericht van: don diégo(voorheen vaya con dios) This thread Refback 01-11-2009 17:37
D-Kadett 700+ pk!!!!! hoe bedoel je extreem.... This thread Refback 26-10-2009 20:08
???????? ???? ????? ??????? ??????? ??????????!? - ????????? ? ??????????? - ????? ?????? - 5k Customs ????? This thread Refback 20-10-2009 09:22
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 02-08-2009 20:07
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 20-07-2009 17:18
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 15-07-2009 20:00
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 09-07-2009 20:46
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 06-07-2009 18:15
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 01-07-2009 04:10
Kp un slp :: Apskatt tematu - interesanti projekti. This thread Refback 28-06-2009 12:01
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 21-06-2009 20:52
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 13:51
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 11:20
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 07:01
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 06:38
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 05:36
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 05:16
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 04:34
• Temos rodymas - Projektai-Opel ... This thread Refback 07-06-2009 17:52
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 02-06-2009 22:27
• Temos rodymas - Projektai-Opel ... This thread Refback 30-05-2009 17:36
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 28-05-2009 21:27
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 27-05-2009 18:22
• Temos rodymas - Projektai-Opel ... This thread Refback 25-05-2009 16:09
• Temos rodymas - Projektai-Opel ... This thread Refback 24-05-2009 13:39
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 20-05-2009 13:20
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 19-05-2009 09:44
• Temos rodymas - Projektai-Opel ... This thread Refback 19-05-2009 06:18
• Temos rodymas - Projektai-Opel ... This thread Refback 18-05-2009 19:50
• Temos rodymas - Projektai-Opel ... This thread Refback 18-05-2009 17:59
• Temos rodymas - Projektai-Opel ... This thread Refback 17-05-2009 16:49
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 10-05-2009 13:24
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 06-05-2009 14:00
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 29-04-2009 13:05
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 19-04-2009 19:37
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 15-04-2009 15:03
Calibra Club Estonia This thread Refback 13-04-2009 09:44
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 10-04-2009 06:41
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-04-2009 16:35
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 31-03-2009 22:55
Calibra Club Estonia This thread Refback 31-03-2009 21:11
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 27-03-2009 20:02
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 26-03-2009 21:17
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 19-03-2009 13:35
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 14-03-2009 16:16
OldSchoolAuto • Temos rodymas - Projektai-Opel ... This thread Refback 11-03-2009 02:52
Volvo Engine Swap, Volvo Diesel Engines, Volvo Front Grill - Avantirh1500S This thread Refback 10-03-2009 12:42
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 09-03-2009 22:52
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 09-03-2009 00:48
Serpentine Belt Diagram 95 Plymouth Voyager, Serpentine Belt Diagram 2000 Bmw 528I 6 Cyl, Serpentine Belt Diagram Caravan - Bmwhouston This thread Refback 08-03-2009 09:39
OldSchoolAuto • Temos rodymas - Projektai-Opel ... This thread Refback 04-03-2009 14:51
OldSchoolAuto • Temos rodymas - Projektai-Opel ... This thread Refback 03-03-2009 08:35
OldSchoolAuto • Temos rodymas - kadett D This thread Refback 02-03-2009 14:31
OldSchoolAuto • Temos rodymas - kadett D This thread Refback 27-02-2009 22:04
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-02-2009 11:17
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 23-02-2009 17:49
OldSchoolAuto • Temos rodymas - kadett D This thread Refback 22-02-2009 16:46
OldSchoolAuto • Temos rodymas - kadett D This thread Refback 22-02-2009 10:54
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 22-02-2009 10:32
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 21-02-2009 20:19
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 21-02-2009 20:16
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 18-02-2009 02:18
[C20XE] Admision - clubGSIspain This thread Refback 16-02-2009 19:21
[C20XE] Admision - clubGSIspain This thread Refback 16-02-2009 17:55
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 13-02-2009 19:59
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 09-02-2009 20:28
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 09-02-2009 18:53
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 09-02-2009 12:48
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 08-02-2009 15:22
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-02-2009 13:24
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 04-02-2009 14:57
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 03-02-2009 10:56
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 29-01-2009 21:14
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 25-01-2009 15:28
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 17-01-2009 21:10
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-01-2009 15:15
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 07-01-2009 12:07
MK1 Astra Owners Club :: View topic - Astra MKI from Sweden with 4x4 and a lot of grunt This thread Refback 03-01-2009 11:49
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 30-12-2008 12:20
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 27-12-2008 16:39
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-12-2008 04:02
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 19:40
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 17:13
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 16:26
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 22-12-2008 13:04
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-12-2008 15:34
Alice - Rechercher VIDEOS CALIBRA 700CV This thread Refback 13-12-2008 19:25
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 01-12-2008 14:38
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 30-11-2008 17:32
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 29-11-2008 19:52
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 24-11-2008 06:47
Opel-Forum - Powered by XMB This thread Refback 23-11-2008 10:20
Opel-Forum - Powered by XMB This thread Refback 23-11-2008 09:56
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-11-2008 06:50
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 19-11-2008 08:55
Calibra Club Estonia This thread Refback 05-11-2008 22:18
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 03-11-2008 17:27
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 02-11-2008 10:39
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-10-2008 23:15
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-10-2008 19:11
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 19-10-2008 11:34
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 11-10-2008 15:48
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 30-09-2008 18:41
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 29-09-2008 18:01
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 28-09-2008 20:58
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 25-09-2008 22:14
MK1 Astra Owners Club :: View topic - Astra MKI from Sweden with 4x4 and a lot of grunt This thread Refback 19-09-2008 18:35
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-09-2008 07:14
Rallyecorse :: Voir le sujet - faudrait que j'arrête de fréquenter ce forum moaaaaaaaa This thread Refback 13-09-2008 18:55
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET (11.7 kuvia s.16) This thread Refback 12-09-2008 18:32
Rallyecorse :: Voir le sujet - faudrait que j'arrête de fréquenter ce forum moaaaaaaaa This thread Refback 11-09-2008 18:45
Rallyecorse :: Voir le sujet - faudrait que j'arrête de fréquenter ce forum moaaaaaaaa This thread Refback 11-09-2008 18:04
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET (11.7 kuvia s.16) This thread Refback 05-09-2008 19:55
MK1 Astra Owners Club :: View topic - Astra MKI from Sweden with 4x4 and a lot of grunt This thread Refback 02-09-2008 18:17
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 30-08-2008 22:05
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET (11.7 kuvia s.16) This thread Refback 18-08-2008 20:11
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 31-07-2008 18:01
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET (11.7 kuvia s.16) This thread Refback 30-07-2008 12:12
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 09-07-2008 01:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-07-2008 20:08
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 07-07-2008 20:48
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 29-06-2008 09:22
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 16-06-2008 20:28
2.2 & 2.4 XE Rally Engines - Turbosport Forums This thread Refback 15-06-2008 20:15
Alice - Rechercher This thread Refback 15-06-2008 14:07
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-06-2008 16:08
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 27-05-2008 17:32
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 25-05-2008 18:36
Calibra Club Estonia This thread Refback 20-05-2008 17:43
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-05-2008 17:06
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 19-05-2008 22:59
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 19-05-2008 00:08
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 15-05-2008 10:35
Calibra Club Estonia This thread Refback 13-05-2008 12:05
Calibra Club Estonia This thread Refback 13-05-2008 11:39
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 10-05-2008 17:50
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 05-05-2008 17:20
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 03-05-2008 20:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 01-05-2008 07:30
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-04-2008 20:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 24-04-2008 15:18
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 22-04-2008 10:57
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 21-04-2008 19:25
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 19-04-2008 13:28
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 17-04-2008 14:08
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-04-2008 19:12
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 12-04-2008 18:12
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 11-04-2008 17:16
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 11-04-2008 15:52
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 10-04-2008 17:57
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-04-2008 19:00
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 08-04-2008 11:18
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-04-2008 10:37
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 07-04-2008 08:17
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 07-04-2008 06:51
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 06-04-2008 20:43
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-04-2008 20:12
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 06-04-2008 19:01
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 06-04-2008 12:44
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 06-04-2008 07:56
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 04-04-2008 14:57
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 30-03-2008 13:05
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 30-03-2008 10:23
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 21-03-2008 18:35
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-03-2008 09:45
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 18-03-2008 19:30
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 17-03-2008 13:06
Versione tradotta della pagina http://www.migweb.co.uk/forums/projects-restorations/293172-insaneswedes-astra-mki-2.html (BETA) This thread Refback 10-03-2008 15:30
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 10-03-2008 08:39
mint vauxhalls? anyone got one!!!??? :cry: - Page 2 - PassionFord This thread Refback 08-03-2008 14:23
BLITZ-GSI.com :: Voir le sujet - ... Kadett ... This thread Refback 07-03-2008 19:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-03-2008 20:56
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-03-2008 20:55
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 04-03-2008 21:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 03-03-2008 11:38
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 01-03-2008 07:33
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 29-02-2008 13:36
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 29-02-2008 11:32
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 29-02-2008 08:56
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-02-2008 17:32
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 26-02-2008 17:59
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 25-02-2008 19:44
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 24-02-2008 05:39
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 23-02-2008 20:14
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 23-02-2008 13:53
Colectores de admisión LEXMAUL - Page 5 - clubGSIspain This thread Refback 23-02-2008 10:59
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 23-02-2008 09:07
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 22-02-2008 05:03
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 19-02-2008 12:47
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 18-02-2008 10:39
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 15-02-2008 14:24
GermanBrutal ~ View topic - Escape... zinho This thread Refback 11-02-2008 01:10
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 10-02-2008 17:17
MK1 Astra Owners Club :: View topic - new pic.. i went nuts...(almost) This thread Refback 09-02-2008 22:08
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-02-2008 05:54
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 07-02-2008 16:42
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 19:28
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 17:37
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 17:04
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 16:04
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 15:05
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 05-02-2008 14:31
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 03-02-2008 16:53
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 31-01-2008 19:38
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 27-01-2008 16:44
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 26-01-2008 21:40
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-01-2008 16:13
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 25-01-2008 21:39
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 24-01-2008 20:04
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 24-01-2008 06:50
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 24-01-2008 05:59
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:49
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:35
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:34
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:17
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:10
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:09
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:05
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 21-01-2008 20:42
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 21-01-2008 19:43
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-01-2008 13:55
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-01-2008 11:53
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 17-01-2008 10:10
super Kadett .... - Page 4 - forum.4tuning.ro This thread Refback 17-01-2008 01:01
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-01-2008 21:42
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-01-2008 20:59
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-01-2008 19:48
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-01-2008 19:24
super Kadett .... - Page 4 - forum.4tuning.ro This thread Refback 16-01-2008 18:36
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 15-01-2008 06:51
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-01-2008 15:32
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 14-01-2008 15:02
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 13-01-2008 09:40
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 10-01-2008 18:54
GermanBrutal ~ View topic - Escape... zinho This thread Refback 09-01-2008 11:47
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 09-01-2008 08:46
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 08-01-2008 14:11
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-01-2008 12:31
GermanBrutal ~ View topic - Escape... zinho This thread Refback 08-01-2008 00:03
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 07-01-2008 19:13
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 07-01-2008 18:21
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 07-01-2008 10:28
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-01-2008 19:16
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-01-2008 00:18
MK1 Astra Owners Club :: View topic - possable Newbie? This thread Refback 05-01-2008 22:35
MK1 Astra Owners Club :: View topic - new pic.. i went nuts...(almost) This thread Refback 04-01-2008 20:06
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 02-01-2008 18:36
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 01-01-2008 17:49
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 01-01-2008 08:29
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 31-12-2007 13:03
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 31-12-2007 11:46
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 30-12-2007 20:47
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 30-12-2007 20:43
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 30-12-2007 20:40
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 30-12-2007 20:07
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 30-12-2007 19:56
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 30-12-2007 14:07
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 30-12-2007 01:59
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 29-12-2007 14:22
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 29-12-2007 13:49
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-12-2007 16:43
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 26-12-2007 20:34
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-12-2007 16:59
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-12-2007 16:37
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 21-12-2007 18:52
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 21-12-2007 08:57
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-12-2007 01:37
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 19-12-2007 08:20
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 18-12-2007 17:11
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 18-12-2007 11:26
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 17-12-2007 13:34
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-12-2007 10:15
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-12-2007 07:43
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 15-12-2007 15:05
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-12-2007 19:52
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 14-12-2007 14:15
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-12-2007 10:54
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 22:34
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 17:49
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 17:12
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 15:52
The 'Pleasant Motor Vehicle' Photo Thread - Edition 38 Forums This thread Refback 13-12-2007 15:46
The 'Pleasant Motor Vehicle' Photo Thread - Edition 38 Forums This thread Refback 13-12-2007 15:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 14:33
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 14:31
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 13-12-2007 14:20
passer son 20NE ou 20XE ou C20LET en 2.2L This thread Refback 12-12-2007 11:49
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 11-12-2007 15:14
MK1 Astra Owners Club :: View topic - new pic.. i went nuts...(almost) This thread Refback 07-12-2007 11:42
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 02-12-2007 10:56
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 01-12-2007 10:40
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 30-11-2007 12:24
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 29-11-2007 14:09
MK1 Astra Owners Club :: View topic - new pic.. i went nuts...(almost) This thread Refback 19-11-2007 10:11
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 15-11-2007 19:37
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 15-11-2007 13:04
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 15-11-2007 10:38
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 14-11-2007 19:17
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 14-11-2007 09:19
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 13-11-2007 10:54
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & Kadett D Caravan *Pätkä maalattu s.5* This thread Refback 13-11-2007 02:10
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & Kadett D Caravan *Pätkä maalattu s.5* This thread Refback 12-11-2007 20:09
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 08-11-2007 15:41
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 08-11-2007 12:22
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 04-11-2007 17:04
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 30-10-2007 21:08
Das Forum für Corsa XE/LET Umbauten | Smalltalk | unglaublich Kadett d Let This thread Refback 24-10-2007 01:29
Das Forum für Corsa XE/LET Umbauten | Smalltalk | unglaublich Kadett d Let This thread Refback 23-10-2007 18:49
Das Forum für Corsa XE/LET Umbauten | Smalltalk | unglaublich Kadett d Let This thread Refback 23-10-2007 17:56
Das Forum für Corsa XE/LET Umbauten | Smalltalk | unglaublich Kadett d Let This thread Refback 23-10-2007 11:29
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 21-10-2007 20:29
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 21-10-2007 14:01
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 21-10-2007 10:44
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 16:47
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 16:27
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 16:00
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 09:15
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 08:20
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 20:14
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 16:52
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 13:37
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 12:34
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 10:36
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 10:17
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 09:26
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 20:15
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 19:42
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 19:16
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 19:12
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 19:08
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 18:52
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 18:51
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 18:48
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 12-10-2007 05:48
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 06-10-2007 08:45
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 28-09-2007 19:52
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 27-09-2007 07:42
4x4 onto a nova - Page 5 - Performance Nova Group - PNG This thread Refback 24-09-2007 16:51
4x4 onto a nova - Page 4 - Performance Nova Group - PNG This thread Refback 23-09-2007 21:10
4x4 onto a nova - Page 4 - Performance Nova Group - PNG This thread Refback 23-09-2007 21:08
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 16:39
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 12:24
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 17-09-2007 11:20
BLITZ-GSI.com :: Revue du sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 11:10
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 08:49
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 08:11
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 08:09
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 16-09-2007 23:41
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 16-09-2007 23:30
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 16-09-2007 23:07
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 21-08-2007 18:14
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 21-08-2007 17:59
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 20-08-2007 21:46
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 20-08-2007 13:05
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 17-08-2007 14:59
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 17-08-2007 14:30
MK1 Astra Owners Club :: View topic - possable Newbie? This thread Refback 23-01-2007 20:46
©MIGWeb 1997-2009 - MIGWeb Home - Archive - Privacy Statement - Top
Powered by: vBulletin. Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0
