Page 36 of 39 FirstFirst ... 26 27 28 29 30 31 32 33 34 35 36 37 38 39 LastLast
Results 876 to 900 of 972
Thread: InsaneSwede's Astra MKI
  1. #876
    Sep 2002
    Stourport, Worcester
    ZX Volcane TD
    Re: InsaneSwede's Astra MKI
    Hi, still really enjoying this thread! The liner fix sounds like an interesting approach I havn't seen before. One thing, I think you mean to use a "clock" just for clarity. Please don't take that as a dig because your english is very good As Gav says, pics are always good!
    Never stick your finger where you wouldn't stick your dick and you won't go far wrong.
    Oct 2002
    Sweden
    Astra MkI
    pictures are coming.
    i mean a measuringadvice like a clock.
    to see if liners are flexing when screwing in the screws.
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
  4. #878
    Oct 2002
    Sweden
    Astra MkI
    First off, Drilling a whole lot of holes:
    Second: Tapping
    Then the threadlocker and sealer(not a seal, but i´ve used it befor to seal and it works perfectly)
    next onto a test how much torque on screws before the liner starts to flex, screwed in 5pcs on one liner 7Nm and gauge didn´t move, good enough!!
    Then i locked all 6 at 6Nm with loctite.
    result:
    This is an classic mod used in the states before different companies started to cast better engineblocks.
    Now if the liner would like to flex, it has to push out the outer wall on the block too.
    Should stop it
    Now just a cleanup and then start to bolt it together again.
    Kadett GT/E
  5. #879
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    nice work!
    SHoNkyOpELs.de
  6. #880
    So the bolts help hold the liner in if it trys to move?
  7. #881
    Jan 2006
    Willington,Co.Durham
    400 BHP MK3, MK4 Coupe T
    its just took me 4 hours and 50 mins to read all of this, all i can say is brilliant
  8. #882
    Sep 2004
    GREECE
    tigra/westy
    Quick 1 Patrick,shouldnt the ram pipes "lips" should touch all the way to the bottom of the aly sheet and not having that gap underneeth,or doesnt matter,iam asking cause in my nissan inlet built,they look like yours ,with less gap though,and i got another set that was panning of "planting" them all the way down,what you think?
    Quote Originally Posted by InsaneSwede View Post
    Hi guys..
    Ofcourse there can´t be a weekend without any pics from me
    i´ve been working houses chimney,, finally done.. it was i minor h_ll to complete.
    Installed a stainless hose into the chimney to get it leak free.
    anyway some pics of manifold i´m building.
    first the 'slit' i was talking about:
    and some outside pics mounted and testing buildup for throttlebody:
    And final some work on what will be the bosses for injectors,and compared to my own manifold:
    I´ve been promised the exhausthousing this week,, let us all keep our fingers crossed or something to bring me luck.
    I can then start to build exhaustmanifold, the one i started to build befor has gone the drain as my plans changed a bit when i bougt the GT3582r turbo.
    Cheers.
    //Insane......
    MIG.....Made In Greece LOL
  9. #883
    Oct 2002
    Sweden
    Astra MkI
    I have found it easier for the air to deliver more equal over the runners if you do it like i have done.
    if you do the way you suggest the inlet will flow more, but with the cost of that it may deliver air differently over the runners.
    that is really bad if you want to receive big numbers on huge boost.(lots of air running)
    often it is the runner in the back from inlet in plenum that receives the most mass of air then. = no good!
    Wiseboy! : glad you like it and you took the time to read it.
    Kadett GT/E
  10. #884
    Sep 2004
    GREECE
    tigra/westy
    wouldnt plann more than 400 on a gt2876 and max 1.9 bar,my gap its about 1.5cm,should i leave it like that?
  11. #885
    Feb 2010
    Örebro, Sweden
    That car is worth killing for, Ill hope that I see it live sometime
  12. #886
    Oct 2002
    Sweden
    Astra MkI
    I´m having small plans to take it to Gatebil on Mantorp maybe, but in my eye´s it ain´t worth killing for
    Kadett GT/E
  13. #887
    Sep 2004
    GREECE
    tigra/westy
    just looked at the OEM cossie inlet,and yes they look that they have this "gap" from stock,so i think i leave them like that,and not "shave" them,so the can touch the inlet back space if not needed then.
  14. #888
    Nov 2004
    Oslo, Norway
    This looks great! (as usual)
    Hope I get to see the car live this summer!
  15. #889
    Oct 2002
    Sweden
    Astra MkI
    Pantera!
    i might be going to South Africa soon.
    What kind of possibilities is there for checking up local motorsports events?
    Kadett GT/E
  16. #890
    Oct 2002
    Sweden
    Astra MkI
    Yes, exactly. or either way help it to keep up with more pressure.
    Kadett GT/E
  17. #891
    Feb 2007
    Cape Town - S.A.
    96 Kadette 200TS
    Pantera!
    When are you coming and where will you be going. There are plenty motorsport events happening all the time.
    Opel Corsa 20xe throttle bodies - 245bhp - 13.2 1/4 mile
    Opel Corsa 20XE Turbo - 10.7 1/4 mile @ 231km/h
    Opel 200TS - eds phase 2 - water/methanol 306bhp @ 0.9 bar boost - stock turbo
  18. #892
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Love the old skool solutions to new skool problems.
    www.shonkyopels.de
  19. #893
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by Pantera View Post
    If i´m going i´ll be living in the area of Johannesburg, working for ABB.
    It´s planned for leaving here late february or early march.
    And i´ll be down there for about a month or so.
    Kadett GT/E
  20. #894
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by spanishfly View Post
    never underestimate old yankee stuff
    Kadett GT/E
  21. #895
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Should stop it
    I've never heard of this being done before, have you got any links to other people that have done it? I've tried searching but I can't find anything like it.
  22. #896
    Oct 2002
    Sweden
    Astra MkI
    well,, i have never seen anything on the web either.
    it´s a thing i snapped up long time ago in an dragrace-pit
    Kadett GT/E
  23. #897
    Dec 2005
    UK
    Coool. Looks awesome.
  24. #898
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by TigraTurbo View Post
    Yes,, Ford Engineers might just be a little bit smarter than us..
    so if you look at that manifold you are on the correct path.
    Kadett GT/E
  25. #899
    Jan 2008
    London E11
    Corsa 1.4 SRi
    Nascar Motorsport should be pretty close to ABB (near the airport?). It the home of the 8 second street legal Astra E.
    NASCAR SA
  26. #900
    Nov 2008
    South Africa
    Corsa
    Quote Originally Posted by pas-chill View Post
    NASCAR SA
    Like pas chill said also the nascar dyno day is on the 5 march with some pretty strong cars, and there should be some events at tartlton to, but ill suggest going to the nascar dyno day which is hosted by the opel owners
  1. 06-02-2012, 15:20
  2. 30-01-2012, 00:34
  3. 29-01-2012, 23:45
  4. 28-01-2012, 21:31
  5. 27-01-2012, 22:23
  6. 27-01-2012, 00:32
  7. 11-12-2011, 12:42
  8. 10-12-2011, 22:43
  9. 10-12-2011, 22:43
  10. 10-12-2011, 22:02
  11. 10-12-2011, 21:41
  12. 10-12-2011, 20:14
  13. 10-12-2011, 18:11
  14. 10-12-2011, 00:06
  15. 09-12-2011, 20:47
  16. 09-12-2011, 20:04
  17. 09-12-2011, 17:55
  18. 09-12-2011, 16:33
  19. 09-12-2011, 08:48
  20. 06-12-2011, 21:35
  21. 03-12-2011, 23:06
  22. 10-11-2011, 20:01
  23. 08-11-2011, 23:39
  24. 01-11-2011, 00:39
  25. 27-10-2011, 11:09
  26. 27-10-2011, 10:20
  27. 25-10-2011, 23:33
  28. 24-10-2011, 09:39
  29. 23-10-2011, 21:43
  30. 23-10-2011, 21:43
  31. 21-10-2011, 21:14
  32. 02-10-2011, 21:17
  33. 02-10-2011, 20:51
  34. 17-09-2011, 20:32
  35. 28-06-2011, 00:36
  36. 09-06-2011, 20:33
  37. 08-06-2011, 18:45
  38. 02-06-2011, 17:02
  39. 01-06-2011, 16:47
  40. 28-05-2011, 16:33
  41. 22-05-2011, 09:37
  42. 22-05-2011, 09:37
  43. 21-05-2011, 19:26
  44. 20-05-2011, 22:10
  45. 19-05-2011, 16:50
  46. 17-05-2011, 09:57
  47. 10-05-2011, 00:49
  48. 09-05-2011, 21:00
  49. 10-04-2011, 21:58
  50. 27-03-2011, 22:43
  51. 21-02-2011, 00:23
  52. 14-02-2011, 18:19
  53. 05-02-2011, 16:32
  54. 29-01-2011, 19:08
  55. 24-01-2011, 14:05
  56. 13-01-2011, 20:17
  57. 25-12-2010, 09:26
  58. 30-11-2010, 08:48
  59. 14-11-2010, 01:07
  60. 29-10-2010, 13:14
  61. 07-10-2010, 11:21
  62. 03-10-2010, 13:29
  63. 08-09-2010, 19:17
  64. 02-09-2010, 20:10
  65. 01-09-2010, 14:09
  66. 14-07-2010, 23:50
  67. 14-07-2010, 12:19
  68. 11-07-2010, 18:12
  69. 08-06-2010, 19:40
  70. 24-05-2010, 20:34
  71. 16-05-2010, 21:22
  72. 25-04-2010, 08:20
  73. 21-04-2010, 17:31
  74. 15-04-2010, 23:25
  75. 12-03-2010, 08:14
  76. 09-03-2010, 18:28
  77. 02-03-2010, 10:11
  78. 27-02-2010, 21:45
  79. 17-02-2010, 18:45
  80. 12-02-2010, 22:20
  81. 06-02-2010, 20:07
  82. 02-02-2010, 16:04
  83. 01-02-2010, 16:23
  84. 29-01-2010, 12:39
  85. 24-01-2010, 08:08
  86. 20-01-2010, 12:13
  87. 18-01-2010, 16:50
  88. 12-01-2010, 04:00
  89. 05-01-2010, 20:40
  90. 20-11-2009, 12:36
  91. 18-11-2009, 16:11
  92. 05-11-2009, 18:49
  93. 01-11-2009, 17:37
  94. 26-10-2009, 21:08
  95. 20-10-2009, 10:22
  96. 02-08-2009, 21:07
  97. 20-07-2009, 18:18
  98. 15-07-2009, 21:00
  99. 09-07-2009, 21:46
  100. 06-07-2009, 19:15
  101. 01-07-2009, 05:10
  102. 28-06-2009, 13:01
  103. 21-06-2009, 21:52
  104. 13-06-2009, 14:51
  105. 13-06-2009, 12:20
  106. 13-06-2009, 08:01
  107. 13-06-2009, 07:38
  108. 13-06-2009, 06:36
  109. 13-06-2009, 06:16
  110. 13-06-2009, 05:34
  111. 07-06-2009, 18:52
  112. 02-06-2009, 23:27
  113. 30-05-2009, 18:36
  114. 28-05-2009, 22:27
  115. 27-05-2009, 19:22
  116. 25-05-2009, 17:09
  117. 24-05-2009, 14:39
  118. 20-05-2009, 14:20
  119. 19-05-2009, 10:44
  120. 19-05-2009, 07:18
  121. 18-05-2009, 20:50
  122. 18-05-2009, 18:59
  123. 17-05-2009, 17:49
  124. 10-05-2009, 14:24
  125. 06-05-2009, 15:00
  126. 29-04-2009, 14:05
  127. 19-04-2009, 20:37
  128. 15-04-2009, 16:03
  129. 13-04-2009, 10:44
  130. 10-04-2009, 07:41
  131. 06-04-2009, 17:35
  132. 31-03-2009, 23:55
  133. 31-03-2009, 22:11
  134. 27-03-2009, 21:02
  135. 26-03-2009, 22:17
  136. 19-03-2009, 14:35
  137. 14-03-2009, 17:16
  138. 11-03-2009, 03:52
  139. 10-03-2009, 13:42
  140. 09-03-2009, 23:52
  141. 09-03-2009, 01:48
  142. 08-03-2009, 10:39
  143. 04-03-2009, 14:51
  144. 03-03-2009, 08:35
  145. 02-03-2009, 14:31
  146. 27-02-2009, 22:04
  147. 27-02-2009, 11:17
  148. 23-02-2009, 17:49
  149. 22-02-2009, 16:46
  150. 22-02-2009, 10:54
  151. 22-02-2009, 10:32
  152. 21-02-2009, 20:19
  153. 21-02-2009, 20:16
  154. 18-02-2009, 02:18
  155. 16-02-2009, 19:21
  156. 16-02-2009, 17:55
  157. 13-02-2009, 19:59
  158. 09-02-2009, 20:28
  159. 09-02-2009, 18:53
  160. 09-02-2009, 12:48
  161. 09-02-2009, 12:48
  162. 08-02-2009, 15:22
  163. 06-02-2009, 13:24
  164. 04-02-2009, 14:57
  165. 03-02-2009, 10:56
  166. 29-01-2009, 21:14
  167. 25-01-2009, 15:28
  168. 17-01-2009, 21:10
  169. 13-01-2009, 15:15
  170. 07-01-2009, 12:07
  171. 03-01-2009, 11:49
  172. 30-12-2008, 12:20
  173. 27-12-2008, 16:39
  174. 26-12-2008, 04:02
  175. 22-12-2008, 19:40
  176. 22-12-2008, 17:13
  177. 22-12-2008, 16:26
  178. 22-12-2008, 13:04
  179. 22-12-2008, 13:04
  180. 20-12-2008, 15:34
  181. 13-12-2008, 19:25
  182. 01-12-2008, 14:38
  183. 30-11-2008, 17:32
  184. 29-11-2008, 19:52
  185. 24-11-2008, 06:47
  186. 23-11-2008, 10:20
  187. 23-11-2008, 09:56
  188. 20-11-2008, 06:50
  189. 19-11-2008, 08:55
  190. 05-11-2008, 22:18
  191. 03-11-2008, 17:27
  192. 02-11-2008, 10:39
  193. 28-10-2008, 00:15
  194. 26-10-2008, 20:11
  195. 19-10-2008, 12:34
  196. 11-10-2008, 16:48
  197. 30-09-2008, 19:41
  198. 29-09-2008, 19:01
  199. 28-09-2008, 21:58
  200. 25-09-2008, 23:14
  201. 19-09-2008, 19:35
  202. 14-09-2008, 08:14
  203. 13-09-2008, 19:55
  204. 12-09-2008, 19:32
  205. 11-09-2008, 19:45
  206. 11-09-2008, 19:04
  207. 05-09-2008, 20:55
  208. 02-09-2008, 19:17
  209. 30-08-2008, 23:05
  210. 18-08-2008, 21:11
  211. 31-07-2008, 19:01
  212. 30-07-2008, 13:12
  213. 09-07-2008, 02:13
  214. 08-07-2008, 21:08
  215. 07-07-2008, 21:48
  216. 29-06-2008, 10:22
  217. 16-06-2008, 21:28
  218. 15-06-2008, 21:15
  219. 15-06-2008, 15:07
  220. 14-06-2008, 17:08
  221. 27-05-2008, 18:32
  222. 25-05-2008, 19:36
  223. 20-05-2008, 18:43
  224. 20-05-2008, 18:06
  225. 19-05-2008, 23:59
  226. 19-05-2008, 01:08
  227. 15-05-2008, 11:35
  228. 13-05-2008, 13:05
  229. 13-05-2008, 12:39
  230. 10-05-2008, 18:50
  231. 05-05-2008, 18:20
  232. 03-05-2008, 21:13
  233. 01-05-2008, 08:30
  234. 27-04-2008, 21:13
  235. 24-04-2008, 16:18
  236. 22-04-2008, 11:57
  237. 21-04-2008, 20:25
  238. 19-04-2008, 14:28
  239. 17-04-2008, 15:08
  240. 14-04-2008, 20:12
  241. 12-04-2008, 19:12
  242. 11-04-2008, 18:16
  243. 11-04-2008, 16:52
  244. 10-04-2008, 18:57
  245. 08-04-2008, 20:00
  246. 08-04-2008, 12:18
  247. 08-04-2008, 11:37
  248. 07-04-2008, 09:17
  249. 07-04-2008, 07:51
  250. 06-04-2008, 21:43
  251. 06-04-2008, 21:12
  252. 06-04-2008, 20:01
  253. 06-04-2008, 13:44
  254. 06-04-2008, 08:56
  255. 04-04-2008, 15:57
  256. 30-03-2008, 14:05
  257. 30-03-2008, 11:23
  258. 21-03-2008, 19:35
  259. 20-03-2008, 10:45
  260. 18-03-2008, 20:30
  261. 17-03-2008, 14:06
  262. 10-03-2008, 16:30
  263. 10-03-2008, 09:39
  264. 08-03-2008, 14:23
  265. 07-03-2008, 19:13
  266. 06-03-2008, 20:56
  267. 06-03-2008, 20:55
  268. 04-03-2008, 21:13
  269. 03-03-2008, 11:38
  270. 01-03-2008, 07:33
  271. 29-02-2008, 13:36
  272. 29-02-2008, 11:32
  273. 29-02-2008, 08:56
  274. 27-02-2008, 17:32
  275. 26-02-2008, 17:59
  276. 25-02-2008, 19:44
  277. 24-02-2008, 05:39
  278. 23-02-2008, 20:14
  279. 23-02-2008, 13:53
  280. 23-02-2008, 10:59
  281. 23-02-2008, 09:07
  282. 22-02-2008, 05:03
  283. 19-02-2008, 12:47
  284. 18-02-2008, 10:39
  285. 15-02-2008, 14:24
  286. 11-02-2008, 01:10
  287. 10-02-2008, 17:17
  288. 09-02-2008, 22:08
  289. 08-02-2008, 05:54
  290. 07-02-2008, 16:42
  291. 06-02-2008, 19:28
  292. 06-02-2008, 17:37
  293. 06-02-2008, 17:04
  294. 06-02-2008, 16:04
  295. 06-02-2008, 15:05
  296. 05-02-2008, 14:31
  297. 03-02-2008, 16:53
  298. 31-01-2008, 19:38
  299. 27-01-2008, 16:44
  300. 26-01-2008, 21:40
  301. 26-01-2008, 16:13
  302. 25-01-2008, 21:39
  303. 24-01-2008, 20:04
  304. 24-01-2008, 06:50
  305. 24-01-2008, 05:59
  306. 23-01-2008, 22:49
  307. 23-01-2008, 22:35
  308. 23-01-2008, 22:34
  309. 23-01-2008, 22:17
  310. 23-01-2008, 22:10
  311. 23-01-2008, 22:09
  312. 23-01-2008, 22:05
  313. 21-01-2008, 20:42
  314. 21-01-2008, 19:43
  315. 20-01-2008, 13:55
  316. 20-01-2008, 11:53
  317. 17-01-2008, 10:10
  318. 17-01-2008, 01:01
  319. 16-01-2008, 21:42
  320. 16-01-2008, 20:59
  321. 16-01-2008, 19:48
  322. 16-01-2008, 19:24
  323. 16-01-2008, 18:36
  324. 15-01-2008, 06:51
  325. 14-01-2008, 15:32
  326. 14-01-2008, 15:02
  327. 13-01-2008, 09:40
  328. 10-01-2008, 18:54
  329. 09-01-2008, 11:47
  330. 09-01-2008, 08:46
  331. 08-01-2008, 14:11
  332. 08-01-2008, 12:31
  333. 08-01-2008, 00:03
  334. 07-01-2008, 19:13
  335. 07-01-2008, 18:21
  336. 07-01-2008, 10:28
  337. 06-01-2008, 19:16
  338. 06-01-2008, 00:18
  339. 05-01-2008, 22:35
  340. 04-01-2008, 20:06
  341. 02-01-2008, 18:36
  342. 01-01-2008, 17:49
  343. 01-01-2008, 08:29
  344. 31-12-2007, 13:03
  345. 31-12-2007, 11:46
  346. 31-12-2007, 11:46
  347. 30-12-2007, 20:47
  348. 30-12-2007, 20:43
  349. 30-12-2007, 20:40
  350. 30-12-2007, 20:07
  351. 30-12-2007, 19:56
  352. 30-12-2007, 14:07
  353. 30-12-2007, 01:59
  354. 29-12-2007, 14:22
  355. 29-12-2007, 13:49
  356. 27-12-2007, 16:43
  357. 26-12-2007, 20:34
  358. 26-12-2007, 16:59
  359. 26-12-2007, 16:37
  360. 21-12-2007, 18:52
  361. 21-12-2007, 08:57
  362. 20-12-2007, 01:37
  363. 19-12-2007, 08:20
  364. 18-12-2007, 17:11
  365. 18-12-2007, 11:26
  366. 17-12-2007, 13:34
  367. 16-12-2007, 10:15
  368. 16-12-2007, 07:43
  369. 15-12-2007, 15:05
  370. 14-12-2007, 19:52
  371. 14-12-2007, 14:15
  372. 14-12-2007, 10:54
  373. 13-12-2007, 22:34
  374. 13-12-2007, 17:49
  375. 13-12-2007, 17:12
  376. 13-12-2007, 15:52
  377. 13-12-2007, 15:46
  378. 13-12-2007, 15:13
  379. 13-12-2007, 14:33
  380. 13-12-2007, 14:31
  381. 13-12-2007, 14:20
  382. 12-12-2007, 11:49
  383. 11-12-2007, 15:14
  384. 07-12-2007, 11:42
  385. 02-12-2007, 10:56
  386. 01-12-2007, 10:40
  387. 30-11-2007, 12:24
  388. 29-11-2007, 14:09
  389. 19-11-2007, 10:11
  390. 15-11-2007, 19:37
  391. 15-11-2007, 13:04
  392. 15-11-2007, 10:38
  393. 14-11-2007, 19:17
  394. 14-11-2007, 09:19
  395. 13-11-2007, 10:54
  396. 13-11-2007, 02:10
  397. 12-11-2007, 20:09
  398. 08-11-2007, 15:41
  399. 08-11-2007, 12:22
  400. 04-11-2007, 17:04
  401. 30-10-2007, 22:08
  402. 24-10-2007, 02:29
  403. 23-10-2007, 19:49
  404. 23-10-2007, 18:56
  405. 23-10-2007, 12:29
  406. 21-10-2007, 21:29
  407. 21-10-2007, 15:01
  408. 21-10-2007, 11:44
  409. 20-10-2007, 17:47
  410. 20-10-2007, 17:27
  411. 20-10-2007, 17:00
  412. 20-10-2007, 10:15
  413. 20-10-2007, 09:20
  414. 19-10-2007, 21:14
  415. 19-10-2007, 17:52
  416. 19-10-2007, 14:37
  417. 19-10-2007, 13:34
  418. 19-10-2007, 11:36
  419. 19-10-2007, 11:17
  420. 19-10-2007, 10:26
  421. 18-10-2007, 21:15
  422. 18-10-2007, 20:42
  423. 18-10-2007, 20:16
  424. 18-10-2007, 20:12
  425. 18-10-2007, 20:08
  426. 18-10-2007, 19:52
  427. 18-10-2007, 19:51
  428. 18-10-2007, 19:48
  429. 18-10-2007, 19:48
  430. 12-10-2007, 06:48
  431. 06-10-2007, 09:45
  432. 28-09-2007, 20:52
  433. 27-09-2007, 08:42
  434. 24-09-2007, 17:51
  435. 23-09-2007, 22:10
  436. 23-09-2007, 22:08
  437. 17-09-2007, 17:39
  438. 17-09-2007, 13:24
  439. 17-09-2007, 12:20
  440. 17-09-2007, 12:10
  441. 17-09-2007, 09:49
  442. 17-09-2007, 09:11
  443. 17-09-2007, 09:09
  444. 17-09-2007, 00:41
  445. 17-09-2007, 00:30
  446. 17-09-2007, 00:07
  447. 21-08-2007, 19:14
  448. 21-08-2007, 18:59
  449. 20-08-2007, 22:46
  450. 20-08-2007, 14:05
  451. 17-08-2007, 15:59
  452. 17-08-2007, 15:30
  453. 23-01-2007, 20:46
