Page 30 of 39 FirstFirst ... 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 LastLast
Results 726 to 750 of 972
Thread: InsaneSwede's Astra MKI
  1. #726
    Nov 2006
    Cambridgeshire
    Astra GSI MK3
    Re: InsaneSwede's Astra MKI
    good to see the project back on track, ive missed reading this thread
    300bhp mk3 astra GSI LET (a work in progress)
    Dec 2008
    banbury
    enjoyed reading through this thread! that astras an absolutely insane machine! well done
  4. #728
    Oct 2002
    Sweden
    Astra MkI
    Not much, but i´ve done a bracket for strengthening the gearbox a bit:
    Tomorrow i´m about to mount the engine and gearbox back in the car to see what i have to modify with the new inlet manifold.
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
  5. #729
    Oct 2002
    Sweden
    Astra MkI
    Testing new inletmanifold:
    This is BMW E36 M3 throttles.
    Kadett GT/E
  6. #730
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Love how compact the m3 TB's are, i did look into some from jenvey that were even more compact but only 38mm..... not usre if that would be big enough, what size are the m3 tb's?
    "THE ROB"
  7. #731
    Oct 2002
    Sweden
    Astra MkI
    ohh.. i can´t remember exatcly. became unsure.. but i think they are 52mm
    Kadett GT/E
  8. #732
    Dec 2004
    willingham near camb
    corsa xe, vectra 3.0
    Nice, not looked at this thread in ages!
    ASTRA TURBO PROJECT:http://www.migweb.co.uk/forums/projects-restorations/418177-ashtals-astra-mk4.html
  9. #733
    Dec 2001
    Braintree, Essex
    Mk3 Astra
    Quote Originally Posted by InsaneSwede View Post
    Will you flow test head with new intake on? How did old intake + head compare to piston cfm demand?
  10. #734
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by Stefan View Post
    Honestly Stefan, I don´t give a f**k about flow.
    I recon diggin deep in teories is for those who not have the talent to see how the air behaves.
    This is my ONLY flowed head as i was a little bit curios how i stood up against the Swedish pro´s.(and cncheads.co.uk)
    This head flows 308CFM at 13mm lift and 28", there were no testing, just straight off my hands.
    Other unflowed heads i have produced always deliver good hp.
    example:
    Vauxhall: 800hp powercurve still heading upward at 7k rpm were the valvesprings started to float, more rpm would have given about 860hp.(the turbo also had a little bit more to give, so about 900hp could have been a reachable goal.)
    Audi: 881hp at 2.4bar(later on raised to 2.7bar,and trapspeed at 402m also went better, about 930-940hp at 2.7bar)
    so with that in mind, i´m thinking,, no need to flow any heads...
    Kadett GT/E
  11. #735
    Oct 2002
    Sweden
    Astra MkI
    Update:
    been carpenting onthe new plenum a little:
    Kadett GT/E
  12. #736
    Oct 2002
    Sweden
    Astra MkI
    Kadett GT/E
  13. #737
    Sep 2004
    GREECE
    tigra/westy
    looks great Swede
    MIG.....Made In Greece LOL
  14. #738
    Nov 2009
    Poland
    Hello. What power to the GT35?
  15. #739
    Oct 2002
    Sweden
    Astra MkI
    Kamil, I really don´t understand the question, do you mean how much power the GT35 could deliver?
    Kadett GT/E
  16. #740
    Oct 2002
    Sweden
    Astra MkI
    Coming together, The idle airsystem is a thing i have given a thought or two.
    You can see the canister on the strutbrace, this is the 'plenum' for giving me an 'complete' vaccumsignal for the mapsensor, and you can also see that i got a manifold that looks like an fuelrail, this is where i inject the idle air into the runners.
    My thought of this is to atomize the fuel more on idle as the air has an higher speed next to the fuelinjector than if i used the throttles.
    Not many of you guys will ever have this problem as i´m running quite big injectors(1680cc) and on a small engine the injectortimes will be so very short that the fuel won´t be atomized correct.
    I hope this helps out.
    Kadett GT/E
  17. #741
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by djivesp View Post
    this thread makes my brain hurt
    pistons in the bin, 'only' 2 bar, full boost at 2800, am i reading all this right lol?!!
    Yes you´re reading correctly.
    If you put some thought into it,, big volume engine,big NA power equals a lot of exhaustgasses, this combined with an correct designed exhaustmanifold, and by that i dont just mean the manifold, i mean the whole system, i got some trick up my sleeve.
    take a look at the closest lorry or what they are called, cargotruck?
    with an small tiny turbo that delivers about 350 diesel hp, produces slightly the double on an petrol engine.
    The air and exhaustsystem is massive on those, with no restrictions at all.
    From airfilter you got about 8" pipe
    and from turbine you got about 6" system.
    Put that in mind and you get the idea that the turbocharger doesn´t want any restrictions at all.
    Plus that fact that i´ve tuned the NA engine quite high.
    simulations on engine says me that it will produce about 270hp with no boost.
    At as low rpm as 7000rpms,,
    At 3000rpm it produces almost the half of the top end power(120hp)
    An std LET engine produces about that amount at 6000rpm with no boost.
    Rgds.
    Kadett GT/E
  18. #742
    Mar 2005
    newport s.wales
    nova
    very impressive patrick
    Built by Pete Burgess, Mapped by Dave Young
  19. #743
    Oct 2002
    Sweden
    Astra MkI
    Today i have plumbed the pipes and hose for the new hydraulic clutch.
    No pic, but pedal felt perfect.
    With my 1000Nm+ clutch the pedal felt just like an std clutch =)
    Maincylinder from Toyota was easy to mount in Opel, almost like the had some work together back at -84 Opel and Toyota
    Kadett GT/E
  20. #744
    Oct 2002
    Sweden
    Astra MkI
    another post,,
    I might have forgotten to tell you about these new mods i´m updating the car with.
    Last summer when i drove the car, it was very 'on the edge' and hard to drive, had to be sharp all the time.
    Engine was easy to stall when releasing clutch.
    Why?
    because the clutch was HARD to operate and lumpy camshafts with a light cranksystem in engine.
    I´m hoping now with clutchmod and individual runner manifold it should be much smoother to drive.
    I have also mounteed back the complete std interior and have built exhaust all to the back on the vehicle.
    I might have been infected with my other cars qualities *lol*
    (yes it´s mine, I also got an Vectra OPC -06 but no pics)
    Kadett GT/E
  21. #745
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    You're going soft! lmao
  22. #746
    Nov 2009
    Poland
    hehehe . yes .how much power the GT35 could deliver ?
  23. #747
    Oct 2002
    Sweden
    Astra MkI
    It depends on a little bit.
    wich fuel and wich exhausthousing
    And how the engine is tuned.
    Say you got an 200Hp NA engine and runs on E85(colder gasses from exhaust)
    2bar on that is ~600hp.
    This turbo looses effiency fast over 2.2bar(640hp)
    But if your engine is producing say 270hp as NA the turbo won´t be able to produce all that boost, it might run into wall at somewhere around 1.7-1.8bar
    But in that area the turbo is quite a lung, calculations says ~750hp
    and the worldrecord i´ve seen is i think NorrisDesigns and 739hp.
    My engine was in that area too.the boost adjuster was in the far end and i got no more than 2.08bar at 6000rpm and lowering down to 1.88bar at 7800rpm.(closed wastegate)
    Rgds.
    Patrick
    Kadett GT/E
  24. #748
    Oct 2002
    Sweden
    Astra MkI
    Comptest done: almost evenly at 13.4bar on all cylinders.
    Oilpressure built up: 3.5bar with really bad battery,, and i mean REALLY bad...
    New oilpump is a little sweetie,, pressure builded up on just ~2 revs...
    Kadett GT/E
  25. #749
    Jun 2008
    Patra-Greece
    Astra Gsi Turbo
    Go on Patrick...
    You gave me some ideas...4WD...Toyota...
    Astra Gsi Turbo
    http://www.youtube.com/watch?v=VxItGW8XDtw
  26. #750
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Looking forward to seeing some monster graphs from this, more cc's is the way to go in LET's now i think.... makes them driveable on a decent size turbo's. Just getting the correct technology into a LET block is rare as rocking horse **** as nobody really is pushing vaux turbo's over here, its all cossies and evo's.
    "THE ROB"
  1. 06-02-2012, 15:20
  2. 30-01-2012, 00:34
  3. 29-01-2012, 23:45
  4. 28-01-2012, 21:31
  5. 27-01-2012, 22:23
  6. 27-01-2012, 00:32
  7. 11-12-2011, 12:42
  8. 10-12-2011, 22:43
  9. 10-12-2011, 22:43
  10. 10-12-2011, 22:02
  11. 10-12-2011, 21:41
  12. 10-12-2011, 20:14
  13. 10-12-2011, 18:11
  14. 10-12-2011, 00:06
  15. 09-12-2011, 20:47
  16. 09-12-2011, 20:04
  17. 09-12-2011, 17:55
  18. 09-12-2011, 16:33
  19. 09-12-2011, 08:48
  20. 06-12-2011, 21:35
  21. 03-12-2011, 23:06
  22. 10-11-2011, 20:01
  23. 08-11-2011, 23:39
  24. 01-11-2011, 00:39
  25. 27-10-2011, 11:09
  26. 27-10-2011, 10:20
  27. 25-10-2011, 23:33
  28. 24-10-2011, 09:39
  29. 23-10-2011, 21:43
  30. 23-10-2011, 21:43
  31. 21-10-2011, 21:14
  32. 02-10-2011, 21:17
  33. 02-10-2011, 20:51
  34. 17-09-2011, 20:32
  35. 28-06-2011, 00:36
  36. 09-06-2011, 20:33
  37. 08-06-2011, 18:45
  38. 02-06-2011, 17:02
  39. 01-06-2011, 16:47
  40. 28-05-2011, 16:33
  41. 22-05-2011, 09:37
  42. 22-05-2011, 09:37
  43. 21-05-2011, 19:26
  44. 20-05-2011, 22:10
  45. 19-05-2011, 16:50
  46. 17-05-2011, 09:57
  47. 10-05-2011, 00:49
  48. 09-05-2011, 21:00
  49. 10-04-2011, 21:58
  50. 27-03-2011, 22:43
  51. 21-02-2011, 00:23
  52. 14-02-2011, 18:19
  53. 05-02-2011, 16:32
  54. 29-01-2011, 19:08
  55. 24-01-2011, 14:05
  56. 13-01-2011, 20:17
  57. 25-12-2010, 09:26
  58. 30-11-2010, 08:48
  59. 14-11-2010, 01:07
  60. 29-10-2010, 13:14
  61. 07-10-2010, 11:21
  62. 03-10-2010, 13:29
  63. 08-09-2010, 19:17
  64. 02-09-2010, 20:10
  65. 01-09-2010, 14:09
  66. 14-07-2010, 23:50
  67. 14-07-2010, 12:19
  68. 11-07-2010, 18:12
  69. 08-06-2010, 19:40
  70. 24-05-2010, 20:34
  71. 16-05-2010, 21:22
  72. 25-04-2010, 08:20
  73. 21-04-2010, 17:31
  74. 15-04-2010, 23:25
  75. 12-03-2010, 08:14
  76. 09-03-2010, 18:28
  77. 02-03-2010, 10:11
  78. 27-02-2010, 21:45
  79. 17-02-2010, 18:45
  80. 12-02-2010, 22:20
  81. 06-02-2010, 20:07
  82. 02-02-2010, 16:04
  83. 01-02-2010, 16:23
  84. 29-01-2010, 12:39
  85. 24-01-2010, 08:08
  86. 20-01-2010, 12:13
  87. 18-01-2010, 16:50
  88. 12-01-2010, 04:00
  89. 05-01-2010, 20:40
  90. 20-11-2009, 12:36
  91. 18-11-2009, 16:11
  92. 05-11-2009, 18:49
  93. 01-11-2009, 17:37
  94. 26-10-2009, 21:08
  95. 20-10-2009, 10:22
  96. 02-08-2009, 21:07
  97. 20-07-2009, 18:18
  98. 15-07-2009, 21:00
  99. 09-07-2009, 21:46
  100. 06-07-2009, 19:15
  101. 01-07-2009, 05:10
  102. 28-06-2009, 13:01
  103. 21-06-2009, 21:52
  104. 13-06-2009, 14:51
  105. 13-06-2009, 12:20
  106. 13-06-2009, 08:01
  107. 13-06-2009, 07:38
  108. 13-06-2009, 06:36
  109. 13-06-2009, 06:16
  110. 13-06-2009, 05:34
  111. 07-06-2009, 18:52
  112. 02-06-2009, 23:27
  113. 30-05-2009, 18:36
  114. 28-05-2009, 22:27
  115. 27-05-2009, 19:22
  116. 25-05-2009, 17:09
  117. 24-05-2009, 14:39
  118. 20-05-2009, 14:20
  119. 19-05-2009, 10:44
  120. 19-05-2009, 07:18
  121. 18-05-2009, 20:50
  122. 18-05-2009, 18:59
  123. 17-05-2009, 17:49
  124. 10-05-2009, 14:24
  125. 06-05-2009, 15:00
  126. 29-04-2009, 14:05
  127. 19-04-2009, 20:37
  128. 15-04-2009, 16:03
  129. 13-04-2009, 10:44
  130. 10-04-2009, 07:41
  131. 06-04-2009, 17:35
  132. 31-03-2009, 23:55
  133. 31-03-2009, 22:11
  134. 27-03-2009, 21:02
  135. 26-03-2009, 22:17
  136. 19-03-2009, 14:35
  137. 14-03-2009, 17:16
  138. 11-03-2009, 03:52
  139. 10-03-2009, 13:42
  140. 09-03-2009, 23:52
  141. 09-03-2009, 01:48
  142. 08-03-2009, 10:39
  143. 04-03-2009, 14:51
  144. 03-03-2009, 08:35
  145. 02-03-2009, 14:31
  146. 27-02-2009, 22:04
  147. 27-02-2009, 11:17
  148. 23-02-2009, 17:49
  149. 22-02-2009, 16:46
  150. 22-02-2009, 10:54
  151. 22-02-2009, 10:32
  152. 21-02-2009, 20:19
  153. 21-02-2009, 20:16
  154. 18-02-2009, 02:18
  155. 16-02-2009, 19:21
  156. 16-02-2009, 17:55
  157. 13-02-2009, 19:59
  158. 09-02-2009, 20:28
  159. 09-02-2009, 18:53
  160. 09-02-2009, 12:48
  161. 09-02-2009, 12:48
  162. 08-02-2009, 15:22
  163. 06-02-2009, 13:24
  164. 04-02-2009, 14:57
  165. 03-02-2009, 10:56
  166. 29-01-2009, 21:14
  167. 25-01-2009, 15:28
  168. 17-01-2009, 21:10
  169. 13-01-2009, 15:15
  170. 07-01-2009, 12:07
  171. 03-01-2009, 11:49
  172. 30-12-2008, 12:20
  173. 27-12-2008, 16:39
  174. 26-12-2008, 04:02
  175. 22-12-2008, 19:40
  176. 22-12-2008, 17:13
  177. 22-12-2008, 16:26
  178. 22-12-2008, 13:04
  179. 22-12-2008, 13:04
  180. 20-12-2008, 15:34
  181. 13-12-2008, 19:25
  182. 01-12-2008, 14:38
  183. 30-11-2008, 17:32
  184. 29-11-2008, 19:52
  185. 24-11-2008, 06:47
  186. 23-11-2008, 10:20
  187. 23-11-2008, 09:56
  188. 20-11-2008, 06:50
  189. 19-11-2008, 08:55
  190. 05-11-2008, 22:18
  191. 03-11-2008, 17:27
  192. 02-11-2008, 10:39
  193. 28-10-2008, 00:15
  194. 26-10-2008, 20:11
  195. 19-10-2008, 12:34
  196. 11-10-2008, 16:48
  197. 30-09-2008, 19:41
  198. 29-09-2008, 19:01
  199. 28-09-2008, 21:58
  200. 25-09-2008, 23:14
  201. 19-09-2008, 19:35
  202. 14-09-2008, 08:14
  203. 13-09-2008, 19:55
  204. 12-09-2008, 19:32
  205. 11-09-2008, 19:45
  206. 11-09-2008, 19:04
  207. 05-09-2008, 20:55
  208. 02-09-2008, 19:17
  209. 30-08-2008, 23:05
  210. 18-08-2008, 21:11
  211. 31-07-2008, 19:01
  212. 30-07-2008, 13:12
  213. 09-07-2008, 02:13
  214. 08-07-2008, 21:08
  215. 07-07-2008, 21:48
  216. 29-06-2008, 10:22
  217. 16-06-2008, 21:28
  218. 15-06-2008, 21:15
  219. 15-06-2008, 15:07
  220. 14-06-2008, 17:08
  221. 27-05-2008, 18:32
  222. 25-05-2008, 19:36
  223. 20-05-2008, 18:43
  224. 20-05-2008, 18:06
  225. 19-05-2008, 23:59
  226. 19-05-2008, 01:08
  227. 15-05-2008, 11:35
  228. 13-05-2008, 13:05
  229. 13-05-2008, 12:39
  230. 10-05-2008, 18:50
  231. 05-05-2008, 18:20
  232. 03-05-2008, 21:13
  233. 01-05-2008, 08:30
  234. 27-04-2008, 21:13
  235. 24-04-2008, 16:18
  236. 22-04-2008, 11:57
  237. 21-04-2008, 20:25
  238. 19-04-2008, 14:28
  239. 17-04-2008, 15:08
  240. 14-04-2008, 20:12
  241. 12-04-2008, 19:12
  242. 11-04-2008, 18:16
  243. 11-04-2008, 16:52
  244. 10-04-2008, 18:57
  245. 08-04-2008, 20:00
  246. 08-04-2008, 12:18
  247. 08-04-2008, 11:37
  248. 07-04-2008, 09:17
  249. 07-04-2008, 07:51
  250. 06-04-2008, 21:43
  251. 06-04-2008, 21:12
  252. 06-04-2008, 20:01
  253. 06-04-2008, 13:44
  254. 06-04-2008, 08:56
  255. 04-04-2008, 15:57
  256. 30-03-2008, 14:05
  257. 30-03-2008, 11:23
  258. 21-03-2008, 19:35
  259. 20-03-2008, 10:45
  260. 18-03-2008, 20:30
  261. 17-03-2008, 14:06
  262. 10-03-2008, 16:30
  263. 10-03-2008, 09:39
  264. 08-03-2008, 14:23
  265. 07-03-2008, 19:13
  266. 06-03-2008, 20:56
  267. 06-03-2008, 20:55
  268. 04-03-2008, 21:13
  269. 03-03-2008, 11:38
  270. 01-03-2008, 07:33
  271. 29-02-2008, 13:36
  272. 29-02-2008, 11:32
  273. 29-02-2008, 08:56
  274. 27-02-2008, 17:32
  275. 26-02-2008, 17:59
  276. 25-02-2008, 19:44
  277. 24-02-2008, 05:39
  278. 23-02-2008, 20:14
  279. 23-02-2008, 13:53
  280. 23-02-2008, 10:59
  281. 23-02-2008, 09:07
  282. 22-02-2008, 05:03
  283. 19-02-2008, 12:47
  284. 18-02-2008, 10:39
  285. 15-02-2008, 14:24
  286. 11-02-2008, 01:10
  287. 10-02-2008, 17:17
  288. 09-02-2008, 22:08
  289. 08-02-2008, 05:54
  290. 07-02-2008, 16:42
  291. 06-02-2008, 19:28
  292. 06-02-2008, 17:37
  293. 06-02-2008, 17:04
  294. 06-02-2008, 16:04
  295. 06-02-2008, 15:05
  296. 05-02-2008, 14:31
  297. 03-02-2008, 16:53
  298. 31-01-2008, 19:38
  299. 27-01-2008, 16:44
  300. 26-01-2008, 21:40
  301. 26-01-2008, 16:13
  302. 25-01-2008, 21:39
  303. 24-01-2008, 20:04
  304. 24-01-2008, 06:50
  305. 24-01-2008, 05:59
  306. 23-01-2008, 22:49
  307. 23-01-2008, 22:35
  308. 23-01-2008, 22:34
  309. 23-01-2008, 22:17
  310. 23-01-2008, 22:10
  311. 23-01-2008, 22:09
  312. 23-01-2008, 22:05
  313. 21-01-2008, 20:42
  314. 21-01-2008, 19:43
  315. 20-01-2008, 13:55
  316. 20-01-2008, 11:53
  317. 17-01-2008, 10:10
  318. 17-01-2008, 01:01
  319. 16-01-2008, 21:42
  320. 16-01-2008, 20:59
  321. 16-01-2008, 19:48
  322. 16-01-2008, 19:24
  323. 16-01-2008, 18:36
  324. 15-01-2008, 06:51
  325. 14-01-2008, 15:32
  326. 14-01-2008, 15:02
  327. 13-01-2008, 09:40
  328. 10-01-2008, 18:54
  329. 09-01-2008, 11:47
  330. 09-01-2008, 08:46
  331. 08-01-2008, 14:11
  332. 08-01-2008, 12:31
  333. 08-01-2008, 00:03
  334. 07-01-2008, 19:13
  335. 07-01-2008, 18:21
  336. 07-01-2008, 10:28
  337. 06-01-2008, 19:16
  338. 06-01-2008, 00:18
  339. 05-01-2008, 22:35
  340. 04-01-2008, 20:06
  341. 02-01-2008, 18:36
  342. 01-01-2008, 17:49
  343. 01-01-2008, 08:29
  344. 31-12-2007, 13:03
  345. 31-12-2007, 11:46
  346. 31-12-2007, 11:46
  347. 30-12-2007, 20:47
  348. 30-12-2007, 20:43
  349. 30-12-2007, 20:40
  350. 30-12-2007, 20:07
  351. 30-12-2007, 19:56
  352. 30-12-2007, 14:07
  353. 30-12-2007, 01:59
  354. 29-12-2007, 14:22
  355. 29-12-2007, 13:49
  356. 27-12-2007, 16:43
  357. 26-12-2007, 20:34
  358. 26-12-2007, 16:59
  359. 26-12-2007, 16:37
  360. 21-12-2007, 18:52
  361. 21-12-2007, 08:57
  362. 20-12-2007, 01:37
  363. 19-12-2007, 08:20
  364. 18-12-2007, 17:11
  365. 18-12-2007, 11:26
  366. 17-12-2007, 13:34
  367. 16-12-2007, 10:15
  368. 16-12-2007, 07:43
  369. 15-12-2007, 15:05
  370. 14-12-2007, 19:52
  371. 14-12-2007, 14:15
  372. 14-12-2007, 10:54
  373. 13-12-2007, 22:34
  374. 13-12-2007, 17:49
  375. 13-12-2007, 17:12
  376. 13-12-2007, 15:52
  377. 13-12-2007, 15:46
  378. 13-12-2007, 15:13
  379. 13-12-2007, 14:33
  380. 13-12-2007, 14:31
  381. 13-12-2007, 14:20
  382. 12-12-2007, 11:49
  383. 11-12-2007, 15:14
  384. 07-12-2007, 11:42
  385. 02-12-2007, 10:56
  386. 01-12-2007, 10:40
  387. 30-11-2007, 12:24
  388. 29-11-2007, 14:09
  389. 19-11-2007, 10:11
  390. 15-11-2007, 19:37
  391. 15-11-2007, 13:04
  392. 15-11-2007, 10:38
  393. 14-11-2007, 19:17
  394. 14-11-2007, 09:19
  395. 13-11-2007, 10:54
  396. 13-11-2007, 02:10
  397. 12-11-2007, 20:09
  398. 08-11-2007, 15:41
  399. 08-11-2007, 12:22
  400. 04-11-2007, 17:04
  401. 30-10-2007, 22:08
  402. 24-10-2007, 02:29
  403. 23-10-2007, 19:49
  404. 23-10-2007, 18:56
  405. 23-10-2007, 12:29
  406. 21-10-2007, 21:29
  407. 21-10-2007, 15:01
  408. 21-10-2007, 11:44
  409. 20-10-2007, 17:47
  410. 20-10-2007, 17:27
  411. 20-10-2007, 17:00
  412. 20-10-2007, 10:15
  413. 20-10-2007, 09:20
  414. 19-10-2007, 21:14
  415. 19-10-2007, 17:52
  416. 19-10-2007, 14:37
  417. 19-10-2007, 13:34
  418. 19-10-2007, 11:36
  419. 19-10-2007, 11:17
  420. 19-10-2007, 10:26
  421. 18-10-2007, 21:15
  422. 18-10-2007, 20:42
  423. 18-10-2007, 20:16
  424. 18-10-2007, 20:12
  425. 18-10-2007, 20:08
  426. 18-10-2007, 19:52
  427. 18-10-2007, 19:51
  428. 18-10-2007, 19:48
  429. 18-10-2007, 19:48
  430. 12-10-2007, 06:48
  431. 06-10-2007, 09:45
  432. 28-09-2007, 20:52
  433. 27-09-2007, 08:42
  434. 24-09-2007, 17:51
  435. 23-09-2007, 22:10
  436. 23-09-2007, 22:08
  437. 17-09-2007, 17:39
  438. 17-09-2007, 13:24
  439. 17-09-2007, 12:20
  440. 17-09-2007, 12:10
  441. 17-09-2007, 09:49
  442. 17-09-2007, 09:11
  443. 17-09-2007, 09:09
  444. 17-09-2007, 00:41
  445. 17-09-2007, 00:30
  446. 17-09-2007, 00:07
  447. 21-08-2007, 19:14
  448. 21-08-2007, 18:59
  449. 20-08-2007, 22:46
  450. 20-08-2007, 14:05
  451. 17-08-2007, 15:59
  452. 17-08-2007, 15:30
  453. 23-01-2007, 20:46
