Advertise Here - Click for More Info
LinkBack (378) Thread Tools
Old 01-08-2007, 18:51   #101
InsaneSwede
Drives: Astra MkI
Rs1,, thanks for the feedback.
i will be running E85 fuel and it needs about 40% bigger injectors than on regular fuel.
And there arent any good 1200cc injectors on the market.
And i got a 'fetish' for non american stuff., my injectors are Bosch
Rgds
Kadett GT/E
Sometimes you are the bug
sometimes you are the windsheild
InsaneSwede is offline   Reply With Quote
Old 01-08-2007, 18:54   #102
InsaneSwede
Drives: Astra MkI
Originally Posted by Rs1 View Post
Patrick is that the x22 block your using?
forgot to answer this. Yes it´s the X22XE from an Frontera i´m using.
Rgds.
Old 01-08-2007, 19:17   #103
Rs1
Drives: LET...coming soon
Ah yeah E85, that explains it.
I seen a x22 block just recently, it had almost.....open deck, have you had some kind of inserts made add strength as yours does not look like the x22 i seen. I heard this is a weak spot on the 22 block.
"THE ROB"
Rs1 is offline   Reply With Quote
Old 01-08-2007, 19:27   #104
InsaneSwede
Drives: Astra MkI
yes i have made two mods to get the deck more stable.
if you browse around in my photobucket you´ll find some pics of it.
You can say i have filled the block with concrete from the deck and 10mm down
and underneeth there are some 'girdlescrew' to keep it together too.
this is an old trick in the tuning book,, they used to use this screws on old 'yanks' before they started to cast more stable block(merlin,dart etc etc)
Old 02-08-2007, 17:29   #105
InsaneSwede
Drives: Astra MkI
today i have sorted the loom in the enginebay to look better, i did also cut away a lot of unused cables to get 'smoother look'
then i went away to a friend and bought his brand new oilcooler that didn´t fit his car(corrado)
but it did fit mine perfectly.
piccies:
I used 'hockey tape', the kind of tape you tape your blade on your stick.
Now when the oilcooler stis on top of watercooler i can start weld up som brackets for the whole cooling system.
Cheers...
Old 02-08-2007, 18:01   #106
Drizz
Drives: Audi QTS, Defender
Thats hooooge!
Old 03-08-2007, 06:56   #107
mattcoupturbo
Drives: Focus LX
Excuse my ignorance, but how on earth did you fit the toyota gearbox to the engine, did you get a bell housing made up to do it?
But going awesome as well.
mattcoupturbo is offline   Reply With Quote
Old 03-08-2007, 07:52   #108
InsaneSwede
Drives: Astra MkI
Mattcoup,,
Well,, i made an 'adapterplate' in between engine and gearbox.
8mm thick, you can see it on pics if you look closer.
then i milled off 8mm from gearbox to get the correct measurement for clutch etc etc.
but.. i can´t recomend this mod to guys with their thumb in the middle of the hand.
there are lots of mods, and it aint easy to figure them all out.
but, if somebody is willing to do the job, i´ll help him.
Will go much faster now as i know what to be done.
example: the belt for the alternator suddenly went into the 'beam' under the strut at ht right side.
so i did some massaging on the beam.
this was because i couldnt tilt the engine in the same angle as standard as the transferbox would then be inside the engine *lol*
so,, all new enginebrackets,, etc etc etc..
nothing left alone...
but now it´s done
Rgds
Old 03-08-2007, 08:12   #109
Nobbie
Central Regional Coordinator / Moderator
Nobbie's Avatar
Drives: Mk3 Astra GSi XE
Was gonna say it looks a bit tight, but the block is sitting quite low, so should be better.
Central Region Co-ordinator
Central Region Forums/Events
Nobbie is offline   Reply With Quote
Old 03-08-2007, 09:08   #110
CortraGTE
CortraGTE's Avatar
Drives: Club Roost DH9
Looking good mate!
CortraGTE is offline   Reply With Quote
Old 03-08-2007, 12:35   #111
hendrix
Drives: Astra Coupe Turbo
wow this is absolutely incredible!!!!!
hendrix is offline   Reply With Quote
Old 15-08-2007, 06:57   #112
InsaneSwede
Drives: Astra MkI
Thanks again for the response.
today there are no pics just yet. i have forgotten the phone every time i went down to the garage.
but what´s been done,,,
Brackets on IC for the watercooler
Started to weld close the std outlet from IC but ran out of material.(there will be a new outlet from IC slightly higher up as it wanted the the same space as the water outlet on watercooler.)
Have been modifying the tank to accept hydraulic couplings with 1/2 inch diam at the inside..
Repaired one seatbracket for my recaro´s.
right at the moment i will be rerouting the 'plasticpipe' with a new one in stainless and a new routing as it wanted the same space as the clutchwire..
There´s no end of the mods.. *LOL*
piccies later today or tomorrow.
Rgds
Old 16-08-2007, 07:21   #113
InsaneSwede
Drives: Astra MkI
well whaddayaknow...
my phone went bang yesterday, i have to take new pics for you today.. *grrr*
but,, those will be in higher quality now instead
Old 16-08-2007, 08:19   #114
sbd16vastra
Drives: wife around the bend
good good we like hi res
sbd16vastra is offline   Reply With Quote
Old 16-08-2007, 16:39   #115
InsaneSwede
Drives: Astra MkI
the promised pics:
just a pic.
little bit closer:
Closeup on clutchwire bracket: (the toyota gearbox have hydraulic as standard,the wire comes from Opel Manta B)
Closeup on new waterpipe:
2 pic´s to show how low the car is: (i´m 1.90cm long)
cheers lads..
//Patrick
Old 16-08-2007, 16:40   #116
Drizz
Is there something im missing or do you just not have the pulleys and belt on?
DRIZZ
DEVELOPMENTS
Old 16-08-2007, 17:33   #117
Rs1
Theres a big nasty turbo missing, all the boost pipework, air intake, dizzyless setup so quite alot to cram in there just yet i reckon
Also look like he's machined the end of the cam cover to get rid of the lip.....very swish mod
Awesome work Patrick, some real effort went into this
Old 16-08-2007, 19:29   #118
InsaneSwede
Drives: Astra MkI
Thanks mate
Yes as Rs1 says there are a whole lot missing.
and as for the campulleys arent there, it´s because the head is empty, no valves no nothing.
I´m waiting for the retainers for my double valvesprings to arrive from Sbdev,, not today either.
but in the meantime i try to fabricate all brackets and stuff for coolers and yada yada yada.
some piccies of todays work:
Oilcooler, fits perfectly underneeth the 'panel'
Tested to hook up the turbo just to have a picture in my mind, so i can go around and have ideas for the piping. sort of 'melt it in into the brain',, well you know
tested to build an 3" downpipe a little fast,, no problems just yet, but my fuelpump should be right where the std servopump on astras is located, might run in to problems, but i think i have a plan for that.
Then i mounted back the prepped tank(no pics)
and then mounted the propshaft.(no pics)
Tomorrow i´ll try to make brackets for oilcooler for the gearbox.
Have a cold one fellas....
//Patrick
Old 16-08-2007, 21:21   #119
The Simps
Drives: Nova Coupe
The Simps is offline   Reply With Quote
Old 17-08-2007, 08:04   #120
P17FLD
Drives: Honda Cb250
Ive already said, but thats pure awesomeness
Two chavs, Dave and Bob race their Novas over a cliff to see who hits the bottom first...who wins? Society.
P17FLD is offline   Reply With Quote
Old 17-08-2007, 08:06   #121
Nobbie
Nobbie's Avatar
Good progress. What turbo did you go for in the end, as i thought you changed your mind and went for a slightly smaller one than you had?
Still looks uber tight at the cambelt end, but i'm not up on XE/LET nova's.
Water pipe mod looks good, but do you really need a heater, lol.
Old 17-08-2007, 09:00   #122
masch.tab
Drives: Vectra SRi
It's a mk1 Astra!!!
Amazing work by the way.
masch.tab is offline   Reply With Quote
Old 17-08-2007, 13:10   #123
InsaneSwede
Drives: Astra MkI
Actually this turbo is slightly bigger in capacity than my old one.
even thou this one has smaller outer measurements.
The old turbo had capacity of ~620-630hp
GT3582r can produce almost 700Hp, have seen 697hp at it´s most.(with 1.06 exhaust)
And just yesterday an Audi S2 received 677 hp(0.82 exhaust) with an exactly the same setup on turbo as i got now.
I´m waiting for my Tial Exhaust house also,, might get som more than 677hp if were really lucky., as the tial exhausthouse flows better than Garrett std.
In astra MkI´s there are really tight at the cambelt side. but no worries.. it fits.
Ofcourse i need an heater,,,,, it´s cold at night when the streetracing occurs...
Old 17-08-2007, 13:14   #124
Jack
Jack's Avatar
Drives: Mondeo TDDI
I want to move to Sweden.
"The mig community had a genuine concern for my Calibra and its safety."
MIG: A caring, sharing community of peer-pressure bullies.
Jack is offline   Reply With Quote
Old 17-08-2007, 13:15   #125
InsaneSwede
Drives: Astra MkI
oh by the way...
Retainers received,,, now there will be some more work done on engine...
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/293172-insaneswedes-astra-mki.html
Posted By For Type Date
Ready to hit the street´s - Sida 2 - Opel Sport Club This thread Refback Yesterday 18:28
Ready to hit the street´s - Sida 2 - Opel Sport Club This thread Refback 02-03-2010 10:11
Opel-Forum - Powered by XMB This thread Refback 27-02-2010 21:45
:: Team Calibra 026 :: - Ver Tema - colectores de admision artesanales This thread Refback 17-02-2010 18:45
:: Team Calibra 026 :: - Ver Tema - colectores de admision artensalales This thread Refback 12-02-2010 22:20
2.2 & 2.4 XE Rally Engines This thread Refback 06-02-2010 20:07
först i år med racebilen? - Sida 2 - Opel Sport Club This thread Refback 02-02-2010 16:04
MK1 Astra Owners Club :: View topic - 4x4 help Glenn and Ant B This thread Refback 01-02-2010 16:23
jogr - Opel Kadett GSi Type-R - Sidan 6 - zatzy.com This thread Refback 29-01-2010 12:39
jogr - Opel Kadett GSi Type-R - Sidan 41 - zatzy.com This thread Refback 24-01-2010 08:08
C20LET-Forum :: Thema anzeigen - Kadett D GT35 AWD ?? This thread Refback 20-01-2010 12:13
• Temos rodymas - Projektai-Opel ... This thread Refback 18-01-2010 16:50
Der Opel-Sechser Talk • Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 12-01-2010 04:00
Opel Tuning : super Kadett - Page 4 - 4TuningRO This thread Refback 05-01-2010 20:40
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 20-11-2009 12:36
Opel Calibra Club :: Ïðîñìîòð òåìû - Ñöåïëåíèå ê F28 This thread Refback 18-11-2009 16:11
C20LET-Forum :: Thema anzeigen - Leistungfähigkeit LET-Saugrohr This thread Refback 05-11-2009 18:49
Laatste bericht van: don diégo(voorheen vaya con dios) This thread Refback 01-11-2009 17:37
D-Kadett 700+ pk!!!!! hoe bedoel je extreem.... This thread Refback 26-10-2009 20:08
???????? ???? ????? ??????? ??????? ??????????!? - ????????? ? ??????????? - ????? ?????? - 5k Customs ????? This thread Refback 20-10-2009 09:22
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 02-08-2009 20:07
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 20-07-2009 17:18
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 15-07-2009 20:00
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 09-07-2009 20:46
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 06-07-2009 18:15
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 01-07-2009 04:10
Kp un slp :: Apskatt tematu - interesanti projekti. This thread Refback 28-06-2009 12:01
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 21-06-2009 20:52
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 13:51
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 11:20
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 07:01
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 06:38
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 05:36
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 05:16
Opel Calibra Club :: - PROJECT CLOSED........ This thread Refback 13-06-2009 04:34
• Temos rodymas - Projektai-Opel ... This thread Refback 07-06-2009 17:52
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 02-06-2009 22:27
• Temos rodymas - Projektai-Opel ... This thread Refback 30-05-2009 17:36
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 28-05-2009 21:27
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 27-05-2009 18:22
• Temos rodymas - Projektai-Opel ... This thread Refback 25-05-2009 16:09
• Temos rodymas - Projektai-Opel ... This thread Refback 24-05-2009 13:39
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 20-05-2009 13:20
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 19-05-2009 09:44
• Temos rodymas - Projektai-Opel ... This thread Refback 19-05-2009 06:18
• Temos rodymas - Projektai-Opel ... This thread Refback 18-05-2009 19:50
• Temos rodymas - Projektai-Opel ... This thread Refback 18-05-2009 17:59
• Temos rodymas - Projektai-Opel ... This thread Refback 17-05-2009 16:49
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 10-05-2009 13:24
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 06-05-2009 14:00
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 29-04-2009 13:05
ffp :: Nyt viesti - Projektikertomus bongaukset This thread Refback 19-04-2009 19:37
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 15-04-2009 15:03
Calibra Club Estonia This thread Refback 13-04-2009 09:44
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 10-04-2009 06:41
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-04-2009 16:35
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 31-03-2009 22:55
Calibra Club Estonia This thread Refback 31-03-2009 21:11
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 27-03-2009 20:02
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 26-03-2009 21:17
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 19-03-2009 13:35
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 14-03-2009 16:16
OldSchoolAuto • Temos rodymas - Projektai-Opel ... This thread Refback 11-03-2009 02:52
Volvo Engine Swap, Volvo Diesel Engines, Volvo Front Grill - Avantirh1500S This thread Refback 10-03-2009 12:42
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 09-03-2009 22:52
VauxSport - Vauxhall advice and chat forum :: View topic - c20xe 2067cc or hybrid 22xe 2274cc performance engine This thread Refback 09-03-2009 00:48
Serpentine Belt Diagram 95 Plymouth Voyager, Serpentine Belt Diagram 2000 Bmw 528I 6 Cyl, Serpentine Belt Diagram Caravan - Bmwhouston This thread Refback 08-03-2009 09:39
OldSchoolAuto • Temos rodymas - Projektai-Opel ... This thread Refback 04-03-2009 14:51
OldSchoolAuto • Temos rodymas - Projektai-Opel ... This thread Refback 03-03-2009 08:35
OldSchoolAuto • Temos rodymas - kadett D This thread Refback 02-03-2009 14:31
OldSchoolAuto • Temos rodymas - kadett D This thread Refback 27-02-2009 22:04
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-02-2009 11:17
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 23-02-2009 17:49
OldSchoolAuto • Temos rodymas - kadett D This thread Refback 22-02-2009 16:46
OldSchoolAuto • Temos rodymas - kadett D This thread Refback 22-02-2009 10:54
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 22-02-2009 10:32
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 21-02-2009 20:19
:::classic opel club/forum::: :: Perþiûrëti temà - Kadett D This thread Refback 21-02-2009 20:16
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 18-02-2009 02:18
[C20XE] Admision - clubGSIspain This thread Refback 16-02-2009 19:21
[C20XE] Admision - clubGSIspain This thread Refback 16-02-2009 17:55
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 13-02-2009 19:59
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 09-02-2009 20:28
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 09-02-2009 18:53
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 09-02-2009 12:48
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 08-02-2009 15:22
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-02-2009 13:24
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 04-02-2009 14:57
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 03-02-2009 10:56
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 29-01-2009 21:14
Opel Club Finland (OCF) • katso viestiketjua - Lexmaul imusarja C20XE This thread Refback 25-01-2009 15:28
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 17-01-2009 21:10
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-01-2009 15:15
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 07-01-2009 12:07
MK1 Astra Owners Club :: View topic - Astra MKI from Sweden with 4x4 and a lot of grunt This thread Refback 03-01-2009 11:49
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 30-12-2008 12:20
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 27-12-2008 16:39
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-12-2008 04:02
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 19:40
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 17:13
Kûp un slîpç :: Apskatît tematu - SPAM ''finansu krîze, draga klases un citas izvirtîbas'' This thread Refback 22-12-2008 16:26
Kûp un slîpç :: Apskatît tematu - interesanti projekti. This thread Refback 22-12-2008 13:04
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-12-2008 15:34
Alice - Rechercher VIDEOS CALIBRA 700CV This thread Refback 13-12-2008 19:25
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 01-12-2008 14:38
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 30-11-2008 17:32
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 29-11-2008 19:52
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 24-11-2008 06:47
Opel-Forum - Powered by XMB This thread Refback 23-11-2008 10:20
Opel-Forum - Powered by XMB This thread Refback 23-11-2008 09:56
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-11-2008 06:50
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 19-11-2008 08:55
Calibra Club Estonia This thread Refback 05-11-2008 22:18
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 03-11-2008 17:27
Opel Club Finland (OCF) • katso viestiketjua - Kadett D HB & Caravan LET This thread Refback 02-11-2008 10:39
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-10-2008 23:15
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-10-2008 19:11
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 19-10-2008 11:34
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 11-10-2008 15:48
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 30-09-2008 18:41
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 29-09-2008 18:01
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 28-09-2008 20:58
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET This thread Refback 25-09-2008 22:14
MK1 Astra Owners Club :: View topic - Astra MKI from Sweden with 4x4 and a lot of grunt This thread Refback 19-09-2008 18:35
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-09-2008 07:14
Rallyecorse :: Voir le sujet - faudrait que j'arrête de fréquenter ce forum moaaaaaaaa This thread Refback 13-09-2008 18:55
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET (11.7 kuvia s.16) This thread Refback 12-09-2008 18:32
Rallyecorse :: Voir le sujet - faudrait que j'arrête de fréquenter ce forum moaaaaaaaa This thread Refback 11-09-2008 18:45
Rallyecorse :: Voir le sujet - faudrait que j'arrête de fréquenter ce forum moaaaaaaaa This thread Refback 11-09-2008 18:04
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET (11.7 kuvia s.16) This thread Refback 05-09-2008 19:55
MK1 Astra Owners Club :: View topic - Astra MKI from Sweden with 4x4 and a lot of grunt This thread Refback 02-09-2008 18:17
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 30-08-2008 22:05
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET (11.7 kuvia s.16) This thread Refback 18-08-2008 20:11
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 31-07-2008 18:01
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB & Caravan LET (11.7 kuvia s.16) This thread Refback 30-07-2008 12:12
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 09-07-2008 01:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-07-2008 20:08
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 07-07-2008 20:48
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 29-06-2008 09:22
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 16-06-2008 20:28
2.2 & 2.4 XE Rally Engines - Turbosport Forums This thread Refback 15-06-2008 20:15
Alice - Rechercher This thread Refback 15-06-2008 14:07
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-06-2008 16:08
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 27-05-2008 17:32
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 25-05-2008 18:36
Calibra Club Estonia This thread Refback 20-05-2008 17:43
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-05-2008 17:06
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 19-05-2008 22:59
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 19-05-2008 00:08
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 15-05-2008 10:35
Calibra Club Estonia This thread Refback 13-05-2008 12:05
Calibra Club Estonia This thread Refback 13-05-2008 11:39
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 10-05-2008 17:50
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 05-05-2008 17:20
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 03-05-2008 20:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 01-05-2008 07:30
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-04-2008 20:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 24-04-2008 15:18
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 22-04-2008 10:57
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 21-04-2008 19:25
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 19-04-2008 13:28
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 17-04-2008 14:08
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-04-2008 19:12
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 12-04-2008 18:12
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 11-04-2008 17:16
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 11-04-2008 15:52
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 10-04-2008 17:57
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-04-2008 19:00
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 08-04-2008 11:18
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-04-2008 10:37
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 07-04-2008 08:17
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 07-04-2008 06:51
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 06-04-2008 20:43
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-04-2008 20:12
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 06-04-2008 19:01
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 06-04-2008 12:44
Opel Calibra Club :: Ïðîñìîòð òåìû - Âïóñêíîé êîëëåêòîð è äðîñåëü íà ëåò íå ñòîê This thread Refback 06-04-2008 07:56
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 04-04-2008 14:57
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 30-03-2008 13:05
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 30-03-2008 10:23
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 21-03-2008 18:35
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-03-2008 09:45
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 18-03-2008 19:30
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 17-03-2008 13:06
Versione tradotta della pagina http://www.migweb.co.uk/forums/projects-restorations/293172-insaneswedes-astra-mki-2.html (BETA) This thread Refback 10-03-2008 15:30
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 10-03-2008 08:39
mint vauxhalls? anyone got one!!!??? :cry: - Page 2 - PassionFord This thread Refback 08-03-2008 14:23
BLITZ-GSI.com :: Voir le sujet - ... Kadett ... This thread Refback 07-03-2008 19:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-03-2008 20:56
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-03-2008 20:55
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 04-03-2008 21:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 03-03-2008 11:38
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 01-03-2008 07:33
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 29-02-2008 13:36
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 29-02-2008 11:32
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 29-02-2008 08:56
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-02-2008 17:32
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 26-02-2008 17:59
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 25-02-2008 19:44
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 24-02-2008 05:39
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 23-02-2008 20:14
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 23-02-2008 13:53
Colectores de admisión LEXMAUL - Page 5 - clubGSIspain This thread Refback 23-02-2008 10:59
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 23-02-2008 09:07
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 22-02-2008 05:03
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 19-02-2008 12:47
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 18-02-2008 10:39
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 15-02-2008 14:24
GermanBrutal ~ View topic - Escape... zinho This thread Refback 11-02-2008 01:10
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 10-02-2008 17:17
MK1 Astra Owners Club :: View topic - new pic.. i went nuts...(almost) This thread Refback 09-02-2008 22:08
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-02-2008 05:54
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 07-02-2008 16:42
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 19:28
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 17:37
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 17:04
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 16:04
Der Opel-Sechser Talk :: Thema anzeigen - astra f mv6 auf 4x4 umbauen This thread Refback 06-02-2008 15:05
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 05-02-2008 14:31
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 03-02-2008 16:53
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 31-01-2008 19:38
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 27-01-2008 16:44
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 26-01-2008 21:40
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-01-2008 16:13
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 25-01-2008 21:39
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 24-01-2008 20:04
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 24-01-2008 06:50
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 24-01-2008 05:59
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:49
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:35
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:34
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:17
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:10
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:09
BLITZ-GSI.com :: Voir le sujet - ... Kadett c22let ... This thread Refback 23-01-2008 22:05
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 21-01-2008 20:42
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 21-01-2008 19:43
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-01-2008 13:55
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-01-2008 11:53
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 17-01-2008 10:10
super Kadett .... - Page 4 - forum.4tuning.ro This thread Refback 17-01-2008 01:01
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-01-2008 21:42
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-01-2008 20:59
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-01-2008 19:48
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-01-2008 19:24
super Kadett .... - Page 4 - forum.4tuning.ro This thread Refback 16-01-2008 18:36
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 15-01-2008 06:51
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-01-2008 15:32
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 14-01-2008 15:02
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 13-01-2008 09:40
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 10-01-2008 18:54
GermanBrutal ~ View topic - Escape... zinho This thread Refback 09-01-2008 11:47
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 09-01-2008 08:46
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 08-01-2008 14:11
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 08-01-2008 12:31
GermanBrutal ~ View topic - Escape... zinho This thread Refback 08-01-2008 00:03
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 07-01-2008 19:13
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 07-01-2008 18:21
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 07-01-2008 10:28
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-01-2008 19:16
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 06-01-2008 00:18
MK1 Astra Owners Club :: View topic - possable Newbie? This thread Refback 05-01-2008 22:35
MK1 Astra Owners Club :: View topic - new pic.. i went nuts...(almost) This thread Refback 04-01-2008 20:06
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 02-01-2008 18:36
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 01-01-2008 17:49
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 01-01-2008 08:29
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 31-12-2007 13:03
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 31-12-2007 11:46
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 30-12-2007 20:47
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 30-12-2007 20:43
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 30-12-2007 20:40
Opel Club Finland (OCF) :: Näytä viesti - Lexmaul imusarja C20XE This thread Refback 30-12-2007 20:07
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 30-12-2007 19:56
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 30-12-2007 14:07
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 30-12-2007 01:59
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 29-12-2007 14:22
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 29-12-2007 13:49
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 27-12-2007 16:43
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 26-12-2007 20:34
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-12-2007 16:59
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 26-12-2007 16:37
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 21-12-2007 18:52
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 21-12-2007 08:57
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 20-12-2007 01:37
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 19-12-2007 08:20
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 18-12-2007 17:11
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 18-12-2007 11:26
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 17-12-2007 13:34
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-12-2007 10:15
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 16-12-2007 07:43
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 15-12-2007 15:05
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-12-2007 19:52
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 14-12-2007 14:15
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 14-12-2007 10:54
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 22:34
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 17:49
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 17:12
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 15:52
The 'Pleasant Motor Vehicle' Photo Thread - Edition 38 Forums This thread Refback 13-12-2007 15:46
The 'Pleasant Motor Vehicle' Photo Thread - Edition 38 Forums This thread Refback 13-12-2007 15:13
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 14:33
ffp :: Näytä viesti - Projektikertomus bongaukset This thread Refback 13-12-2007 14:31
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 13-12-2007 14:20
passer son 20NE ou 20XE ou C20LET en 2.2L This thread Refback 12-12-2007 11:49
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 11-12-2007 15:14
MK1 Astra Owners Club :: View topic - new pic.. i went nuts...(almost) This thread Refback 07-12-2007 11:42
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 02-12-2007 10:56
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 01-12-2007 10:40
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan LET projektit This thread Refback 30-11-2007 12:24
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 29-11-2007 14:09
MK1 Astra Owners Club :: View topic - new pic.. i went nuts...(almost) This thread Refback 19-11-2007 10:11
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 15-11-2007 19:37
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 15-11-2007 13:04
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 15-11-2007 10:38
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 14-11-2007 19:17
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & D Caravan *Pätkä maalattu, kuvia s.5-6 This thread Refback 14-11-2007 09:19
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 13-11-2007 10:54
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & Kadett D Caravan *Pätkä maalattu s.5* This thread Refback 13-11-2007 02:10
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB LET & Kadett D Caravan *Pätkä maalattu s.5* This thread Refback 12-11-2007 20:09
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 08-11-2007 15:41
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 08-11-2007 12:22
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 04-11-2007 17:04
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 30-10-2007 21:08
Das Forum für Corsa XE/LET Umbauten | Smalltalk | unglaublich Kadett d Let This thread Refback 24-10-2007 01:29
Das Forum für Corsa XE/LET Umbauten | Smalltalk | unglaublich Kadett d Let This thread Refback 23-10-2007 18:49
Das Forum für Corsa XE/LET Umbauten | Smalltalk | unglaublich Kadett d Let This thread Refback 23-10-2007 17:56
Das Forum für Corsa XE/LET Umbauten | Smalltalk | unglaublich Kadett d Let This thread Refback 23-10-2007 11:29
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 21-10-2007 20:29
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 21-10-2007 14:01
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 21-10-2007 10:44
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 16:47
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 16:27
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 16:00
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 09:15
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 20-10-2007 08:20
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 20:14
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 16:52
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 13:37
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 12:34
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 10:36
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 10:17
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 19-10-2007 09:26
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 20:15
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 19:42
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 19:16
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 19:12
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 19:08
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 18:52
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 18:51
Opel Club Finland (OCF) :: Näytä viesti - Kadett D HB 2.0 16v turbo & Kadett D Caravan projektit This thread Refback 18-10-2007 18:48
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 12-10-2007 05:48
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 06-10-2007 08:45
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 28-09-2007 19:52
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 27-09-2007 07:42
4x4 onto a nova - Page 5 - Performance Nova Group - PNG This thread Refback 24-09-2007 16:51
4x4 onto a nova - Page 4 - Performance Nova Group - PNG This thread Refback 23-09-2007 21:10
4x4 onto a nova - Page 4 - Performance Nova Group - PNG This thread Refback 23-09-2007 21:08
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 16:39
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 12:24
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 17-09-2007 11:20
BLITZ-GSI.com :: Revue du sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 11:10
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 08:49
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 08:11
BLITZ-GSI.com :: Voir le sujet - kadettd 4X4 c23let de 700ch a 2.1bar This thread Refback 17-09-2007 08:09
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 16-09-2007 23:41
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 16-09-2007 23:30
JSO :: Voir le sujet - nouveau projet astra turbo 4x4 +-700cv This thread Refback 16-09-2007 23:07
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 21-08-2007 18:14
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 21-08-2007 17:59
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 20-08-2007 21:46
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 20-08-2007 13:05
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 17-08-2007 14:59
MK1 Astra Owners Club :: View topic - Swedish Guys Insane MK1 This thread Refback 17-08-2007 14:30
MK1 Astra Owners Club :: View topic - possable Newbie? This thread Refback 23-01-2007 20:46
©MIGWeb 1997-2009 - MIGWeb Home - Archive - Privacy Statement - Top
Powered by: vBulletin. Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0
