Page 26 of 39 FirstFirst ... 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 ... LastLast
Results 626 to 650 of 972
Thread: InsaneSwede's Astra MKI
  1. #626
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Re: InsaneSwede's Astra MKI
    Sell the car?
    At least get some cool in-car videos first.
    Oct 2008
    Glenrothes
    Astra V6
    Awsome!!!! would love a mk1 some day!!
  4. #628
    Apr 2006
    Atherstone
    2 many 2 list
    just keep them ideas in your head fella ha ha
    has scrapped the sig with all the cars to do list!!!!! 3 novas i own says it all really
  5. #629
    Sep 2002
    Stourport, Worcester
    ZX Volcane TD
    Hey,
    I've been waiting patiently for ages for an update with some decent current pics and vids on your car. Sort it out! With all the work and ingenuity you've put into the mk1 it deserves better than being sat in a garage.
    Paul.
    Never stick your finger where you wouldn't stick your dick and you won't go far wrong.
  6. #630
    Nov 2006
    Cambridgeshire
    Astra GSI MK3
    noooooo! you cant sell it after all the hard work you have put in, youll regret it afterwards honest, i regretted selling my newly built xe straight after building it, i wish i still had it now.
    a quatre mile video would be great
    steve
  7. #631
    Jun 2008
    the colour is awsome
  8. #632
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    wow!!
    i've read the whole thread today !
    great hand made works
    great solutions
    absolute not worked at office... i'll be fired tomorrow
    do you have some pictures about the rear drive?
  9. #633
    Nov 2007
    Chesterfield
    650bhp astra coupe
    Looks like a good inlet
    Turbonetics GTK 850 @ 25psi
  10. #634
    Oct 2002
    Sweden
    Astra MkI
    small update.
    been working on my own company for a time and haven´t got that much time for the Astra.
    But i have bought a new oilpump, Z20LET
    As i´m going to upgrade with oilsquirters
    and need some more capacity to pump against the high centripetal forces when revving 7500rm with 95mm stroke.
    A question thou,,
    is there anybody that has calculated the flows from the pumps std vs Z20let?
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
  11. #635
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    i thought it was the pressure thats the issue not flow.
    www.wix.com/vxlgsi/zxr-750-r
  12. #636
    Oct 2002
    Sweden
    Astra MkI
    It´s flow who is the most important part.
    If your pump doesn´t flow enough, your bearings will run 'dry' at higher rpm as it can´t keep up the pressure needed to overcome the centripetalforce etc etc.
    You don´t want to adjust your pump to get higher pressures as it will run 'dry' anyway at higher rpm.
    and with high pressure you heat up the oil unnecessary and wears it out.
    Keep in mind!
    the pressure you see on your meter in cockpit doesnt tell you anything but the pressure going out from the pump.
    The pressure that reaches your bearing are way lower.
    Rgds
    Kadett GT/E
  13. #637
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Dry sump it Patrick, i think thats the safer option especially with a grippy 4wd...no oil surge issues with hard cornering, drifting, donuts
    The zlet pump does flow more but i'm not sure by how much. It also has a steel drive gear which doesn't disintergrate at high rpm which is nice.
    Definatly with you on monitoring capillery pressure rather than whats coming direct out the pump
    "THE ROB"
  14. #638
    Oct 2002
    Sweden
    Astra MkI
    Yes i know dryspump would solve a lot of issues.
    but! i haven´t got any room for it
    If this setup doesen´t work, then i´ll have to remake whole exhaust, manifold etc etc..
    I´ll try this first.
    I had some abnormal wear on bigend bearings, that´s why i´m upgrading also.
    But i think the wear i had on the bearings came from a little bit to early ignition.
    But, i got the pump for 'free', i ported and polished a Coscast head for a friend.
    That LET is about to take XE camshaft to a whole new level
    Rgds
    Kadett GT/E
  15. #639
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Ok sounds good.
    I think what might be a good idea here is to look into getting the correct oil jets. Drop ChrisReay a pm and he will let you know what we use, atleast thats one option.
    We dont use the 17dtl jets like most people on here.
    Yours being a fairly unusual build doesn't help, theres nobody to compare with really, i hope premature bearing wear isn't part of the running nature of somehting with your stroke, bore, torque and rpm. The stories ive read about people running 2.2, 2.3's in the past have never been great
    Just curious, what kind of oil pressure were you seeing? I'm sure those violent launches didnt help as the oil would be splatered against the back of the sump for a good whilelmao
    "THE ROB"
  16. #640
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    big wing and good baffleing are the way track/drag evo's are going with high cornering speeds/launches
    i think you will have to bench test the pumps to determine flow at your chosen pressure i can't see anyone having flow data for them
  17. #641
    Nov 2006
    Cambridgeshire
    Astra GSI MK3
    would a z20let oil pump be a good upgrade for a c20let?
    what are the benefits and is it a direct replacement with no other modifications needed
    300bhp mk3 astra GSI LET (a work in progress)
  18. #642
    Oct 2002
    Sweden
    Astra MkI
    I got baffeled tray and 'windage' catching.
    An oilpump with more capacity is always a good invest when tuning an engine.
    My old pump had steelgears and plastic valve.,, but that doesnt add more flow.
    The squirters i tend to use comes from BMW M5,, dunno the engine code, but it´s the 3.8 litre straight six.
    I will also make more mods to main bearings, more holes in them basicly explained.and a groove in the mains behind them.
    just to feed the squirter and to more easy feed the bigend bearings with oil.
    Kadett GT/E
  19. #643
    Apr 2007
    Hi, do you have some pics of the rear running gear on the car I am in the process of the 4wd conversion and any info will be usefull but am running the gm gear.
  20. #644
    Aug 2004
    estonia
    vectra 2000 16v 91`
    IIRC he uses the same rear axle as calibra/cavalier with toyota rear diff. Good idea with the bearings , and we went for the bmw oilsquirters for my mates turbo build too
    C20XE , machined down pistons , MS-I v3.0 , HX35W 1.2bar and broken F20
  21. #645
    Oct 2002
    Sweden
    Astra MkI
    A little pic from where i´m at, at this moment.
    i´m upgrading the things i mentioned above.
    has gone through the hardware in the engine, looking good
    Kadett GT/E
  22. #646
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Looks likes its never been ran almost
    Was there never any concrete on the inlet side of no. 1 Patrick? If not.....reasons for this please matey.
    Bit gutted this has to be in bits so early in its life, suppose that R&D for you.
    Keep up the good work dude
    "THE ROB"
  23. #647
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by Rs1 View Post
    Back in the scene
  24. #648
    Oct 2002
    Sweden
    Astra MkI
    about the concrete,
    i saw that it had wen´t loose, sad,, but i think there will be no problem to add new concrete as i got the 'studs' that keeps the cylinders in place.
    i have measured the cylinder and it´s round and fine.
    But i´ll think i´ll use epoxi instead this time as the concrete may disform the cylinder when hardening.
    Rgds
    Patrick
    Kadett GT/E
  25. #649
    Nov 2007
    Chesterfield
    650bhp astra coupe
    Hi which block did you use for the build? I am using a x22xe block and the water jacket ports look slighty different. Also do you work for sanvik coromant?
    Keep up the good work!
  26. #650
    Oct 2002
    Sweden
    Astra MkI
    Quote Originally Posted by corsa_sport_let View Post
    No, i´m just using their tools at waork.
    And i used the Frontera X22XE block.
    Rgds
    Kadett GT/E
  1. 06-02-2012, 15:20
  2. 30-01-2012, 00:34
  3. 29-01-2012, 23:45
  4. 28-01-2012, 21:31
  5. 27-01-2012, 22:23
  6. 27-01-2012, 00:32
  7. 11-12-2011, 12:42
  8. 10-12-2011, 22:43
  9. 10-12-2011, 22:43
  10. 10-12-2011, 22:02
  11. 10-12-2011, 21:41
  12. 10-12-2011, 20:14
  13. 10-12-2011, 18:11
  14. 10-12-2011, 00:06
  15. 09-12-2011, 20:47
  16. 09-12-2011, 20:04
  17. 09-12-2011, 17:55
  18. 09-12-2011, 16:33
  19. 09-12-2011, 08:48
  20. 06-12-2011, 21:35
  21. 03-12-2011, 23:06
  22. 10-11-2011, 20:01
  23. 08-11-2011, 23:39
  24. 01-11-2011, 00:39
  25. 27-10-2011, 11:09
  26. 27-10-2011, 10:20
  27. 25-10-2011, 23:33
  28. 24-10-2011, 09:39
  29. 23-10-2011, 21:43
  30. 23-10-2011, 21:43
  31. 21-10-2011, 21:14
  32. 02-10-2011, 21:17
  33. 02-10-2011, 20:51
  34. 17-09-2011, 20:32
  35. 28-06-2011, 00:36
  36. 09-06-2011, 20:33
  37. 08-06-2011, 18:45
  38. 02-06-2011, 17:02
  39. 01-06-2011, 16:47
  40. 28-05-2011, 16:33
  41. 22-05-2011, 09:37
  42. 22-05-2011, 09:37
  43. 21-05-2011, 19:26
  44. 20-05-2011, 22:10
  45. 19-05-2011, 16:50
  46. 17-05-2011, 09:57
  47. 10-05-2011, 00:49
  48. 09-05-2011, 21:00
  49. 10-04-2011, 21:58
  50. 27-03-2011, 22:43
  51. 21-02-2011, 00:23
  52. 14-02-2011, 18:19
  53. 05-02-2011, 16:32
  54. 29-01-2011, 19:08
  55. 24-01-2011, 14:05
  56. 13-01-2011, 20:17
  57. 25-12-2010, 09:26
  58. 30-11-2010, 08:48
  59. 14-11-2010, 01:07
  60. 29-10-2010, 13:14
  61. 07-10-2010, 11:21
  62. 03-10-2010, 13:29
  63. 08-09-2010, 19:17
  64. 02-09-2010, 20:10
  65. 01-09-2010, 14:09
  66. 14-07-2010, 23:50
  67. 14-07-2010, 12:19
  68. 11-07-2010, 18:12
  69. 08-06-2010, 19:40
  70. 24-05-2010, 20:34
  71. 16-05-2010, 21:22
  72. 25-04-2010, 08:20
  73. 21-04-2010, 17:31
  74. 15-04-2010, 23:25
  75. 12-03-2010, 08:14
  76. 09-03-2010, 18:28
  77. 02-03-2010, 10:11
  78. 27-02-2010, 21:45
  79. 17-02-2010, 18:45
  80. 12-02-2010, 22:20
  81. 06-02-2010, 20:07
  82. 02-02-2010, 16:04
  83. 01-02-2010, 16:23
  84. 29-01-2010, 12:39
  85. 24-01-2010, 08:08
  86. 20-01-2010, 12:13
  87. 18-01-2010, 16:50
  88. 12-01-2010, 04:00
  89. 05-01-2010, 20:40
  90. 20-11-2009, 12:36
  91. 18-11-2009, 16:11
  92. 05-11-2009, 18:49
  93. 01-11-2009, 17:37
  94. 26-10-2009, 21:08
  95. 20-10-2009, 10:22
  96. 02-08-2009, 21:07
  97. 20-07-2009, 18:18
  98. 15-07-2009, 21:00
  99. 09-07-2009, 21:46
  100. 06-07-2009, 19:15
  101. 01-07-2009, 05:10
  102. 28-06-2009, 13:01
  103. 21-06-2009, 21:52
  104. 13-06-2009, 14:51
  105. 13-06-2009, 12:20
  106. 13-06-2009, 08:01
  107. 13-06-2009, 07:38
  108. 13-06-2009, 06:36
  109. 13-06-2009, 06:16
  110. 13-06-2009, 05:34
  111. 07-06-2009, 18:52
  112. 02-06-2009, 23:27
  113. 30-05-2009, 18:36
  114. 28-05-2009, 22:27
  115. 27-05-2009, 19:22
  116. 25-05-2009, 17:09
  117. 24-05-2009, 14:39
  118. 20-05-2009, 14:20
  119. 19-05-2009, 10:44
  120. 19-05-2009, 07:18
  121. 18-05-2009, 20:50
  122. 18-05-2009, 18:59
  123. 17-05-2009, 17:49
  124. 10-05-2009, 14:24
  125. 06-05-2009, 15:00
  126. 29-04-2009, 14:05
  127. 19-04-2009, 20:37
  128. 15-04-2009, 16:03
  129. 13-04-2009, 10:44
  130. 10-04-2009, 07:41
  131. 06-04-2009, 17:35
  132. 31-03-2009, 23:55
  133. 31-03-2009, 22:11
  134. 27-03-2009, 21:02
  135. 26-03-2009, 22:17
  136. 19-03-2009, 14:35
  137. 14-03-2009, 17:16
  138. 11-03-2009, 03:52
  139. 10-03-2009, 13:42
  140. 09-03-2009, 23:52
  141. 09-03-2009, 01:48
  142. 08-03-2009, 10:39
  143. 04-03-2009, 14:51
  144. 03-03-2009, 08:35
  145. 02-03-2009, 14:31
  146. 27-02-2009, 22:04
  147. 27-02-2009, 11:17
  148. 23-02-2009, 17:49
  149. 22-02-2009, 16:46
  150. 22-02-2009, 10:54
  151. 22-02-2009, 10:32
  152. 21-02-2009, 20:19
  153. 21-02-2009, 20:16
  154. 18-02-2009, 02:18
  155. 16-02-2009, 19:21
  156. 16-02-2009, 17:55
  157. 13-02-2009, 19:59
  158. 09-02-2009, 20:28
  159. 09-02-2009, 18:53
  160. 09-02-2009, 12:48
  161. 09-02-2009, 12:48
  162. 08-02-2009, 15:22
  163. 06-02-2009, 13:24
  164. 04-02-2009, 14:57
  165. 03-02-2009, 10:56
  166. 29-01-2009, 21:14
  167. 25-01-2009, 15:28
  168. 17-01-2009, 21:10
  169. 13-01-2009, 15:15
  170. 07-01-2009, 12:07
  171. 03-01-2009, 11:49
  172. 30-12-2008, 12:20
  173. 27-12-2008, 16:39
  174. 26-12-2008, 04:02
  175. 22-12-2008, 19:40
  176. 22-12-2008, 17:13
  177. 22-12-2008, 16:26
  178. 22-12-2008, 13:04
  179. 22-12-2008, 13:04
  180. 20-12-2008, 15:34
  181. 13-12-2008, 19:25
  182. 01-12-2008, 14:38
  183. 30-11-2008, 17:32
  184. 29-11-2008, 19:52
  185. 24-11-2008, 06:47
  186. 23-11-2008, 10:20
  187. 23-11-2008, 09:56
  188. 20-11-2008, 06:50
  189. 19-11-2008, 08:55
  190. 05-11-2008, 22:18
  191. 03-11-2008, 17:27
  192. 02-11-2008, 10:39
  193. 28-10-2008, 00:15
  194. 26-10-2008, 20:11
  195. 19-10-2008, 12:34
  196. 11-10-2008, 16:48
  197. 30-09-2008, 19:41
  198. 29-09-2008, 19:01
  199. 28-09-2008, 21:58
  200. 25-09-2008, 23:14
  201. 19-09-2008, 19:35
  202. 14-09-2008, 08:14
  203. 13-09-2008, 19:55
  204. 12-09-2008, 19:32
  205. 11-09-2008, 19:45
  206. 11-09-2008, 19:04
  207. 05-09-2008, 20:55
  208. 02-09-2008, 19:17
  209. 30-08-2008, 23:05
  210. 18-08-2008, 21:11
  211. 31-07-2008, 19:01
  212. 30-07-2008, 13:12
  213. 09-07-2008, 02:13
  214. 08-07-2008, 21:08
  215. 07-07-2008, 21:48
  216. 29-06-2008, 10:22
  217. 16-06-2008, 21:28
  218. 15-06-2008, 21:15
  219. 15-06-2008, 15:07
  220. 14-06-2008, 17:08
  221. 27-05-2008, 18:32
  222. 25-05-2008, 19:36
  223. 20-05-2008, 18:43
  224. 20-05-2008, 18:06
  225. 19-05-2008, 23:59
  226. 19-05-2008, 01:08
  227. 15-05-2008, 11:35
  228. 13-05-2008, 13:05
  229. 13-05-2008, 12:39
  230. 10-05-2008, 18:50
  231. 05-05-2008, 18:20
  232. 03-05-2008, 21:13
  233. 01-05-2008, 08:30
  234. 27-04-2008, 21:13
  235. 24-04-2008, 16:18
  236. 22-04-2008, 11:57
  237. 21-04-2008, 20:25
  238. 19-04-2008, 14:28
  239. 17-04-2008, 15:08
  240. 14-04-2008, 20:12
  241. 12-04-2008, 19:12
  242. 11-04-2008, 18:16
  243. 11-04-2008, 16:52
  244. 10-04-2008, 18:57
  245. 08-04-2008, 20:00
  246. 08-04-2008, 12:18
  247. 08-04-2008, 11:37
  248. 07-04-2008, 09:17
  249. 07-04-2008, 07:51
  250. 06-04-2008, 21:43
  251. 06-04-2008, 21:12
  252. 06-04-2008, 20:01
  253. 06-04-2008, 13:44
  254. 06-04-2008, 08:56
  255. 04-04-2008, 15:57
  256. 30-03-2008, 14:05
  257. 30-03-2008, 11:23
  258. 21-03-2008, 19:35
  259. 20-03-2008, 10:45
  260. 18-03-2008, 20:30
  261. 17-03-2008, 14:06
  262. 10-03-2008, 16:30
  263. 10-03-2008, 09:39
  264. 08-03-2008, 14:23
  265. 07-03-2008, 19:13
  266. 06-03-2008, 20:56
  267. 06-03-2008, 20:55
  268. 04-03-2008, 21:13
  269. 03-03-2008, 11:38
  270. 01-03-2008, 07:33
  271. 29-02-2008, 13:36
  272. 29-02-2008, 11:32
  273. 29-02-2008, 08:56
  274. 27-02-2008, 17:32
  275. 26-02-2008, 17:59
  276. 25-02-2008, 19:44
  277. 24-02-2008, 05:39
  278. 23-02-2008, 20:14
  279. 23-02-2008, 13:53
  280. 23-02-2008, 10:59
  281. 23-02-2008, 09:07
  282. 22-02-2008, 05:03
  283. 19-02-2008, 12:47
  284. 18-02-2008, 10:39
  285. 15-02-2008, 14:24
  286. 11-02-2008, 01:10
  287. 10-02-2008, 17:17
  288. 09-02-2008, 22:08
  289. 08-02-2008, 05:54
  290. 07-02-2008, 16:42
  291. 06-02-2008, 19:28
  292. 06-02-2008, 17:37
  293. 06-02-2008, 17:04
  294. 06-02-2008, 16:04
  295. 06-02-2008, 15:05
  296. 05-02-2008, 14:31
  297. 03-02-2008, 16:53
  298. 31-01-2008, 19:38
  299. 27-01-2008, 16:44
  300. 26-01-2008, 21:40
  301. 26-01-2008, 16:13
  302. 25-01-2008, 21:39
  303. 24-01-2008, 20:04
  304. 24-01-2008, 06:50
  305. 24-01-2008, 05:59
  306. 23-01-2008, 22:49
  307. 23-01-2008, 22:35
  308. 23-01-2008, 22:34
  309. 23-01-2008, 22:17
  310. 23-01-2008, 22:10
  311. 23-01-2008, 22:09
  312. 23-01-2008, 22:05
  313. 21-01-2008, 20:42
  314. 21-01-2008, 19:43
  315. 20-01-2008, 13:55
  316. 20-01-2008, 11:53
  317. 17-01-2008, 10:10
  318. 17-01-2008, 01:01
  319. 16-01-2008, 21:42
  320. 16-01-2008, 20:59
  321. 16-01-2008, 19:48
  322. 16-01-2008, 19:24
  323. 16-01-2008, 18:36
  324. 15-01-2008, 06:51
  325. 14-01-2008, 15:32
  326. 14-01-2008, 15:02
  327. 13-01-2008, 09:40
  328. 10-01-2008, 18:54
  329. 09-01-2008, 11:47
  330. 09-01-2008, 08:46
  331. 08-01-2008, 14:11
  332. 08-01-2008, 12:31
  333. 08-01-2008, 00:03
  334. 07-01-2008, 19:13
  335. 07-01-2008, 18:21
  336. 07-01-2008, 10:28
  337. 06-01-2008, 19:16
  338. 06-01-2008, 00:18
  339. 05-01-2008, 22:35
  340. 04-01-2008, 20:06
  341. 02-01-2008, 18:36
  342. 01-01-2008, 17:49
  343. 01-01-2008, 08:29
  344. 31-12-2007, 13:03
  345. 31-12-2007, 11:46
  346. 31-12-2007, 11:46
  347. 30-12-2007, 20:47
  348. 30-12-2007, 20:43
  349. 30-12-2007, 20:40
  350. 30-12-2007, 20:07
  351. 30-12-2007, 19:56
  352. 30-12-2007, 14:07
  353. 30-12-2007, 01:59
  354. 29-12-2007, 14:22
  355. 29-12-2007, 13:49
  356. 27-12-2007, 16:43
  357. 26-12-2007, 20:34
  358. 26-12-2007, 16:59
  359. 26-12-2007, 16:37
  360. 21-12-2007, 18:52
  361. 21-12-2007, 08:57
  362. 20-12-2007, 01:37
  363. 19-12-2007, 08:20
  364. 18-12-2007, 17:11
  365. 18-12-2007, 11:26
  366. 17-12-2007, 13:34
  367. 16-12-2007, 10:15
  368. 16-12-2007, 07:43
  369. 15-12-2007, 15:05
  370. 14-12-2007, 19:52
  371. 14-12-2007, 14:15
  372. 14-12-2007, 10:54
  373. 13-12-2007, 22:34
  374. 13-12-2007, 17:49
  375. 13-12-2007, 17:12
  376. 13-12-2007, 15:52
  377. 13-12-2007, 15:46
  378. 13-12-2007, 15:13
  379. 13-12-2007, 14:33
  380. 13-12-2007, 14:31
  381. 13-12-2007, 14:20
  382. 12-12-2007, 11:49
  383. 11-12-2007, 15:14
  384. 07-12-2007, 11:42
  385. 02-12-2007, 10:56
  386. 01-12-2007, 10:40
  387. 30-11-2007, 12:24
  388. 29-11-2007, 14:09
  389. 19-11-2007, 10:11
  390. 15-11-2007, 19:37
  391. 15-11-2007, 13:04
  392. 15-11-2007, 10:38
  393. 14-11-2007, 19:17
  394. 14-11-2007, 09:19
  395. 13-11-2007, 10:54
  396. 13-11-2007, 02:10
  397. 12-11-2007, 20:09
  398. 08-11-2007, 15:41
  399. 08-11-2007, 12:22
  400. 04-11-2007, 17:04
  401. 30-10-2007, 22:08
  402. 24-10-2007, 02:29
  403. 23-10-2007, 19:49
  404. 23-10-2007, 18:56
  405. 23-10-2007, 12:29
  406. 21-10-2007, 21:29
  407. 21-10-2007, 15:01
  408. 21-10-2007, 11:44
  409. 20-10-2007, 17:47
  410. 20-10-2007, 17:27
  411. 20-10-2007, 17:00
  412. 20-10-2007, 10:15
  413. 20-10-2007, 09:20
  414. 19-10-2007, 21:14
  415. 19-10-2007, 17:52
  416. 19-10-2007, 14:37
  417. 19-10-2007, 13:34
  418. 19-10-2007, 11:36
  419. 19-10-2007, 11:17
  420. 19-10-2007, 10:26
  421. 18-10-2007, 21:15
  422. 18-10-2007, 20:42
  423. 18-10-2007, 20:16
  424. 18-10-2007, 20:12
  425. 18-10-2007, 20:08
  426. 18-10-2007, 19:52
  427. 18-10-2007, 19:51
  428. 18-10-2007, 19:48
  429. 18-10-2007, 19:48
  430. 12-10-2007, 06:48
  431. 06-10-2007, 09:45
  432. 28-09-2007, 20:52
  433. 27-09-2007, 08:42
  434. 24-09-2007, 17:51
  435. 23-09-2007, 22:10
  436. 23-09-2007, 22:08
  437. 17-09-2007, 17:39
  438. 17-09-2007, 13:24
  439. 17-09-2007, 12:20
  440. 17-09-2007, 12:10
  441. 17-09-2007, 09:49
  442. 17-09-2007, 09:11
  443. 17-09-2007, 09:09
  444. 17-09-2007, 00:41
  445. 17-09-2007, 00:30
  446. 17-09-2007, 00:07
  447. 21-08-2007, 19:14
  448. 21-08-2007, 18:59
  449. 20-08-2007, 22:46
  450. 20-08-2007, 14:05
  451. 17-08-2007, 15:59
  452. 17-08-2007, 15:30
  453. 23-01-2007, 20:46
