Page 28 of 39 FirstFirst ... 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 ... LastLast
Results 676 to 700 of 972
Thread: InsaneSwede's Astra MKI
  1. #676
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Re: InsaneSwede's Astra MKI
    Shame about your mates engine.
    Yeah there definatly some valves thats are a bit suspect, the ones in Rick Drapers last build didn't even get through final mapping without breaking. I try to stick to QED valves.
    Steveboyslim is the dude to speak to for pistons and it'll be worth asking him about valves while you on.
    "THE ROB"
    Macclesfield
    www.Retrobike.c
    Steve sorted my valves from Paul Ivey iirc or someone like that. I had autosprint valves in my let and they did not last long, 3 pulls on the rolling road and one started to fail. Right load of **** imho, it was false economy as i saved about £100 on the valves and it cost me about £400 at least.
  4. #678
    Jun 2008
    Patra-Greece
    Astra Gsi Turbo
    Quote Originally Posted by Rs1 View Post
    What do you think about QED valves?
    Simon is a friend of mine..
    Astra Gsi Turbo
    http://www.youtube.com/watch?v=VxItGW8XDtw
  5. #679
    Oct 2005
    Oswestry
    corsa c 1.3
    what kind of gains do you expect to see with the m3 throttle bodies? are they much hassle to fit also?
    keep up the good work
  6. #680
    Mar 2009
    Estonia
    In particular which Volvo`s models valve springs do you use? Can you be more specific regarding the mark, year etc,
  7. #681
    Jun 2008
    Patra-Greece
    Astra Gsi Turbo
    Quote Originally Posted by InsaneSwede View Post
    Yesterday my friends Omega wen´t BOOM!!!
    This is the result:
    we´re trying to rebuild it, but i´ve got a couple of questions for you guys.
    First,, are there any 'bad quality valves' on the market in UK?
    Theese ones were stainless 34/30mm valves and they were bought from UK.
    And second, are there any reseller of JE-pistons that you might know of, that sells pistons one on one, not a complete set?
    Rgds
    Patrick
    Big damage Patrick...
    It seems to me that the valves tached to the pistons...
    Astra Gsi Turbo
  8. #682
    Oct 2002
    Sweden
    Astra MkI
    Yes they have touched the pistons, probably why they wen´t off.
    but ordinary valves only get 'krooked'
    We are running 34kg seatpressure on the valvesprings, BUT!! when dynoing the engine the at the time ran stdsprings(24kg) didn´t take the pressure at all above 7k rpm´s
    Now when he changed the springs and rised the rpmlimit to 7500rpm the engine blew..
    They might have taken some damage at dyno.
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
  9. #683
    Oct 2002
    Sweden
    Astra MkI
    Marco: I have to come back to you on that question(don´t remember)
    Kadett GT/E
  10. #684
    Oct 2002
    Sweden
    Astra MkI
    Movietime!!
    a friend of mine´s Audi S2(i have ported and flowed the head) 883hp
    http://www.youtube.com/watch?v=J15qbuGzQx8
    Kadett GT/E
  11. #685
    May 2001
    South Wales
    Nippy Cav Turbo
    Movietime!!
    lush! i wanna get a S3 eventally..when i mature and turbo it bigger
  12. #686
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by rudd86 View Post
    I just made an adapterplate between opelhead and BMW throttles, piece of cake actually.
    you just have to portmatch them together afterwards.
    In my case i had to port the bodies, i think you have to port the head to fit.
    i run quite big runners in head
    (51x31mm at inlet)
    The gains i´m after is to smoothen out my lumpy idle.
    And i might get a little more flow as these ones taper more correctly than my old manifold.
    But the big reason is to get more drivability.
    Kadett GT/E
  13. #687
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by Rick Draper View Post
    Those were the the ones
    Kadett GT/E
  14. #688
    Jun 2008
    Patra-Greece
    Astra Gsi Turbo
    Patrick here it is our C20XE with M3 throtlle bodies.
    You see that we made them to look to the top.
    Astra Gsi Turbo
  15. #689
    Oct 2002
    Sweden
    Astra MkI
    Cool.
    i had ideas to do the same way. but as i´m running boosted engine i thought it doesen´t matter.
    i also see you did it the same way as me with an adapterplate =)
    Kadett GT/E
  16. #690
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Movietime!!
    Full engine spec please as I also have a S2
    Bad luck on those valves, for peace of mind maybe Paul Ivey or REC valves would of been better but I still firmly believe the one that failed in Ricks was simply down to something other than a poor quality valve.
    I personally thought the heads snapping off was quite normal on a set of wasted valves as they are obviously weak in that area, especially if they take a hit from the piston.
  17. #691
    Jun 2008
    Patra-Greece
    Astra Gsi Turbo
    Cool.
    Exactlly.
    Astra Gsi Turbo
  18. #692
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by jonlem View Post
    Let´s see..
    Head modified by me
    286 degree camshafts with 11.6mm lift
    Uprated valves on exhaust.
    JE pistons
    Verdi rods
    Fully balanced
    Tubular manifold
    GT4088 turbo
    Race inletmanifold from www.furans.se a friend of mine)
    1200cc injectors
    E85 fuel
    Arp bolts.
    Actually when i think of it,, there´s nothing special about the engine.
    it runs at 2.4bar of boost, so there´s good flow through the head.
    Revlimit at 8500rpm.
    Kadett GT/E
  19. #693
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Impressive stuff, thanks for the info !
  20. #694
    Aug 2006
    huntingdon
    E46M3/GSXR750/RWD SCOOB
    Bring it round James, we use the Novas GT4088 and the 1200cc squirts on the Audi lmaolmaolmao
    add a set of rods for safety we should see 765 PUB BHP lmao
  21. #695
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Don't even tempt me ! I could happily sell up just to throw all the money at the Audi when you hear one with that much grunt lmao
  22. #696
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    http://www.youtube.com/watch?v=OqQGl...eature=related
    Just listen to that !!!! screw your poxy vauxhalls, thats a proper sounding engine
    ABY engine ? what transmission and clutch ?
  23. #697
    Mar 2008
    Fareham
    c20let corsa
    i love this mk 1! looks awesome!
  24. #698
    Mar 2008
    Fareham
    c20let corsa
    sweet jesus! lmao!
  25. #699
    Feb 2009
    suffolk
    just read this, tis very nice, great craftsmanship
  26. #700
    Nov 2005
    A little update:
    These are bodies from BMW E36 M3
    They measure 50mm in diam. and almost fits perfect on my head.
    I´ll just manufacture an 10mm adapterplate between head and manifold.
    Piece of cake =)
    That looks beasty!
    Impressed by the almost perfect fitment!
    Let´s see..
    Head modified by me
    JE pistons
    Verdi rods
    Fully balanced
    Tubular manifold
    GT4088 turbo
    1200cc injectors
    E85 fuel
    Arp bolts.
    Thats a nicely specced S2 engine! Obviously works well if its making nearly 900 hp!!
    Just awesome!
    What are the differences between the different Audi 20v 5 pots?
    I'm after one for my project and want to know which one to go for!
    Keep up the good work InsaneSwede! You live up to your name alright!!
  1. 06-02-2012, 15:20
  2. 30-01-2012, 00:34
  3. 29-01-2012, 23:45
  4. 28-01-2012, 21:31
  5. 27-01-2012, 22:23
  6. 27-01-2012, 00:32
  7. 11-12-2011, 12:42
  8. 10-12-2011, 22:43
  9. 10-12-2011, 22:43
  10. 10-12-2011, 22:02
  11. 10-12-2011, 21:41
  12. 10-12-2011, 20:14
  13. 10-12-2011, 18:11
  14. 10-12-2011, 00:06
  15. 09-12-2011, 20:47
  16. 09-12-2011, 20:04
  17. 09-12-2011, 17:55
  18. 09-12-2011, 16:33
  19. 09-12-2011, 08:48
  20. 06-12-2011, 21:35
  21. 03-12-2011, 23:06
  22. 10-11-2011, 20:01
  23. 08-11-2011, 23:39
  24. 01-11-2011, 00:39
  25. 27-10-2011, 11:09
  26. 27-10-2011, 10:20
  27. 25-10-2011, 23:33
  28. 24-10-2011, 09:39
  29. 23-10-2011, 21:43
  30. 23-10-2011, 21:43
  31. 21-10-2011, 21:14
  32. 02-10-2011, 21:17
  33. 02-10-2011, 20:51
  34. 17-09-2011, 20:32
  35. 28-06-2011, 00:36
  36. 09-06-2011, 20:33
  37. 08-06-2011, 18:45
  38. 02-06-2011, 17:02
  39. 01-06-2011, 16:47
  40. 28-05-2011, 16:33
  41. 22-05-2011, 09:37
  42. 22-05-2011, 09:37
  43. 21-05-2011, 19:26
  44. 20-05-2011, 22:10
  45. 19-05-2011, 16:50
  46. 17-05-2011, 09:57
  47. 10-05-2011, 00:49
  48. 09-05-2011, 21:00
  49. 10-04-2011, 21:58
  50. 27-03-2011, 22:43
  51. 21-02-2011, 00:23
  52. 14-02-2011, 18:19
  53. 05-02-2011, 16:32
  54. 29-01-2011, 19:08
  55. 24-01-2011, 14:05
  56. 13-01-2011, 20:17
  57. 25-12-2010, 09:26
  58. 30-11-2010, 08:48
  59. 14-11-2010, 01:07
  60. 29-10-2010, 13:14
  61. 07-10-2010, 11:21
  62. 03-10-2010, 13:29
  63. 08-09-2010, 19:17
  64. 02-09-2010, 20:10
  65. 01-09-2010, 14:09
  66. 14-07-2010, 23:50
  67. 14-07-2010, 12:19
  68. 11-07-2010, 18:12
  69. 08-06-2010, 19:40
  70. 24-05-2010, 20:34
  71. 16-05-2010, 21:22
  72. 25-04-2010, 08:20
  73. 21-04-2010, 17:31
  74. 15-04-2010, 23:25
  75. 12-03-2010, 08:14
  76. 09-03-2010, 18:28
  77. 02-03-2010, 10:11
  78. 27-02-2010, 21:45
  79. 17-02-2010, 18:45
  80. 12-02-2010, 22:20
  81. 06-02-2010, 20:07
  82. 02-02-2010, 16:04
  83. 01-02-2010, 16:23
  84. 29-01-2010, 12:39
  85. 24-01-2010, 08:08
  86. 20-01-2010, 12:13
  87. 18-01-2010, 16:50
  88. 12-01-2010, 04:00
  89. 05-01-2010, 20:40
  90. 20-11-2009, 12:36
  91. 18-11-2009, 16:11
  92. 05-11-2009, 18:49
  93. 01-11-2009, 17:37
  94. 26-10-2009, 21:08
  95. 20-10-2009, 10:22
  96. 02-08-2009, 21:07
  97. 20-07-2009, 18:18
  98. 15-07-2009, 21:00
  99. 09-07-2009, 21:46
  100. 06-07-2009, 19:15
  101. 01-07-2009, 05:10
  102. 28-06-2009, 13:01
  103. 21-06-2009, 21:52
  104. 13-06-2009, 14:51
  105. 13-06-2009, 12:20
  106. 13-06-2009, 08:01
  107. 13-06-2009, 07:38
  108. 13-06-2009, 06:36
  109. 13-06-2009, 06:16
  110. 13-06-2009, 05:34
  111. 07-06-2009, 18:52
  112. 02-06-2009, 23:27
  113. 30-05-2009, 18:36
  114. 28-05-2009, 22:27
  115. 27-05-2009, 19:22
  116. 25-05-2009, 17:09
  117. 24-05-2009, 14:39
  118. 20-05-2009, 14:20
  119. 19-05-2009, 10:44
  120. 19-05-2009, 07:18
  121. 18-05-2009, 20:50
  122. 18-05-2009, 18:59
  123. 17-05-2009, 17:49
  124. 10-05-2009, 14:24
  125. 06-05-2009, 15:00
  126. 29-04-2009, 14:05
  127. 19-04-2009, 20:37
  128. 15-04-2009, 16:03
  129. 13-04-2009, 10:44
  130. 10-04-2009, 07:41
  131. 06-04-2009, 17:35
  132. 31-03-2009, 23:55
  133. 31-03-2009, 22:11
  134. 27-03-2009, 21:02
  135. 26-03-2009, 22:17
  136. 19-03-2009, 14:35
  137. 14-03-2009, 17:16
  138. 11-03-2009, 03:52
  139. 10-03-2009, 13:42
  140. 09-03-2009, 23:52
  141. 09-03-2009, 01:48
  142. 08-03-2009, 10:39
  143. 04-03-2009, 14:51
  144. 03-03-2009, 08:35
  145. 02-03-2009, 14:31
  146. 27-02-2009, 22:04
  147. 27-02-2009, 11:17
  148. 23-02-2009, 17:49
  149. 22-02-2009, 16:46
  150. 22-02-2009, 10:54
  151. 22-02-2009, 10:32
  152. 21-02-2009, 20:19
  153. 21-02-2009, 20:16
  154. 18-02-2009, 02:18
  155. 16-02-2009, 19:21
  156. 16-02-2009, 17:55
  157. 13-02-2009, 19:59
  158. 09-02-2009, 20:28
  159. 09-02-2009, 18:53
  160. 09-02-2009, 12:48
  161. 09-02-2009, 12:48
  162. 08-02-2009, 15:22
  163. 06-02-2009, 13:24
  164. 04-02-2009, 14:57
  165. 03-02-2009, 10:56
  166. 29-01-2009, 21:14
  167. 25-01-2009, 15:28
  168. 17-01-2009, 21:10
  169. 13-01-2009, 15:15
  170. 07-01-2009, 12:07
  171. 03-01-2009, 11:49
  172. 30-12-2008, 12:20
  173. 27-12-2008, 16:39
  174. 26-12-2008, 04:02
  175. 22-12-2008, 19:40
  176. 22-12-2008, 17:13
  177. 22-12-2008, 16:26
  178. 22-12-2008, 13:04
  179. 22-12-2008, 13:04
  180. 20-12-2008, 15:34
  181. 13-12-2008, 19:25
  182. 01-12-2008, 14:38
  183. 30-11-2008, 17:32
  184. 29-11-2008, 19:52
  185. 24-11-2008, 06:47
  186. 23-11-2008, 10:20
  187. 23-11-2008, 09:56
  188. 20-11-2008, 06:50
  189. 19-11-2008, 08:55
  190. 05-11-2008, 22:18
  191. 03-11-2008, 17:27
  192. 02-11-2008, 10:39
  193. 28-10-2008, 00:15
  194. 26-10-2008, 20:11
  195. 19-10-2008, 12:34
  196. 11-10-2008, 16:48
  197. 30-09-2008, 19:41
  198. 29-09-2008, 19:01
  199. 28-09-2008, 21:58
  200. 25-09-2008, 23:14
  201. 19-09-2008, 19:35
  202. 14-09-2008, 08:14
  203. 13-09-2008, 19:55
  204. 12-09-2008, 19:32
  205. 11-09-2008, 19:45
  206. 11-09-2008, 19:04
  207. 05-09-2008, 20:55
  208. 02-09-2008, 19:17
  209. 30-08-2008, 23:05
  210. 18-08-2008, 21:11
  211. 31-07-2008, 19:01
  212. 30-07-2008, 13:12
  213. 09-07-2008, 02:13
  214. 08-07-2008, 21:08
  215. 07-07-2008, 21:48
  216. 29-06-2008, 10:22
  217. 16-06-2008, 21:28
  218. 15-06-2008, 21:15
  219. 15-06-2008, 15:07
  220. 14-06-2008, 17:08
  221. 27-05-2008, 18:32
  222. 25-05-2008, 19:36
  223. 20-05-2008, 18:43
  224. 20-05-2008, 18:06
  225. 19-05-2008, 23:59
  226. 19-05-2008, 01:08
  227. 15-05-2008, 11:35
  228. 13-05-2008, 13:05
  229. 13-05-2008, 12:39
  230. 10-05-2008, 18:50
  231. 05-05-2008, 18:20
  232. 03-05-2008, 21:13
  233. 01-05-2008, 08:30
  234. 27-04-2008, 21:13
  235. 24-04-2008, 16:18
  236. 22-04-2008, 11:57
  237. 21-04-2008, 20:25
  238. 19-04-2008, 14:28
  239. 17-04-2008, 15:08
  240. 14-04-2008, 20:12
  241. 12-04-2008, 19:12
  242. 11-04-2008, 18:16
  243. 11-04-2008, 16:52
  244. 10-04-2008, 18:57
  245. 08-04-2008, 20:00
  246. 08-04-2008, 12:18
  247. 08-04-2008, 11:37
  248. 07-04-2008, 09:17
  249. 07-04-2008, 07:51
  250. 06-04-2008, 21:43
  251. 06-04-2008, 21:12
  252. 06-04-2008, 20:01
  253. 06-04-2008, 13:44
  254. 06-04-2008, 08:56
  255. 04-04-2008, 15:57
  256. 30-03-2008, 14:05
  257. 30-03-2008, 11:23
  258. 21-03-2008, 19:35
  259. 20-03-2008, 10:45
  260. 18-03-2008, 20:30
  261. 17-03-2008, 14:06
  262. 10-03-2008, 16:30
  263. 10-03-2008, 09:39
  264. 08-03-2008, 14:23
  265. 07-03-2008, 19:13
  266. 06-03-2008, 20:56
  267. 06-03-2008, 20:55
  268. 04-03-2008, 21:13
  269. 03-03-2008, 11:38
  270. 01-03-2008, 07:33
  271. 29-02-2008, 13:36
  272. 29-02-2008, 11:32
  273. 29-02-2008, 08:56
  274. 27-02-2008, 17:32
  275. 26-02-2008, 17:59
  276. 25-02-2008, 19:44
  277. 24-02-2008, 05:39
  278. 23-02-2008, 20:14
  279. 23-02-2008, 13:53
  280. 23-02-2008, 10:59
  281. 23-02-2008, 09:07
  282. 22-02-2008, 05:03
  283. 19-02-2008, 12:47
  284. 18-02-2008, 10:39
  285. 15-02-2008, 14:24
  286. 11-02-2008, 01:10
  287. 10-02-2008, 17:17
  288. 09-02-2008, 22:08
  289. 08-02-2008, 05:54
  290. 07-02-2008, 16:42
  291. 06-02-2008, 19:28
  292. 06-02-2008, 17:37
  293. 06-02-2008, 17:04
  294. 06-02-2008, 16:04
  295. 06-02-2008, 15:05
  296. 05-02-2008, 14:31
  297. 03-02-2008, 16:53
  298. 31-01-2008, 19:38
  299. 27-01-2008, 16:44
  300. 26-01-2008, 21:40
  301. 26-01-2008, 16:13
  302. 25-01-2008, 21:39
  303. 24-01-2008, 20:04
  304. 24-01-2008, 06:50
  305. 24-01-2008, 05:59
  306. 23-01-2008, 22:49
  307. 23-01-2008, 22:35
  308. 23-01-2008, 22:34
  309. 23-01-2008, 22:17
  310. 23-01-2008, 22:10
  311. 23-01-2008, 22:09
  312. 23-01-2008, 22:05
  313. 21-01-2008, 20:42
  314. 21-01-2008, 19:43
  315. 20-01-2008, 13:55
  316. 20-01-2008, 11:53
  317. 17-01-2008, 10:10
  318. 17-01-2008, 01:01
  319. 16-01-2008, 21:42
  320. 16-01-2008, 20:59
  321. 16-01-2008, 19:48
  322. 16-01-2008, 19:24
  323. 16-01-2008, 18:36
  324. 15-01-2008, 06:51
  325. 14-01-2008, 15:32
  326. 14-01-2008, 15:02
  327. 13-01-2008, 09:40
  328. 10-01-2008, 18:54
  329. 09-01-2008, 11:47
  330. 09-01-2008, 08:46
  331. 08-01-2008, 14:11
  332. 08-01-2008, 12:31
  333. 08-01-2008, 00:03
  334. 07-01-2008, 19:13
  335. 07-01-2008, 18:21
  336. 07-01-2008, 10:28
  337. 06-01-2008, 19:16
  338. 06-01-2008, 00:18
  339. 05-01-2008, 22:35
  340. 04-01-2008, 20:06
  341. 02-01-2008, 18:36
  342. 01-01-2008, 17:49
  343. 01-01-2008, 08:29
  344. 31-12-2007, 13:03
  345. 31-12-2007, 11:46
  346. 31-12-2007, 11:46
  347. 30-12-2007, 20:47
  348. 30-12-2007, 20:43
  349. 30-12-2007, 20:40
  350. 30-12-2007, 20:07
  351. 30-12-2007, 19:56
  352. 30-12-2007, 14:07
  353. 30-12-2007, 01:59
  354. 29-12-2007, 14:22
  355. 29-12-2007, 13:49
  356. 27-12-2007, 16:43
  357. 26-12-2007, 20:34
  358. 26-12-2007, 16:59
  359. 26-12-2007, 16:37
  360. 21-12-2007, 18:52
  361. 21-12-2007, 08:57
  362. 20-12-2007, 01:37
  363. 19-12-2007, 08:20
  364. 18-12-2007, 17:11
  365. 18-12-2007, 11:26
  366. 17-12-2007, 13:34
  367. 16-12-2007, 10:15
  368. 16-12-2007, 07:43
  369. 15-12-2007, 15:05
  370. 14-12-2007, 19:52
  371. 14-12-2007, 14:15
  372. 14-12-2007, 10:54
  373. 13-12-2007, 22:34
  374. 13-12-2007, 17:49
  375. 13-12-2007, 17:12
  376. 13-12-2007, 15:52
  377. 13-12-2007, 15:46
  378. 13-12-2007, 15:13
  379. 13-12-2007, 14:33
  380. 13-12-2007, 14:31
  381. 13-12-2007, 14:20
  382. 12-12-2007, 11:49
  383. 11-12-2007, 15:14
  384. 07-12-2007, 11:42
  385. 02-12-2007, 10:56
  386. 01-12-2007, 10:40
  387. 30-11-2007, 12:24
  388. 29-11-2007, 14:09
  389. 19-11-2007, 10:11
  390. 15-11-2007, 19:37
  391. 15-11-2007, 13:04
  392. 15-11-2007, 10:38
  393. 14-11-2007, 19:17
  394. 14-11-2007, 09:19
  395. 13-11-2007, 10:54
  396. 13-11-2007, 02:10
  397. 12-11-2007, 20:09
  398. 08-11-2007, 15:41
  399. 08-11-2007, 12:22
  400. 04-11-2007, 17:04
  401. 30-10-2007, 22:08
  402. 24-10-2007, 02:29
  403. 23-10-2007, 19:49
  404. 23-10-2007, 18:56
  405. 23-10-2007, 12:29
  406. 21-10-2007, 21:29
  407. 21-10-2007, 15:01
  408. 21-10-2007, 11:44
  409. 20-10-2007, 17:47
  410. 20-10-2007, 17:27
  411. 20-10-2007, 17:00
  412. 20-10-2007, 10:15
  413. 20-10-2007, 09:20
  414. 19-10-2007, 21:14
  415. 19-10-2007, 17:52
  416. 19-10-2007, 14:37
  417. 19-10-2007, 13:34
  418. 19-10-2007, 11:36
  419. 19-10-2007, 11:17
  420. 19-10-2007, 10:26
  421. 18-10-2007, 21:15
  422. 18-10-2007, 20:42
  423. 18-10-2007, 20:16
  424. 18-10-2007, 20:12
  425. 18-10-2007, 20:08
  426. 18-10-2007, 19:52
  427. 18-10-2007, 19:51
  428. 18-10-2007, 19:48
  429. 18-10-2007, 19:48
  430. 12-10-2007, 06:48
  431. 06-10-2007, 09:45
  432. 28-09-2007, 20:52
  433. 27-09-2007, 08:42
  434. 24-09-2007, 17:51
  435. 23-09-2007, 22:10
  436. 23-09-2007, 22:08
  437. 17-09-2007, 17:39
  438. 17-09-2007, 13:24
  439. 17-09-2007, 12:20
  440. 17-09-2007, 12:10
  441. 17-09-2007, 09:49
  442. 17-09-2007, 09:11
  443. 17-09-2007, 09:09
  444. 17-09-2007, 00:41
  445. 17-09-2007, 00:30
  446. 17-09-2007, 00:07
  447. 21-08-2007, 19:14
  448. 21-08-2007, 18:59
  449. 20-08-2007, 22:46
  450. 20-08-2007, 14:05
  451. 17-08-2007, 15:59
  452. 17-08-2007, 15:30
  453. 23-01-2007, 20:46
